Duvar
Kokü-Junkie (m/w)
Schaut bitte den letzten Spoiler hier an bzgl des CPU Takts Strictly technical: Matisse (Not really) - Overclock.net - An Overclocking Community
Auszug:
"Performance per Watt
As expected, Matisse provides significantly higher performance per watt than its competition, thanks to its leading edge 7nm manufacturing process. Some of you might notice that Matisse's power efficiency seems to peak at 3.5GHz, despite the fact that semiconductors do not behave like that. The reason behind this was revealed by Vmin testing, which clearly illustrated that Matisse lacks fused V/F (voltage-frequency) curve below 3.4GHz. This means that below 3.4GHz frequencies the voltage is always at the same level, it is at 3.4GHz. The stock (fused) V/F curve appears to be extremely well optimized as well, leaving only the temperature factor on the table."
Auszug:
.gif)
