Mit ATI und nVidia zusammen PhysX nutzen (Anleitung) * Neu All in one driver AMD+NV incl.*
AW: Mit ATI und nVidia zusammen PhysX nutzen (Anleitung) * Neu AIO Automatik installer AMD+NV incl.*
US Menü, Gut so? // is this good??
Sparachmenue / language menu
Druecke 1 fuer Deutsch
Press 2 for English
Druecke/Entering (1 or 2):
:English
Run only with administrator rights!
Recommend for Windows 7 and 8
only X64 support
Main Menu
If you select 1 (13.4 WHQL AMD) or 2 (AMD 13.5 beta 2)
nVidia 314.22 driver installation is carried out with Automatic.
When the 13.4 WHQL AMD or AMD 13.5 beta 2 installed
press button 3 to continue with the nVidia installation.
After the nVidia driver installation takes you to the PhysX
installation menu. Here you have the choice between:
PhysX mod 0.3me (all games from Mafia II), and
PhysX0.3 extended (all PhysX games).
PhysX SDK 3 Games not working. These are the files,to the
identification(Game Folder):
(PhysX3_x86.dll,PhysX3Common_x86.dll,PhysX3Cooking_x86.dll)
Press 1 for AMD 13.4 WHQL driver installation
Press 2 for AMD 13.5 beta 2 driver installation
Press 3 for nVidia 314.22 driver installation
Note:
Installation from PhysX Mod
This selection is only recommended when the AMD and nVidia driver
is already installed, or you want to change from PhysXmod0.3me
to the PhysXmod0.3extended.
Press 4 for PhysX mod 0.3 me Installation
Press 5 for PhysX0.3 extended installation
Press 6 for Restart
Press 7 for Close
Entering (1-7):
###### AMD 13.4 WHQL Driver install ###########
###### AMD 13.5 Beta 2 Driver install ###########
###### nVidia 314.22 Beta Driver install ###########
PhysX Mod Menu
Installation from PhysX Mod:
1 PhysX mod 0.3 me
2 PhysX mod 0.3 extended
3 Restart
4 Close
Entering (1-4):
###### PhysX mod 0.3 me install ###########
###### PhysX mod 0.3 extended install ###########
# completed installation #
error
The command is incorrect.
error
Go Back to main choice
error
error
Go Back To PhysX Mod Menu
For accept Restart:
1 Yes
2 NO
Entering (1or 2):
Wenn Ja ist er Morgen Online. It so good, is next day online.
also an deinem Englisch solltest du noch ein wenig arbeiten :D
Schade nur das ich so wenig zeit morgen habe, sonst würde ich dir helfen.
So hab jetzt Hybrid PhysX :D Gt640 und Sapphire Radeon HD7970 läuft supeeeer :D hier schon mal ein kleines video
JX3 Benchmark läuft auch
Batman AC ebenfalls
Arma3 habe ich auch aber ich sehe dort keine options möglichkeit PhysX einzustellen o.ä
suche noch nach einem Comparison video auf youtube oder so damit ich vergleichen kann
Genau hier liegt das Problem. Beide Games funktionieren leider nicht mit dem Physx mod.
Warframe
PlanetSide 2
Hawken
Das sind die drei F2P Titel die leider noch nicht funktionieren. Warframe verwendet z. B. PhysX 3.0. Der PhysX mod geht nur bis 2.x.x
Hawken funktioniert mit diesem PhysX mod habs gerade getestet werde ein video dazu hochladen um zu zeigen das es geht
Planetside 2 werde ich auch noch testen und Warframe ebenfalls
Bist du dir sicher das Hawken funktioniert und die Effekte nicht auf dem CPU berechnet werden? Zeigt GPU-Z eine GPU-Load beim NVIDIA GPU an, wenn du Hawken spielst? Wenn ja ist das echt genial und zeig mir wie du das gemacht hast, will das auch haben :D
Einzige datei die ich verschoben habe is die PhysxDevice.dll
und ja meine GT640 hat auslastung angezeigt
video is noch am hochladen
Moin Gordon, hab diesen Part entfernt und auch nicht korrigiert:
"Note:
to the PhysXmod0.3extended."
Dieser Hinweis verwirrt irgendwie nur, und würde eigentlich nur Sinn machen, wenn man schon AMD und NVIDIA Treiber (non-mod) installiert hat und beim Starten des AIO Treibers, im Menu, gleich am Anfang, beispielsweise die Option hätte, die AMD und NVIDIA Treiber Installation, durch drücken der Taste 4 zu überspringen und quasi sofort mit der Physx mod Treiber installation zu beginnen. Oder verstehe ich da was falsch?
Main Menu
Type 1 to run AMD 13.4 WHQL setup
Type 2 to run AMD 13.5 beta 2 setup
Attention: The nVidia 314.22 driver setup runs automatically and without any prompt after the AMD drivers setup.
Type 3 to skip the setup of AMD drivers(13.4 WHQL AMD or AMD 13.5 beta 2, if they are already installed)
to continue with the nVidia drivers setup.
After the completion of the nVidia driver installation, it will run the PhysX mod setup routine.
It will show the following options:
PhysX mod 0.3me (supports all games - recommended), and
PhysX0.3 extended (includes older versions of PhysX for better compatibally).
PhysX SDK 3 games are currenlty not supported. To identify PhysX 3 Versions, check if any files
like PhysX3_x86.dll, PhysX3Common_x86.dll, PhysX3Cooking _x86.dll exists in your game folder.
Press 1 to run AMD 13.4 WHQL driver setup
Press 2 to run AMD 13.5 beta 2 driver setup
Press 3 to run nVidia 314.22 driver setup
Note:
PhysX Mod Setup
Press 4 to run the PhysX mod 0.3 me setup
Press 5 to run the PhysX0.3 extended setup
Press 6 to restart
Press 7 to exit
Entering (1-7):
Welchen Physx mod hast du installiert den 0.3me oder die extended version?
Hab die Physxdevice.dll auch gelöscht aber die GPU Load meiner NVIDIA ist immer noch 0%
EDIT: Oder hast du irgendeine der physxdevice.dll's aus dem NVIDIA ordner in den Hawken ordner reinkopiert?
nein habe nur diese datei Gelöscht bzw auf den desktop gezogen
habe den extended installiert weil da alle games unterstützt werden auch wenn es nicht so stabil ist richtig?
und 0.3me ist stabil aber nicht alle unterstützt richtig?
kann ich einfach zwischen 0.3me und extended wechseln?
oder muss ich alles wieder neu installieren ?
Hawken mit PhysX mod extended installation
PhysXDevice.dll desktop/löschen hauptsache aus dem ordner raus
dann ingame auf High (Nvidia Only) gestellt Hawken restart und voila Hawken Mit PhsyX und über die Nvidia GPU genießen
auslastung war von 20-77% alles dabei je nach in-game anforderung
Tutorial mission bis zum ende 20-58% dann in der "arena" bis zu 77% mit mehreren zerstörten Mech´s
Ps.: Youtube verarbeitet noch und somit ist es noch nicht in HD
edit: 1080p verfügbar
Hab mir zwar jetzt auch mal den physx extended mod auf das System installiert, aber hab immer noch 0% GPU Load. Alle Physx Effekte werden immer noch auf dem CPU ausgeführt. Naja nicht weiter tragisch, da ich Hawken nur zu Testzwecken installiert habe.
EDIT: Zur Frage ob man zwischen extended und non extended hin und her wechseln kann, ja kann man. Im Endeffekt enthält der extended mod ja einfach die älteren Physx Bibliotheken.
das heisst das PhysX mod 0.3me erweitert ist bzw neuer?
Physx mod extended und 0.3 me können eigentlich das gleiche der Unterschied ist nur, das die extended Version noch zusätzlich die Physx Bibliotheken vor der Version 2.7.x enthalten, also 2.6.4, 2.6.3, ... 2.5.0, bis hin zu 2.3.1. Ich glaube Gordon hat die alten Bibliothen hinzugepackt zwecks besserer Kompatibilität mit älteren Spielen. Aber er wird sich sicherlich noch selbst dazu zu Wort melden. Also ich konnte eigentlich mit dem Physx mod 0.3 me alle Physx Games spielen außer meine 3 genannten Warframe, PlanetSide2 und Hawken.
ah ok danke :D super naja ich bin heute leider nicht dazu gekommen warframe oder PLanetside 2 zu testen
werde mich aber morgen damit mal auseinander setzten (über nacht bei steam laden)
Hawken benutzt die PhysX SDK 2.8.4.8 und das kann vielleicht funktionieren aber, das Game prüft nach jeden Start die Dateien, daher 50/50 Chance.
Warframe, PlanetSide2 und Catzilla nutzen die PhysX SDK 3.x nicht möglich zu aktivieren.
crizzler was soll das??
Woher willst du das wissen??
PhysX0.3_extended habe ich ältere Bibiliotheken mit mods unterzogen und eingefügt, diese sind aber eigentlich nur für ältere games.
Ich brauche zu der http://extreme.pcgameshardware.de/g...ik-installer-amd-nv-incl-269.html#post5240596 eine gute Übersetzung (nix hinzuerfinden, vereinfachen kann man).
Hier noch mal in Deutsch:
Nur als Administrator ausfuehren!
empfohlen fuer Windows 7 und 8
nur X64 Support
Haupmenue
Bei Auswahl 1 (AMD 13.4 WHQL) oder Auswahl 2 (AMD 13.5 Beta 2)
wird nVidia 314.22 Treiberinstallation Automatisch mit
durchgefuehrt.
Wenn der AMD 13.4 WHQL oder AMD 13.5 Beta 2 installiert ist
druecken sie Taste 3 um mit der nVidia Installation forzufahren.
Nach der nVidia Treiberinstallation gelangen sie zum
PhysX InstallationsMenue. Dabei hat man die Wahl zwischen
PhysX mod 0.3me (alle Spiele ab Mafia II) und
PhysX0.3 extended (alle PhysX Spiele ).
Druecke 1 fuer AMD 13.4 WHQL Treiberinstallation
Druecke 2 fuer AMD 13.5 Beta 2 Treiberinstallation
Druecke 3 fuer nVidia 314.22 Treiberinstallation
Hinweis:
Installation von PhysX Mod:
Diese Auswahl wird nur Empfohlen wenn der AMD und nVidia Treiber
schon installiert ist oder man vom PhysX mod 0.3me auf den
PhysX mod 0.3 extended wechseln moechten.
Druecke 4 fuer PhysX mod 0.3me Installation
Druecke 5 fuer PhysX0.3 extended Installation
Druecke 6 fuer Neustart
Druecke 7 fuer Beenden
Eingabe (1-7):
nur X64 Support
Haupmenue
durchgefuehrt.
Hinweis:
Eingabe (1-7):
dürfte ich dir vllt. behilflich sein bei der übersetzung?
edit:
ich war einfach mal so frei :P wenn nicht nehm ichs wieder raus
Run as Administrator only!
Recommended for Windows 7 and 8
only X64 Support
Main menu
If Selection 1 (AMD 13.4 WHQL) or Selection 2 (AMD 13.5 Beta 2)
the nVidia 314.22 Driver will be automatically installed.
If the AMD 13.4 WHQL or AMD 13.5 Beta 2 driver is installed
press 3 to continue with the nVidia installation.
After the nVidia driver installation you will be directed
to the PhysX Installation menu.
There you have the choice between
PhysX mod 0.3me (All Games from Mafia II) and
Press 2 for AMD 13.5 Beta 2 driver installation
Notice:
This selection is only recommended if the AMD and nVidia driver
is already installed or if you want to switch from the
PhysX mod 0.3me to PhysX0.3 extended
Press 4 for PhysX mod 0.3me installation
Press 6 for a restart
Press 7 for exit
Enter (1-7):
Weil ich das weiß, und ich 1 und 1 zusammenzählen kann, ein paar Beiträge über deinem Post schreibe ich genau, dass du diese für ältere Games hinzugefügt hast, was ergo zu einer besseren Kompatibilität führt, da mehr Spiele möglicherweise funktionieren. Das ist doch deine Absicht oder? Und ganz ehrlich gewöhne dir einen anderen Ton an und lern Deutsch und Englisch. Respekt zu deiner Arbeit bekommst du von mir, aber für dein kommunikatives Feingefühl sicher nicht.
crizzler denn extended überarbeite ich noch da in der reg noch einige fehler sind. Und Sorry wenn ich so :kotz: rüber gekommen bin, war nicht meine Absicht.
FairLight_V1 THX, werde mir deine und dir von crizzler zusammentragen. Dauert aber noch einige Tage.
Daher Achtung. Der PhysX mod 0.3 extended bekommt die tage ein update, reg ist nicht ganz sauber. Könnte am liebsten :heul: :kotz: :motz: . Daher sorry für meine schlechte Laune.
Ich habe hier eine MSI N210-MD1GD3H (Geforce 210 mit 1Gb) rumliegen.
Kann ich sie einbauen und PhysX nutzen bzw. bringt sie was oder lassen.
Hm... das ganze ist irgendwie zu Unübersichtlich... und wirklich sehr viele Grammatikfehler.. :motz::( Normal mecker ich ja nicht da drüber aber das ganze kann man leider nur sehr schwer nachvollziehen
Oder
Der neue PhysX Mod Treiber
1. AIO Treiber herunterladen Hier downloaden
Oder dieser mit WHQL Hier downloaden
Oder dieser mit WHQL und Beta Hier downloaden, der 31422.134_135.2
2. AMD und nVidia Treiber deinstallieren (vollständig)
3. neu starten
4. AIO Treiber starten und auf Abfrage Drücken sie eine Beliebige Taste ... warten
5. Beliebige Taste drücken und warten, kann ca. 5 Minuten dauern
6. Abfrage Zum uebernehmen neustarten: mit 1 bestätigen mit Enter übernehmen
7. Neustart
8. Fertig
Wann baue ich da welche Grafikkarte ein? Das wird nirgends erwähnt für einen der sich etwas weniger auskennt schwer nachzuvollziehen... Ich hab das leider noch nicht getestet oder sonstiges da ich noch nicht die Möglichkeit dazu habe aber ich bin einer der sich das ganze erstmal durchliest.... Prägung durch die Schule.. da Ich mal im Chemieunterricht sowas wie einen Psychologentest hatte ;)
Der ging wie folgt:
Schritt 1: Falte ein papier in der mitte
Schritt 2: Falte es nochmal
Schritt 3: Nun scheidest du innerste ecke mit einer schere ab
Schritt 4: Falte das ganze nochmal
Schritt 5: Nochmals die innerste Ecke abschneiden
das ging immer so weiter bis
Schritt 11: Beachte schritt 1-10 nicht
Schritt 12:Nimm einfach ein Papier und schreib deinen namen drauf
Schritt 13: Und nun lehn dich zurück und schau was deine Klassenkameraden machen...
Seitdem... Nie wieder arbeiten bevor ich das ganze durchgelesen hab.... Aber leider hilft hier mir selbst das nicht weiter...
Ich könnte dir auch dabei helfen die Textparts zu überarbeiten ;) Würde dir das ganze per PN schicken :D Nicht böse aufnehmen oder so ob du es letztendlich übernimmst ist ja dann deine Sache :D
PS: Eine Erläuterung zu der Tabelle wo die GraKa's in Stufen aufgeteilt sind wäre gut, ich mein mit ein bisschen Grips findet man schon heraus das dies höchstwahrscheinlich die Karten sind die am besten zueinander passen, aber... Der Mensch ist nunmal faul :ugly:
