DAN A4-SFX das kleinste Gaming-Gehäuse der Welt
AW: Der A4 das kleinste Gaming-Gehäuse der Welt < 6Liter [Neue Bilder vom Prototyp]
I agree, I just want to show my respect to the forum (not a very good try)
I wish some motherboard manufacturer would make a cheap, low profile socket 1150 motherboard, with pci-e x16 and the CPU and RAM placed to the extreme right. A bit like BIOSTAR NM70I-1037U (but it has a crappy CPU - but is good for inexpensive prototyping).
Newegg.com - BIOSTAR NM70I-1037U Intel Celeron 1037U Dual-Core 1.8GHz Intel NM70 Mini ITX Motherboard/CPU/VGA Combo
Look to the Asus Mainboards.
I think that shows how awesome the project is. Rarely people from other countries register just for a work log.
ASUS are nice and relatively inexpensive, but I cant find any with RAM and CPU to the extreme right ?
I think "As small as possible, as big as necessary" is an attractive universal idea and nicely open to interpretation.
And the current technological development works in its favor.
Maybe it includes a bit of "Revenge of the PC" against the nice form factor consoles
But bring us awesome high-end, low power Maxwell GPUs soon - please ...
I agree, I just want to show my respect to the forum (not a very good try) I wish some motherboard manufacturer would make a cheap, low profile socket 1150 motherboard, with pci-e x16 and the CPU and RAM placed to the extreme right. A bit like BIOSTAR NM70I-1037U (but it has a crappy CPU - but is good for inexpensive prototyping). Newegg.com - BIOSTAR NM70I-1037U Intel Celeron 1037U Dual-Core 1.8GHz Intel NM70 Mini ITX Motherboard/CPU/VGA Combo
Oh no don't go with that..
I tried this kind of mabo/CPU .. It's awfully sucks..
First we want to use this machine for our VPN connection to Europe , because my girlfriend wanted to watch German/Austrian TV.
But it's way to less for a 4k screen ..
It will just get destroyed ...
So we decided to go with an i3 haswell...
If you wanna go for an small cheap project take a look at the "in win BQ656" with an AMD A10 APU.
He just said that it has the form factor he wants, and therefore is useful to build the case, serving as a placeholder for the actual hardware, not that he is planning to use it ;)
No problem, you are right - I would never use a celeron for gaming.
I would use a Intel Xeon E3-1240Lv3 ...
Well, one (expensive) way of building extremely low profile is to use a riser angling to the left, but then you will need to change your air cooling for water cooling, or your fans have no space. And then theres the question if you save space with all the stuff you need then...
:offtopic: Zurück zum Thema und zwar auf deutsch. Es gibt extra einen englischsprachigen Thread zu diesem Thema im Hardforum. Motherboard diskussionen oder Grafikkartendiskussion die sich nicht wirklich auf das Projekt beziehen, bitte in den dazugehörigen Threads diskutieren.
Ich bin damit einverstanden.
Cooles Projekt
@bigdaniel
ich bin sicher, dass du das schon tausendmal gefragt wurdest:
Aber warum benutzt du nicht einfach ein internes Netzteil im EPC oder HE/Flex-ATX-Format? Die würden in jedem Fall in den vorderen Teil reinpassen.
Es gibt kein Netzteilformat welches passen würde ohne das man das Gehäuse vergrößern müsste oder den Platz für lange Grafikkarten verliert. Dies gilt für TFX, SFX, Flex und 1U. Bedenke, selbst Flex passt nicht, denn vor dem Netzteil ist noch der Abgewinkelte Kaltgerätestecker und hinter dem Netzteil der Kabelstrang. Außerdem gibt es nur 1 leistungsstarkes Flex Netzteil mit 400w aus den USA und ich kann mir nicht vorstellen, dass dieses leise ist.
Hmm, da magst du sogar recht haben. Bin da von den 150mm langen Flex-ATX-NTs ausgegangen, aber das wird in der Tat eng.
Hätte es da denn nicht von diversen Elektronik-Händlern auch Open-Frame-Netzteile gegeben? In meinem Chenbro ES34169 ist bspw. so eines verbaut.
Ich frage eigentlich nur, weil halt die Auswahl dieser Boards noch eher spärlich ist und wenig Erfahrungsberichte vorliegen. Ansonsten finde ich diese Lösung aber durchaus recht elegant, wenn ich auch eher ein 1cm höheres Gehäuse in Kauf genommen hätte, um nicht durch externe Netzteile wieder eingeschränkt zu sein (Mobilität, Platz, Optik).
Hm, Netzteil -> Optik?
Ich mein, wenn man das Teil irgendwo hinstellt, dann verschwindet das NT doch irgendwo hinter einem Schrank oder darunter, oder?
Wenn Sie es klein und stillen wollen, müssen Sie ein externes Netzteil haben - wenn Sie nicht Sony sind
De facto erkauft man sich halt die 6L in gewisser Weise "unrechtmäßig", da das externe Netzteil ebenfalls Platz braucht und das mit Sicherheit mehr als ein 2cm höheres Gehäuse.
Für mich wird damit das Gehäuse zu einer Art Hybrid zwischen Laptop und PC. Ich möchte die Leistung und das ganze Setup aber nicht schmälern, der PC ist und bleibt ziemlich genial.
Ich wollte dir damit nicht auf die Füße treten, aber gibt ja auch beispielsweise einige Spielekonsolen deren Netzteil auch extern gelöst wurde.
Und ich ordne diesen Mini Gaming PC in der Konsolen Region ein, auch wenn er mehr Power hat als eine aktuelle Konsole.
Man denke alleine an die XBox One, die hat ein "Schwein von Netzteil".
Das Gehäuse von bigdaniels Gehäuse hat etwa 4,9 Liter + Netzteil, er bleibt also unter 6 Litern insgesamt.
Die Diskussion gab es schon zum Anfang des Buildlogs :D
