in nicht mal 2 Monaten
ist der Verbrauch:
. Unigine Heaven+DirectX 9 stürtzt immer noch ab, aber das hat glaube ich andere Gründe.....
15:20:39:WU01:FS01:Started FahCore on PID 4476
15:20:39:WU01:FS01:Core PID:1500
15:20:39:WU01:FS01:FahCore 0x17 started
15:20:39:WU01:FS01:0x17:*********************** Log Started 2014-05-20T15:20:39Z ***********************
15:20:39:WU01:FS01:0x17:Project: 13000 (Run 89, Clone 8, Gen 0)
15:20:39:WU01:FS01:0x17:Unit: 0x00000001538b3db7530fb5636e9650cf
15:20:39:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
15:20:39:WU01:FS01:0x17:Machine: 1
15:20:39:WU01:FS01:0x17:Reading tar file system.xml
15:20:39:WU01:FS01:0x17:Reading tar file integrator.xml
15:20:39:WU01:FS01:0x17:Reading tar file state.xml
15:20:40:WU01:FS01:0x17:Reading tar file core.xml
15:20:40:WU01:FS01:0x17:Digital signatures verified
15:20:40:WU01:FS01:0x17:Folding@home GPU core17
15:20:40:WU01:FS01:0x17:Version 0.0.52
15:25:45:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
15:25:46:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:01:46:WU01:FS01:0x17:ERROR:exception: The periodic box size has decreased to less than twice the nonbonded cutoff.
16:01:46:WU01:FS01:0x17:Saving result file logfile_01.txt
16:01:46:WU01:FS01:0x17:Saving result file log.txt
16:01:46:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
16:01:46:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:01:46:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13000 run:89 clone:8 gen:0 core:0x17 unit:0x00000001538b3db7530fb5636e9650cf
23:35:27:WU00:FS00:0x17:Completed 4900000 out of 5000000 steps (98%)
23:48:55:WU00:FS00:0x17:Completed 4950000 out of 5000000 steps (99%)
23:50:04:WU00:FS00:0x17:ERROR:exception: Error creating array interactingTiles: clCreateBuffer (-61)
23:50:05:WU00:FS00:0x17:Saving result file logfile_01.txt
23:50:05:WU00:FS00:0x17:Saving result file log.txt
[COLOR="red"]23:50:05:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:50:06:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)23:50:06:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:13000 run:278 clone:2 gen:1 core:0x17 unit:0x00000003538b3db7530fea5c651322de
23:50:06:WU00:FS00:Uploading 3.11KiB to 140.163.4.231
23:50:06:WU00:FS00:Connecting to 140.163.4.231:8080
23:50:06:WU01:FS00:Connecting to 171.67.108.201:80
23:50:08:WU01:FS00:Assigned to work server 171.64.65.56
23:50:08:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Pitcairn [Radeon HD 7800] from 171.64.65.56
23:50:08:WU01:FS00:Connecting to 171.64.65.56:8080
23:50:09:WU00:FS00:Upload complete
23:50:09:WU00:FS00:Server responded WORK_ACK (400)
23:50:09:WU00:FS00:Cleaning up
11:34:12:WU00:FS00:Assigned to work server 171.64.65.93
11:34:12:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Pitcairn [Radeon HD 7800] from 171.64.65.93
11:34:12:WU00:FS00:Connecting to 171.64.65.93:8080
11:34:12:ERROR:WU00:FS00:Exception: Server did not assign work unit
11:34:19:WU01:FS00:Upload complete
11:34:19:WU01:FS00:Server responded WORK_ACK (400)
11:34:19:WU01:FS00:Final credit estimate, 27584.00 points
11:34:19:WU01:FS00:Cleaning up
11:35:48:WU00:FS00:Connecting to 171.67.108.201:80
11:35:49:WU00:FS00:Assigned to work server 171.64.65.93
11:35:49:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Pitcairn [Radeon HD 7800] from 171.64.65.93
11:35:49:WU00:FS00:Connecting to 171.64.65.93:8080
11:35:50:ERROR:WU00:FS00:Exception: Server did not assign work unit
11:38:25:WU00:FS00:Connecting to 171.67.108.201:80
11:38:26:WU00:FS00:Assigned to work server 171.64.65.93
11:38:26:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Pitcairn [Radeon HD 7800] from 171.64.65.93
11:38:26:WU00:FS00:Connecting to 171.64.65.93:8080
11:38:27:ERROR:WU00:FS00:Exception: Server did not assign work unit
11:42:40:WU00:FS00:Connecting to 171.67.108.201:80
11:42:40:WU00:FS00:Assigned to work server 171.64.65.93
11:42:40:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Pitcairn [Radeon HD 7800] from 171.64.65.93
11:42:40:WU00:FS00:Connecting to 171.64.65.93:8080
11:42:41:ERROR:WU00:FS00:Exception: Server did not assign work unit
11:49:31:WU00:FS00:Connecting to 171.67.108.201:80
11:49:32:WU00:FS00:Assigned to work server 171.64.65.93
11:49:32:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Pitcairn [Radeon HD 7800] from 171.64.65.93
11:49:32:WU00:FS00:Connecting to 171.64.65.93:8080
11:49:33:ERROR:WU00:FS00:Exception: Server did not assign work unit
12:00:37:WU00:FS00:Connecting to 171.67.108.201:80
12:00:37:WU00:FS00:Assigned to work server 171.64.65.93
12:00:37:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Pitcairn [Radeon HD 7800] from 171.64.65.93
12:00:37:WU00:FS00:Connecting to 171.64.65.93:8080
12:00:38:ERROR:WU00:FS00:Exception: Server did not assign work unit
bekommt ihr gerade core17 WUs zugeteilt?![]()
. Hab mich schon gewundert, aber ja auch meine zwei Karten bekommen gerade mal wieder keine WU mehr zugeteilt. Da muss der NaCl wohl die Zeit überbrücken
. Irgendwas muss ja mein Wasser im PC aufwärmen, sonst frier ich am Ende noch bei den temperaturen.
@ Curecoin Curecoin - Team Summary - EXTREME Overclocking Folding @ Home Stats
Mir ist echt nicht klar wie man !! als Einzelfalter !! 8+ Millionen PPD erreichen kann
Auf alle Fälle absolutwas die da auffahren
bzw. dass die stanford server unter der last noch net zusammengebrochen sind. Könnte natürlich auch sein, dass genau daher auch der kurze ausfall des WU Servers kam.mh, die werden doch garantiert gpu folding betreiben, schon ein kleines Wunder, dass es bei der Anzahl an WUs, die die so durchziehen, noch welche für uns gibtbzw. dass die stanford server unter der last noch net zusammengebrochen sind. Könnte natürlich auch sein, dass genau daher auch der kurze ausfall des WU Servers kam.
