[PCGH-X & HWBot RANKING] 3DMark (2013)
AW: [RANKING] 3DMark (2013)
macht das echt soviel aus wenn man die Grafikkarten soviel übertaktet ? ... komm nich mal über 10.000 punkte Grenze mit 2 Karten
OKi ;)
UPDATE
Ice Storm: 132955 | Maurer | i7-2600k @ 4,5GHz | 12GB DDR3-1333 9-9-9-24 2T | AMD6950 @ 880/1375 | Link
Cloud Gate: 19739 | Maurer | i7-2600k @ 4,5GHz | 12GB DDR3-1333 9-9-9-24 2T | AMD6950 @ 880/1375 | Link
Fire Strike: 3918 | Maurer | i7-2600k @ 4,5GHz | 12GB DDR3-1333 9-9-9-24 2T | AMD6950 @ 880/1375 | Link
So habs nochmal mit 4,5GHz und dem alten AMD Treiber probiert, nachdem der Beta5 bei mir abgeschmiert ist.
Icestorm: 146089 | technus1975 | Core i7-970 @4,2 GHz | 18GB DDR3-2000MHz CL 9-10-9-27 2T | GTX 580 @932/1864/2363 | NVIDIA GeForce GTX 580 video card benchmark result - Intel Core i7-970 Processor ,ASUSTeK Computer INC. SABERTOOTH X58?
Cloudgate: 24109 | technus1975 | Core i7-970 @4,2 GHz | 18GB DDR3-2000MHz CL 9-10-9-27 2T | GTX 580 @932/1864/2363 | NVIDIA GeForce GTX 580 video card benchmark result - Intel Core i7-970 Processor ,ASUSTeK Computer INC. SABERTOOTH X58?
Firestrike: 5286 | technus1975 | Core i7-970 @4,2 GHz | 18GB DDR3-2000MHz CL 9-10-9-27 2T | GTX 580 @932/1864/2363 | NVIDIA GeForce GTX 580 video card benchmark result - Intel Core i7-970 Processor ,ASUSTeK Computer INC. SABERTOOTH X58?
Ice Storm: 180618 | J.Ryan | I7 3770k @ 4,7 | 16GB DDR-2133 XMP Profil 9-11-10-28-2N |NVidia GTX680 @ 1215/1536 | NVIDIA GeForce GTX 680 video card benchmark result - Intel Core i7-3770K Processor,ASUSTeK COMPUTER INC. MAXIMUS V FORMULA score: P180618 3DMarks
Cloud Gate: 26011 | J.Ryan | I7 3770k @ 4.7 | 16GB DDR-2133 XMP Profil 9-11-10-28-2N |NVidia GTX680@ 1215/1536 | NVIDIA GeForce GTX 680 video card benchmark result - Intel Core i7-3770K Processor,ASUSTeK COMPUTER INC. MAXIMUS V FORMULA score: P26011 3DMarks
Fire Strike: 7112 | J.Ryan | I7 3770k @ 4.7 | 16GB DDR-2133 XMP Profil 9-11-10-28-2N |NVidia GTX680 @ 1215/1536 | NVIDIA GeForce GTX 680 video card benchmark result - Intel Core i7-3770K Processor,ASUSTeK COMPUTER INC. MAXIMUS V FORMULA score: P7112 3DMarks
Update
mitn bisl oc nur graka
Icestorm: 112114 | Evgasüchtiger | Phenom II X4 @ 3,6 GHz | 8 GB DDR3-1800MHz CL 9-10-9-28 1T | 7950 @1200/1650|Cat13.2|Link
Cloudgate: 13571| Evgasüchtiger | Phenom II X4 @ 3,6 GHz | 8 GB DDR3-1800MHz CL 9-10-9-28 1T | 7950 @1200/1650|Cat13.2|Link
Firestrike: 6821 | Evgasüchtiger | Phenom II X4 @ 3,6 GHz | 8 GB DDR3-1800MHz CL 9-10-9-28 1T | 7950 @1200/1650|Cat13.2|Link
So, hier die Ergebnisse mit der Sapphire HD7870XT - erstmal @ stock, ich teste die Karte erstmal ein Stück weit und schau ob alles stabil läuft, bevor ich mich an's OC mache. Dann folgen aber nochmal Ergebnisse :D
Icestorm: 137897 | Thallassa | Core i7-860 @ 3,8GHz | 8GB DDR3-1450 CL9-9-9-24-2T | HD7870XT @ 975/1500 Mhz | link
Cloudgate: 18968 | Thallassa | Core i7-860 @ 3,8GHz | 8GB DDR3-1450 CL9-9-9-24-2T | HD7870XT @ 975/1500 | link
Firestrike: 5442 | Thallassa | Core i7-860 @ 3,8GHz | 8GB DDR3-1450 CL9-9-9-24-2T | HD7870XT @ 975/1500 | link
Update meines KüchenPC
Firststrike
3209 | Singlecoreplayer2500+ | Pentium E5700 @ 4GHz | 4GB DDR3-1066 CL 6-6-6-15 1T | GTX 560Ti @1000/2200 MHz | Link
Ice Storm
68491 | Singlecoreplayer2500+ | Pentium E5700 @ 4GHz | 4GB DDR3-1066 CL 6-6-6-15 1T | GTX 560Ti @1000/2200 MHz | Link
Du hast die Ergebnisse nachträglich editiert ;) Außerdem habe ich es Dir ja gestern abend noch auf die Pinnwand gemeißelt, dass ich die neuen Scores heute einfügen werde. :P
Und Du hast im Icestorm-Update weniger Punkte als im Moment. Soll ich das auch updaten? :gruebel: :D
***Updates eingefügt***
sorry war gestern gleich offline und nun bei der Arbeit. icestorm kannste so lassen ;-) heute Abend kommt mal die cpu bisl höher ;-)
Icestorm: 130269 | LTB | i5 - 3470 @ stock (3,2ghz) | 8GB DDR3-1600MHz CL 9-9-9-24 2T | HD7970 @ 1000/1375 | Link
Cloudgate: 15287 | LTB | i5 - 3470 @ stock (3,2ghz) | 8GB DDR3-1600MHz CL 9-9-9-24 2T | HD7970 @ 1000/1375 | Link
Firestrike: 6489 | LTB | i5 - 3470 @ stock (3,2ghz) | 8GB DDR3-1600MHz CL 9-9-9-24 2T | HD7970 @ 1000/1375 | Link
Was das mit dem Grafiktreiber soll weiß ich auch nicht :ka: ... habe den 13.1 installiert.
edit: soo Links sind eingefügt
Icestorm: 39721 | Möbyus | Intel Core 2 Duo E7200 @ 2,5 GHz | 4GB DDR2-400MHz CL 6-6-6-18 2T | GTX 650 @ 1110/2500 | Link
Cloudgate: 4651 | Möbyus | Intel Core 2 Duo E7200 @ 2,5 GHz| 4GB DDR2-400MHz CL 6-6-6-18 2T | GTX 650 @ 1110/2500 | Link
Firestrike: 1694 | Möbyus | Intel Core 2 Duo E7200 @ 2,5 GHz| 4GB DDR2-400MHz CL 6-6-6-18 2T | GTX 650 @ 1110/2500 | Link
Icestorm: 84608 | Chicago | C2Q 6600 @ 3,0GHz | 4GB DDR2-1020MHz CL 5-5-5-15 2T | GTX 560Ti @ 880/1760/1050 | Link
Cloudgate: 10561 | Chicago | C2Q 6600 @ 3,0GHz | 4GB DDR2-1020MHz CL 5-5-5-15 2T | GTX 560Ti @ 880/1760/1050 | Link
Firestrike: 2945 | Chicago | C2Q 6600 @ 3,0GHz | 4GB DDR2-1020MHz CL 5-5-5-15 2T | GTX 560Ti @ 880/1760/1050 | Linkhttp://extreme.pcgameshardware.de/benchmarks/259341-ranking-3dmark-2013-a.html
Hallo Softy...
Habe leider bei der System Beschreibung User Name ---The Black Pearl--- geschrieben richtig wäre aber " J.Ryan "könntest du so nett sein und es bitte ändern :schief:
---------Danke dir schon mal im voraus, für die Mühe die du dir hier machst--------- :daumen::daumen::daumen:
Mfg. J.Ryan
