Micro lags/stuttering in fast allen Spielen
Ai Overclock Tuner (Ai-Übertaktungstuner) [XMP
XMP [XMP DDR4-3200 16-18-18-38-1.35V]
BCLK Frequency (BCLK-Frequenz) [100.00]
FCLK Frequency [Auto]
ASUS Multicore Enhancement (ASUS Multicore-Erweiterung) [Disabled]
CPU Core Ratio [Sync All Cores]
1-Core Ratio Limit [43]
2-Core Ratio Limit [43]
3-Core Ratio Limit [43]
4-Core Ratio Limit [43]
BCLK Frequency : DRAM Frequency Ratio [Auto]
DRAM Odd Ratio Mode (Modus eigentümliches DRAM-Verhältnis) [Enabled]
DRAM Frequency [DDR4-3200MHz]
OC Tuner [Keep Current Settings]
EPU Power Saving Mode (EPU-Energiesparmodus) [Deaktiviert]
CPU SVID Support (CPU-SVID-Unterstützung) [Auto]
CPU Core/Cache Current Limit Max. (CPU-Kern-/Cache-Stromgrenze max.) [255.50]
Min CPU Cache Ratio (Minimales CPU-Cache-Verhältnis) [8]
Max CPU Cache Ratio [41]
Internal PLL Voltage [Auto]
Extreme Überspannung [Disabled]
CPU Core/Cache Voltage [Adaptive Mode]
- Offset-Modus-Zeichen [-]
- Additional Turbo Mode CPU Core Voltage [1.350]
- Offset Voltage [0.001]
DRAM Voltage [1.350]
CPU VCCIO Voltage [Auto]
CPU System Agent Voltage [Auto]
PCH Core Voltage [Auto]
CPU Standby Voltage [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL0 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL1 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL2 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL3 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL4 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL5 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL6 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL7 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL0 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL1 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL2 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL3 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL4 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL5 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL6 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL7 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL0 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL1 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL2 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL3 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL4 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL5 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL6 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL7 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL0 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL1 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL2 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL3 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL4 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL5 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL6 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL7 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL0 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL1 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL2 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL3 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL4 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL5 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL6 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL7 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL0 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL1 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL2 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL3 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL4 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL5 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL6 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL7 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL0 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL1 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL2 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL3 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL4 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL5 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL6 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL7 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL0 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL1 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL2 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL3 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL4 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL5 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL6 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL7 [Auto]
DRAM CAS# Latency [16]
DRAM RAS# to CAS# Delay [18]
DRAM RAS# ACT Time [38]
DRAM Command Rate [Auto]
DRAM RAS# to RAS# Delay L [Auto]
DRAM RAS# to RAS# Delay S [Auto]
DRAM REF Cycle Time [Auto]
DRAM Refresh Interval [Auto]
DRAM WRITE Recovery Time [Auto]
DRAM READ to PRE Time [Auto]
DRAM FOUR ACT WIN Time [Auto]
DRAM WRITE to READ Delay L [Auto]
DRAM WRITE to READ Delay S [Auto]
DRAM CKE Minimum Pulse Width [Auto]
DRAM Write Latency [Auto]
tRDRD_sg [Auto]
tRDRD_dg [Auto]
tRDWR_sg [Auto]
tRDWR_dg [Auto]
tWRWR_sg [Auto]
tWRWR_dg [Auto]
tWRRD_sg [Auto]
tWRRD_dg [Auto]
tRDRD_dr [Auto]
tRDRD_dd [Auto]
tRDWR_dr [Auto]
tRDWR_dd [Auto]
tWRWR_dr [Auto]
tWRWR_dd [Auto]
tWRRD_dr [Auto]
tWRRD_dd [Auto]
TWRPRE [Auto]
TRDPRE [Auto]
tREFIX9 [Auto]
OREF_RI [Auto]
MRC Fast Boot [Deaktiviert]
DRAM CLK Period [Auto]
Memory Scrambler [Aktiviert]
Channel A DIMM Control [Enable both DIMMs]
Channel B DIMM Control [Enable both DIMMs]
MCH Full Check [Auto]
DLLBwEn [Auto]
DRAM SPD Write [Disabled]
DRAM RTL INIT value [Auto]
DRAM RTL (CHA DIMM0 Rank0) [Auto]
DRAM RTL (CHA DIMM0 Rank1) [Auto]
DRAM RTL (CHA DIMM1 Rank0) [Auto]
DRAM RTL (CHA DIMM1 Rank1) [Auto]
DRAM RTL (CHB DIMM0 Rank0) [Auto]
DRAM RTL (CHB DIMM0 Rank1) [Auto]
DRAM RTL (CHB DIMM1 Rank0) [Auto]
DRAM RTL (CHB DIMM1 Rank1) [Auto]
DRAM IOL (CHA DIMM0 Rank0) [Auto]
DRAM IOL (CHA DIMM0 Rank1) [Auto]
DRAM IOL (CHA DIMM1 Rank0) [Auto]
DRAM IOL (CHA DIMM1 Rank1) [Auto]
DRAM IOL (CHB DIMM0 Rank0) [Auto]
DRAM IOL (CHB DIMM0 Rank1) [Auto]
DRAM IOL (CHB DIMM1 Rank0) [Auto]
DRAM IOL (CHB DIMM1 Rank1) [Auto]
CHA IO_Latency_offset [Auto]
CHB IO_Latency_offset [Auto]
CHA RFR delay [Auto]
CHB RFR delay [Auto]
ODT RTT WR (CHA) [Auto]
ODT RTT PARK (CHA) [Auto]
ODT RTT NOM (CHA) [Auto]
ODT RTT WR (CHB) [Auto]
ODT RTT PARK (CHB) [Auto]
ODT RTT NOM (CHB) [Auto]
ODT_READ_DURATION [Auto]
ODT_READ_DELAY [Auto]
ODT_WRITE_DURATION [Auto]
ODT_WRITE_DELAY [Auto]
Data Rising Slope [Auto]
Data Rising Slope Offset [Auto]
Cmd Rising Slope [Auto]
Cmd Rising Slope Offset [Auto]
Ctl Rising Slope [Auto]
Ctl Rising Slope Offset [Auto]
Clk Rising Slope [Auto]
Clk Rising Slope Offset [Auto]
Data Falling Slope [Auto]
Data Falling Slope Offset [Auto]
Cmd Falling Slope [Auto]
Cmd Falling Slope Offset [Auto]
Ctl Falling Slope [Auto]
Ctl Falling Slope Offset [Auto]
Clk Falling Slope [Auto]
Clk Falling Slope Offset [Auto]
CPU Load-Line Calibration (CPU-Belastungslinie-Kalibrierung) [Level 4]
CPU Current Capability (CPU-Stromfähigkeit) [Auto]
CPU VRM Switching Frequency (CPU-VRM-Schaltfrequenz) [Auto]
VRM Spread Spectrum (VRM-Streuspektrum) [Disabled]
CPU Power Duty Control (CPU-Leistungszyklusregelung) [T.Probe]
CPU Power Phase Control (CPU-Leistungsphasensteuerung) [Auto]
Intel(R) SpeedStep(tm) [Auto]
Turbo Mode [Enabled]
Long Duration Package Power Limit (Langzeit-Paket-Leistungslimit) [Auto]
Package Power Time Window (Paket-Leistungszeitfenster) [Auto]
Short Duration Package Power Limit (Kurzzeit-Paket-Leistungslimit) [Auto]
IA AC Load Line [0.01]
IA DC Load Line [0.01]
Security Device Support [Enable]
Hyper-threading [Enabled]
Active Processor Cores [All]
Intel Virtualization Technology [Disabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetch [Enabled]
CPU C states [Auto]
CFG lock [Disabled]
PCI Express Native Power Management [Deaktiviert]
DMI Link ASPM Control [Deaktiviert]
ASPM Support [Deaktiviert]
PEG - ASPM [Deaktiviert]
VT-d [Deaktiviert]
Primary Display [Auto]
iGPU-Initialisierung [Deaktiviert]
PCIEX16_1-Verbindungsgeschwindigkeit [Auto]
PCIEX16_2-Verbindungsgeschwindigkeit [Auto]
DMI Max Link Speed [Auto]
IOAPIC 24-119 Entries [Aktiviert]
PCIe Speed [Auto]
Hyper kit Mode [Deaktiviert]
SATA Controller(s) [Aktiviert]
SATA Mode Selection [AHCI]
Aggressive LPM Support [Deaktiviert]
SMART Self Test [Enabled]
SATA6G_1(Gray) [Aktiviert]
Hot Plug [Deaktiviert]
SATA6G_2(Gray) [Aktiviert]
SATA6G_3(Gray) [Aktiviert]
SATA6G_4(Gray) [Aktiviert]
SATA6G_5(Gray) [Aktiviert]
SATA6G_6(Gray) [Aktiviert]
Legacy USB Support [Enabled]
XHCI Hand-off [Disabled]
USB [Auto]
Generic-Compact Flash 1.01 [Auto]
Generic-SD/MMC 1.00 [Auto]
Generic-MS/MS-PRO 1.03 [Auto]
Generic-xD-Picture 1.02 [Auto]
USB3_1 [Aktiviert]
USB3_2 [Aktiviert]
USB3_3 [Aktiviert]
USB3_4 [Aktiviert]
USB3_5 [Aktiviert]
USB3_6 [Aktiviert]
USB7 [Aktiviert]
USB8 [Aktiviert]
USB9 [Aktiviert]
USB10 [Aktiviert]
USB11 [Aktiviert]
USB12 [Aktiviert]
USB13 [Aktiviert]
USB14 [Aktiviert]
ErP-Bereit [Aktivieren (S4 + S5)]
Nach Stromausfall wiederherstellen [Ausgeschaltet]
Einschalten durch PCI-E [Deaktiviert]
Einschalten durch Ring (Eingehender Ruf) [Deaktiviert]
Einschalten durch RTC [Deaktiviert]
Model Name LED Lighting [Breathing Mode]
Azalia HD Audio-Controller [Aktiviert]
Fronttafeltyp [HD Audio]
DVI Port Audio [Deaktiviert]
Depop [Aktiviert]
SupremeFX LED Lighting [Breathing Mode]
M.2/SATA Express Detect Mode [Auto]
Asmedia USB 3.1-Controller [Aktiviert]
Asmedia USB 3.1-Akkuladeunterstützung [Deaktiviert]
Intel-LAN-Controller [Aktivieren]
Intel PXE Option ROM [Disabled]
USB Type C Power Switch [Auto]
Serielle Schnittstelle [Enabled]
Einstellungen ändern [IO=3F8h; IRQ=4]
Network Stack [Deaktiviert]
Gerät [TOSHIBA DT01ACA100 ]
Hide Asus Logo [Disabled]
CPU-Temperatur(PECI) [Verwaltung]
MB-Temperatur [Verwaltung]
VRM Temperature [Verwaltung]
PCH Temperature [Verwaltung]
T_Sensor Temperature [Verwaltung]
EXT_Sensor1 Temperature [Verwaltung]
EXT_Sensor2 Temperature [Verwaltung]
EXT_Sensor3 Temperature [Verwaltung]
CPU-Lüftergeschwindigkeit [Verwaltung]
CPU Optionale Lüftergeschwindigkeit [Verwaltung]
Gehäuselüfter-1-Drehzahl [Verwaltung]
Gehäuselüfter-2-Drehzahl [Verwaltung]
Gehäuselüfter-3-Drehzahl [Verwaltung]
Extension 1-Geschwindigkeit [Verwaltung]
Extension 2-Geschwindigkeit [Verwaltung]
Lüfter8-Geschwindigkeit [Verwaltung]
CPU-Kern-Spannung [Verwaltung]
CPU Graphics Voltage [Verwaltung]
3.3V-Spannung [Verwaltung]
5V-Spannung [Verwaltung]
12V-Spannung [Verwaltung]
PCH Core Voltage [Verwaltung]
CPU System Agent Voltage [Verwaltung]
CPU VCCIO Voltage [Verwaltung]
DRAM Voltage [Verwaltung]
CPU Standby Voltage [Verwaltung]
Anti-Surge-Unterstützung [Enabled]
CPU Q-Fan-Kontrolle [Deaktiviert]
Gehäuselüfter 1 Q-Fan-Steuerung [DC Mode]
Chassis Fan 1 Q-Fan Source [CPU]
Unterer Grenzwert der Gehäuselüftergeschwindigkeit [300 RPM]
Gehäuselüfter-1-Profil [Standard]
Gehäuselüfter 2 Q-Fan-Steuerung [DC Mode]
Chassis Fan 2 Q-Fan Source [CPU]
Gehäuselüfter-2-Profil [Standard]
Gehäuselüfter3-Q-Fan-Steuerung [DC Mode]
Chassis Fan 3 Q-Fan Source [CPU]
Gehäuselüfter-3-Profil [Standard]
Extension Fan 1 Q-Fan Control [DC Mode]
Extension Fan 1 Q-Fan Source [CPU]
Extension Fan 1 Speed Low Limit [300 RPM]
Extension Fan 1 Profile [Standard]
Extension Fan 2 Q-Fan Control [DC Mode]
Extension Fan 2 Q-Fan Source [CPU]
Extension Fan 2 Speed Low Limit [300 RPM]
Extension Fan 2 Profile [Standard]
Extension Fan 3 Q-Fan Control [DC Mode]
Extension Fan 3 Q-Fan Source [CPU]
Extension Fan 3 Speed Low Limit [300 RPM]
Extension Fan 3 Profile [Standard]
Fast Boot [Disabled]
Boot-Logo-Anzeige [Auto]
POST-Verzögerungszeit [0 Sek]
NUM-Zustand beim Bootup [An]
Bei Fehler auf 'F1' warten [Deaktiviert]
Option-ROM-Meldungen [Force BIOS]
Interrupt 19 Capture [Deaktiviert]
Einrichtungsmodus [EZ-Modus]
CSM starten [Aktiviert]
Bootgerätekontrolle [UEFI und Legacy OPROM]
Von Netzwerkgeräten booten [Legacy only]
Von externen Datenträger booten [Legacy only]
PCI-E/PCI-Erweiterungskarten booten [Legacy only]
Art des Betriebssystems [Anderes Betriebssystem]
Setup Animator [Deaktiviert]
Vom Profil laden [1]
Profilname []
Im Profil speichern [1]
Bus Interface [PCIEX16_1]
ok soweit...
prüfen wir mal ob Vcore fix geht..alles andere bitte lassen:
CPU Core/Cache Voltage [Adaptive Mode] -> [Manual Mode]
- CPU Core Voltage Override [1.350]
Min CPU Cache Ratio (Minimales CPU-Cache-Verhältnis) [41]
IA AC Load Line [0.01] ->[Auto]
IA DC Load Line [0.01]->[Auto]
Dann windows starten und nur HWinfo und Cinebranch laufen lassen.
Den Energiesparmodus auf "Höchstleistung"
wenn Chinebranch ohne Fehler durchgelaufen ist, prime starten...
ok wieder keine einbrüche.
Es kann aber auch am GPU liegen weil der takt von der GPU Dropt bei eimen lack nemlich auch.Bei den Lags die ich jetzt hate ist nur der tackt der GPU runter gegangen.
Habe noch ein bisschen gespielt und es ist ganz gut gelaufen ihr die Ergebnisse.
Es schmiert ab.
Ein Core steigt aus
Die CPU hält den Takt nicht.
Also alles Sachen, die Dir eventuell sofort auffallen :-)
so....dann weiter....
Multi von 43 auf 45 und prime nochmal 15- 30 min laufen lassen.
Dabei beobachtest du mit hwinfo:Temperaturen und Vcore (Linke Spalte unter "Current")
Mach bitte ein Bild von den Spannungen unter Last und lade dieses hoch.
Bevor ich die Änderungen im bios mache wollte ich nur sagen das meine Spannung unter last jetzt schon bei 1,380 V liegt.
Ach und kann ich die Stromeinstellung wieder auf Ausbalanciert stehlen,
