Habe nochmal ein latencymon test gemacht und hatte auch wieder ein paar Stutterings:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:09:39 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: NICOLAS-PC
OS version: Windows 11, 10.0, version 2009, build: 26100 (x64)
Hardware: MS-7E26, Micro-Star International Co., Ltd.
BIOS: 1.J0
CPU: AuthenticAMD AMD Ryzen 7 7800X3D 8-Core Processor
Logical processors: 16
Processor groups: 1
Processor group size: 16
RAM: 32361 MB total
CPU SPEED
Reported CPU speed (WMI): 4201 MHz
Reported CPU speed (registry): 420 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 177,50
Average measured interrupt to process latency (µs): 9,904712
Highest measured interrupt to DPC latency (µs): 170,0
Average measured interrupt to DPC latency (µs): 2,864339
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 8,720
Driver with highest ISR routine execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Highest reported total ISR routine time (%): 0,001082
Driver with highest ISR total time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in ISRs (%) 0,001082
ISR count (execution time <250 µs): 150484
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 968,770
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 576.40 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,049892
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0,13050
DPC count (execution time <250 µs): 1414336
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 13
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: system
Total number of hard pagefaults 5359
Hard pagefault count of hardest hit process: 4236
Number of processes hit: 21
PER CPU DATA
CPU 0 Interrupt cycle time (s): 31,283466
CPU 0 ISR highest execution time (µs): 8,720
CPU 0 ISR total execution time (s): 0,100293
CPU 0 ISR count: 150484
CPU 0 DPC highest execution time (µs): 968,770
CPU 0 DPC total execution time (s): 11,801129
CPU 0 DPC count: 1301213
CPU 1 Interrupt cycle time (s): 1,495579
CPU 1 ISR highest execution time (µs): 0,0
CPU 1 ISR total execution time (s): 0,0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 29,460
CPU 1 DPC total execution time (s): 0,010770
CPU 1 DPC count: 8730
CPU 2 Interrupt cycle time (s): 3,640424
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 101,930
CPU 2 DPC total execution time (s): 0,136141
CPU 2 DPC count: 28133
CPU 3 Interrupt cycle time (s): 1,617810
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 298,530
CPU 3 DPC total execution time (s): 0,014364
CPU 3 DPC count: 7203
CPU 4 Interrupt cycle time (s): 1,240227
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 34,690
CPU 4 DPC total execution time (s): 0,008590
CPU 4 DPC count: 6969
CPU 5 Interrupt cycle time (s): 1,112933
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 32,660
CPU 5 DPC total execution time (s): 0,007562
CPU 5 DPC count: 6327
CPU 6 Interrupt cycle time (s): 1,340998
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 29,150
CPU 6 DPC total execution time (s): 0,012281
CPU 6 DPC count: 10289
CPU 7 Interrupt cycle time (s): 1,313829
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 296,960
CPU 7 DPC total execution time (s): 0,018478
CPU 7 DPC count: 8479
CPU 8 Interrupt cycle time (s): 1,071734
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 50,570
CPU 8 DPC total execution time (s): 0,006255
CPU 8 DPC count: 5672
CPU 9 Interrupt cycle time (s): 0,920907
CPU 9 ISR highest execution time (µs): 0,0
CPU 9 ISR total execution time (s): 0,0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 31,910
CPU 9 DPC total execution time (s): 0,007469
CPU 9 DPC count: 3457
CPU 10 Interrupt cycle time (s): 1,161062
CPU 10 ISR highest execution time (µs): 0,0
CPU 10 ISR total execution time (s): 0,0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 38,760
CPU 10 DPC total execution time (s): 0,009031
CPU 10 DPC count: 5621
CPU 11 Interrupt cycle time (s): 1,014820
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 38,60
CPU 11 DPC total execution time (s): 0,007315
CPU 11 DPC count: 4200
CPU 12 Interrupt cycle time (s): 0,785048
CPU 12 ISR highest execution time (µs): 0,0
CPU 12 ISR total execution time (s): 0,0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 101,540
CPU 12 DPC total execution time (s): 0,025028
CPU 12 DPC count: 7165
CPU 13 Interrupt cycle time (s): 0,760128
CPU 13 ISR highest execution time (µs): 0,0
CPU 13 ISR total execution time (s): 0,0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 288,660
CPU 13 DPC total execution time (s): 0,024260
CPU 13 DPC count: 5974
CPU 14 Interrupt cycle time (s): 0,885686
CPU 14 ISR highest execution time (µs): 0,0
CPU 14 ISR total execution time (s): 0,0
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 69,770
CPU 14 DPC total execution time (s): 0,005255
CPU 14 DPC count: 2438
CPU 15 Interrupt cycle time (s): 0,868894
CPU 15 ISR highest execution time (µs): 0,0
CPU 15 ISR total execution time (s): 0,0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 42,260
CPU 15 DPC total execution time (s): 0,006365
CPU 15 DPC count: 2479
