mAlkAv
PCGHX-HWbot-Member (m/w)
von welchem tweak der wohl redet...![]()
Stelaras war so frei das Vorgehen bei hwbot zu posten:
"Open nvidia inspector and go to the elevated settings. Then press the third button from the right "show unknown settings from nvidia predefined profiles". Then you will see some more options available. Search lower at the "unknown settings", there is an option "pre_d3d9_compatibility_bits". Just pull the arrow and select the "0x00000040 option".
