Legacyy
PCGHX-HWbot-Member (m/w)
Hier die Patchnotes:
Max Payne 3 PC: New Patch for Commonly Reported Issues | Rockstar Games
We've had a lot of positive feedback from the community on the launch of Max Payne 3 on PC and our support for a wide range of specs. That said, there are still a few commonly reported issues, and we'll be rolling out a series of patches that address these starting tonight.
Issues fixed by tonight's patch are below. Our goal is to get everyone up and running as smoothly as possible so be sure to hit http://support.rockstargames.com if you are having any specific issues.
Compatibility Issues
* Fixed reported issues with needing service packs, compatibility with incorrect OS.
Various Crashes
* Fixed a range of issues which could have led to crashes on startup and in-game.
Audio Crash
* Fixed reported issues of audio dropouts when no audio device was plugged in, or when the headphones/speakers disconnected while in game.
Mouse Sensitivity
* Fixed reported issues of mouse being sluggish, especially in prone and Shootdodge™. Increased top end range of mouse sensitivity, but kept the slider from 1-10, allowing the user more range in their sensitivity setting.
Mouse Acceleration
* Fixed reported issues of mouse acceleration affecting aiming, included commandline option to disable mouse acceleration, -nomouseaccel (In a future update, this will be added as an option in the Mouse Controls menu).
Stretched Image / Wrong Aspect Ratio
* Fixed reported issues of game locked in incorrect aspect ratio, or alt-entering and having incorrect aspect ratio. Added commandline option for locked aspect ratio as commandline option -aspectratio width:height (ie. -aspectratio 4:3 / -aspectratio 16:9) In a future update, this will be added as an option in the Graphics menu.
Video Memory Reporting as 0MB
* Fixed reported issues of the video card reporting having 0MB of video memory available. Users unable to adjust Graphics options because of this (Also helps fix stuttering on some video cards).
We are aware of a few outstanding issues including multiplayer cheaters and hackers. Rest assured this will be dealt with in a forthcoming patch.
Various Crashes
Audio Crash
Mouse Sensitivity
Mouse Acceleration
