Error | Redshift
3.0.01 RTX OFF: 6:07
3.0.01 RTX ON: 5:31
3.0.01 RTX OFF: 3:44
3.0.01 RTX ON: 3:26
Error | Redshift
Example 1: Example scene where RTX really takes advantage of the scene. Really simple shading and just a lot of instances of a single object. It obviously has no issue tearing through this and scales beautifully. No depth of field, no volumes, etc.
Resolution: 3840 x 2160 UHD
Total triangles: 50,602,962
RTX ON - Rendering time: 3m:2s (1 GPU(s) used
RTX OFF - Rendering time: 6m:18s (1 GPU(s) used
RTX ON = 108% Faster
2x 2080ti
RTX ON = Rendering time: 1m:35s (2 GPU(s) used
RTX OFF = Rendering time: 3m:7s (2 GPU(s) used
RTX ON = 97% Faster
Example 2: This time we have a scene with mass scattering and volumetric fog/scattering. In this example RTX still scales very well albiet not as much but still performs excelently compared to CUDA only.
Resolution: 3840 x 1607 Anamorphic UHD
Total triangles: 93,741,172,946
RTX ON - Rendering time: 1m:46s (1 GPU(s) used
RTX OFF - Rendering time: 3m:5s (1 GPU(s) used
RTX ON = 74% Faster
2x 2080ti
RTX ON = Rendering time: 1m:20s (2 GPU(s) used
RTX OFF = Rendering time: 1m:36s (2 GPU(s) used
Dual RTX = 20% Faster
Example 3: This scene has a decent amount of 4k different texture maps for all the different Megascan assets with a variety of shader properties, it also has some pretty heavy DOF. So this is a scene that RTX generally wouldn’t accelerate too much. Even then the results are still surprisingly good.
Resolution: 2048 x 857 Anamorphic
Total triangles: 96,910,342
RTX ON - Rendering time: 49.4s (1 GPU(s) used
RTX OFF - Rendering time: 1m:10s (1 GPU(s) used
RTX ON = 43% Faster
2x 2080ti
RTX ON = Rendering time: 29s (2 GPU(s) used
RTX OFF = Rendering time: 59s (2 GPU(s) used
RTX ON = 103% Faster
Example 4: In this final example we have a scene that has several instances but most of the geometry (leaves) consist of the sprite shader which can’t be accelerated by the RT cores. Even in this example though there are still a lot of regular pieces of geometry which can be accelerated like the branches on the trees. I also pushed the unified sampler pretty high to clean up the DOF as much as possible. Even though the sprite node doesn’t get accelerated by RT cores, all the geometry and DOF ray-tracing does, so it still provides a great boost in performance.
Resolution: 1920 x 803 HD Anamorphic
Total triangles: 480,250,028
RTX ON = Rendering time: 12m:16s (1 GPU(s) used
RTX OFF = Rendering time: 15m:54s (1 GPU(s) used
RTX ON = 30% Faster
2x 2080ti
RTX ON = Rendering time: 6m:15s (2 GPU(s) used
RTX OFF = Rendering time: 7m:59s (2 GPU(s) used
RTX ON = 28% Faster
