[PCGH-X & HWBot RANKING] 3DMark (2013)
Neuer Eintrag mit GTX 770
Icestorm
193918 | Ion | i7-3770K @ 4.5GHz | 16GB DDR3 @ 1600MHz CL7-8-8-24 CR1 | GTX 770 @ 1306/4001MHz | Link
Cloudgate
19657 | Ion | i7-3770K @ 4.5GHz | 16GB DDR3 @ 1600MHz CL7-8-8-24 CR1 | GTX 770 @ 1306/4001MHz | Link
Firestrike
7586 | Ion | i7-3770K @ 4.5GHz | 16GB DDR3 @ 1600MHz CL7-8-8-24 CR1 | GTX 770 @ 1306/4001MHz | Link
Icestorm: 159829 | MrWoogey | i7-4770 @ 3,9 GHz | 8GB DDR3-1866 MHz CL 11-11-11-28 1T | GTX 770 @ 1150/1536/1753 | Link
Cloudgate: 23307 | MrWoogey | i7-4770 @ 3,9 GHz | 8GB DDR3-1866 MHz CL 11-11-11-28 1T | GTX 770 @ 1150/1536/1753 | Link
Firestrike: 7242 | MrWoogey | i7-4770 @ 3,9 GHz | 8GB DDR3-1866 MHz CL 11-11-11-28 1T | GTX 770 @ 1150/1536/1753 | Link
Update
Icestorm: 160556 | MrWoogey | i7-4770 @ 3,9 GHz | 8GB DDR3-1866 MHz CL 11-11-11-28 2T | GTX 770 @ 1150/1536/1753 | Link
Cloudgate: 23631 | MrWoogey | i7-4770 @ 3,9 GHz | 8GB DDR3-1866 MHz CL 11-11-11-28 2T | GTX 770 @ 1150/1536/1753 | Link
Firestrike: 7260 | MrWoogey | i7-4770 @ 3,9 GHz | 8GB DDR3-1866 MHz CL 11-11-11-28 2T | GTX 770 @ 1150/1536/1753 | Link
AW: [RANKING] 3DMark (2013)
***update***
IceStorm
131128 | PCGHGS | X6 1055T @ 4,1 GHz | 8GB DDR3-1626MHz CL 11-11-11-28 2T | GTX 670 @ 1163/3150 | Link
IceStorm Extreme
122402 | PCGHGS | X6 1055T @ 4,1 GHz | 8GB DDR3-1626MHz CL 11-11-11-28 2T | GTX 670 @ 1163/3150 | Link
Cloud Gate
18043 | PCGHGS | X6 1055T @ 4,1 GHz | 8GB DDR3-1626MHz CL 11-11-11-28 2T | GTX 670 @ 1163/3150 | Link
Update:
Fire Strike Extreme:
9257 | Chris77 | 3960X @ 4,4 GHz | 16 GB DDR3-1866 CL 9-10-9-28 1T | 2 x GTX Titan @ 876 MHz (+60 MHz)/3304 MHz | Link
Fire Strike:
17388 | Chris77 | 3960X @ 4,4 GHz | 16 GB DDR3-1866 CL 9-10-9-28 1T | 2 x GTX Titan @ 876 MHz (+60 MHz)/3304 MHz | Link
Neuer Eintrag
Icestorm
158565| Veget90 | i5-4670K @ 3.7GHz | 8GB DDR3 @ 1600MHz CL7-8-8-24 | GTX 770 @ 1306/3505MHz | Link
Cloudgate
17532 | Veget90 | i5-4670K @ 3.7GHz | 8GB DDR3 @ 1600MHz CL7-8-8-24 | GTX 770 @ 1306/3505MHz | Link
Firestrike
6956 | Veget90| i5-4670K @ 3.7GHz | 8GB DDR3 @ 1600MHz CL7-8-8-24 | GTX 770 @ 1306/3505MHz | Linkhttp://www.3dmark.com/3dm/871319
Firestrike
6113 | 45thFuchs | i5-4670K @ 4,9GHz | 8GB DDR3 @ 1600MHz CL9-9-9-24 1T | Gtx 660ti @ 1290/3685MHz |Link
Cloudgate
20442 | 45thFuchs | i5-4670K @ 4,9GHz | 8GB DDR3 @ 1600MHz CL9-9-9-24 1T | Gtx 660ti @ 1290/3685MHz |Link
Icestorm
207458 | 45thFuchs | i5-4670K @ 4,9GHz | 8GB DDR3 @ 1600MHz CL9-9-9-24 1T | Gtx 660ti @ 1290/3685MHz |Link
So, und noch ein Update :D
Multi GPU
Cloudgate: 35394 | MADman_One | i7-3930K @4,3 GHz | 32GB DDR3-1600MHz CL 9-9-9-24 2T | 2-WAY GeForce GTX TITAN SLI @993(max. Boost: 1163)/3055 | Link
Firestrike Extreme: 8407 | MADman_One | i7-3930K @4,3 GHz | 32GB DDR3-1600MHz CL 9-9-9-24 2T | 2-WAY GeForce GTX TITAN SLI @993(max. Boost: 1163)/3055 | Link
Könntest Du bei meinem Icestorm und Firestrike Ergebnis des Titan SLI noch die Taktwerte für die GraKas nachziehen (siehe oben: 2-WAY GeForce GTX TITAN SLI@993(max. Boost: 1163)/3055) ?
Hatte bisher nur den max. Boost angegeben, das ist beim Vergleich evtl. etwas irreführend, daher habe ich noch den Baseclock mit eingefügt.
Und ich habe auch mal SLI deaktiviert und nur eine einzelne Titan getestet:
Single GPU
Icestorm: 182333 | MADman_One | i7-3930K @4,3 GHz | 32GB DDR3-1600MHz CL 9-9-9-24 2T | GeForce GTX TITAN @993(max. Boost: 1163)/3055 | Link
Cloudgate: 31346 | MADman_One | i7-3930K @4,3 GHz | 32GB DDR3-1600MHz CL 9-9-9-24 2T | GeForce GTX TITAN @993(max. Boost: 1163)/3055 | Link
Firestrike: 10001 | MADman_One | i7-3930K @4,3 GHz | 32GB DDR3-1600MHz CL 9-9-9-24 2T | GeForce GTX TITAN @993(max. Boost: 1163)/3055 | Link
Firestrike Extreme: 5064 | MADman_One | i7-3930K @4,3 GHz | 32GB DDR3-1600MHz CL 9-9-9-24 2T | GeForce GTX TITAN @993(max. Boost: 1163)/3055 | Link
Nochmal danke, Du machst einen super Job hier :)
Und nochmal ein Update nach längerer Zeit:
Multi GPU
Cloudgate: 37700 | MADman_One | i7-3930K @4,3 GHz | 32GB DDR3-1600MHz CL 9-9-9-24 2T | 2-WAY GeForce GTX TITAN SLI @993(max. Boost: 1163)/3055 | Link
Firestrike: 17099 | MADman_One | i7-3930K @4,3 GHz | 32GB DDR3-1600MHz CL 9-9-9-24 2T | 2-WAY GeForce GTX TITAN SLI 1163/3055 | Link
Firestrike Extreme: 9105 | MADman_One | i7-3930K @4,5 GHz | 32GB DDR3-1600MHz CL 9-9-9-24 2T | 2-WAY GeForce GTX TITAN SLI 1163/3005 | Link
Update Firestrike Multi-GPU :
17012| eagle*23* | i7-3770K @ 4.8 GHz | 8GB DDR3-2200 MHz CL 10-11-11-1 21T | 2x GTX 780 @ 1250/1835MHz Link
Firestrike Extreme Multi-GPU
9430| eagle*23* | i7-3770K @ 4.8 GHz | 8GB DDR3-2200 MHz CL 10-11-11-1 21T | 2x GTX 780 @ 1250/1835MHz Link :what: :stupid:
@eagle*23*
Ich habe Dein altes Ergebnis mit drin gelassen, weil Du mit einer anderen CPU gebencht hast. Ist ganz interessant zum Vergleich :daumen:
up-up-up-up-up-update
