DanielK (einge werden diesen Namen kennen) hat im Creative Forum vor einiger Zeit mal was interessantes über diesen neuen Core3D Chip geschreiben:
Thanks to the user BF, I was able to see what the Recon3D is all about, just by analyzing the software and driver included in the Installation Disc.
About the card itself:
- Recon3D does have a DSP with pre-programmed functions for the THX TruStudio and CrystalVoice.
About the Sound Core3D quad-core processor:
- Not quad-core at all: even the original SB Live! could process as many sound effects at the same time.
- Design is based around the CA0110 PCI Express HD Audio controller with an embedded DSP and integrated DAC.
- EAX is software based, as it is supported through Host OpenAL.
- Pre-programmed DSP with as many sound effects you could find on any car stereo or home theater.
Pros
- Less compatibility issues, as it basically uses simple codec drivers and all EAX gaming effects are processed in software by the system's CPU.
- Dedicated Headphone amplifier.
- THX TruStudio surround sound effects are better than Creative's CMSS3D.
- Hardware accelerated THX TruStudio/CrystalVoice effects.
- Microphone enhancements by CrystalVoice.
Cons
- Really overpriced, not justifiable for such cheap design.
- Average sound quality, even worse than some motherboard integrated HD Audio codecs.
- Limited to 5.1 speakers and 96kHz, questionable for a cutting edge sound card, even if a gaming only card.
- Sound Core3D is just a simple pre-programmed DSP.
- No HDMI connector.
- No hardware EAX acceleration.
- No THX speaker calibration.
- No hardware MIDI synthesizer.
- No ASIO.
- Control panel written in Microsoft .NET, loads slowly and wastes 50MB of RAM when minimized to tray.
- No WHQL drivers.
- Questionable dedicated headphone amp, as the integrated DAC is of poor quality.
The included drivers are not WHQL signed and worse, are from a debug version (just open the .sys driver and you'll see it).
Did Creative improve the software/drivers?
No, if it has less compatibility issues or does not have any at all, is because the drivers MUST be simple, as it is just an HD Audio driver, like I've said before. Then we have the Control Panel which uses a DLL to access the registers in the embedded DSP to enable and adjust the sound enhancements.
Is this a revolutionary sound card?
Not a all.
THX TruStudio Surround is the only REALLY improved feature.
CrystalVoice enhancements have been around for years, being the hardware implementation the only improvement.
As Creative have just released X-Fi MB2 as a retail product, you should better buy this if you DO NOT have a Creative soundcard and want THX TruStudio and EAX5.
Curiously, X-Fi MB2 does not work with Creative cards.
X-Fi MB2 works with ANY soundcard or HD Audio codec, although it needs some tweking for the ASUS Xonar series.
X-Fi Titanium Features you'll be missing:
- Hardware accelerated EAX.
- Fully programmable DSP in Audio Creation mode.
- Hardware MIDI Synthesizer with SoundFont support.
- Very good sound quality for Creative designs, premium/audiophile sound quality for Auzentech/Onkyo designs.
- THX speaker calibration.
- DTS Connect (DTS Interactive encoder/DTS Neo
C)
- HDMI connector for some models.
Quelle:
Keep Titanium HD or get Recon3D? - Page 2
