Hallo.
Ich habe seit heute auch Probleme mit bluescreen.Kam beim zocken von two Worlds.
Habe die Dumpdatei schon nach deiner Anleitung ausgewertet:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\Mini121110-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*
Symbol information
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 6002.18267.amd64fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0xfffff800`02858000 PsLoadedModuleList = 0xfffff800`02a1cdd0
Debug session time: Sat Dec 11 15:22:55.380 2010 (UTC + 1:00)
System Uptime: 0 days 0:13:05.327
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffffa6002fe0f12, fffffa6008b83f20, 0}
*** WARNING: Unable to verify timestamp for cmudax3.sys
*** ERROR: Module load completed but symbols could not be loaded for cmudax3.sys
Probably caused by : ks.sys ( ks!KsProbeStreamIrp+49e )
Followup: MachineOwner
0: kd> !analyse -v
No export analyse found
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffffa6002fe0f12, Address of the instruction which caused the bugcheck
Arg3: fffffa6008b83f20, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
FAULTING_IP:
fffffa60`02fe0f12 ff15d073ffff call qword ptr [ks!_imp_IoFreeMdl (fffffa60`02fd82e8)]
CONTEXT: fffffa6008b83f20 -- (.cxr 0xfffffa6008b83f20)
rax=0000000000000000 rbx=fffffa80050a78d0 rcx=fffffa80050a78d0
rdx=fffffa6008b85000 rsi=fffffa80048a6d30 rdi=fffffa80048a6d30
rip=fffffa6002fe0f12 rsp=fffffa6008b84780 rbp=fffffa8006648060
r8=fffffa6008b85000 r9=ffffffffc0000005 r10=fffffa6008b84448
r11=fffffa6008b82e80 r12=00000000c0000005 r13=0000000000000000
r14=0000000000000071 r15=fffffa80076dc600
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010246
ks!KsProbeStreamIrp+0x49e:
fffffa60`02fe0f12 ff15d073ffff call qword ptr [ks!_imp_IoFreeMdl (fffffa60`02fd82e8)] ds:002b:fffffa60`02fd82e8=0000000000030db8
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: audiodg.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffffa6002f90ed0 to fffffa6002fe0f12
STACK_TEXT:
fffffa60`08b84780 fffffa60`02f90ed0 : fffffa80`048a6d30 fffffa80`08107a70 fffffa80`00000000 fffffa80`048a6f68 : ks!KsProbeStreamIrp+0x49e
fffffa60`08b84810 fffffa60`02f990ef : 00000000`c0000010 fffffa80`06648060 fffffa80`048a6d30 fffffa80`06648060 : portcls!CIrpStream::TransferKsIrp+0x60
fffffa60`08b84860 fffffa60`02f8ab01 : fffffa80`048a6d30 fffffa80`06648060 00000000`00000000 fffff800`029ea478 : portcls!CPortPinWaveCyclic:
eviceIoControl+0xff
fffffa60`08b848d0 fffffa60`02fe06d8 : 00000000`c000000d fffffa80`048a6f68 00000000`c0000002 00000000`00000000 : portcls!DispatchDeviceIoControl+0x79
fffffa60`08b84900 fffffa60`02f8a06c : 00000000`00000000 00000000`20707249 fffffa80`06535730 fffffa60`02e005fb : ks!KsDispatchIrp+0xd8
fffffa60`08b84930 fffffa60`02f31d6a : 00000000`0035b364 00000000`00000000 fffffa60`08b84a20 fffffa60`02e00a0f : portcls!PcDispatchIrp+0x5c
fffffa60`08b84960 00000000`0035b364 : 00000000`00000000 fffffa60`08b84a20 fffffa60`02e00a0f fffffa80`048a6d30 : cmudax3+0x129d6a
fffffa60`08b84968 00000000`00000000 : fffffa60`08b84a20 fffffa60`02e00a0f fffffa80`048a6d30 fffffa80`06535730 : 0x35b364
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: ks!KsProbeStreamIrp+49e
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: ks
IMAGE_NAME: ks.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 49e02bbf
STACK_COMMAND: .cxr 0xfffffa6008b83f20 ; kb
FAILURE_BUCKET_ID: X64_0x3B_ks!KsProbeStreamIrp+49e
Hoffe,jemand kann mir helfen,denn ich wüßte sonst nicht weiter.
Danke schonmal
