AW: Allgemeiner Ryzen Laberthread
Schaut mal meinen post hier an, paar interessante Sachen dabei:
AMD Ryzen: Microsoft prüft Software-Probleme mit neuen CPUs
Edit:
**** IMPORTANT INFO FOR CROSSHAIR VI OWNERS ****
Originally Posted by elmor
Thanks to everyone helping people in the thread, offloads us lot! And they guys showing off their rigs running nicely at way above rated speeds, great job. That's what why we make these products.
Couple of things:
1. Temperature readings on 0902 and pre 5803. We tweaked it a bit too far and will be reversed in future updates, you can manually go back to stock/5803 behavior by going to Tweaker's paradise and set Sense MI skew = Enabled and Sense MI offset = 272 (0902 setting when overclocked is 283). Reading too low can affect your DRAM stability, so if your system is reading less than 30*C I suggest you set it.
2. DRAM settings, we changed to 2T when 2666 or higher ratio is used because of compability and helping some sticks work on the board. Unfortunately we can't set it dynamically or have an option for it until AMD gives us an update. I think overall it should be better for all, if you want to keep 1T you can use 2400 or lower DRAM Ratio + increase REFCLK (140-145 with 2400 DRAM Ratio is a sweet spot).
3. We're aware fan control has a lot of issues at the moment, I'll let you know when we have a fix for it.
Let me know if there's anything else serious that I missed, you guys are busy
We haven't seen many USB issues when pushing REFCLK except when going 145MHz+, perhaps you could try different USB ports from CPU or Promontory?
2x16GB DS most likely with future BIOS updates.
The source is credible. The option would have been to not have any boards at launch, don't think that would have made anyone happier.
