So hab spannung auf 1.60V.
Aber aber nun nach ner weile wieder einen
gehabt. Diesmal was anderes. Hier:
PFN_LIST_CORRUPT (4e)
Typically caused by drivers passing bad memory descriptor lists (ie: calling
MmUnlockPages twice with the same list, etc). If a kernel debugger is
available get the stack trace.
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 00000000000b8201, page frame number
Arg3: 0000000000000000, current page state
Arg4: 00000000000b8281, 0
Debugging Details:
BUGCHECK_STR: 0x4E_99
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: mscorsvw.exe
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff80002b0a2bc to fffff80002a7a600
STACK_TEXT:
fffff880`091b7f98 fffff800`02b0a2bc : 00000000`0000004e 00000000`00000099 00000000`000b8201 00000000`00000000 : nt!KeBugCheckEx
fffff880`091b7fa0 fffff800`02aec937 : 00000000`00000000 fffff680`0000b8c8 00000000`00000002 00000000`00000001 : nt!MiBadShareCount+0x4c
fffff880`091b7fe0 fffff800`02a4eb43 : fffffa80`03f44060 fffff700`000006ec 0000007f`fffffff8 fffff8a0`01fa1930 : nt! ?? ::FNODOBFM::`string'+0x3227e
fffff880`091b8070 fffff800`02a4d5a2 : fffffa80`03f44060 fffffa80`00000006 fffff8a0`00000283 fffff880`00000000 : nt!MiDeleteAddressesInWorkingSet+0x307
fffff880`091b8920 fffff800`02d60c4f : fffff8a0`02294840 fffff880`091b8c20 00000000`00000000 fffffa80`06324b60 : nt!MmCleanProcessAddressSpace+0x96
fffff880`091b8970 fffff800`02d394d1 : 00000000`00000000 fffff8a0`06adcd01 00000000`7efd8000 fffffa80`067b4800 : nt!PspExitThread+0x92f
fffff880`091b8a30 fffff800`02a570e3 : 00000000`00000000 fffffa80`03f8b1c0 00000000`00000000 00000000`00000000 : nt!PsExitSpecialApc+0x1d
fffff880`091b8a60 fffff800`02a57520 : 00000000`00b5fedc fffff880`091b8ae0 fffff800`02d395dc 00000000`00000001 : nt!KiDeliverApc+0x2eb
fffff880`091b8ae0 fffff800`02a798f7 : fffffa80`06324b60 00000000`7efd8000 00000000`000000c0 00000000`7efd8000 : nt!KiInitiateUserApc+0x70
fffff880`091b8c20 00000000`776e17ba : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9c
00000000`0038e7e8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x776e17ba
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!MiBadShareCount+4c
fffff800`02b0a2bc cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!MiBadShareCount+4c
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4b88cfeb
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0x4E_99_nt!MiBadShareCount+4c
Followup: MachineOwner
Arguments:
Debugging Details:
CURRENT_IRQL: 2
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
mal schauen was dann passiert
machen, wenn die Dose einigermassen läuft
Auch notieren, dass die Module EINZELN ohne Probleme funktionieren.
