AW: [Sammelthread] Fakefactory Cinematic Mod 9.51 + HD Addon
FAKEFACTORY CINEMATIC MOD V9.5
Update Build 9.51 Hotfix-Release
This is a strongly recommended hotfix release for a installed CM9 or CM9.5, fixing tons of bugs and adding some improvements.
It contains the complete 9.5 update, so no separate 9.5 patching is required.
HD-ADDON USERS:
Apply this patch *AFTER* you have installed the HD-addon. If you ever install the HD-addon after the hotfix, you MUST apply this hotfix again. For taking effect reselect and install the new models with the Character Pimper.
+ Added new HD Alyx model (Adriana Lima style) with realistic (gravity influenced) hair motion
V14 tagged model is a WIP/TEST
V16 tagged model is a final model
Hint: Not suitable for fans of the battle-worn VALVE style.
+ Recompiled Monk / Barney / GMan models, fixing some Bone-Errors
+ Added new HD Mossman model (blonde again)
+ Added new HD Barney model (closer to VALVE original)
+ Added GMan-Hybrid Model (old VALVE mech with Hires-Facemap as seen in older versions of CM)
+ Reworked Character Pimper for multiple model variations in "Maincharacter" section.
+ Recompiled the maps with higher precision lightmaps and per-vertex-lighting accuracy on props
Fix: Worked around an old Valve Bug in Response-System. Alyx will now allways react if you are staring at her for some time in Non-Combat situations. Reaction depends on her actual condition (relaxed, stimulated, alarmed)
Fix: Portuguese subtitles
Fix: Areaportal error in map prison_05
Fix: Terrain hole in map coast_03
Fix: Ugly skybox and heavy performance drop in canals_13
Fix: Wrong rendered blood splashes
Fix: Wrong LORES-Civilian models (if HD addon was installed)
Fix: Anorexic Monk HD model
Fix (hopefully): Twin-Alyx in prison-levels
Fix: Slowmotion when Quickload (F9) was pressed
Fix: Tons of other small glitches
Hier der HotFix per
Torrent downloaden
