Rumpelkammer: PCGH Folding@Home-Thread II
Code:
[11:51:38] Project: 10057 (Run 9, Clone 0, Gen 12)
[11:51:38] Unit: 0x000000110001329c4c61916d00003aa0
[11:51:38] User: 0x00000000000000000000000000000000
[11:51:38] Machine: 4
[11:51:38] Reading tar file par_all27_prot_lipid.inp
[11:51:39] Reading tar file scpismQuartic.inp
[11:51:39] Reading tar file ww.pdb
[11:51:39] Reading tar file ww.psf
[11:51:39] Reading tar file checkpt
[11:51:39] Reading tar file ww.1002.pos
[11:51:39] Reading tar file ww.1002.vel
[11:51:39] Reading tar file protomol.conf
[11:51:39] Reading tar file core.xml
[11:51:39] Digital signatures verified
[11:51:40] Completed 0 out of 499375 steps (0%)
[12:01:23] Completed 5000 out of 499375 steps (1%)
[12:10:46] Completed 10000 out of 499375 steps (2%)
[12:20:07] Completed 15000 out of 499375 steps (3%)
[12:29:17] Completed 20000 out of 499375 steps (4%)
[12:38:03] Completed 25000 out of 499375 steps (5%)
[12:47:26] Completed 30000 out of 499375 steps (6%)
[12:56:51] Completed 35000 out of 499375 steps (7%)
[13:06:02] Completed 40000 out of 499375 steps (8%)
[13:14:44] Completed 45000 out of 499375 steps (9%)
[13:23:29] Completed 50000 out of 499375 steps (10%)
[13:32:07] Completed 55000 out of 499375 steps (11%)
[13:40:37] Completed 60000 out of 499375 steps (12%)
[13:49:33] Completed 65000 out of 499375 steps (13%)
[13:58:30] Completed 70000 out of 499375 steps (14%)
[14:07:08] Completed 74900 out of 499375 steps (14%)
[14:15:52] Completed 79900 out of 499375 steps (16%)
[14:24:33] Completed 84900 out of 499375 steps (17%)
[14:32:59] Completed 89900 out of 499375 steps (18%)
[14:41:36] Completed 94900 out of 499375 steps (19%)
[14:50:25] Completed 99900 out of 499375 steps (20%)
[14:59:07] Completed 104900 out of 499375 steps (21%)
[15:07:47] Completed 109900 out of 499375 steps (22%)
[15:15:53] Completed 114900 out of 499375 steps (23%)
[15:24:37] Completed 119900 out of 499375 steps (24%)
[15:33:29] Completed 124900 out of 499375 steps (25%)
[15:42:17] Completed 129900 out of 499375 steps (26%)
[15:51:22] Completed 134900 out of 499375 steps (27%)
[16:00:37] Completed 139900 out of 499375 steps (28%)
[16:09:27] Completed 144800 out of 499375 steps (28%)
[16:18:41] Completed 149800 out of 499375 steps (29%)
[16:27:09] Completed 154800 out of 499375 steps (30%)
[16:36:03] Completed 159800 out of 499375 steps (32%)
[16:42:35] ERROR: ProtoMol ERROR: ABORT
[16:42:35] Saving result file logfile_01.txt
[16:42:35] Saving result file checkpt
[16:42:35] Saving result file checkpt.crc
[16:42:35] Saving result file log.txt
[16:42:36] Saving result file protomol.conf
[16:42:36] Saving result file ww.1096.pos
[16:42:36] Saving result file ww.1096.vel
[16:42:36] Saving result file ww.dcd
[16:42:37] Folding@home Core Shutdown: BAD_WORK_UNIT
[16:42:40] CoreStatus = 72 (114)
[16:42:40] Sending work to server
[16:42:40] Project: 10057 (Run 9, Clone 0, Gen 12)
[16:42:40] - Read packet limit of 540015616... Set to 524286976.
[16:42:40] + Attempting to send results [September 27 16:42:40 UTC]
Kann mir jemand sagen warum der jetzt die WU abgebrochen hat?
Temps waren okay und übertaktet wurde der i3 auch nicht. Andere Arbeiten wurden nicht gemacht.
lg
Nichtraucher91
Moin liebe Mitfalter,
ich wollte mal kurz eine kleines Gesuch unseres lieben Stanforders Imran Haque publik machen:
Hi all,
You all are waiting for an OpenCL GPU FAH client, I know. I'm sorry to say I don't have one for you right now...but I do have another piece of OpenCL software that's fun for the whole family! And if you own an OpenCL-capable ATI/AMD board, I have a request for you.
I'll be presenting a study on GPU memory reliability in a couple weeks, but all I have is data on Nvidia boards (and mostly non-Fermi at that). That previous data shows that the typical failure modes of boards depend dramatically on GPU architecture; it's reasonable to surmise that there might be a difference, then, between ATI and Nvidia, but I've got no data to back this up quite yet. So that's what I need .
The proposition is simple: if you own an ATI 4000 or 5000-series GPU, please download MemtestCL and run as much of it as you're willing over the next two weeks, making sure to allow it to report results back to Stanford. Running more test iterations and a larger amount of memory is useful (to a point: if the amount of memory is too large, you may get timeout errors), but I'll take whatever data I can get. If you have multiple GPUs, it'd be great if you could run it on as many as possible. If you want to run it on your CPU or Nvidia board (heaven forfend that anyone in this subforum would have one of those ), all data is welcome!
You won't get any Folding@home points for doing this, but you will have my gratitude. If I find an interesting pattern in the data, I'll update this thread after my presentation.
Imran
* MemtestCL can be downloaded here: Folding@home - DownloadUtils. Installation instructions in this post: viewtopic.php?p=155637#p155637.
* If you want to loop the test, there's an example batch script in this post: viewtopic.php?p=142297#p142297. It was written for MemtestG80, but basically all you have to do is change "memtestg80" to "memtestcl" and it should pretty much work - you may have to add a command line option to auto-select device and platform.
PS - Also, please pass this request on to your folding teammates
PPS - Some of you may remember a similar thread back in the spring. That was for Fermi, this is for ATI. Though more Fermi data is good too...
Oder der grobe Inhalt auch in einem Satz:
Um die Entwicklung des OpenCL-Clients voranzubringen sind Alltagsunterhaltungen zwischen HD4/5k und Mutterbrettchen zur Betrachtung spezifischer OpenCL-Charakteristika von Nöten.
Lasst MemtestCL so oft es geht fehlerfrei rennen und Stanford die Daten zukommen.
Bringt die Entwicklung voran!
So, GPU und CPU arbeiten auf 100%, sind ja beide OpenCL fähig. Meine ppd ist somit wieder auf 0 runter, nachdem ich ja eigentlich in die Top 200 wollte.
Immerhin habe ich mit der GPU schon 20Durchgänge ohne Fehler durch, das lässt hoffen.
Edit: so 500Durchgänge durch, 150 mit der CPU und den Rest mit der GPU.
ich hab mich mal selbst von dem Thema überzeugen lassen und wollte in Zunkunft die ein oder andere WU im Namen des Teams spenden.
Ich hab mir mal den Client auf meiner PS3 Slim installiert.
Die Bedienung ist ja wirklich sehr einfach. Auch dass man der PS3 sagen kann, sie soll nach dem Abarbeiten abschalten. Sehr angenehm. :)
Werde sicherlich, unregelmässig, die ein oder andere Nacht rechnen lassen.
Fürs Team natürlich! :)
Letzte Nacht war die Erste.
So, ich hab mich in die Top 500 reingefaltet:D
In ein paar Tagen von 950 auf 495 find ich nicht schlecht^^
35.000 waren es, jetzt sinds 121.000 Punkte:)
Hi nyso, ist echt nicht schlecht! Was hast du für Hardware?
Danke^^ Phenom II X4 940 @ stock und eine GTX 275 SSC massiv übertaktet^^
bist mir auf der Kakao Stats - Team Members - PC Games Hardware
liste schon ganz dicht auf den Fersen. lässt du dein pc über Nacht laufen?
Bist mir auch schon aufgefallen:D Ich komme dir jeden Tag ein paar Punkte näher;)
Mal läuft der über Nacht, mal nicht. Heute sollte er nachts falten, da hab ich morgens gesehen das er abgestürzt war.....
Wenigstens der GPU-Client faltet dann wieder von alleine weiter^^
Hi, na ja so neue Hardware hab ich nicht ausr meine gerade erworbene GTX 460 2GB, sonst hab ich nur ein Intel Q6600 @3,11GHZ und die GTX 460 läuft auf 830-4008-1660MHZ. Da mir leider das geld Fehlt die GTX 460 in mein Wasserkreißlauf einzubinden macht die schon ein höllen Lärm und das ist nachts nicht auszuhalten, sonst würde ich auch nachts falten würde dan so 16080PPD pro 24h bringen bei mir, nur der strom verbrauch ist mir dan auch zu hoch 380watt bei cpu und gpu volllast.
MFG: acer86
hab 10000 memtestCL Durchgänge mit meiner hd5770, hab den gpu-client weiterlaufen lassen. Dabei ist die Leistung auf 1500ppd gesunken :(,hoffentlich wird das irgendwann was mit dem ati-client.
weiss nicht so genau, über 12 stunden mit 128mb. hatte am ende fast 14k errors :ugly: bei random blocks. aber nur bei 14 von 10000 Durchläufen sind die fehler aufgetreten. werde noch 256mb testen.
So, ich werde leider schon wieder mit der Falterei aufhören müssen...in wenigen Tagen fängt mein Studium an, und mein Desktop Rechner bleibt zu hause. Immerhin konnte ich 77 WUs mit meinem Q6700 spenden.
Viel Spaß noch beim (Wett-)Falten!
Danke für deinen Beitrag und gut Studi
Nicht vergessen, du kannst all die vielen Mitstudenten mit dem Faltvirus anstecken ;)
