JayxG
Wie schafft ihr es momentan reihenweise eure rechner zu freezen ?![]()
Mein SMP hatte die Nacht auch mal wieder keine Lust
Zum Glück kein freezze- so hat wenigstens der GPUclient weiter gefaltet! Hier mal nen Auszug aus dem Fahlog...... dann etwas später noch Versuch Nummer2...
[22:29:41] Completed 1750000 out of 5000000 steps (35 percent)
[22:39:53] Writing local files
[22:39:53] Completed 1800000 out of 5000000 steps (36 percent)
[22:49:05] Gromacs cannot continue further.
[22:49:05] Going to send back what have done.
[22:49:05] logfile size: 54672
[22:49:05] - Writing 55208 bytes of core data to disk...
[22:49:05] ... Done.
[22:49:05] - Failed to delete work/wudata_01.chk
[22:49:05] - Failed to delete work/wudata_01.sas
[22:49:05] - Failed to delete work/wudata_01.pdo
[22:49:05] Warning: check for stray files
[22:51:05]
[22:51:05] Folding@home Core Shutdown: EARLY_UNIT_END
[22:51:05]
[22:51:08] CoreStatus = 7B (123)
[22:51:08] Sending work to server
[22:51:08] Project: 3064 (Run 1, Clone 365, Gen 23)
[22:51:08] + Attempting to send results [May 25 22:51:08 UTC]
[22:51:11] + Results successfully sent
[22:51:11] Thank you for your contribution to Folding@Home.
[01:06:48] + Working ...
[01:06:49]
[01:06:49] *------------------------------*
[01:06:49] Folding@Home Gromacs SMP Core
[01:06:49] Version 1.74 (March 10, 2007)
[01:06:49]
[01:06:49] Preparing to commence simulation
[01:06:49] - Looking at optimizations...
[01:06:49] - Created dyn
[01:06:49] - Files status OK
[01:06:54] - Expanded 4691648 -> 24111057 (decompressed 513.9 percent)
[01:06:54] - Starting from initial work packet
[01:06:54]
[01:06:54] Project: 2665 (Run 1, Clone 202, Gen 116)
[01:06:54]
[01:06:54] Assembly optimizations on if available.
[01:06:54] Entering M.D.
[01:07:15] percent)
[01:07:15] cket
[01:07:15]
[01:07:15] Project: 2665 (Run 1, Clone 202, Gen 116)
[01:07:15]
[01:07:15] Entering M.D.
[01:07:15] e 202, Gen 116)
[01:07:15]
[01:07:22] Rejecting checkpoint
[01:07:23]
[01:07:23] Writing local files
[01:07:23]
[01:07:24] Writing local files
[01:07:25] Gromacs cannot continue further.
[01:07:25] Going to send back what have done.
[01:07:25] logfile size: 7423
[01:07:25] - Writing 7959 bytes of core data to disk...
[01:07:25] ... Done.
[01:07:25] - Failed to delete work/wudata_02.sas
[01:07:25] - Failed to delete work/wudata_02.goe
[01:07:25] Warning: check for stray files
[01:07:25]
[01:07:25] Folding@home Core Shutdown: EARLY_UNIT_END
[01:07:25]
[01:07:29] CoreStatus = 7B (123)
[01:07:29] Sending work to server
[01:07:29] Project: 2665 (Run 1, Clone 202, Gen 116)
[01:07:29] + Attempting to send results [May 26 01:07:29 UTC]
[01:07:30] + Results successfully sent
[01:07:30] Thank you for your contribution to Folding@Home.
WTF!?...bin schon den ganzen Morgen auf der Fehlersuche
meine Vermutung liegt beim RAM!? Mal Memtest mit Furmark oder dem folding GPUclient bzw. mal mit Prime- bisher keinerlei Fehler. Hab dann grad mal von Ganged auf Unganged gestellt- mal schauen ob es was bringt
und viel Glück! Da kann man ja ne Flut an Pts erwarten
