*********************** Log Started 2015-02-09T08:31:50Z ***********************
08:31:50:************************* Folding@home Client *************************
08:31:50: Website:
Folding@home
08:31:50: Copyright: (c) 2009-2014 Stanford University
08:31:50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:31:50: Args:
08:31:50: Config: C:/Users/Rarek/AppData/Roaming/FAHClient/config.xml
08:31:50:******************************** Build ********************************
08:31:50: Version: 7.4.4
08:31:50: Date: Mar 4 2014
08:31:50: Time: 20:26:54
08:31:50: SVN Rev: 4130
08:31:50: Branch: fah/trunk/client
08:31:50: Compiler: Intel(R) C++ MSVC 1500 mode 1200
08:31:50: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
08:31:50: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
08:31:50: Platform: win32 XP
08:31:50: Bits: 32
08:31:50: Mode: Release
08:31:50:******************************* System ********************************
08:31:50: CPU: AMD FX(tm)-6300 Six-Core Processor
08:31:50: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
08:31:50: CPUs: 6
08:31:50: Memory: 8.00GiB
08:31:50: Free Memory: 6.26GiB
08:31:50: Threads: WINDOWS_THREADS
08:31:50: OS Version: 6.1
08:31:50: Has Battery: false
08:31:50: On Battery: false
08:31:50: UTC Offset: 1
08:31:50: PID: 6068
08:31:50: CWD: C:/Users/Rarek/AppData/Roaming/FAHClient
08:31:50: OS: Windows 7 Professional
08:31:50: OS Arch: AMD64
08:31:50: GPUs: 1
08:31:50: GPU 0: NVIDIA:3 GK106 [GeForce GTX 650 Ti]
08:31:50: CUDA: Not detected
08:31:50:Win32 Service: false
08:31:50:***********************************************************************
08:31:50:<config>
08:31:50: <service-description v='Folding@home Client'/>
08:31:50: <service-restart v='true'/>
08:31:50: <service-restart-delay v='5000'/>
08:31:50:
08:31:50: <!-- Client Control -->
08:31:50: <client-threads v='6'/>
08:31:50: <cycle-rate v='4'/>
08:31:50: <cycles v='-1'/>
08:31:50: <data-directory v='.'/>
08:31:50: <disable-sleep-when-active v='true'/>
08:31:50: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
08:31:50: <exit-when-done v='false'/>
08:31:50: <fold-anon v='false'/>
08:31:50: <open-web-control v='false'/>
08:31:50:
08:31:50: <!-- Configuration -->
08:31:50: <config-rotate v='true'/>
08:31:50: <config-rotate-dir v='configs'/>
08:31:50: <config-rotate-max v='16'/>
08:31:50:
08:31:50: <!-- Debugging -->
08:31:50: <assignment-servers>
08:31:50: assign3.stanford.edu:8080 assign4.stanford.edu:80
08:31:50: </assignment-servers>
08:31:50: <auth-as v='true'/>
08:31:50: <capture-directory v='capture'/>
08:31:50: <capture-on-error v='false'/>
08:31:50: <capture-packets v='false'/>
08:31:50: <capture-requests v='false'/>
08:31:50: <capture-responses v='false'/>
08:31:50: <capture-sockets v='false'/>
08:31:50: <core-exec v='FahCore_$type'/>
08:31:50: <core-wrapper-exec v='FAHCoreWrapper'/>
08:31:50: <debug-sockets v='false'/>
08:31:50: <exception-locations v='true'/>
08:31:50: <gpu-assignment-servers>
08:31:50: assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
08:31:50: </gpu-assignment-servers>
08:31:50: <stack-traces v='false'/>
08:31:50:
08:31:50: <!-- Error Handling -->
08:31:50: <max-slot-errors v='10'/>
08:31:50: <max-unit-errors v='5'/>
08:31:50:
08:31:50: <!-- Folding Core -->
08:31:50: <checkpoint v='15'/>
08:31:50: <core-dir v='cores'/>
08:31:50: <core-priority v='low'/>
08:31:50: <cpu-affinity v='false'/>
08:31:50: <cpu-usage v='100'/>
08:31:50: <gpu-usage v='100'/>
08:31:50: <no-assembly v='false'/>
08:31:50:
08:31:50: <!-- Folding Slot Configuration -->
08:31:50: <cause v='ANY'/>
08:31:50: <client-subtype v='STDCLI'/>
08:31:50: <client-type v='advanced'/>
08:31:50: <cpu-species v='X86_AMD'/>
08:31:50: <cpu-type v='AMD64'/>
08:31:50: <cpus v='-1'/>
08:31:50: <gpu v='true'/>
08:31:50: <max-packet-size v='normal'/>
08:31:50: <os-species v='UNKNOWN'/>
08:31:50: <os-type v='WIN32'/>
08:31:50: <project-key v='0'/>
08:31:50: <smp v='true'/>
08:31:50:
08:31:50: <!-- GUI -->
08:31:50: <gui-enabled v='true'/>
08:31:50:
08:31:50: <!-- HTTP Server -->
08:31:50: <allow v='127.0.0.1'/>
08:31:50: <connection-timeout v='60'/>
08:31:50: <deny v='0/0'/>
08:31:50: <http-addresses v='0:7396'/>
08:31:50: <https-addresses v=''/>
08:31:50: <max-connect-time v='900'/>
08:31:50: <max-connections v='800'/>
08:31:50: <max-request-length v='52428800'/>
08:31:50: <min-connect-time v='300'/>
08:31:50: <threads v='6'/>
08:31:50:
08:31:50: <!-- Logging -->
08:31:50: <log v='log.txt'/>
08:31:50: <log-color v='false'/>
08:31:50: <log-crlf v='true'/>
08:31:50: <log-date v='false'/>
08:31:50: <log-date-periodically v='21600'/>
08:31:50: <log-debug v='true'/>
08:31:50: <log-domain v='false'/>
08:31:50: <log-header v='true'/>
08:31:50: <log-level v='true'/>
08:31:50: <log-no-info-header v='true'/>
08:31:50: <log-redirect v='false'/>
08:31:50: <log-rotate v='true'/>
08:31:50: <log-rotate-dir v='logs'/>
08:31:50: <log-rotate-max v='16'/>
08:31:50: <log-short-level v='false'/>
08:31:50: <log-simple-domains v='true'/>
08:31:50: <log-thread-id v='false'/>
08:31:50: <log-thread-prefix v='true'/>
08:31:50: <log-time v='true'/>
08:31:50: <log-to-screen v='true'/>
08:31:50: <log-truncate v='false'/>
08:31:50: <verbosity v='5'/>
08:31:50:
08:31:50: <!-- Network -->
08:31:50: <proxy v=':8080'/>
08:31:50: <proxy-enable v='false'/>
08:31:50: <proxy-pass v=''/>
08:31:50: <proxy-user v=''/>
08:31:50:
08:31:50: <!-- Process Control -->
08:31:50: <child v='false'/>
08:31:50: <daemon v='false'/>
08:31:50: <pid v='false'/>
08:31:50: <pid-file v='Folding@home Client.pid'/>
08:31:50: <respawn v='false'/>
08:31:50: <service v='false'/>
08:31:50:
08:31:50: <!-- Remote Command Server -->
08:31:50: <command-address v='0.0.0.0'/>
08:31:50: <command-allow-no-pass v='127.0.0.1'/>
08:31:50: <command-deny-no-pass v='0/0'/>
08:31:50: <command-enable v='true'/>
08:31:50: <command-port v='36330'/>
08:31:50:
08:31:50: <!-- Slot Control -->
08:31:50: <idle v='false'/>
08:31:50: <max-shutdown-wait v='60'/>
08:31:50: <pause-on-battery v='false'/>
08:31:50: <pause-on-start v='false'/>
08:31:50: <paused v='false'/>
08:31:50: <power v='full'/>
08:31:50:
08:31:50: <!-- User Information -->
08:31:50: <machine-id v='0'/>
08:31:50: <passkey v='********************************'/>
08:31:50: <team v='70335'/>
08:31:50: <user v='Rarek'/>
08:31:50:
08:31:50: <!-- Web Server -->
08:31:50: <web-allow v='127.0.0.1'/>
08:31:50: <web-deny v='0/0'/>
08:31:50: <web-enable v='true'/>
08:31:50:
08:31:50: <!-- Web Server Sessions -->
08:31:50: <session-cookie v='sid'/>
08:31:50: <session-lifetime v='86400'/>
08:31:50: <session-timeout v='3600'/>
08:31:50:
08:31:50: <!-- Work Unit Control -->
08:31:50: <dump-after-deadline v='true'/>
08:31:50: <max-queue v='16'/>
08:31:50: <max-units v='0'/>
08:31:50: <next-unit-percentage v='99'/>
08:31:50: <stall-detection-enabled v='false'/>
08:31:50: <stall-percent v='5'/>
08:31:50: <stall-timeout v='1800'/>
08:31:50:
08:31:50: <!-- Folding Slots -->
08:31:50: <slot id='1' type='GPU'>
08:31:50: <max-packet-size v='medium'/>
08:31:50: <next-unit-percentage v='100'/>
08:31:50: <paused v='true'/>
08:31:50: </slot>
08:31:50:</config>
08:31:50:Trying to access database...
08:31:50:Successfully acquired database lock
08:31:50:Enabled folding slot 01: PAUSED gpu:0:GK106 [GeForce GTX 650 Ti] (by user)
08:31:50:Started thread 4 on PID 6068
08:31:50:Started thread 5 on PID 6068
08:31:50:Started thread 7 on PID 6068
08:31:50:Started thread 9 on PID 6068
08:31:50:Started thread 8 on PID 6068
08:31:50:Started thread 6 on PID 6068
08:31:59:1:127.0.0.1 GET /ping?_=1423470718903&callback=jQuery19009482980351895094_1423470718902
08:32:00:2:127.0.0.1 GET /?nocache=0.8455041330307722
08:32:01:3:127.0.0.1 GET /api/updates/set?_=1423470721160&sid=42a1abb23b2c890be7b8d113082fb4f0&update_id=0&update_path=/api/basic&update_rate=1
08:32:02:4:127.0.0.1 GET /api/updates/set?_=1423470721161&sid=42a1abb23b2c890be7b8d113082fb4f0&update_id=1&update_path=/api/slots&update_rate=1
08:32:02:5:127.0.0.1 GET /api/configured?_=1423470721162&sid=42a1abb23b2c890be7b8d113082fb4f0
08:32:02:6:127.0.0.1 GET /?nocache=0.8455041330307722
08:32:03:7:127.0.0.1 GET /css/normalize.css
08:32:03:8:127.0.0.1 GET /css/main.css
08:32:03:9:127.0.0.1 GET /images/mail.png
08:32:03:10:127.0.0.1 GET /images/facebook.png
08:32:03:11:127.0.0.1 GET /images/twitter.png
08:32:03:12:127.0.0.1 GET /js/jquery-1.10.2.min.js
08:32:04:13:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
08:32:04:14:127.0.0.1 GET /js/intercom.min.js
08:32:04:15:127.0.0.1 GET /js/main.js
08:32:04:15:127.0.0.1:New Web connection
08:32:04:16:127.0.0.1 GET /images/report-bug.png
08:32:06:17:127.0.0.1 GET /images/template/bg.jpg
08:32:06:18:127.0.0.1 GET /images/template/logo_folding_home.png
08:32:06:19:127.0.0.1 GET /images/template/input_radio.png
08:32:06:20:127.0.0.1 GET /images/template/button_bg.png
08:32:06:21:127.0.0.1 GET /api/updates/set?_=1423470725592&sid=7b515f59b46c85a87e5886cf7248abef&update_id=0&update_path=/api/basic&update_rate=1
08:32:06:22:127.0.0.1 GET /api/updates/set?_=1423470725593&sid=7b515f59b46c85a87e5886cf7248abef&update_id=1&update_path=/api/slots&update_rate=1
08:32:06:23:127.0.0.1 GET /api/configured?_=1423470725594&sid=7b515f59b46c85a87e5886cf7248abef
08:32:06:24:127.0.0.1 GET /images/template/select-icons.png
08:32:06:25:127.0.0.1 GET /images/template/ui-bg-slider.png
08:32:07:26:127.0.0.1 GET /images/template/ui-icon-slider.png
08:32:07:27:127.0.0.1 GET /images/template/ui-progress-bg.png
08:32:08:28:127.0.0.1 GET /api/updates?_=1423470725595&sid=7b515f59b46c85a87e5886cf7248abef
08:32:08:29:127.0.0.1 GET /api/updates?_=1423470725596&sid=7b515f59b46c85a87e5886cf7248abef
08:32:09:Started thread 10 on PID 6068
08:32:10:28:127.0.0.1 GET /api/updates?_=1423470725599&sid=7b515f59b46c85a87e5886cf7248abef
08:32:14:29:127.0.0.1 GET /api/updates?_=1423470725600&sid=7b515f59b46c85a87e5886cf7248abef
08:32:15:29:127.0.0.1 GET /api/updates?_=1423470725601&sid=7b515f59b46c85a87e5886cf7248abef
08:32:20:28:127.0.0.1 GET /api/updates?_=1423470725602&sid=7b515f59b46c85a87e5886cf7248abef
08:32:25:28:127.0.0.1 GET /api/updates?_=1423470725603&sid=7b515f59b46c85a87e5886cf7248abef
08:32:30:28:127.0.0.1 GET /api/updates?_=1423470725604&sid=7b515f59b46c85a87e5886cf7248abef
08:32:35:28:127.0.0.1 GET /api/updates?_=1423470725605&sid=7b515f59b46c85a87e5886cf7248abef
08:32:40:28:127.0.0.1 GET /api/updates?_=1423470725606&sid=7b515f59b46c85a87e5886cf7248abef
08:32:44:29:127.0.0.1 GET /api/updates?_=1423470725607&sid=7b515f59b46c85a87e5886cf7248abef
08:32:51:28:127.0.0.1 GET /api/updates?_=1423470725608&sid=7b515f59b46c85a87e5886cf7248abef
08:32:55:29:127.0.0.1 GET /api/updates?_=1423470725609&sid=7b515f59b46c85a87e5886cf7248abef
08:33:00:29:127.0.0.1 GET /api/updates?_=1423470725610&sid=7b515f59b46c85a87e5886cf7248abef
08:33:05:28:127.0.0.1 GET /api/updates?_=1423470725611&sid=7b515f59b46c85a87e5886cf7248abef
08:33:11:28:127.0.0.1 GET /api/updates?_=1423470725612&sid=7b515f59b46c85a87e5886cf7248abef
08:33:15:29:127.0.0.1 GET /api/updates?_=1423470725613&sid=7b515f59b46c85a87e5886cf7248abef
08:33:20:29:127.0.0.1 GET /api/updates?_=1423470725614&sid=7b515f59b46c85a87e5886cf7248abef
08:33:25:28:127.0.0.1 GET /api/updates?_=1423470725615&sid=7b515f59b46c85a87e5886cf7248abef
08:33:30:28:127.0.0.1 GET /api/updates?_=1423470725616&sid=7b515f59b46c85a87e5886cf7248abef
08:33:35:28:127.0.0.1 GET /api/updates?_=1423470725617&sid=7b515f59b46c85a87e5886cf7248abef
08:33:41:28:127.0.0.1 GET /api/updates?_=1423470725618&sid=7b515f59b46c85a87e5886cf7248abef
08:33:46:28:127.0.0.1 GET /api/updates?_=1423470725619&sid=7b515f59b46c85a87e5886cf7248abef
08:33:50:31:127.0.0.1 GET /api/updates?_=1423470725620&sid=7b515f59b46c85a87e5886cf7248abef
08:33:57:28:127.0.0.1 GET /api/updates?_=1423470725621&sid=7b515f59b46c85a87e5886cf7248abef
08:34:02:31:127.0.0.1 GET /api/updates?_=1423470725622&sid=7b515f59b46c85a87e5886cf7248abef
08:34:12:Started thread 11 on PID 6068
08:34:38:FS01:Unpaused
08:34:38:WU00:FS01:Starting
08:34:38:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rarek/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 6068 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:34:38:WU00:FS01:Started FahCore on PID 5304
08:34:38:Started thread 12 on PID 6068
08:34:38:WU00:FS01:Core PID:5752
08:34:38:WU00:FS01:FahCore 0x15 started
08:34:38:WU00:FS01:0x15:
08:34:38:WU00:FS01:0x15:*------------------------------*
08:34:38:WU00:FS01:0x15:Folding@Home GPU Core
08:34:38:WU00:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
08:34:38:WU00:FS01:0x15:Build host AmoebaRemote
08:34:38:WU00:FS01:0x15:Board Type NVIDIA/CUDA
08:34:38:WU00:FS01:0x15:Core 15
08:34:38:WU00:FS01:0x15:Window's signal control handler registered.
reparing to commence simulation
08:34:38:WU00:FS01:0x15:- Looking at optimizations...
eleteFrameFiles: successfully deleted file=00/wudata_01.ckp
08:34:38:WU00:FS01:0x15:- Created dyn
08:34:38:WU00:FS01:0x15:- Files status OK
08:34:38:WU00:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:34:38:WU00:FS01:0x15:- Expanded 125249 -> 503186 (decompressed 401.7 percent)
08:34:38:WU00:FS01:0x15:Called DecompressByteArray: compressed_data_size=125249 data_size=503186, decompressed_data_size=503186 diff=0
08:34:38:WU00:FS01:0x15:- Digital signature verified
roject: 7627 (Run 100, Clone 0, Gen 209)
08:34:38:WU00:FS01:0x15:Assembly optimizations on if available.
08:34:38:WU00:FS01:0x15:Entering M.D.
08:34:40:WU00:FS01:0x15:Tpr hash 00/wudata_01.tpr: 1005294786 3750188015 246819857 3421209231 367781298
08:34:40:WU00:FS01:0x15:GPU device id=0
08:34:40:WU00:FS01:0x15:Working on Protein
08:34:40:WU00:FS01:0x15:Client config unavailable.
08:34:40:WU00:FS01:0x15:Finished fah_main status=59
08:34:40:WU00:FS01:0x15:mdrun_gpu returned 59
08:34:40:WU00:FS01:0x15:GPU memtest failure
08:34:40:WU00:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
08:34:40:WARNING:WU00:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
08:34:41:WU00:FS01:Starting
08:34:41:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rarek/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 6068 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:34:41:WU00:FS01:Started FahCore on PID 3972
08:34:41:Started thread 13 on PID 6068
08:34:41:WU00:FS01:Core PID:5400
08:34:41:WU00:FS01:FahCore 0x15 started
08:34:41:WU00:FS01:0x15:
08:34:41:WU00:FS01:0x15:*------------------------------*
08:34:41:WU00:FS01:0x15:Folding@Home GPU Core
08:34:41:WU00:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
08:34:41:WU00:FS01:0x15:Build host AmoebaRemote
08:34:41:WU00:FS01:0x15:Board Type NVIDIA/CUDA
08:34:41:WU00:FS01:0x15:Core 15
08:34:41:WU00:FS01:0x15:Window's signal control handler registered.
08:34:41:WU00:FS01:0x15:- Looking at optimizations...
08:34:41:WU00:FS01:0x15:- Created dyn
08:34:41:WU00:FS01:0x15:- Files status OK
08:34:41:WU00:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:34:41:WU00:FS01:0x15:- Expanded 125249 -> 503186 (decompressed 401.7 percent)
08:34:41:WU00:FS01:0x15:Called DecompressByteArray: compressed_data_size=125249 data_size=503186, decompressed_data_size=503186 diff=0
08:34:41:WU00:FS01:0x15:- Digital signature verified
08:34:41:WU00:FS01:0x15:Assembly optimizations on if available.
08:34:41:WU00:FS01:0x15:Entering M.D.
08:34:43:WU00:FS01:0x15:Tpr hash 00/wudata_01.tpr: 1005294786 3750188015 246819857 3421209231 367781298
08:34:43:WU00:FS01:0x15:GPU device id=0
08:34:43:WU00:FS01:0x15:Working on Protein
08:34:43:WU00:FS01:0x15:Client config unavailable.
08:34:43:WU00:FS01:0x15:Finished fah_main status=59
08:34:43:WU00:FS01:0x15:mdrun_gpu returned 59
08:34:43:WU00:FS01:0x15:GPU memtest failure
08:34:43:WU00:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
08:34:43:WARNING:WU00:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
08:34:43:WARNING:WU00:FS01:Too many errors, failing
08:34:44:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:7627 run:100 clone:0 gen:209 core:0x15 unit:0x0000010f664f2dd152a3c480e1fb28d5
08:34:44:WU00:FS01:Connecting to 171.64.65.105:8080
08:34:44:WU01:FS01:Connecting to 171.67.108.200:80
08:34:45:WU01:FS01:Assigned to work server 171.64.65.105
08:34:45:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK106 [GeForce GTX 650 Ti] from 171.64.65.105
08:34:45:WU01:FS01:Connecting to 171.64.65.105:8080
08:34:53:Removing old file 'configs/config-20150205-235704.xml'
08:34:53:Saving configuration to config.xml
08:34:53:<config>
08:34:53: <!-- Folding Core -->
08:34:53: <core-priority v='low'/>
08:34:53:
08:34:53: <!-- Folding Slot Configuration -->
08:34:53: <client-type v='advanced'/>
08:34:53:
08:34:53: <!-- Logging -->
08:34:53: <verbosity v='5'/>
08:34:53:
08:34:53: <!-- Network -->
08:34:53: <proxy v=':8080'/>
08:34:53:
08:34:53: <!-- Slot Control -->
08:34:53: <pause-on-battery v='false'/>
08:34:53: <power v='full'/>
08:34:53:
08:34:53: <!-- User Information -->
08:34:53: <passkey v='********************************'/>
08:34:53: <team v='70335'/>
08:34:53: <user v='Rarek'/>
08:34:53:
08:34:53: <!-- Folding Slots -->
08:34:53: <slot id='1' type='GPU'>
08:34:53: <max-packet-size v='medium'/>
08:34:53: <next-unit-percentage v='100'/>
08:34:53: </slot>
08:34:53:</config>
08:34:57:WU00:FS01:Server responded WORK_QUIT (404)
08:34:57:WARNING:WU00:FS01:Server did not like results, dumping
08:34:57:WU00:FS01:Cleaning up
08:34:58:WU01:FS01
ownloading 122.35KiB
08:35:01:WU01:FS01
ownload complete
08:35:01:WU01:FS01:Received Unit: id:01 state
OWNLOAD error:NO_ERROR project:7623 run:354 clone:0 gen:281 core:0x15 unit:0x00000193664f2dd14fe4fa723ed6eecd
08:35:01:WU01:FS01:Starting
08:35:01:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rarek/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 6068 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:35:01:WU01:FS01:Started FahCore on PID 5272
08:35:01:Started thread 14 on PID 6068
08:35:01:WU01:FS01:Core PID:4120
08:35:01:WU01:FS01:FahCore 0x15 started
08:35:01:WU01:FS01:0x15:
08:35:01:WU01:FS01:0x15:*------------------------------*
08:35:01:WU01:FS01:0x15:Folding@Home GPU Core
08:35:01:WU01:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
08:35:01:WU01:FS01:0x15:Build host AmoebaRemote
08:35:01:WU01:FS01:0x15:Board Type NVIDIA/CUDA
08:35:01:WU01:FS01:0x15:Core 15
08:35:01:WU01:FS01:0x15:Window's signal control handler registered.
08:35:01:WU01:FS01:0x15:- Looking at optimizations...
eleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:35:01:WU01:FS01:0x15:- Created dyn
08:35:01:WU01:FS01:0x15:- Files status OK
08:35:01:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:35:01:WU01:FS01:0x15:- Expanded 124777 -> 501826 (decompressed 402.1 percent)
08:35:01:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=124777 data_size=501826, decompressed_data_size=501826 diff=0
08:35:01:WU01:FS01:0x15:- Digital signature verified
roject: 7623 (Run 354, Clone 0, Gen 281)
08:35:01:WU01:FS01:0x15:Assembly optimizations on if available.
08:35:01:WU01:FS01:0x15:Entering M.D.
08:35:03:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 781931956 1811288714 2361240860 1031335851 1503369018
08:35:03:WU01:FS01:0x15:GPU device id=0
08:35:03:WU01:FS01:0x15:Working on Protein
08:35:03:WU01:FS01:0x15:Client config unavailable.
08:35:03:WU01:FS01:0x15:Finished fah_main status=59
08:35:03:WU01:FS01:0x15:mdrun_gpu returned 59
08:35:03:WU01:FS01:0x15:GPU memtest failure
08:35:03:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
08:35:03:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
08:35:04:WU01:FS01:Starting
08:35:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rarek/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 6068 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:35:04:WU01:FS01:Started FahCore on PID 6116
08:35:04:Started thread 15 on PID 6068
08:35:04:WU01:FS01:Core PID:4784
08:35:04:WU01:FS01:FahCore 0x15 started
08:35:04:WU01:FS01:0x15:
08:35:04:WU01:FS01:0x15:*------------------------------*
08:35:04:WU01:FS01:0x15:Folding@Home GPU Core
08:35:04:WU01:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
08:35:04:WU01:FS01:0x15:Build host AmoebaRemote
08:35:04:WU01:FS01:0x15:Board Type NVIDIA/CUDA
08:35:04:WU01:FS01:0x15:Core 15
08:35:04:WU01:FS01:0x15:Window's signal control handler registered.
08:35:04:WU01:FS01:0x15:- Looking at optimizations...
08:35:04:WU01:FS01:0x15:- Created dyn
08:35:04:WU01:FS01:0x15:- Files status OK
08:35:04:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:35:04:WU01:FS01:0x15:- Expanded 124777 -> 501826 (decompressed 402.1 percent)
08:35:04:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=124777 data_size=501826, decompressed_data_size=501826 diff=0
08:35:04:WU01:FS01:0x15:- Digital signature verified
08:35:04:WU01:FS01:0x15:Assembly optimizations on if available.
08:35:04:WU01:FS01:0x15:Entering M.D.
08:35:06:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 781931956 1811288714 2361240860 1031335851 1503369018
08:35:06:WU01:FS01:0x15:GPU device id=0
08:35:06:WU01:FS01:0x15:Working on Protein
08:35:06:WU01:FS01:0x15:Client config unavailable.
08:35:06:WU01:FS01:0x15:Finished fah_main status=59
08:35:06:WU01:FS01:0x15:mdrun_gpu returned 59
08:35:06:WU01:FS01:0x15:GPU memtest failure
08:35:06:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
08:35:06:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
08:35:39:Removing old file 'configs/config-20150205-235906.xml'
08:35:39:Saving configuration to config.xml
08:35:39:<config>
08:35:39: <!-- Folding Core -->
08:35:39: <core-priority v='low'/>
08:35:39:
08:35:39: <!-- Folding Slot Configuration -->
08:35:39: <client-type v='advanced'/>
08:35:39:
08:35:39: <!-- Logging -->
08:35:39: <verbosity v='5'/>
08:35:39:
08:35:39: <!-- Network -->
08:35:39: <proxy v=':8080'/>
08:35:39:
08:35:39: <!-- Slot Control -->
08:35:39: <pause-on-battery v='false'/>
08:35:39: <power v='full'/>
08:35:39:
08:35:39: <!-- User Information -->
08:35:39: <passkey v='********************************'/>
08:35:39: <team v='70335'/>
08:35:39: <user v='Rarek'/>
08:35:39:
08:35:39: <!-- Folding Slots -->
08:35:39: <slot id='1' type='GPU'>
08:35:39: <next-unit-percentage v='100'/>
08:35:39: </slot>
08:35:39:</config>
08:35:54:Removing old file 'configs/config-20150206-001320.xml'
08:35:54:Saving configuration to config.xml
08:35:54:<config>
08:35:54: <!-- Folding Core -->
08:35:54: <core-priority v='low'/>
08:35:54:
08:35:54: <!-- Folding Slot Configuration -->
08:35:54: <client-type v='advanced'/>
08:35:54:
08:35:54: <!-- Logging -->
08:35:54: <verbosity v='5'/>
08:35:54:
08:35:54: <!-- Network -->
08:35:54: <proxy v=':8080'/>
08:35:54:
08:35:54: <!-- Slot Control -->
08:35:54: <pause-on-battery v='false'/>
08:35:54: <power v='full'/>
08:35:54:
08:35:54: <!-- User Information -->
08:35:54: <passkey v='********************************'/>
08:35:54: <team v='70335'/>
08:35:54: <user v='Rarek'/>
08:35:54:
08:35:54: <!-- Folding Slots -->
08:35:54: <slot id='1' type='GPU'>
08:35:54: <next-unit-percentage v='100'/>
08:35:54: </slot>
08:35:54:</config>
08:36:04:WU01:FS01:Starting
08:36:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rarek/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 6068 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:36:04:WU01:FS01:Started FahCore on PID 3164
08:36:04:Started thread 16 on PID 6068
08:36:04:WU01:FS01:Core PID:5896
08:36:04:WU01:FS01:FahCore 0x15 started
08:36:04:WU01:FS01:0x15:
08:36:04:WU01:FS01:0x15:*------------------------------*
08:36:04:WU01:FS01:0x15:Folding@Home GPU Core
08:36:04:WU01:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
08:36:04:WU01:FS01:0x15:Build host AmoebaRemote
08:36:04:WU01:FS01:0x15:Board Type NVIDIA/CUDA
08:36:04:WU01:FS01:0x15:Core 15
08:36:04:WU01:FS01:0x15:Window's signal control handler registered.
08:36:04:WU01:FS01:0x15:- Looking at optimizations...
08:36:04:WU01:FS01:0x15:- Created dyn
08:36:04:WU01:FS01:0x15:- Files status OK
08:36:04:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:36:04:WU01:FS01:0x15:- Expanded 124777 -> 501826 (decompressed 402.1 percent)
08:36:04:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=124777 data_size=501826, decompressed_data_size=501826 diff=0
08:36:04:WU01:FS01:0x15:- Digital signature verified
08:36:04:WU01:FS01:0x15:Assembly optimizations on if available.
08:36:04:WU01:FS01:0x15:Entering M.D.
08:36:06:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 781931956 1811288714 2361240860 1031335851 1503369018
08:36:06:WU01:FS01:0x15:GPU device id=0
08:36:06:WU01:FS01:0x15:Working on Protein
08:36:06:WU01:FS01:0x15:Client config unavailable.
08:36:06:WU01:FS01:0x15:Finished fah_main status=59
08:36:06:WU01:FS01:0x15:mdrun_gpu returned 59
08:36:06:WU01:FS01:0x15:GPU memtest failure
08:36:06:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
08:36:07:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
08:37:04:WU01:FS01:Starting
08:37:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rarek/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 6068 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:37:04:WU01:FS01:Started FahCore on PID 2188
08:37:04:Started thread 17 on PID 6068
08:37:04:WU01:FS01:Core PID:5288
08:37:04:WU01:FS01:FahCore 0x15 started
08:37:05:WU01:FS01:0x15:
08:37:05:WU01:FS01:0x15:*------------------------------*
08:37:05:WU01:FS01:0x15:Folding@Home GPU Core
08:37:05:WU01:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
08:37:05:WU01:FS01:0x15:Build host AmoebaRemote
08:37:05:WU01:FS01:0x15:Board Type NVIDIA/CUDA
08:37:05:WU01:FS01:0x15:Core 15
08:37:05:WU01:FS01:0x15:Window's signal control handler registered.
08:37:05:WU01:FS01:0x15:- Looking at optimizations...
08:37:05:WU01:FS01:0x15:- Created dyn
08:37:05:WU01:FS01:0x15:- Files status OK
08:37:05:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:37:05:WU01:FS01:0x15:- Expanded 124777 -> 501826 (decompressed 402.1 percent)
08:37:05:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=124777 data_size=501826, decompressed_data_size=501826 diff=0
08:37:05:WU01:FS01:0x15:- Digital signature verified
08:37:05:WU01:FS01:0x15:Assembly optimizations on if available.
08:37:05:WU01:FS01:0x15:Entering M.D.
08:37:07:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 781931956 1811288714 2361240860 1031335851 1503369018
08:37:07:WU01:FS01:0x15:GPU device id=0
08:37:07:WU01:FS01:0x15:Working on Protein
08:37:07:WU01:FS01:0x15:Client config unavailable.
08:37:07:WU01:FS01:0x15:Finished fah_main status=59
08:37:07:WU01:FS01:0x15:mdrun_gpu returned 59
08:37:07:WU01:FS01:0x15:GPU memtest failure
08:37:07:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
08:37:07:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
08:38:04:WU01:FS01:Starting
08:38:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rarek/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 6068 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:38:04:WU01:FS01:Started FahCore on PID 5140
08:38:04:Started thread 18 on PID 6068
08:38:04:WU01:FS01:Core PID:3916
08:38:04:WU01:FS01:FahCore 0x15 started
08:38:05:WU01:FS01:0x15:
08:38:05:WU01:FS01:0x15:*------------------------------*
08:38:05:WU01:FS01:0x15:Folding@Home GPU Core
08:38:05:WU01:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
08:38:05:WU01:FS01:0x15:Build host AmoebaRemote
08:38:05:WU01:FS01:0x15:Board Type NVIDIA/CUDA
08:38:05:WU01:FS01:0x15:Core 15
08:38:05:WU01:FS01:0x15:Window's signal control handler registered.
08:38:05:WU01:FS01:0x15:- Looking at optimizations...
08:38:05:WU01:FS01:0x15:- Created dyn
08:38:05:WU01:FS01:0x15:- Files status OK
08:38:05:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:38:05:WU01:FS01:0x15:- Expanded 124777 -> 501826 (decompressed 402.1 percent)
08:38:05:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=124777 data_size=501826, decompressed_data_size=501826 diff=0
08:38:05:WU01:FS01:0x15:- Digital signature verified
08:38:05:WU01:FS01:0x15:Assembly optimizations on if available.
08:38:05:WU01:FS01:0x15:Entering M.D.
08:38:07:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr: 781931956 1811288714 2361240860 1031335851 1503369018
08:38:07:WU01:FS01:0x15:GPU device id=0
08:38:07:WU01:FS01:0x15:Working on Protein
08:38:07:WU01:FS01:0x15:Client config unavailable.
08:38:07:WU01:FS01:0x15:Finished fah_main status=59
08:38:07:WU01:FS01:0x15:mdrun_gpu returned 59
08:38:07:WU01:FS01:0x15:GPU memtest failure
08:38:07:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
08:38:07:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
08:38:07:WARNING:WU01:FS01:Too many errors, failing
08:38:07:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:7623 run:354 clone:0 gen:281 core:0x15 unit:0x00000193664f2dd14fe4fa723ed6eecd
08:38:07:WU01:FS01:Connecting to 171.64.65.105:8080
08:38:07:WU00:FS01:Connecting to 171.67.108.200:80
08:38:08:WU01:FS01:Server responded WORK_QUIT (404)
08:38:08:WARNING:WU01:FS01:Server did not like results, dumping
08:38:08:WU01:FS01:Cleaning up
08:38:09:WU00:FS01:Assigned to work server 171.67.108.52
08:38:09:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GK106 [GeForce GTX 650 Ti] from 171.67.108.52
08:38:09:WU00:FS01:Connecting to 171.67.108.52:8080
08:38:10:WU00:FS01
ownloading 1.52MiB
08:38:16:WU00:FS01
ownload 73.92%
08:38:17:WU00:FS01
ownload complete
08:38:17:WU00:FS01:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:9201 run:618 clone:4 gen:219 core:0x17 unit:0x000001256652edc45399ee58bdcc432d
08:38:17:WU00:FS01:Starting
08:38:17:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rarek/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 6068 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:38:17:WU00:FS01:Started FahCore on PID 1972
08:38:17:Started thread 19 on PID 6068
08:38:17:WU00:FS01:Core PID:5320
08:38:17:WU00:FS01:FahCore 0x17 started
08:38:18:WU00:FS01:0x17:*********************** Log Started 2015-02-09T08:38:17Z ***********************
roject: 9201 (Run 618, Clone 4, Gen 219)
08:38:18:WU00:FS01:0x17:Unit: 0x000001256652edc45399ee58bdcc432d
08:38:18:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
08:38:18:WU00:FS01:0x17:Machine: 1
08:38:18:WU00:FS01:0x17:Reading tar file state.xml
08:38:18:WU00:FS01:0x17:Reading tar file system.xml
08:38:18:WU00:FS01:0x17:Reading tar file integrator.xml
08:38:18:WU00:FS01:0x17:Reading tar file core.xml
igital signatures verified
08:38:18:WU00:FS01:0x17:Folding@home GPU core17
08:38:18:WU00:FS01:0x17:Version 0.0.52
08:38:18:WU00:FS01:0x17:ERROR:exception: Bad platformId size.
08:38:18:WU00:FS01:0x17:Saving result file logfile_01.txt
08:38:18:WU00:FS01:0x17:Saving result file log.txt
08:38:18:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
08:38:18:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:38:19:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:618 clone:4 gen:219 core:0x17 unit:0x000001256652edc45399ee58bdcc432d
08:38:19:WU00:FS01:Uploading 1.85KiB to 171.67.108.52
08:38:19:WU00:FS01:Connecting to 171.67.108.52:8080
08:38:19:WU01:FS01:Connecting to 171.67.108.200:80
08:38:20:WU00:FS01:Upload complete
08:38:20:WU00:FS01:Server responded WORK_ACK (400)
08:38:20:WU00:FS01:Cleaning up
08:38:21:WU01:FS01:Assigned to work server 171.64.65.84
08:38:21:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK106 [GeForce GTX 650 Ti] from 171.64.65.84
08:38:21:WU01:FS01:Connecting to 171.64.65.84:8080
08:38:22:WU01:FS01
ownloading 3.45MiB
08:38:28:WU01:FS01
ownload 18.11%
08:38:34:WU01:FS01
ownload 59.78%
08:38:39:WU01:FS01
ownload complete
08:38:39:WU01:FS01:Received Unit: id:01 state
OWNLOAD error:NO_ERROR project:9112 run:3 clone:8 gen:35 core:0x18 unit:0x0000002e0a3b1e7854738489b0bbeadf
08:38:39:WU01:FS01:Starting
08:38:39:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rarek/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 6068 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:38:39:WU01:FS01:Started FahCore on PID 124
08:38:39:Started thread 20 on PID 6068
08:38:42:WU01:FS01:Core PID:4240
08:38:42:WU01:FS01:FahCore 0x18 started
08:38:42:WU01:FS01:0x18:*********************** Log Started 2015-02-09T08:38:42Z ***********************
roject: 9112 (Run 3, Clone 8, Gen 35)
08:38:42:WU01:FS01:0x18:Unit: 0x0000002e0a3b1e7854738489b0bbeadf
08:38:42:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
08:38:42:WU01:FS01:0x18:Machine: 1
08:38:42:WU01:FS01:0x18:Reading tar file state.xml
08:38:43:WU01:FS01:0x18:Reading tar file system.xml
08:38:44:WU01:FS01:0x18:Reading tar file integrator.xml
08:38:44:WU01:FS01:0x18:Reading tar file core.xml
08:38:44:WU01:FS01:0x18:Folding@home GPU core18
08:38:44:WU01:FS01:0x18:Version 0.0.3
08:38:44:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:38:44:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9112 run:3 clone:8 gen:35 core:0x18 unit:0x0000002e0a3b1e7854738489b0bbeadf
08:38:44:WU01:FS01:Uploading 1.85KiB to 171.64.65.84
08:38:44:WU01:FS01:Connecting to 171.64.65.84:8080
08:38:44:WU00:FS01:Connecting to 171.67.108.200:80
08:38:45:WU01:FS01:Upload complete
08:38:45:WU01:FS01:Server responded WORK_ACK (400)
08:38:45:WU01:FS01:Cleaning up
08:38:46:WU00:FS01:Assigned to work server 140.163.4.233
08:38:46:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GK106 [GeForce GTX 650 Ti] from 140.163.4.233
08:38:46:WU00:FS01:Connecting to 140.163.4.233:8080
08:38:47:WU00:FS01
ownloading 4.93MiB
08:38:53:WU00:FS01
ownload 15.21%
08:38:59:WU00:FS01
ownload 44.37%
08:39:05:WU00:FS01
ownload 73.53%
08:39:10:WU00:FS01
ownload complete
08:39:10:WU00:FS01:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:10469 run:0 clone:6 gen:107 core:0x17 unit:0x000000b8538b3db95388d22fbc7688fd
08:39:10:WU00:FS01:Starting
08:39:10:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Rarek/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 6068 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:39:10:WU00:FS01:Started FahCore on PID 2860
08:39:10:Started thread 21 on PID 6068
08:39:10:WU00:FS01:Core PID:4288
08:39:10:WU00:FS01:FahCore 0x17 started
08:39:10:WU00:FS01:0x17:*********************** Log Started 2015-02-09T08:39:10Z ***********************
roject: 10469 (Run 0, Clone 6, Gen 107)
08:39:10:WU00:FS01:0x17:Unit: 0x000000b8538b3db95388d22fbc7688fd
08:39:10:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
08:39:10:WU00:FS01:0x17:Machine: 1
08:39:10:WU00:FS01:0x17:Reading tar file state.xml
08:39:11:WU00:FS01:0x17:Reading tar file system.xml
08:39:13:WU00:FS01:0x17:Reading tar file integrator.xml
08:39:13:WU00:FS01:0x17:Reading tar file core.xml
08:39:13:WU00:FS01:0x17:Folding@home GPU core17
08:39:13:WU00:FS01:0x17:Version 0.0.52
08:39:13:WU00:FS01:0x17:ERROR:exception: Bad platformId size.
08:39:13:WU00:FS01:0x17:Saving result file logfile_01.txt
08:39:13:WU00:FS01:0x17:Saving result file log.txt
08:39:13:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
08:39:13:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:39:13:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:10469 run:0 clone:6 gen:107 core:0x17 unit:0x000000b8538b3db95388d22fbc7688fd
08:39:13:WU00:FS01:Uploading 1.84KiB to 140.163.4.233
08:39:13:WU00:FS01:Connecting to 140.163.4.233:8080
08:39:13:WU01:FS01:Connecting to 171.67.108.200:80
08:39:13:WU00:FS01:Upload complete
08:39:13:WU00:FS01:Server responded WORK_ACK (400)
08:39:13:WU00:FS01:Cleaning up
08:39:14:WU01:FS01:Assigned to work server 171.67.108.52
08:39:14:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK106 [GeForce GTX 650 Ti] from 171.67.108.52
08:39:14:WU01:FS01:Connecting to 171.67.108.52:8080
08:39:15:WU01:FS01
ownloading 1.52MiB
08:39:21:WU01:FS01
ownload 24.69%
08:39:27:WU01:FS01
ownload 53.49%
