*********************** Log Started 2015-02-07T01:39:11Z ***********************
01:39:11:************************* Folding@home Client *************************
01:39:11: Website:
Folding@home
01:39:11: Copyright: (c) 2009-2014 Stanford University
01:39:11: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:39:11: Args:
01:39:11: Config: C:/Users/User/AppData/Roaming/FAHClient/config.xml
01:39:11:******************************** Build ********************************
01:39:11: Version: 7.4.4
01:39:11: Date: Mar 4 2014
01:39:11: Time: 20:26:54
01:39:11: SVN Rev: 4130
01:39:11: Branch: fah/trunk/client
01:39:11: Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:39:11: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:39:11: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:39:11: Platform: win32 XP
01:39:11: Bits: 32
01:39:11: Mode: Release
01:39:11:******************************* System ********************************
01:39:11: CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
01:39:11: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
01:39:11: CPUs: 8
01:39:11: Memory: 15.88GiB
01:39:11: Free Memory: 14.59GiB
01:39:11: Threads: WINDOWS_THREADS
01:39:11: OS Version: 6.2
01:39:11: Has Battery: false
01:39:11: On Battery: false
01:39:11: UTC Offset: 1
01:39:11: PID: 1936
01:39:11: CWD: C:/Users/User/AppData/Roaming/FAHClient
01:39:11: OS: Windows 8.1 Pro
01:39:11: OS Arch: AMD64
01:39:11: GPUs: 1
01:39:11: GPU 0: NVIDIA:3 GK110 [GeForce GTX 780 Ti]
01:39:11: CUDA: 3.5
01:39:11: CUDA Driver: 7000
01:39:11:Win32 Service: false
01:39:11:***********************************************************************
01:39:11:<config>
01:39:11: <!-- Slot Control -->
01:39:11: <power v='FULL'/>
01:39:11:
01:39:11: <!-- User Information -->
01:39:11: <passkey v='********************************'/>
01:39:11: <team v='70335'/>
01:39:11: <user v='User'/>
01:39:11:
01:39:11: <!-- Folding Slots -->
01:39:11: <slot id='0' type='CPU'>
01:39:11: <paused v='true'/>
01:39:11: </slot>
01:39:11: <slot id='1' type='GPU'>
01:39:11: </slot>
01:39:11:</config>
01:39:11:Trying to access database...
01:39:11:Successfully acquired database lock
01:39:11:Enabled folding slot 00: PAUSED cpu:7 (by user)
01:39:11:Enabled folding slot 01: PAUSED gpu:0:GK110 [GeForce GTX 780 Ti] (by user)
01:39:43:17:127.0.0.1:New Web connection
01:39:48:FS00:Unpaused
01:39:48:FS01:Unpaused
01:39:48:WU02:FS01:Starting
01:39:48:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
01:39:48:WU02:FS01:Started FahCore on PID 2644
01:39:48:WU02:FS01:Core PID:4780
01:39:48:WU02:FS01:FahCore 0x18 started
01:39:48:WU01:FS00:Starting
01:39:48:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
01:39:48:WU01:FS00:Started FahCore on PID 6264
01:39:48:WU01:FS00:Core PID:6280
01:39:48:WU01:FS00:FahCore 0xa4 started
01:39:48:WU02:FS01:0x18:*********************** Log Started 2015-02-07T01:39:48Z ***********************
roject: 10477 (Run 0, Clone 216, Gen 10)
01:39:48:WU02:FS01:0x18:Unit: 0x00000012538b3dba548b1ff9ea83d98d
01:39:48:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
01:39:48:WU02:FS01:0x18:Machine: 1
igital signatures verified
01:39:48:WU02:FS01:0x18:Folding@home GPU core18
01:39:48:WU02:FS01:0x18:Version 0.0.3
01:39:48:WU02:FS01:0x18: Found a checkpoint file
01:39:48:WU01:FS00:0xa4:
01:39:48:WU01:FS00:0xa4:*------------------------------*
01:39:48:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
01:39:48:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
reparing to commence simulation
01:39:48:WU01:FS00:0xa4:- Looking at optimizations...
01:39:48:WU01:FS00:0xa4:- Files status OK
01:39:48:WU01:FS00:0xa4:- Expanded 918111 -> 1523092 (decompressed 165.8 percent)
01:39:48:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=918111 data_size=1523092, decompressed_data_size=1523092 diff=0
01:39:48:WU01:FS00:0xa4:- Digital signature verified
roject: 9010 (Run 496, Clone 1, Gen 52)
01:39:48:WU01:FS00:0xa4:Assembly optimizations on if available.
01:39:48:WU01:FS00:0xa4:Entering M.D.
01:39:54:WU01:FS00:0xa4:Using Gromacs checkpoints
01:39:54:WU01:FS00:0xa4:Mapping NT from 7 to 7
01:39:54:WU01:FS00:0xa4:Resuming from checkpoint
01:39:54:WU01:FS00:0xa4:Verified 01/wudata_01.log
01:39:54:WU01:FS00:0xa4:Verified 01/wudata_01.trr
01:39:54:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
01:39:54:WU01:FS00:0xa4:Verified 01/wudata_01.edr
01:39:54:WU01:FS00:0xa4:Completed 64210 out of 250000 steps (25%)
01:40:12:Removing old file 'configs/config-20150204-204237.xml'
01:40:12:Saving configuration to config.xml
01:40:12:<config>
01:40:12: <!-- Slot Control -->
01:40:12: <power v='FULL'/>
01:40:12:
01:40:12: <!-- User Information -->
01:40:12: <passkey v='********************************'/>
01:40:12: <team v='70335'/>
01:40:12: <user v='User'/>
01:40:12:
01:40:12: <!-- Folding Slots -->
01:40:12: <slot id='0' type='CPU'/>
01:40:12: <slot id='1' type='GPU'/>
01:40:12:</config>
01:40:15:WU02:FS01:0x18:Completed 2375000 out of 5000000 steps (47%)
01:40:15:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:40:25:WU01:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
01:42:02:WU01:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
01:42:32:WU02:FS01:0x18:Completed 2400000 out of 5000000 steps (48%)
01:43:29:WU01:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
01:44:59:WU01:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
01:46:27:WU01:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
01:46:45:WU02:FS01:0x18:Completed 2450000 out of 5000000 steps (49%)
01:47:53:WU01:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
01:49:23:WU01:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
01:50:54:WU01:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
01:50:58:WU02:FS01:0x18:Completed 2500000 out of 5000000 steps (50%)
01:52:23:WU01:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
01:53:51:WU01:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
01:55:23:WU01:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
01:55:27:WU02:FS01:0x18:Completed 2550000 out of 5000000 steps (51%)
01:56:51:WU01:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
01:58:17:WU01:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
01:59:43:WU02:FS01:0x18:Completed 2600000 out of 5000000 steps (52%)
01:59:49:WU01:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
02:01:17:WU01:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
02:02:44:WU01:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
02:04:10:WU02:FS01:0x18:Completed 2650000 out of 5000000 steps (53%)
02:04:12:WU01:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
02:05:39:WU01:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
02:07:06:WU01:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
02:08:23:WU02:FS01:0x18:Completed 2700000 out of 5000000 steps (54%)
02:08:33:WU01:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
02:10:02:WU01:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
02:11:28:WU01:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
02:12:35:WU02:FS01:0x18:Completed 2750000 out of 5000000 steps (55%)
02:12:55:WU01:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
02:14:22:WU01:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
02:15:49:WU01:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
02:16:58:WU02:FS01:0x18:Completed 2800000 out of 5000000 steps (56%)
02:17:16:WU01:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
02:18:42:WU01:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
02:20:10:WU01:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
02:21:10:WU02:FS01:0x18:Completed 2850000 out of 5000000 steps (57%)
02:21:37:WU01:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
02:23:04:WU01:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
02:24:32:WU01:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
02:25:33:WU02:FS01:0x18:Completed 2900000 out of 5000000 steps (58%)
02:25:58:WU01:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
02:27:26:WU01:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
02:28:53:WU01:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
02:29:45:WU02:FS01:0x18:Completed 2950000 out of 5000000 steps (59%)
02:30:20:WU01:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
02:31:47:WU01:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
02:33:15:WU01:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
02:33:57:WU02:FS01:0x18:Completed 3000000 out of 5000000 steps (60%)
02:34:42:WU01:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
02:36:10:WU01:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
02:37:37:WU01:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
02:38:20:WU02:FS01:0x18:Completed 3050000 out of 5000000 steps (61%)
02:39:04:WU01:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
02:40:32:WU01:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
02:41:59:WU01:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
02:42:32:WU02:FS01:0x18:Completed 3100000 out of 5000000 steps (62%)
02:43:26:WU01:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
02:44:52:WU01:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
02:46:19:WU01:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
02:46:56:WU02:FS01:0x18:Completed 3150000 out of 5000000 steps (63%)
02:47:46:WU01:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
02:49:13:WU01:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
02:50:40:WU01:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
02:51:07:WU02:FS01:0x18:Completed 3200000 out of 5000000 steps (64%)
02:52:08:WU01:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
02:53:35:WU01:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
02:55:02:WU01:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
02:55:19:WU02:FS01:0x18:Completed 3250000 out of 5000000 steps (65%)
02:56:29:WU01:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
02:57:55:WU01:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
02:59:22:WU01:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
02:59:43:WU02:FS01:0x18:Completed 3300000 out of 5000000 steps (66%)
03:00:50:WU01:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
03:02:16:WU01:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
03:03:43:WU01:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
03:03:54:WU02:FS01:0x18:Completed 3350000 out of 5000000 steps (67%)
03:05:10:WU01:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
03:06:36:WU01:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
03:08:03:WU01:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
03:08:18:WU02:FS01:0x18:Completed 3400000 out of 5000000 steps (68%)
03:09:30:WU01:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
03:10:57:WU01:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
03:12:24:WU01:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
03:12:29:WU02:FS01:0x18:Completed 3450000 out of 5000000 steps (69%)
03:13:51:WU01:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
03:15:18:WU01:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
03:16:41:WU02:FS01:0x18:Completed 3500000 out of 5000000 steps (70%)
03:16:45:WU01:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
03:18:12:WU01:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
03:19:39:WU01:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
03:21:05:WU02:FS01:0x18:Completed 3550000 out of 5000000 steps (71%)
03:21:06:WU01:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
03:22:34:WU01:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
03:24:01:WU01:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
03:25:17:WU02:FS01:0x18:Completed 3600000 out of 5000000 steps (72%)
03:25:28:WU01:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
03:26:56:WU01:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
03:26:57:WU00:FS00:Connecting to 171.67.108.200:8080
03:26:58:WU00:FS00:Assigned to work server 171.64.65.124
03:26:58:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 171.64.65.124
03:26:58:WU00:FS00:Connecting to 171.64.65.124:8080
03:27:00:WU00:FS00
ownloading 892.10KiB
03:27:01:WU00:FS00
ownload complete
03:27:01:WU00:FS00:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:9012 run:335 clone:4 gen:36 core:0xa4 unit:0x0000002d664f2de4548af8ad6175e387
03:28:23:WU01:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
ynamicWrapper: Finished Work Unit: sleep=10000
03:28:33:WU01:FS00:0xa4:
03:28:33:WU01:FS00:0xa4:Finished Work Unit:
03:28:33:WU01:FS00:0xa4:- Reading up to 909432 from "01/wudata_01.trr": Read 909432
03:28:33:WU01:FS00:0xa4:trr file hash check passed.
03:28:33:WU01:FS00:0xa4:- Reading up to 833652 from "01/wudata_01.xtc": Read 833652
03:28:33:WU01:FS00:0xa4:xtc file hash check passed.
03:28:33:WU01:FS00:0xa4:edr file hash check passed.
03:28:33:WU01:FS00:0xa4:logfile size: 24679
03:28:33:WU01:FS00:0xa4:Leaving Run
03:28:37:WU01:FS00:0xa4:- Writing 1770251 bytes of core data to disk...
one: 1769739 -> 1710670 (compressed to 96.6 percent)
03:28:37:WU01:FS00:0xa4: ... Done.
03:28:37:WU01:FS00:0xa4:- Shutting down core
03:28:37:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
03:28:37:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:28:37:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9010 run:496 clone:1 gen:52 core:0xa4 unit:0x00000049664f2de453c87272b42ea943
03:28:37:WU01:FS00:Uploading 1.63MiB to 171.64.65.124
03:28:37:WU01:FS00:Connecting to 171.64.65.124:8080
03:28:38:WU00:FS00:Starting
03:28:38:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
03:28:38:WU00:FS00:Started FahCore on PID 8176
03:28:38:WU00:FS00:Core PID:2704
03:28:38:WU00:FS00:FahCore 0xa4 started
03:28:38:WU00:FS00:0xa4:
03:28:38:WU00:FS00:0xa4:*------------------------------*
03:28:38:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
03:28:38:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:28:38:WU00:FS00:0xa4:- Looking at optimizations...
03:28:38:WU00:FS00:0xa4:- Created dyn
03:28:38:WU00:FS00:0xa4:- Files status OK
03:28:38:WU00:FS00:0xa4:- Expanded 912995 -> 1513440 (decompressed 165.7 percent)
03:28:38:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=912995 data_size=1513440, decompressed_data_size=1513440 diff=0
03:28:38:WU00:FS00:0xa4:- Digital signature verified
roject: 9012 (Run 335, Clone 4, Gen 36)
03:28:38:WU00:FS00:0xa4:Assembly optimizations on if available.
03:28:38:WU00:FS00:0xa4:Entering M.D.
03:28:43:WU01:FS00:Upload 91.92%
03:28:44:WU00:FS00:0xa4:Mapping NT from 7 to 7
03:28:44:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
03:28:47:WU01:FS00:Upload complete
03:28:47:WU01:FS00:Server responded WORK_ACK (400)
03:28:47:WU01:FS00:Final credit estimate, 735.00 points
03:28:47:WU01:FS00:Cleaning up
03:29:40:WU02:FS01:0x18:Completed 3650000 out of 5000000 steps (73%)
03:30:11:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
03:31:38:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
03:33:04:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
03:33:52:WU02:FS01:0x18:Completed 3700000 out of 5000000 steps (74%)
03:34:31:WU00:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
03:35:57:WU00:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
03:37:24:WU00:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
03:38:04:WU02:FS01:0x18:Completed 3750000 out of 5000000 steps (75%)
03:38:51:WU00:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
03:40:18:WU00:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
03:41:44:WU00:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
03:42:27:WU02:FS01:0x18:Completed 3800000 out of 5000000 steps (76%)
03:43:11:WU00:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
03:44:38:WU00:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
03:46:05:WU00:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
03:46:39:WU02:FS01:0x18:Completed 3850000 out of 5000000 steps (77%)
03:47:32:WU00:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
03:48:59:WU00:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
03:50:32:WU00:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
03:51:03:WU02:FS01:0x18:Completed 3900000 out of 5000000 steps (78%)
03:52:24:WU00:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
03:54:25:WU00:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
03:55:16:WU02:FS01:0x18:Completed 3950000 out of 5000000 steps (79%)
03:56:06:WU00:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
03:57:33:WU00:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
03:59:03:WU00:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
03:59:28:WU02:FS01:0x18:Completed 4000000 out of 5000000 steps (80%)
04:00:31:WU00:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
04:01:58:WU00:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
04:03:25:WU00:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
04:03:52:WU02:FS01:0x18:Completed 4050000 out of 5000000 steps (81%)
04:04:51:WU00:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
04:06:18:WU00:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
04:07:44:WU00:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
04:08:04:WU02:FS01:0x18:Completed 4100000 out of 5000000 steps (82%)
04:09:11:WU00:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
04:10:38:WU00:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
04:12:05:WU00:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
04:12:27:WU02:FS01:0x18:Completed 4150000 out of 5000000 steps (83%)
04:13:32:WU00:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
04:14:59:WU00:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
04:16:26:WU00:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
04:16:39:WU02:FS01:0x18:Completed 4200000 out of 5000000 steps (84%)
04:17:53:WU00:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
04:19:21:WU00:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
04:20:48:WU00:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
04:20:51:WU02:FS01:0x18:Completed 4250000 out of 5000000 steps (85%)
04:22:16:WU00:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
04:23:43:WU00:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
04:25:11:WU00:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
04:25:15:WU02:FS01:0x18:Completed 4300000 out of 5000000 steps (86%)
04:26:38:WU00:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
04:28:06:WU00:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
04:29:27:WU02:FS01:0x18:Completed 4350000 out of 5000000 steps (87%)
04:29:33:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
04:31:01:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
04:32:28:WU00:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
04:33:50:WU02:FS01:0x18:Completed 4400000 out of 5000000 steps (88%)
04:33:56:WU00:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
04:35:23:WU00:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
04:36:51:WU00:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
04:38:02:WU02:FS01:0x18:Completed 4450000 out of 5000000 steps (89%)
04:38:18:WU00:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
04:39:46:WU00:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
04:41:13:WU00:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
04:42:13:WU02:FS01:0x18:Completed 4500000 out of 5000000 steps (90%)
04:42:41:WU00:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
04:44:09:WU00:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
04:45:37:WU00:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
04:46:37:WU02:FS01:0x18:Completed 4550000 out of 5000000 steps (91%)
04:47:04:WU00:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
04:48:31:WU00:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
04:49:59:WU00:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
04:50:49:WU02:FS01:0x18:Completed 4600000 out of 5000000 steps (92%)
04:51:26:WU00:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
04:52:53:WU00:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
04:54:21:WU00:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
04:55:12:WU02:FS01:0x18:Completed 4650000 out of 5000000 steps (93%)
04:55:48:WU00:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
04:57:15:WU00:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
04:58:42:WU00:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
04:59:24:WU02:FS01:0x18:Completed 4700000 out of 5000000 steps (94%)
05:00:09:WU00:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
05:01:36:WU00:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
05:03:03:WU00:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
05:03:36:WU02:FS01:0x18:Completed 4750000 out of 5000000 steps (95%)
05:04:30:WU00:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
05:05:56:WU00:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
05:07:23:WU00:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
05:07:59:WU02:FS01:0x18:Completed 4800000 out of 5000000 steps (96%)
05:08:50:WU00:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
05:10:17:WU00:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
05:11:44:WU00:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
05:12:11:WU02:FS01:0x18:Completed 4850000 out of 5000000 steps (97%)
05:13:12:WU00:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
05:14:39:WU00:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
05:16:06:WU00:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
05:16:34:WU02:FS01:0x18:Completed 4900000 out of 5000000 steps (98%)
05:17:32:WU00:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
05:18:58:WU00:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
05:20:25:WU00:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
05:20:46:WU02:FS01:0x18:Completed 4950000 out of 5000000 steps (99%)
05:21:51:WU00:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
05:23:18:WU00:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
05:24:45:WU00:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
05:24:58:WU02:FS01:0x18:Completed 5000000 out of 5000000 steps (100%)
05:24:59:WU01:FS01:Connecting to 171.67.108.200:80
05:24:59:WU01:FS01:Assigned to work server 140.163.4.231
05:24:59:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GK110 [GeForce GTX 780 Ti] from 140.163.4.231
05:24:59:WU01:FS01:Connecting to 140.163.4.231:8080
05:25:01:WU01:FS01
ownloading 4.83MiB
05:25:03:WU01:FS01
ownload complete
05:25:03:WU01:FS01:Received Unit: id:01 state
OWNLOAD error:NO_ERROR project:13000 run:2103 clone:4 gen:88 core:0x17 unit:0x000000a5538b3db75311ee9e219ac1ee
05:25:09:WU02:FS01:0x18:Saving result file logfile_01.txt
05:25:10:WU02:FS01:0x18:Saving result file checkpointState.xml
05:25:11:WU02:FS01:0x18:Saving result file checkpt.crc
05:25:11:WU02:FS01:0x18:Saving result file log.txt
05:25:11:WU02:FS01:0x18:Saving result file positions.xtc
05:25:13:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:25:13:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:10477 run:0 clone:216 gen:10 core:0x18 unit:0x00000012538b3dba548b1ff9ea83d98d
05:25:13:WU02:FS01:Uploading 9.77MiB to 140.163.4.234
05:25:13:WU02:FS01:Connecting to 140.163.4.234:8080
05:25:14:WU01:FS01:Starting
05:25:14:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:25:14:WU01:FS01:Started FahCore on PID 2496
05:25:14:WU01:FS01:Core PID:7736
05:25:14:WU01:FS01:FahCore 0x17 started
05:25:15:WU01:FS01:0x17:*********************** Log Started 2015-02-07T05:25:14Z ***********************
roject: 13000 (Run 2103, Clone 4, Gen 88)
05:25:15:WU01:FS01:0x17:Unit: 0x000000a5538b3db75311ee9e219ac1ee
05:25:15:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
05:25:15:WU01:FS01:0x17:Machine: 1
05:25:15:WU01:FS01:0x17:Reading tar file state.xml
05:25:15:WU01:FS01:0x17:Reading tar file system.xml
05:25:16:WU01:FS01:0x17:Reading tar file integrator.xml
05:25:16:WU01:FS01:0x17:Reading tar file core.xml
05:25:16:WU01:FS01:0x17:Folding@home GPU core17
05:25:16:WU01:FS01:0x17:Version 0.0.52
05:25:19:WU02:FS01:Upload 26.88%
05:25:25:WU02:FS01:Upload 52.47%
05:25:31:WU02:FS01:Upload 86.39%
05:25:41:WU02:FS01:Upload complete
05:25:41:WU02:FS01:Server responded WORK_ACK (400)
05:25:41:WU02:FS01:Final credit estimate, 30558.00 points
05:25:41:WU02:FS01:Cleaning up
05:26:12:WU00:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
05:27:39:WU00:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
05:28:35:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
05:28:35:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:29:07:WU00:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
05:30:33:WU00:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
05:31:59:WU00:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
05:33:25:WU00:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
05:34:06:WU01:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
05:34:51:WU00:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
05:36:17:WU00:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
05:37:43:WU00:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
05:39:09:WU00:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
05:39:22:WU01:FS01:0x17:Completed 100000 out of 5000000 steps (2%)
05:40:36:WU00:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
05:42:03:WU00:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
05:43:29:WU00:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
05:44:55:WU00:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
05:44:57:WU01:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
05:46:22:WU00:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
05:47:48:WU00:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
05:49:15:WU00:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
05:50:14:WU01:FS01:0x17:Completed 200000 out of 5000000 steps (4%)
05:50:41:WU00:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
05:52:07:WU00:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
05:53:33:WU00:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
05:53:34:WU02:FS00:Connecting to 171.67.108.200:8080
05:53:35:WU02:FS00:Assigned to work server 171.64.65.124
05:53:35:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 171.64.65.124
05:53:35:WU02:FS00:Connecting to 171.64.65.124:8080
05:53:37:WU02:FS00
ownloading 897.52KiB
05:53:39:WU02:FS00
ownload complete
05:53:39:WU02:FS00:Received Unit: id:02 state
OWNLOAD error:NO_ERROR project:9010 run:718 clone:5 gen:40 core:0xa4 unit:0x00000034664f2de4548af2afe0732b23
05:54:59:WU00:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
05:55:09:WU00:FS00:0xa4:
05:55:09:WU00:FS00:0xa4:Finished Work Unit:
05:55:09:WU00:FS00:0xa4:- Reading up to 905376 from "00/wudata_01.trr": Read 905376
05:55:09:WU00:FS00:0xa4:trr file hash check passed.
05:55:09:WU00:FS00:0xa4:- Reading up to 829636 from "00/wudata_01.xtc": Read 829636
05:55:09:WU00:FS00:0xa4:xtc file hash check passed.
05:55:09:WU00:FS00:0xa4:edr file hash check passed.
05:55:09:WU00:FS00:0xa4:logfile size: 23764
05:55:09:WU00:FS00:0xa4:Leaving Run
05:55:14:WU00:FS00:0xa4:- Writing 1761264 bytes of core data to disk...
one: 1760752 -> 1703493 (compressed to 96.7 percent)
05:55:14:WU00:FS00:0xa4: ... Done.
05:55:14:WU00:FS00:0xa4:- Shutting down core
05:55:14:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
05:55:15:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:55:15:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9012 run:335 clone:4 gen:36 core:0xa4 unit:0x0000002d664f2de4548af8ad6175e387
05:55:15:WU00:FS00:Uploading 1.63MiB to 171.64.65.124
05:55:15:WU00:FS00:Connecting to 171.64.65.124:8080
05:55:15:WU02:FS00:Starting
05:55:15:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
05:55:15:WU02:FS00:Started FahCore on PID 7980
05:55:15:WU02:FS00:Core PID:7912
05:55:15:WU02:FS00:FahCore 0xa4 started
05:55:15:WU02:FS00:0xa4:
05:55:15:WU02:FS00:0xa4:*------------------------------*
05:55:15:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
05:55:15:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:55:15:WU02:FS00:0xa4:- Looking at optimizations...
05:55:15:WU02:FS00:0xa4:- Created dyn
05:55:15:WU02:FS00:0xa4:- Files status OK
05:55:15:WU02:FS00:0xa4:- Expanded 918547 -> 1523092 (decompressed 165.8 percent)
05:55:15:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=918547 data_size=1523092, decompressed_data_size=1523092 diff=0
05:55:15:WU02:FS00:0xa4:- Digital signature verified
roject: 9010 (Run 718, Clone 5, Gen 40)
05:55:15:WU02:FS00:0xa4:Assembly optimizations on if available.
05:55:15:WU02:FS00:0xa4:Entering M.D.
05:55:21:WU00:FS00:Upload 96.15%
05:55:21:WU02:FS00:0xa4:Mapping NT from 7 to 7
05:55:21:WU02:FS00:0xa4:Completed 0 out of 250000 steps (0%)
05:55:26:WU00:FS00:Upload complete
05:55:27:WU00:FS00:Server responded WORK_ACK (400)
05:55:27:WU00:FS00:Final credit estimate, 1832.00 points
05:55:27:WU00:FS00:Cleaning up
05:55:30:WU01:FS01:0x17:Completed 250000 out of 5000000 steps (5%)
05:56:52:WU02:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
05:58:18:WU02:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
05:59:44:WU02:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
06:01:05:WU01:FS01:0x17:Completed 300000 out of 5000000 steps (6%)
06:01:11:WU02:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
06:02:38:WU02:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
06:04:04:WU02:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
06:05:31:WU02:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
06:06:22:WU01:FS01:0x17:Completed 350000 out of 5000000 steps (7%)
06:06:57:WU02:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
06:08:24:WU02:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
06:09:50:WU02:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
06:11:17:WU02:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
06:11:57:WU01:FS01:0x17:Completed 400000 out of 5000000 steps (8%)
06:12:43:WU02:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
06:14:10:WU02:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
06:15:37:WU02:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
06:17:04:WU02:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
06:17:13:WU01:FS01:0x17:Completed 450000 out of 5000000 steps (9%)
06:18:30:WU02:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
06:19:57:WU02:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
06:21:24:WU02:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
06:22:29:WU01:FS01:0x17:Completed 500000 out of 5000000 steps (10%)
06:22:50:WU02:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
06:24:16:WU02:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
06:25:42:WU02:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
06:27:08:WU02:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
06:28:03:WU01:FS01:0x17:Completed 550000 out of 5000000 steps (11%)
06:28:35:WU02:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
06:30:02:WU02:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
06:31:29:WU02:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
06:32:55:WU02:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
06:33:19:WU01:FS01:0x17:Completed 600000 out of 5000000 steps (12%)
06:34:22:WU02:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
06:35:49:WU02:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
06:37:16:WU02:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
06:38:43:WU02:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
06:38:54:WU01:FS01:0x17:Completed 650000 out of 5000000 steps (13%)
06:40:09:WU02:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
06:41:36:WU02:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
06:43:02:WU02:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
06:44:10:WU01:FS01:0x17:Completed 700000 out of 5000000 steps (14%)
06:44:29:WU02:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
06:45:55:WU02:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
06:47:22:WU02:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
06:48:48:WU02:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
06:49:26:WU01:FS01:0x17:Completed 750000 out of 5000000 steps (15%)
06:50:15:WU02:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
06:51:42:WU02:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
06:53:08:WU02:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
06:54:35:WU02:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
06:55:02:WU01:FS01:0x17:Completed 800000 out of 5000000 steps (16%)
06:56:02:WU02:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
06:57:29:WU02:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
06:58:56:WU02:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
07:00:18:WU01:FS01:0x17:Completed 850000 out of 5000000 steps (17%)
07:00:23:WU02:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
07:01:50:WU02:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
07:03:17:WU02:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
07:04:44:WU02:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
07:05:53:WU01:FS01:0x17:Completed 900000 out of 5000000 steps (18%)
07:06:11:WU02:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
07:07:37:WU02:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
07:09:04:WU02:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
07:10:30:WU02:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
07:11:09:WU01:FS01:0x17:Completed 950000 out of 5000000 steps (19%)
07:11:56:WU02:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
07:13:23:WU02:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
07:14:49:WU02:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
07:16:15:WU02:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
07:16:24:WU01:FS01:0x17:Completed 1000000 out of 5000000 steps (20%)
07:17:43:WU02:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
07:19:09:WU02:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
07:20:36:WU02:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
07:21:59:WU01:FS01:0x17:Completed 1050000 out of 5000000 steps (21%)
07:22:03:WU02:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
07:23:29:WU02:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
07:24:56:WU02:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
07:26:22:WU02:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
07:27:14:WU01:FS01:0x17:Completed 1100000 out of 5000000 steps (22%)
07:27:49:WU02:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
07:29:15:WU02:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
07:30:42:WU02:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
07:32:08:WU02:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
07:32:49:WU01:FS01:0x17:Completed 1150000 out of 5000000 steps (23%)
07:33:35:WU02:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
07:35:02:WU02:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
07:36:29:WU02:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
07:37:55:WU02:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
07:38:05:WU01:FS01:0x17:Completed 1200000 out of 5000000 steps (24%)
******************************* Date: 2015-02-07 *******************************
07:39:22:WU02:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
07:40:52:WU02:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
07:42:18:WU02:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
07:43:22:WU01:FS01:0x17:Completed 1250000 out of 5000000 steps (25%)
07:43:46:WU02:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
07:45:13:WU02:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
07:46:40:WU02:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
07:48:06:WU02:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
07:48:58:WU01:FS01:0x17:Completed 1300000 out of 5000000 steps (26%)
07:49:33:WU02:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
07:50:59:WU02:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
07:52:26:WU02:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
07:53:51:WU02:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
07:54:14:WU01:FS01:0x17:Completed 1350000 out of 5000000 steps (27%)
07:55:17:WU02:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
07:56:43:WU02:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
07:58:13:WU02:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
07:59:39:WU02:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
07:59:49:WU01:FS01:0x17:Completed 1400000 out of 5000000 steps (28%)
08:01:06:WU02:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
08:02:32:WU02:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
08:03:59:WU02:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
08:05:05:WU01:FS01:0x17:Completed 1450000 out of 5000000 steps (29%)
08:05:26:WU02:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
08:06:53:WU02:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
08:08:20:WU02:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
08:09:46:WU02:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
08:10:21:WU01:FS01:0x17:Completed 1500000 out of 5000000 steps (30%)
08:11:13:WU02:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
08:12:40:WU02:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
08:14:07:WU02:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
08:15:34:WU02:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
08:15:55:WU01:FS01:0x17:Completed 1550000 out of 5000000 steps (31%)
08:17:01:WU02:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
08:18:28:WU02:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
08:18:29:WU00:FS00:Connecting to 171.67.108.200:8080
08:18:29:WU00:FS00:Assigned to work server 171.64.65.124
08:18:29:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 171.64.65.124
08:18:29:WU00:FS00:Connecting to 171.64.65.124:8080
08:18:31:WU00:FS00
ownloading 863.93KiB
08:18:32:WU00:FS00
ownload complete
08:18:33:WU00:FS00:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:9009 run:940 clone:3 gen:48 core:0xa4 unit:0x00000040664f2de453868b9781cd7db1
08:19:55:WU02:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
08:20:05:WU02:FS00:0xa4:
08:20:05:WU02:FS00:0xa4:Finished Work Unit:
08:20:05:WU02:FS00:0xa4:- Reading up to 909432 from "02/wudata_01.trr": Read 909432
08:20:05:WU02:FS00:0xa4:trr file hash check passed.
08:20:05:WU02:FS00:0xa4:- Reading up to 834052 from "02/wudata_01.xtc": Read 834052
08:20:05:WU02:FS00:0xa4:xtc file hash check passed.
08:20:05:WU02:FS00:0xa4:edr file hash check passed.
08:20:05:WU02:FS00:0xa4:logfile size: 23790
08:20:05:WU02:FS00:0xa4:Leaving Run
08:20:10:WU02:FS00:0xa4:- Writing 1769762 bytes of core data to disk...
one: 1769250 -> 1711276 (compressed to 96.7 percent)
08:20:10:WU02:FS00:0xa4: ... Done.
08:20:10:WU02:FS00:0xa4:- Shutting down core
08:20:10:WU02:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
08:20:10:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:20:10:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9010 run:718 clone:5 gen:40 core:0xa4 unit:0x00000034664f2de4548af2afe0732b23
08:20:10:WU02:FS00:Uploading 1.63MiB to 171.64.65.124
08:20:10:WU02:FS00:Connecting to 171.64.65.124:8080
08:20:10:WU00:FS00:Starting
08:20:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
08:20:10:WU00:FS00:Started FahCore on PID 3556
08:20:10:WU00:FS00:Core PID:2728
08:20:10:WU00:FS00:FahCore 0xa4 started
08:20:11:WU00:FS00:0xa4:
08:20:11:WU00:FS00:0xa4:*------------------------------*
08:20:11:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
08:20:11:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
08:20:11:WU00:FS00:0xa4:- Looking at optimizations...
08:20:11:WU00:FS00:0xa4:- Created dyn
08:20:11:WU00:FS00:0xa4:- Files status OK
08:20:11:WU00:FS00:0xa4:- Expanded 884153 -> 1476032 (decompressed 166.9 percent)
08:20:11:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=884153 data_size=1476032, decompressed_data_size=1476032 diff=0
08:20:11:WU00:FS00:0xa4:- Digital signature verified
roject: 9009 (Run 940, Clone 3, Gen 48)
08:20:11:WU00:FS00:0xa4:Assembly optimizations on if available.
08:20:11:WU00:FS00:0xa4:Entering M.D.
08:20:17:WU00:FS00:0xa4:Mapping NT from 7 to 7
08:20:17:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
08:20:17:WU02:FS00:Upload complete
08:20:17:WU02:FS00:Server responded WORK_ACK (400)
08:20:17:WU02:FS00:Final credit estimate, 1732.00 points
08:20:17:WU02:FS00:Cleaning up
08:21:11:WU01:FS01:0x17:Completed 1600000 out of 5000000 steps (32%)
08:21:42:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
08:23:08:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
08:24:33:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
08:25:58:WU00:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
08:26:45:WU01:FS01:0x17:Completed 1650000 out of 5000000 steps (33%)
08:27:24:WU00:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
08:28:49:WU00:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
08:30:15:WU00:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
08:31:40:WU00:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
08:32:02:WU01:FS01:0x17:Completed 1700000 out of 5000000 steps (34%)
08:33:06:WU00:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
08:34:32:WU00:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
08:35:58:WU00:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
08:37:19:WU01:FS01:0x17:Completed 1750000 out of 5000000 steps (35%)
08:37:24:WU00:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
08:38:49:WU00:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
08:40:16:WU00:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
08:41:43:WU00:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
08:42:54:WU01:FS01:0x17:Completed 1800000 out of 5000000 steps (36%)
08:43:09:WU00:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
08:44:34:WU00:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
08:46:00:WU00:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
08:47:25:WU00:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
08:48:10:WU01:FS01:0x17:Completed 1850000 out of 5000000 steps (37%)
08:48:51:WU00:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
08:50:16:WU00:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
08:51:42:WU00:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
08:53:08:WU00:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
08:53:45:WU01:FS01:0x17:Completed 1900000 out of 5000000 steps (38%)
08:54:33:WU00:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
08:55:59:WU00:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
08:57:24:WU00:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
08:58:50:WU00:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
08:59:00:WU01:FS01:0x17:Completed 1950000 out of 5000000 steps (39%)
09:00:16:WU00:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
09:01:41:WU00:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
09:03:06:WU00:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
09:04:16:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
09:04:32:WU00:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
09:05:57:WU00:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
09:07:22:WU00:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
09:08:47:WU00:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
09:09:51:WU01:FS01:0x17:Completed 2050000 out of 5000000 steps (41%)
09:10:13:WU00:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
09:11:39:WU00:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
09:13:04:WU00:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
09:14:30:WU00:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
09:15:06:WU01:FS01:0x17:Completed 2100000 out of 5000000 steps (42%)
09:15:55:WU00:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
09:17:20:WU00:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
09:18:45:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
09:20:10:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
09:20:41:WU01:FS01:0x17:Completed 2150000 out of 5000000 steps (43%)
09:21:36:WU00:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
09:23:01:WU00:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
09:24:26:WU00:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
09:25:51:WU00:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
09:25:58:WU01:FS01:0x17:Completed 2200000 out of 5000000 steps (44%)
09:27:16:WU00:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
09:28:40:WU00:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
09:30:05:WU00:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
09:31:14:WU01:FS01:0x17:Completed 2250000 out of 5000000 steps (45%)
09:31:30:WU00:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
09:32:55:WU00:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
09:34:20:WU00:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
09:35:45:WU00:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
09:36:49:WU01:FS01:0x17:Completed 2300000 out of 5000000 steps (46%)
09:37:10:WU00:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
09:38:36:WU00:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
09:40:02:WU00:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
09:41:27:WU00:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
09:42:06:WU01:FS01:0x17:Completed 2350000 out of 5000000 steps (47%)
09:42:53:WU00:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
09:44:17:WU00:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
09:45:43:WU00:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
09:47:07:WU00:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
09:47:41:WU01:FS01:0x17:Completed 2400000 out of 5000000 steps (48%)
09:48:32:WU00:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
09:49:57:WU00:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
09:51:22:WU00:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
09:52:47:WU00:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
09:52:57:WU01:FS01:0x17:Completed 2450000 out of 5000000 steps (49%)
09:54:12:WU00:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
09:55:37:WU00:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
09:57:01:WU00:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
09:58:13:WU01:FS01:0x17:Completed 2500000 out of 5000000 steps (50%)
09:58:30:WU00:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
09:59:55:WU00:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
10:01:20:WU00:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
10:02:45:WU00:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
10:03:48:WU01:FS01:0x17:Completed 2550000 out of 5000000 steps (51%)
10:04:10:WU00:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
10:05:35:WU00:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
10:07:00:WU00:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
10:08:24:WU00:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
10:09:03:WU01:FS01:0x17:Completed 2600000 out of 5000000 steps (52%)
10:09:50:WU00:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
10:11:15:WU00:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
10:12:40:WU00:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
10:14:05:WU00:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
10:14:38:WU01:FS01:0x17:Completed 2650000 out of 5000000 steps (53%)
10:15:30:WU00:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
10:16:55:WU00:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
10:18:20:WU00:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
10:19:45:WU00:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
10:19:54:WU01:FS01:0x17:Completed 2700000 out of 5000000 steps (54%)
10:21:10:WU00:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
10:22:36:WU00:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
10:24:01:WU00:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
10:25:11:WU01:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
10:25:26:WU00:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
10:26:51:WU00:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
10:28:16:WU00:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
10:29:41:WU00:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
10:31:06:WU00:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
10:32:32:WU00:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
10:33:57:WU00:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
10:35:23:WU00:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
10:36:48:WU00:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
10:38:14:WU00:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
10:39:39:WU00:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
10:41:04:WU00:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
10:41:05:WU02:FS00:Connecting to 171.67.108.200:8080
10:41:08:WU02:FS00:Assigned to work server 171.64.65.124
10:41:08:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 171.64.65.124
10:41:08:WU02:FS00:Connecting to 171.64.65.124:8080
10:41:10:WU02:FS00
ownloading 891.48KiB
10:41:11:WU02:FS00
ownload complete
10:41:12:WU02:FS00:Received Unit: id:02 state
OWNLOAD error:NO_ERROR project:9012 run:937 clone:5 gen:32 core:0xa4 unit:0x00000029664f2de4548afac8660cbaa9
10:42:29:WU00:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
10:42:39:WU00:FS00:0xa4:
10:42:39:WU00:FS00:0xa4:Finished Work Unit:
10:42:39:WU00:FS00:0xa4:- Reading up to 872880 from "00/wudata_01.trr": Read 872880
10:42:39:WU00:FS00:0xa4:trr file hash check passed.
10:42:39:WU00:FS00:0xa4:- Reading up to 800944 from "00/wudata_01.xtc": Read 800944
10:42:39:WU00:FS00:0xa4:xtc file hash check passed.
10:42:39:WU00:FS00:0xa4:edr file hash check passed.
10:42:39:WU00:FS00:0xa4:logfile size: 23943
10:42:39:WU00:FS00:0xa4:Leaving Run
10:42:39:WU00:FS00:0xa4:- Writing 1700255 bytes of core data to disk...
10:42:40:WU00:FS00:0xa4
one: 1699743 -> 1647630 (compressed to 96.9 percent)
10:42:40:WU00:FS00:0xa4: ... Done.
10:42:40:WU00:FS00:0xa4:- Shutting down core
10:42:40:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
10:42:40:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:42:40:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9009 run:940 clone:3 gen:48 core:0xa4 unit:0x00000040664f2de453868b9781cd7db1
10:42:40:WU00:FS00:Uploading 1.57MiB to 171.64.65.124
10:42:40:WU00:FS00:Connecting to 171.64.65.124:8080
10:42:40:WU02:FS00:Starting
10:42:40:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
10:42:40:WU02:FS00:Started FahCore on PID 7316
10:42:40:WU02:FS00:Core PID:6952
10:42:40:WU02:FS00:FahCore 0xa4 started
10:42:41:WU02:FS00:0xa4:
10:42:41:WU02:FS00:0xa4:*------------------------------*
10:42:41:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
10:42:41:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:42:41:WU02:FS00:0xa4:- Looking at optimizations...
10:42:41:WU02:FS00:0xa4:- Created dyn
10:42:41:WU02:FS00:0xa4:- Files status OK
10:42:41:WU02:FS00:0xa4:- Expanded 912364 -> 1513440 (decompressed 165.8 percent)
10:42:41:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=912364 data_size=1513440, decompressed_data_size=1513440 diff=0
10:42:41:WU02:FS00:0xa4:- Digital signature verified
roject: 9012 (Run 937, Clone 5, Gen 32)
10:42:41:WU02:FS00:0xa4:Assembly optimizations on if available.
10:42:41:WU02:FS00:0xa4:Entering M.D.
10:42:47:WU02:FS00:0xa4:Mapping NT from 7 to 7
10:42:47:WU00:FS00:Upload complete
10:42:47:WU00:FS00:Server responded WORK_ACK (400)
10:42:47:WU00:FS00:Final credit estimate, 1701.00 points
10:42:47:WU00:FS00:Cleaning up
10:42:47:WU02:FS00:0xa4:Completed 0 out of 250000 steps (0%)
10:44:16:WU02:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
10:45:46:WU02:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
10:47:14:WU02:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
10:48:43:WU02:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
10:50:11:WU02:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
10:51:39:WU02:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
10:53:08:WU02:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
10:54:36:WU02:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
10:56:06:WU02:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
10:57:34:WU02:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
10:59:03:WU02:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
11:00:33:WU02:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
11:02:01:WU02:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
11:03:29:WU02:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
11:04:58:WU02:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
11:06:27:WU02:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
11:07:55:WU02:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
11:09:23:WU02:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
11:10:51:WU02:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
11:12:17:50:127.0.0.1:New Web connection
11:12:20:WU02:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
11:13:50:WU02:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
11:15:19:WU02:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
11:16:47:WU02:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
11:18:16:WU02:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
11:19:43:WU02:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
11:21:12:WU02:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
11:22:39:WU02:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
11:24:08:WU02:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
11:25:36:WU02:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
11:27:04:WU02:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
11:28:32:WU02:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
11:29:58:WU02:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
11:31:26:WU02:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
11:32:53:WU02:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
11:33:29:WU01:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
11:34:21:WU02:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
11:35:48:WU02:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
11:37:15:WU02:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
11:38:43:WU02:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
11:40:11:WU02:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
11:41:38:WU02:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
11:43:07:WU02:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
11:44:34:WU02:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
11:46:02:WU02:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
11:47:29:WU02:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
11:48:57:WU02:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
11:50:25:WU02:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
11:51:53:WU02:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
11:53:21:WU02:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
11:54:49:WU02:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
11:56:16:WU02:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
11:57:44:WU02:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
11:59:14:WU02:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
12:00:43:WU02:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
12:02:11:WU02:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
12:03:38:WU02:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
12:05:05:WU02:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
12:06:33:WU02:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
12:08:00:WU02:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
12:09:27:WU02:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
12:10:55:WU02:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
12:12:21:WU02:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
12:13:49:WU02:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
12:15:16:WU02:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
12:16:43:WU02:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
12:18:11:WU02:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
12:19:39:WU02:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
12:21:06:WU02:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
12:22:34:WU02:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
12:24:01:WU02:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
12:25:29:WU02:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
12:26:57:WU02:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
12:28:26:WU02:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
12:29:55:WU02:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
12:31:24:WU02:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
12:32:52:WU02:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
12:34:20:WU02:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
12:35:48:WU02:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
12:37:17:WU02:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
12:38:46:WU02:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
12:40:15:WU02:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
12:41:44:WU02:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
12:43:13:WU02:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
12:44:41:WU02:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
12:46:11:WU02:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
12:47:40:WU02:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
12:49:08:WU02:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
12:50:36:WU02:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
12:52:05:WU02:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
12:53:33:WU02:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
12:55:02:WU02:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
12:56:30:WU02:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
12:57:59:WU02:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
12:59:27:WU02:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
13:00:56:WU02:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
13:02:32:WU02:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
13:04:08:WU02:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
13:05:40:WU02:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
13:07:08:WU02:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
13:08:36:WU02:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
13:08:38:WU00:FS00:Connecting to 171.67.108.200:8080
13:08:39:WU00:FS00:Assigned to work server 171.64.65.124
13:08:39:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 171.64.65.124
13:08:39:WU00:FS00:Connecting to 171.64.65.124:8080
13:08:41:WU00:FS00
ownloading 902.64KiB
13:08:43:WU00:FS00
ownload complete
13:08:43:WU00:FS00:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:9011 run:630 clone:0 gen:160 core:0xa4 unit:0x000000bf664f2de453c879e215f60355
13:10:04:WU02:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
13:10:14:WU02:FS00:0xa4:
13:10:14:WU02:FS00:0xa4:Finished Work Unit:
13:10:14:WU02:FS00:0xa4:- Reading up to 905376 from "02/wudata_01.trr": Read 905376
13:10:14:WU02:FS00:0xa4:trr file hash check passed.
13:10:14:WU02:FS00:0xa4:- Reading up to 829512 from "02/wudata_01.xtc": Read 829512
13:10:14:WU02:FS00:0xa4:xtc file hash check passed.
13:10:14:WU02:FS00:0xa4:edr file hash check passed.
13:10:14:WU02:FS00:0xa4:logfile size: 23771
13:10:14:WU02:FS00:0xa4:Leaving Run
13:10:15:WU02:FS00:0xa4:- Writing 1761147 bytes of core data to disk...
one: 1760635 -> 1702971 (compressed to 96.7 percent)
13:10:15:WU02:FS00:0xa4: ... Done.
13:10:15:WU02:FS00:0xa4:- Shutting down core
13:10:15:WU02:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
13:10:15:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:10:15:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9012 run:937 clone:5 gen:32 core:0xa4 unit:0x00000029664f2de4548afac8660cbaa9
13:10:15:WU02:FS00:Uploading 1.62MiB to 171.64.65.124
13:10:15:WU02:FS00:Connecting to 171.64.65.124:8080
13:10:15:WU00:FS00:Starting
13:10:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
13:10:15:WU00:FS00:Started FahCore on PID 6536
13:10:15:WU00:FS00:Core PID:3412
13:10:15:WU00:FS00:FahCore 0xa4 started
13:10:16:WU00:FS00:0xa4:
13:10:16:WU00:FS00:0xa4:*------------------------------*
13:10:16:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
13:10:16:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
13:10:16:WU00:FS00:0xa4:- Looking at optimizations...
13:10:16:WU00:FS00:0xa4:- Created dyn
13:10:16:WU00:FS00:0xa4:- Files status OK
13:10:16:WU00:FS00:0xa4:- Expanded 923789 -> 1527780 (decompressed 165.3 percent)
13:10:16:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=923789 data_size=1527780, decompressed_data_size=1527780 diff=0
13:10:16:WU00:FS00:0xa4:- Digital signature verified
roject: 9011 (Run 630, Clone 0, Gen 160)
13:10:16:WU00:FS00:0xa4:Assembly optimizations on if available.
13:10:16:WU00:FS00:0xa4:Entering M.D.
13:10:22:WU00:FS00:0xa4:Mapping NT from 7 to 7
13:10:22:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
13:10:22:WU02:FS00:Upload complete
13:10:22:WU02:FS00:Server responded WORK_ACK (400)
13:10:22:WU02:FS00:Final credit estimate, 1827.00 points
13:10:22:WU02:FS00:Cleaning up
13:11:51:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
13:13:22:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
13:14:51:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
13:16:22:WU00:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
13:17:52:WU00:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
13:18:04:WU01:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
13:19:23:WU00:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
13:20:52:WU00:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
13:22:21:WU00:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
13:23:50:WU00:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
13:25:19:WU00:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
13:26:05:80:127.0.0.1:New Web connection
13:26:49:WU00:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
13:28:17:WU00:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
13:29:46:WU00:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
13:31:14:WU00:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
13:32:43:WU00:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
13:34:12:WU00:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
13:35:41:WU00:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
13:37:10:WU00:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
13:38:40:WU00:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
13:40:10:WU00:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
13:41:39:WU00:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
13:43:08:WU00:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
13:44:38:WU00:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
13:46:07:WU00:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
13:47:36:WU00:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
13:49:05:WU00:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
13:50:33:WU00:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
13:52:03:WU00:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
13:53:33:WU00:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
13:55:03:WU00:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
13:56:32:WU00:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
13:58:01:WU00:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
13:59:30:WU00:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
14:01:31:WU00:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
14:03:24:WU00:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
14:05:08:WU00:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
14:06:43:WU00:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
14:08:16:WU00:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
14:09:49:WU00:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
14:10:23:WU01:FS01:0x17:Bad State detected... attempting to resume from last good checkpoint
14:11:20:WU00:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
14:12:51:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
14:14:22:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
14:15:41:WU01:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
14:15:56:WU00:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
14:17:28:WU00:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
14:19:04:WU00:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
14:20:37:WU00:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
14:20:59:WU01:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
14:22:08:WU00:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
14:23:40:WU00:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
14:25:13:WU00:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
14:26:38:WU01:FS01:0x17:Completed 2900000 out of 5000000 steps (58%)
14:26:44:WU00:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
14:28:16:WU00:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
14:29:48:WU00:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
14:31:20:WU00:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
14:31:57:WU01:FS01:0x17:Completed 2950000 out of 5000000 steps (59%)
14:32:51:WU00:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
14:34:23:WU00:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
14:35:56:WU00:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
14:37:17:WU01:FS01:0x17:Completed 3000000 out of 5000000 steps (60%)
14:37:26:WU00:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
14:38:57:WU00:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
14:40:26:WU00:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
14:41:57:WU00:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
14:42:52:WU01:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
14:43:28:WU00:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
14:44:58:WU00:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
14:46:29:WU00:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
14:47:53:FS00:Shutting core down
14:48:00:WU00:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
14:48:01:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:48:02:WU00:FS00:Starting
14:48:02:WARNING:WU00:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
14:48:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 6
14:48:02:WU00:FS00:Started FahCore on PID 6532
14:48:02:WU00:FS00:Core PID:7624
14:48:02:WU00:FS00:FahCore 0xa4 started
14:48:02:WU00:FS00:0xa4:
14:48:02:WU00:FS00:0xa4:*------------------------------*
14:48:02:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
14:48:02:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
reparing to commence simulation
14:48:02:WU00:FS00:0xa4:- Looking at optimizations...
14:48:02:WU00:FS00:0xa4:- Files status OK
14:48:02:WU00:FS00:0xa4:- Expanded 923789 -> 1527780 (decompressed 165.3 percent)
14:48:02:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=923789 data_size=1527780, decompressed_data_size=1527780 diff=0
14:48:02:WU00:FS00:0xa4:- Digital signature verified
14:48:02:WU00:FS00:0xa4:Assembly optimizations on if available.
14:48:02:WU00:FS00:0xa4:Entering M.D.
14:48:07:Removing old file 'configs/config-20150204-212317.xml'
14:48:07:Saving configuration to config.xml
14:48:07:<config>
14:48:07: <!-- User Information -->
14:48:07: <passkey v='********************************'/>
14:48:07: <team v='70335'/>
14:48:07: <user v='Knussperkopp'/>
14:48:07:
14:48:07: <!-- Folding Slots -->
14:48:07: <slot id='0' type='CPU'/>
14:48:07: <slot id='1' type='GPU'/>
14:48:07:</config>
14:48:08:WU00:FS00:0xa4:Using Gromacs checkpoints
14:48:08:WU00:FS00:0xa4:Mapping NT from 6 to 6
14:48:08:WU00:FS00:0xa4:Resuming from checkpoint
14:48:08:WU00:FS00:0xa4:Verified 00/wudata_01.log
14:48:08:WU00:FS00:0xa4:Verified 00/wudata_01.trr
14:48:08:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
14:48:08:WU00:FS00:0xa4:Verified 00/wudata_01.edr
14:48:08:WU00:FS00:0xa4:Completed 147375 out of 250000 steps (58%)
14:48:09:WU01:FS01:0x17:Completed 3100000 out of 5000000 steps (62%)
14:48:13:WU00:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
14:48:28:FS00
aused
14:48:28:FS01
aused
14:48:29:FS00:Shutting core down
14:48:29:FS01:Shutting core down
14:48:29:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 7736
14:48:29:WU01:FS01:0x17:Exiting, please wait. . .
14:48:29:WU01:FS01:0x17:Lost lifeline PID 2496, exiting
14:48:29:WU01:FS01:0x17:ERROR:103: Lost client lifeline
14:48:29:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
14:48:29:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
14:48:32:WU00:FS00:0xa4:Client no longer detected. Shutting down core
14:48:32:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
14:48:32:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:49:08:Removing old file 'configs/config-20150204-224336.xml'
14:49:08:Saving configuration to config.xml
14:49:08:<config>
14:49:08: <!-- User Information -->
14:49:08: <passkey v='********************************'/>
14:49:08: <team v='70335'/>
14:49:08: <user v='Knussperkopp'/>
14:49:08:
14:49:08: <!-- Folding Slots -->
14:49:08: <slot id='0' type='CPU'>
14:49:08: <paused v='true'/>
14:49:08: </slot>
14:49:08: <slot id='1' type='GPU'>
14:49:08: </slot>
14:49:08:</config>
14:49:58:FS00:Unpaused
14:49:58:FS01:Unpaused
14:49:58:WU01:FS01:Starting
14:49:58:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
14:49:58:WU01:FS01:Started FahCore on PID 7440
14:49:58:WU01:FS01:Core PID:5640
14:49:58:WU01:FS01:FahCore 0x17 started
14:49:58:WU00:FS00:Starting
14:49:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 6
14:49:58:WU00:FS00:Started FahCore on PID 2500
14:49:58:WU00:FS00:Core PID:2780
14:49:58:WU00:FS00:FahCore 0xa4 started
14:49:59:WU01:FS01:0x17:*********************** Log Started 2015-02-07T14:49:58Z ***********************
14:49:59:WU01:FS01:0x17:Unit: 0x000000a5538b3db75311ee9e219ac1ee
14:49:59:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
14:49:59:WU01:FS01:0x17:Machine: 1
igital signatures verified
14:49:59:WU01:FS01:0x17:Folding@home GPU core17
14:49:59:WU01:FS01:0x17:Version 0.0.52
14:49:59:WU01:FS01:0x17: Found a checkpoint file
14:49:59:WU00:FS00:0xa4:
14:49:59:WU00:FS00:0xa4:*------------------------------*
14:49:59:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
14:49:59:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:49:59:WU00:FS00:0xa4:- Looking at optimizations...
14:49:59:WU00:FS00:0xa4:- Files status OK
14:49:59:WU00:FS00:0xa4:- Expanded 923789 -> 1527780 (decompressed 165.3 percent)
14:49:59:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=923789 data_size=1527780, decompressed_data_size=1527780 diff=0
14:49:59:WU00:FS00:0xa4:- Digital signature verified
14:49:59:WU00:FS00:0xa4:Assembly optimizations on if available.
14:49:59:WU00:FS00:0xa4:Entering M.D.
14:50:04:WU00:FS00:0xa4:Using Gromacs checkpoints
14:50:04:WU00:FS00:0xa4:Mapping NT from 6 to 6
14:50:05:WU00:FS00:0xa4:Resuming from checkpoint
14:50:05:WU00:FS00:0xa4:Verified 00/wudata_01.log
14:50:05:WU00:FS00:0xa4:Verified 00/wudata_01.trr
14:50:05:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
14:50:05:WU00:FS00:0xa4:Verified 00/wudata_01.edr
14:50:05:WU00:FS00:0xa4:Completed 147375 out of 250000 steps (58%)
14:50:09:Removing old file 'configs/config-20150204-232618.xml'
14:50:09:Saving configuration to config.xml
14:50:09:<config>
14:50:09: <!-- User Information -->
14:50:09: <passkey v='********************************'/>
14:50:09: <team v='70335'/>
14:50:09: <user v='Knussperkopp'/>
14:50:09:
14:50:09: <!-- Folding Slots -->
14:50:09: <slot id='0' type='CPU'/>
14:50:09: <slot id='1' type='GPU'/>
14:50:09:</config>
14:50:09:WU00:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
14:51:37:WU00:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
14:52:01:FS00:Shutting core down
14:52:08:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:52:09:WU00:FS00:Starting
14:52:09:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
14:52:09:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
14:52:09:WU00:FS00:Started FahCore on PID 5252
14:52:09:WU00:FS00:Core PID:6596
14:52:09:WU00:FS00:FahCore 0xa4 started
14:52:09:WU00:FS00:0xa4:
14:52:09:WU00:FS00:0xa4:*------------------------------*
14:52:09:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
14:52:09:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:52:09:WU00:FS00:0xa4:- Looking at optimizations...
14:52:09:WU00:FS00:0xa4:- Files status OK
14:52:09:WU00:FS00:0xa4:- Expanded 923789 -> 1527780 (decompressed 165.3 percent)
14:52:09:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=923789 data_size=1527780, decompressed_data_size=1527780 diff=0
14:52:09:WU00:FS00:0xa4:- Digital signature verified
14:52:09:WU00:FS00:0xa4:Assembly optimizations on if available.
14:52:09:WU00:FS00:0xa4:Entering M.D.
14:52:11:Removing old file 'configs/config-20150205-001203.xml'
14:52:11:Saving configuration to config.xml
14:52:11:<config>
14:52:11: <!-- Slot Control -->
14:52:11: <power v='full'/>
14:52:11:
14:52:11: <!-- User Information -->
14:52:11: <passkey v='********************************'/>
14:52:11: <team v='70335'/>
14:52:11: <user v='Knussperkopp'/>
14:52:11:
14:52:11: <!-- Folding Slots -->
14:52:11: <slot id='0' type='CPU'/>
14:52:11: <slot id='1' type='GPU'/>
14:52:11:</config>
14:52:15:WU00:FS00:0xa4:Using Gromacs checkpoints
14:52:15:WU00:FS00:0xa4:Mapping NT from 7 to 7
14:52:15:WU00:FS00:0xa4:Resuming from checkpoint
14:52:15:WU00:FS00:0xa4:Verified 00/wudata_01.log
14:52:15:WU00:FS00:0xa4:Verified 00/wudata_01.trr
14:52:15:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
14:52:15:WU00:FS00:0xa4:Verified 00/wudata_01.edr
14:52:15:WU00:FS00:0xa4:Completed 147375 out of 250000 steps (58%)
14:52:20:WU00:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
14:53:00:FS00
aused
14:53:00:FS01
aused
14:53:00:FS00:Shutting core down
14:53:00:FS01:Shutting core down
14:53:00:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 5640
14:53:00:WU01:FS01:0x17:Exiting, please wait. . .
14:53:03:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
14:53:09:Removing old file 'configs/config-20150205-163510.xml'
14:53:09:Saving configuration to config.xml
14:53:09:<config>
14:53:09: <!-- Slot Control -->
14:53:09: <power v='full'/>
14:53:09:
14:53:09: <!-- User Information -->
14:53:09: <passkey v='********************************'/>
14:53:09: <team v='70335'/>
14:53:09: <user v='Knussperkopp'/>
14:53:09:
14:53:09: <!-- Folding Slots -->
14:53:09: <slot id='0' type='CPU'>
14:53:09: <paused v='true'/>
14:53:09: </slot>
14:53:09: <slot id='1' type='GPU'>
14:53:09: </slot>
14:53:09:</config>
