/ Choose effects /
// Set to 1 for ON or 0 for OFF
#define USE_SMAA_ANTIALIASING 1 //[0 or 1] SMAA Anti-aliasing : Smoothens jagged lines using the SMAA technique.
#define USE_FXAA_ANTIALIASING 0 //[0 or 1] FXAA Anti-aliasing : Smoothens jagged lines using the FXAA technique. WIP - Currently only works in DX9 and you need to use the FXAA injector dlls.
#define USE_LUMASHARPEN 1//[0 or 1] LumaSharpen : Also sharpens the antialiased edges which makes them less smooth - I'm working on fixing that.
#define USE_BLOOM 1 //[0 or 1] Bloom : Makes bright lights bleed their light into their surroundings (relatively high performance cost)
#define USE_HDR 0 //[0 or 1] HDR : Not actual HDR - It just tries to mimic an HDR look (relatively high performance cost)
#define USE_TECHNICOLOR 1 //[0 or 1] TECHNICOLOR : Attempts to mimic the look of an old movie using the Technicolor three-strip color process (Techicolor Process 4)
#define USE_DPX 1 //[0 or 1] Cineon DPX : Should make the image look like it's been converted to DXP Cineon - basically it's another movie-like look similar to technicolor.
#define USE_LIFTGAMMAGAIN 0 //[0 or 1] Lift Gamma Gain : Adjust brightness and color of shadows, midtones and highlights (avoids clipping)
#define USE_TONEMAP 1 //[0 or 1] Tonemap : Adjust gamma, exposure, saturation, bleach and defog. (may cause clipping)
#define USE_VIBRANCE 1 //[0 or 1] Vibrance : Intelligently saturates (or desaturates if you use negative values) the pixels depending on their original saturation.
#define USE_CURVES 0 //[0 or 1] Curves : Contrast adjustments using S-curves.
#define USE_CARTOON 1 //[0 or 1] Cartoon : "Toon"s the image
#define USE_SEPIA 0 //[0 or 1] Sepia : Sepia tones the image.
#define USE_VIGNETTE 1 //[0 or 1] Vignette : Darkens the edges of the image to make it look more like it was shot with a camera lens. May cause banding artifacts.
#define USE_CA 1 //[0 or 1] Chromatic aberration
#define USE_DITHER 1 //[0 or 1] Dither : Applies dithering to simulate more colors than your monitor can display. This lessens banding artifacts (mostly caused by Vignette)
#define USE_BORDER 1 //[0 or 1] Border : Makes the screenedge black as a workaround for the bright edge that forcing some AA modes sometimes causes.
#define USE_SPLITSCREEN 0 //[0 or 1] Splitscreen : Enables the before-and-after splitscreen comparison mode.
/ SMAA Anti-aliasing settings /
#define SMAA_THRESHOLD 0.05 // [0.01 to 0.20] Edge detection threshold
#define SMAA_MAX_SEARCH_STEPS 98 // [0 to 98] Determines the radius SMAA will search for aliased edges
#define SMAA_MAX_SEARCH_STEPS_DIAG 16 // [0 to 20] Determines the radius SMAA will search for diagonal aliased edges
#define SMAA_CORNER_ROUNDING 0 //25 // [0 to 100] Determines the percent of antialiasing to apply to corners
// -- Advanced SMAA settings --
#define COLOR_EDGE_DETECTION 1 //[0 or 1] 1 Enables color edge detection (slower but more acurate) - 0 uses luma edge detection (faster)
#define SMAA_DIRECTX9_LINEAR_BLEND 0 //[0 or 1] Using DX9 HARDWARE? (software version doesn't matter) if so this needs to be 1 - If not, leave it at 0.
/ FXAA Anti-aliasing settings /
#define FXAA_QUALITY__PRESET 9 //[1 to 9] Choose the quality preset
#define fxaa_Subpix 0.400 //[0.000 to 1.000] Choose the amount of sub-pixel aliasing removal
#define fxaa_EdgeThreshold 0.250 //[0.000 to 1.000] The minimum amount of local contrast required to apply algorithm
#define fxaa_EdgeThresholdMin 0.060 //[0.000 to 1.000] Trims the algorithm from processing darks
/ LumaSharpen settings /
// -- Sharpening --
#define sharp_strength 1.00 //[0.10 to 3.00] Strength of the sharpening
#define sharp_clamp 0.100 //[0.000 to 1.000] Limits maximum amount of sharpening a pixel recieves - Default is 0.035
// -- Advanced sharpening settings --
#define pattern 2 //[1|2|3|4] Choose a sample pattern. 1 = Fast, 2 = Normal, 3 = Wider, 4 = Pyramid shaped.
#define offset_bias 0.8 //[0.0 to 6.0] Offset bias adjusts the radius of the sampling pattern.
//I designed the pattern for offset_bias 1.0, but feel free to experiment.
// -- Debug sharpening settings --
#define show_sharpen 0 //[0 or 1] Visualize the strength of the sharpen (multiplied by 4 to see it better)
/ Bloom settings /
#define BloomThreshold 20.00 //[0.00 to 50.00] Threshold for what is a bright light (that causes bloom) and what isn't.
#define BloomPower 0.690 //[0.000 to 8.000] Strength of the bloom
#define BloomWidth 0.0690 //[0.0000 to 1.0000] Width of the bloom
/ HDR settings /
#define HDRPower 0.80 //[0.00 to 8.00] Strangely lowering this makes the image brighter
#define radius2 0.50 //[0.00 to 8.00] Raising this seems to make the effect stronger and also brighter
/ TECHNICOLOR settings /
#define TechniAmount 0.05 //[0.0 to 1.0]
#define TechniPower 3.8 //[0.0 to 8.0]
#define redNegativeAmount 0.50 //[0.0 to 1.0]
#define greenNegativeAmount 0.55 //[0.0 to 1.0]
#define blueNegativeAmount 0.60 //[0.0 to 1.0]
/ Cineon DPX settings /
#define Red 15.0 //[1.0 to 15.0]
#define Green 15.0 //[1.0 to 15.0]
#define Blue 15.0 //[1.0 to 15.0]
#define ColorGamma 1.0 //[0.1 to 2.5] Adjusts the colorfulness of the effect in a manner similar to Vibrance. 1.0 is neutral.
#define DPXSaturation 1.0 //[0.0 to 8.0] Adjust saturation of the effect. 1.0 is neutral.
#define RedC 0.36 //[0.60 to 0.20]
#define GreenC 0.36 //[0.60 to 0.20]
#define BlueC 0.34 //[0.60 to 0.20]
#define Blend 0.11 //[0.00 to 1.00] How strong the effect should be.
/ Lift Gamma Gain settings /
#define RGB_Lift float3(0.980, 0.980, 0.980) //[0.000 to 2.000] Adjust shadows for Red, Green and Blue
#define RGB_Gamma float3(0.990, 0.990, 0.990) //[0.000 to 2.000] Adjust midtones for Red, Green and Blue
#define RGB_Gain float3(1.060, 1.060, 1.060) //[0.000 to 2.000] Adjust highlights for Red, Green and Blue
/ Tonemap settings /
#define Gamma 1.1 //[0.000 to 2.000] Adjust midtones
#define Exposure 0.00 //[-1.000 to 1.000] Adjust exposure
#define Saturation 0.00 //[-1.000 to 1.000] Adjust saturation
#define Bleach 0.00 //[0.000 to 1.000] Brightens the shadows and fades the colors
#define Defog 0.010 //[0.000 to 1.000] How much of the color tint to remove
#define FogColor float3(0.00, 0.00, 2.55) //[0.00 to 2.55, 0.00 to 2.55, 0.00 to 2.55] What color to remove - default is blue
/ Vibrance settings /
#define Vibrance 0.45 //[-1.00 to 1.00] Intelligently saturates (or desaturates if you use negative values) the pixels depending on their original saturation.
/ Curves settings /
#define Curves_contrast 0.20 //[-1.00 to 1.00] The amount of contrast you want
// -- Advanced curve settings --
#define Curves_formula 2 //[1|2|3|4|5|6|7] The constrast s-curve you want to use. I prefer 2 myself.
/ Cartoon settings /
#define Cartoonpower 2.5 // [0.1 to 10.0 ] The amount of effect
/ Sepia settings /
#define ColorTone float3(1.40, 1.10, 0.90) //[0.00 to 1.00, 0.00 to 1.00, 0.00 to 1.00] What color to tint the image
#define GreyPower 0.11 //[0.0 to 1.0] How much desaturate the image before tinting it
#define SepiaPower 0.58 //[0.0 to 1.0] How much to tint the image
/ Vignette settings /
#define VignetteRadius 1.00 //[-1.00 to 3.00] lower values = stronger radial effect from center
#define VignetteAmount -1.00 //[-2.00 to 1.00] Strength of black. -2.00 = Max Black, 1.00 = Max White.
#define VignetteSlope 8 //[1 to 16] How far away from the center the change should start to really grow strong (odd numbers cause a larger fps drop than even numbers)
#define VignetteCenter float2(0.500, 0.500) //[0.00 to 1.00, 0.00 to 1.00] Center of effect.
/ Chromatic aberration /
#define outfocus 0.022 //
/ Dither settings /
//No settings yet, beyond switching it on or off in the top section.
//Note that the checkerboard pattern used by Dither, makes an image harder to compress.
//This can make your screenshots and video recordings take up more space.
/ Border settings /
/ Splitscreen settings /
#define splitscreen_mode 1 //[1|2|3|4|5] 1 = Vertical 50/50 split, 2 = Vertical 25/50/25 split, 3 = Vertical 50/50 angled split, 4 = Horizontal 50/50 split, 5 = Horizontal 25/50/25 split
