PC DirectX 11 Issues Please Read: Batman Arkham City CommunityWe have received reports of performance issues from players of Batman: Arkham City on PC. After researching the matter, we found that running the game with DX 11 is causing the performance issues. We’re working on a title update to address this matter and expect to make it available in the near future.
In the meantime, a workaround for this issue is to run the game with DX 9 instead of DX 11. Instructions on how to turn off DX 11 are listed below.
We sincerely apologize for any inconvenience with your gameplay experience and thank you all for your patience as we work to resolve this issue.
Instructions for changing DX 11 to DX 9
The Launcher can be accessed on Games for Windows LIVE and Steam to change DX 11 to DX 9 in the Settings menu.
Change both DirectX 11 Features and DirectX 11 Tessellation to OFF.
Start > All Programs > Games > Right click on Batman: Arkham City and select Launcher > Settings
1. Open the Start Menu
2. Select All Programs and then the Games folder
3. Right click on Batman: Arkham City and select Launcher
4. Choose Settings then click on the arrow next to DX options to change
Steam:
Launch Steam Client > Library > Right click on Batman: Arkham City > Configure PC Options
1. Open Steam
2. Select Library
3. Right click on Batman: Arkham City and select Configure PC Options
؟؟Man man wie ATI den Cayman auf trap gebracht hat unglaublich. Die GTX570 ist gar keine konkurrenz mehr für HD6970 was viele der letzten Benchmarks zeigen.
Respekt![]()
GTX 570 = 52Finde die Karten weiterhin gleichwertig.
Zu Skyrim: Bei den CB- Benches liegt die Karte gar vor der GTX 580 kA warum das bei der PCGH anders is !?
Test: The Elder Scrolls V: Skyrim (Seite 8) - ComputerBase
Reicht denn eine GTX 275 OC um in DX9 mit maximalen Details in 1680*1050 flüssig spielen zu können (PhysX off)? Welche PhysX-Stufe könnte ich denn einstellen damit es noch flüssig läuft?
Liegt eine GTX 275 OC wirklich 10-15% hinter einer GTX 460? Konnte leider keine direkten Vergleiche finden. Aber laut diverser Tests hätte ich mir eigentlich zusammengereimt, dass beide etwa gleichauf liegen müssten:
Test: Nvidia GeForce GTX 460 (Seite 20) - ComputerBase (GTX 460 4% hinter HD 5850)
Test: ATi Radeon HD 5850 (CrossFire) (Seite 18) - ComputerBase (GTX 275 OC = GTX 285 = 1% hinter HD 5850)
.gif)
|MELVIN|
Bei diesem Spiel liegen gtx275 und gtx460 gleich auf, ABER nicht wenn man PhysX dazu schaltet - da sind Fermies generell besser! Also wenn unter DX9+1080p+PhysXoff beide Karten etwa 66fps bringen, dann unter DX9+1080p+PhysXhigh bringt 275er 30fps und 460er 36fps...
Quelle: Russen Test
. Kein Physx Keine Tesselation
