Naja bis zu 13fps mehr finde ich jetzt nicht sooo schlecht, aber klar prozentual ist das nicht viel. Und wer benutzt denn bitte 4000CL20? Das ist ja arschlahm
RAM OC bringt im übrigen nichts.
32gb CL20 vs 16gb CL14 +/- 2frames
AMD Zen 2 Memory Performance Scaling with Ryzen 9 3900X | TechPowerUp
"Overall, when looking at the application averages, there's barely a five percent performance gain to be had going from DDR4-2400 to DDR4-3600."
Overall, when looking at the application averages, there's barely a five percent performance gain to be had going from DDR4-2400 to DDR4-3600. Once you take a closer look at the individual tests, it becomes apparent that some apps simply like high memory clock, whereas others prefer tighter timings over the highest clock, and then there are those with barely any performance differences between memory speeds at all.
Games are a different story from applications as they tend to be more memory bandwidth hungry. Maybe counterintuitively, it's the FPS rate that drives the memory requirements instead of the resolution. At higher resolutions like 1440p and 4K, the GPU is the limiting factor, and the CPU is running at a lighter load than at lower resolutions. For each frame, the game has to calculate many things and adjust the scene geometry; as FPS goes up, so does the load. At 720p, there is a 10 percent performance increment to be had when going from DDR4-2133 to DDR4-3200. When looking at the more real-life 1080p resolution, the gap is still 7%. Depending on your choice of graphics card, gaining that much FPS with a memory upgrade could actually end up being cheaper than buying a faster graphics card.
Das ist zu 99% Fake, Intel würde nie im Leben 14+++ angebenSo sieht die Zukunft aus, zumindest bei Intel... Die nächste aufgewärmte Skylake-Generation kommt.
Funfact 1: Demnächst gibt es reichlich 9900K CPUs und Z370-Boards im Gebrauchtmarkt, weil wieder neuer Sockel.
Funfact 2: Der Name des neuen Chipsatz ist Panic Lake. Ernsthaft jetzt???
Intel 10th Generation Core "Comet Lake" Lineup Detailed | TechPowerUp
Sorry für Doppelpost...
Sachma fällst du jetzt auch auf diesen billigen Fake rein?
Das ist ein Bild von 4Chan oder so - von irgendeinem Amateur mit Paint gebastelt.
Und die würden auch nicht "499$" sondern "$499 USD" schreiben.
Außerdem PanicLake?
Schreit doch nach Fake.
[FONT="]wir bedanken uns bei Ihnen für Ihre Nachricht.
Wir erwarten jeden Tag die nächste Lieferung.
Leider haben Sie recht, dass der Termin sich im Moment immer weiter nach hinten schiebt.
Wir können Ihnen leider kein genaues Lieferddatum nennen, da wir dieses im Moment selber nicht wissen.
Leider kann dies bei neuen Artikeln vorkommen.
Ich entschuldige mich für die Unannehmlichkeiten.[/FONT]
bei 800 verkauften 3900x müsste schon ein container kommen und ich fürchte es schwimmt im besten fall erst jetzt los. oder gestern oder morgen. in diesem monat sehen wir keinen 3900x fürchte ichIch hab bei MF jetzt nochmal nachgebohrt.
Mal schauen ob die antworten bezüglich des 3900X.
EDIT
Hier die rasante Antwort:
Also die wissen es scheinbar selbst nicht.
Ob das stimmt - keine Ahnung.
Die bekomme solche Mails wahrscheinlich alle 15 Minuten.Die gleiche Antwort habe ich auch vorhin bekommen.
Hier mal paar 3800X Resultate: My 3800X benches : Amd
bin ja mal gespannt wann die mir antworten xDDie bekomme solche Mails wahrscheinlich alle 15 Minuten.
