mal ein paar Anreize Beta Patch zu nutzen: ich hatte damit noch kein Problem habe aber auch lange nicht mehr Multiplayer/Coop
gespielt sondern eigentlich immer im Editor und mit verschiedenen User Made Content
http://www.arma2.com/beta-patch.php
[71721] Game is now Large Address Aware, should improve stability and allow using more RAM with 64b OS.
[71543] File cache size increased a lot on systems with 4 GB RAM or more.
[71484] Fixed: C130 was crashing on takeoff.
[71373] Fixed crash
A2 Community Issue Tracker - Bug #11097: [71275] CTD while ALT+TAB in windows / while MP mission was
loaded. - DH: (ArmA) Development Unraveled
[71143] Improved: -cpuCount=4 is now default on computers with more than four logical CPUs to prevent hyperthreading causing
performance problems. If you want to use more CPUs, use -cpuCount=N to override this.
[71117] Optimized: Geometry loading in now optimized for multiple cores. Extra threading now enabled by default on computers with
more that 2 CPUs. New possible -exThreads values: 5 (thread geometry loading only) and 7 (thread all)
[70817] Fixed: Crash while rendering some custom worlds, e.g Schmalfelden
[70793] Fixed: Character animation jerky after a unit disembarked a vehicle (
A2 Community Issue Tracker - Bug #3116: Character
animation jerkiness after vehicle exit (some vehicles) - DH: (ArmA) Development Unraveled)
[70790] Fixed: Fps stayed low after spawning and deleted many units. See
A2 Community Issue Tracker - Bug #5147: Spawning
and deleting units - performance not restored - DH: (ArmA) Development Unraveled
[70663] New: Weather config values "size" and "height" for better control over the cloud layer. Default values: size = 1.0; height
= max(bright,0.6)
[70661] Improved: File handle management when more then 448 pbos are present is now more efficient.
[70651] Improved: Increased limits to prevent "Too many virtual memory blocks requested" error.
[70650] Fixed: Crash possible when loading map with older binarized format (pre 20, e.g. Schmalfelden).
[70646] Fixed: Some objects were shortly "flashing" while changing LODs.
[70582] Improved: Increased dynamic cloud layer visibility.
[70493] Fixed: Shadow artifacts visible on some windows while moving.
[70484] Fixed: Car horn not played in MP
[70439] Fixed: Transient z-fight-like shadows artifacts while zooming.
[70372] Fixed: AI vision was too good on moonless nights.
[70198] Fixed: Steam Overlay used during loading screen no longer disabled the keyboard.
[70192] New: Parameter exThreads=N to control extra threading. Following values of N are currently supported:
0 = no extra threads, 1 = file operations, 3 = texture loading
[69714] "enablesimulation" fixed on dedicated server
[69683] VoN volume slider
[68990] Improved: Reduced stutter when looking around, esp. with visibility 5 km or more.
[68694] Reduced parallax map artifacts on sloped terrain.
[68157] HDRPrecision 16 or 32 respected when users selects it and card supports it.
[68030] MP: Changed bandwidth estimation defaults as almost all players use broadband connection.
[67312] Fixed: AI is now able to take off with Camel airplane addon.
[67033] Improved AI airplane landing from very high altitude.
[66997] Optimized: Grass not rendered when flying high and fast, should reduce stutter.
[65703] New: Units report when reloading in combat situations.
[65703] New: Units report when throwing grenades in combat situations.
[65679] Fixed: AI Units called "covering" repeatedly while reloading.
[65656] "Cover me", "Covering" was often told repeateadly after busy radio channel periods.
[65605] Optimized: Fixed problems caused on some Vista systems by running too many threads at the same time.
[64561] New: Scripting function hideObject.
[64056] Fixed: Shining glasses on head preview in "edit player" menu.
[63164] Changed: Removed relics from dynamic building destruction development, including scripting function
deleteCollection.
[63126] Improved: AI airplane now aiming at the ground targets using rudder as well.
[63126] Fixed: Some AI airplanes oscillated sideways when flying slow.
[62888] Fixed: Improved helicopter aiming with unguided rockets.
[62868] Fixed: AT/RPG soldiers often missed targets.
[62700] Fixed: Spatial weapon sounds
[62687] Fixed: 3D resolution now maintained correctly when Alt-Tabbing.
[62627] Improved: "Invalid crew" config error no longer exits to desktop.
[62533] Fixed: The voice over net speech was often delayed more than required.
[62532] Fixed: The voice over net speech was often delayed more than required.
[62492] Fixed: Window size/position was not stored after a change.
