19:16:15:Saving configuration to config.xml
19:16:15:<config>
19:16:15: <!-- Network -->
19:16:15: <proxy v=':8080'/>
19:16:15:
19:16:15: <!-- Slot Control -->
19:16:15: <power v='full'/>
19:16:15:
19:16:15: <!-- User Information -->
19:16:15: <passkey v='********************************'/>
19:16:15: <team v='70335'/>
19:16:15: <user v='vfxworld'/>
19:16:15:
19:16:15: <!-- Folding Slots -->
19:16:15: <slot id='0' type='CPU'>
19:16:15: <cpus v='14'/>
19:16:15: <paused v='true'/>
19:16:15: </slot>
19:16:15: <slot id='1' type='GPU'>
19:16:15: </slot>
19:16:15:</config>
19:16:20:FS00:Unpaused
19:16:20:FS01:Unpaused
19:16:20:WU00:FS00:Starting
19:16:20:WARNING:WU00:FS00:Changed SMP threads from 15 to 14 this can cause some work units to fail
19:16:20:WU00:FS00:Running FahCore: D:\Programme\Program\FAHClient/FAHCoreWrapper.exe C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 4176 -checkpoint 15 -np 14
19:16:20:WU00:FS00:Started FahCore on PID 6524
19:16:20:WU00:FS00:Core PID:8440
19:16:20:WU00:FS00:FahCore 0xa4 started
19:16:20:WU01:FS01:Starting
19:16:20:WU01:FS01:Running FahCore: D:\Programme\Program\FAHClient/FAHCoreWrapper.exe C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4176 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
19:16:20:WU01:FS01:Started FahCore on PID 8100
19:16:20:WU01:FS01:Core PID:7544
19:16:20:WU01:FS01:FahCore 0x21 started
19:16:21:WU00:FS00:0xa4:
19:16:21:WU00:FS00:0xa4:*------------------------------*
19:16:21:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
19:16:21:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
reparing to commence simulation
19:16:21:WU00:FS00:0xa4:- Looking at optimizations...
19:16:21:WU00:FS00:0xa4:- Files status OK
19:16:21:WU00:FS00:0xa4:- Expanded 825768 -> 1402860 (decompressed 169.8 percent)
19:16:21:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825768 data_size=1402860, decompressed_data_size=1402860 diff=0
19:16:21:WU00:FS00:0xa4:- Digital signature verified
roject: 9038 (Run 62, Clone 8, Gen 29)
19:16:21:WU00:FS00:0xa4:Assembly optimizations on if available.
19:16:21:WU00:FS00:0xa4:Entering M.D.
19:16:21:WU01:FS01:0x21:*********************** Log Started 2016-09-22T19:16:20Z ***********************
roject: 9178 (Run 19, Clone 13, Gen 69)
19:16:21:WU01:FS01:0x21:Unit: 0x00000051ab436c6957b24c2a7ba2494a
19:16:21:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:16:21:WU01:FS01:0x21:Machine: 1
igital signatures verified
19:16:21:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:16:21:WU01:FS01:0x21:Version 0.0.17
19:16:21:WU01:FS01:0x21: Found a checkpoint file
19:16:24:WU01:FS01:0x21:Completed 700000 out of 2500000 steps (28%)
19:16:24:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:16:26:WU00:FS00:0xa4:Using Gromacs checkpoints
19:16:26:WU00:FS00:0xa4:Mapping NT from 14 to 14
19:16:27:WU00:FS00:0xa4:mdrun returned 255
19:16:27:WU00:FS00:0xa4:Going to send back what have done -- stepsTotalG=250000
19:16:27:WU00:FS00:0xa4:Work fraction=0.0000 steps=250000.
19:16:31:WU00:FS00:0xa4:logfile size=14011 infoLength=14011 edr=0 trr=25
19:16:31:WU00:FS00:0xa4:logfile size: 14011 info=14011 bed=0 hdr=25
19:16:31:WU00:FS00:0xa4:- Writing 14549 bytes of core data to disk...
one: 14037 -> 4780 (compressed to 34.0 percent)
19:16:31:WU00:FS00:0xa4: ... Done.
19:16:31:WU00:FS00:0xa4:Folding@home Core Shutdown: EARLY_UNIT_END
19:16:31:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:16:31:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9038 run:62 clone:8 gen:29 core:0xa4 unit:0x00000025ab436c9e56982a4eb98e2ee0
19:16:31:WU00:FS00:Uploading 5.17KiB to 171.67.108.158
19:16:31:WU00:FS00:Connecting to 171.67.108.158:8080
19:16:31:WU02:FS00:Connecting to 171.67.108.45:8080
19:16:31:WU00:FS00:Upload complete
19:16:31:WU00:FS00:Server responded WORK_ACK (400)
19:16:31:WU00:FS00:Cleaning up
19:16:32:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:16:32:WU02:FS00:Connecting to 171.64.65.35:80
19:16:33:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:16:33:ERROR:WU02:FS00:Exception: Could not get an assignment
19:16:33:WU02:FS00:Connecting to 171.67.108.45:8080
19:16:33:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:16:33:WU02:FS00:Connecting to 171.64.65.35:80
19:16:34:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:16:34:ERROR:WU02:FS00:Exception: Could not get an assignment
19:17:04:Saving configuration to config.xml
19:17:04:<config>
19:17:04: <!-- Network -->
19:17:04: <proxy v=':8080'/>
19:17:04:
19:17:04: <!-- Slot Control -->
19:17:04: <power v='full'/>
19:17:04:
19:17:04: <!-- User Information -->
19:17:04: <passkey v='********************************'/>
19:17:04: <team v='70335'/>
19:17:04: <user v='vfxworld'/>
19:17:04:
19:17:04: <!-- Folding Slots -->
19:17:04: <slot id='0' type='CPU'>
19:17:04: <cpus v='14'/>
19:17:04: </slot>
19:17:04: <slot id='1' type='GPU'/>
19:17:04:</config>
19:17:31:WU01:FS01:0x21:Completed 725000 out of 2500000 steps (29%)
19:17:33:WU02:FS00:Connecting to 171.67.108.45:8080
19:17:33:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:17:33:WU02:FS00:Connecting to 171.64.65.35:80
19:17:34:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:17:34:ERROR:WU02:FS00:Exception: Could not get an assignment
19:18:38:WU01:FS01:0x21:Completed 750000 out of 2500000 steps (30%)
19:19:10:WU02:FS00:Connecting to 171.67.108.45:8080
19:19:10:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:19:10:WU02:FS00:Connecting to 171.64.65.35:80
19:19:11:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:19:11:ERROR:WU02:FS00:Exception: Could not get an assignment
19:19:44:WU01:FS01:0x21:Completed 775000 out of 2500000 steps (31%)
19:19:59:FS00
aused
19:20:06:FS00:Unpaused
19:20:10:WU02:FS00:Connecting to 171.67.108.45:8080
19:20:11:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:20:11:WU02:FS00:Connecting to 171.64.65.35:80
19:20:11:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:20:11:ERROR:WU02:FS00:Exception: Could not get an assignment
19:20:51:WU01:FS01:0x21:Completed 800000 out of 2500000 steps (32%)
19:21:47:WU02:FS00:Connecting to 171.67.108.45:8080
19:21:48:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:21:48:WU02:FS00:Connecting to 171.64.65.35:80
19:21:48:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:21:48:ERROR:WU02:FS00:Exception: Could not get an assignment
19:21:59:WU01:FS01:0x21:Completed 825000 out of 2500000 steps (33%)
19:23:06:WU01:FS01:0x21:Completed 850000 out of 2500000 steps (34%)
19:24:13:WU01:FS01:0x21:Completed 875000 out of 2500000 steps (35%)
19:24:25:WU02:FS00:Connecting to 171.67.108.45:8080
19:24:25:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:24:25:WU02:FS00:Connecting to 171.64.65.35:80
19:24:26:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:24:26:ERROR:WU02:FS00:Exception: Could not get an assignment
19:25:08:FS00
aused
19:25:08:FS01
aused
19:25:08:FS01:Shutting core down
19:25:08:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 7544
19:25:08:WU01:FS01:0x21:Exiting, please wait. . .
19:25:08:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
19:25:08:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:25:12:Saving configuration to config.xml
19:25:12:<config>
19:25:12: <!-- Network -->
19:25:12: <proxy v=':8080'/>
19:25:12:
19:25:12: <!-- Slot Control -->
19:25:12: <power v='full'/>
19:25:12:
19:25:12: <!-- User Information -->
19:25:12: <passkey v='********************************'/>
19:25:12: <team v='70335'/>
19:25:12: <user v='vfxworld'/>
19:25:12:
19:25:12: <!-- Folding Slots -->
19:25:12: <slot id='0' type='CPU'>
19:25:12: <cpus v='14'/>
19:25:12: <paused v='true'/>
19:25:12: </slot>
19:25:12: <slot id='1' type='GPU'>
19:25:12: </slot>
19:25:12:</config>
19:25:23:FS00:Unpaused
19:25:23:FS01:Unpaused
19:25:23:WU01:FS01:Starting
19:25:23:WU01:FS01:Running FahCore: D:\Programme\Program\FAHClient/FAHCoreWrapper.exe C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4176 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
19:25:23:WU01:FS01:Started FahCore on PID 6608
19:25:24:WU01:FS01:Core PID:1496
19:25:24:WU01:FS01:FahCore 0x21 started
19:25:24:WU01:FS01:0x21:*********************** Log Started 2016-09-22T19:25:24Z ***********************
19:25:24:WU01:FS01:0x21:Unit: 0x00000051ab436c6957b24c2a7ba2494a
19:25:24:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:25:24:WU01:FS01:0x21:Machine: 1
19:25:24:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:25:24:WU01:FS01:0x21:Version 0.0.17
19:25:24:WU01:FS01:0x21: Found a checkpoint file
19:25:25:WU02:FS00:Connecting to 171.67.108.45:8080
19:25:25:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:25:25:WU02:FS00:Connecting to 171.64.65.35:80
19:25:26:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:25:26:ERROR:WU02:FS00:Exception: Could not get an assignment
19:25:28:WU01:FS01:0x21:Completed 800000 out of 2500000 steps (32%)
19:25:28:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:26:13:Saving configuration to config.xml
19:26:13:<config>
19:26:13: <!-- Network -->
19:26:13: <proxy v=':8080'/>
19:26:13:
19:26:13: <!-- Slot Control -->
19:26:13: <power v='full'/>
19:26:13:
19:26:13: <!-- User Information -->
19:26:13: <passkey v='********************************'/>
19:26:13: <team v='70335'/>
19:26:13: <user v='vfxworld'/>
19:26:13:
19:26:13: <!-- Folding Slots -->
19:26:13: <slot id='0' type='CPU'>
19:26:13: <cpus v='14'/>
19:26:13: </slot>
19:26:13: <slot id='1' type='GPU'/>
19:26:13:</config>
19:26:35:WU01:FS01:0x21:Completed 825000 out of 2500000 steps (33%)
19:27:02:WU02:FS00:Connecting to 171.67.108.45:8080
19:27:02:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:27:02:WU02:FS00:Connecting to 171.64.65.35:80
19:27:03:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:27:03:ERROR:WU02:FS00:Exception: Could not get an assignment
19:27:42:WU01:FS01:0x21:Completed 850000 out of 2500000 steps (34%)
