Knogle
Volt-Modder(in)
Hallo liebe Community ,
Was kann fuer diese BSODs verantwortlich sein? Ist ein Softwareproblem moeglich?
MACHINE_CHECK_EXCEPTION
0x9c
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: hal.dll
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x0000009c (0x0000000000000000, 0xfffff8800307bbd0, 0x0000000000000000,
0x0000000000000000)
*** hal.dll - Address 0xfffff8006303e80e base at 0xfffff80063011000 DateStamp
0x50875a79
to your computer.
these steps:
select Safe Mode.
*** STOP: 0x0000009c (0xffffffffc0000005, 0xfffff80062ec6b3a, 0x0000000000000000,
0xffffffffffffffff)
*** intelppm.sys - Address 0xfffff88001eb0bcb base at 0xfffff88001eaf000 DateStamp
0x52561fc3
to your computer.
The problem seems to be caused by the following file: ntoskrnl.exe
these steps:
select Safe Mode.
*** STOP: 0x0000009c (0x0000000000000001, 0x0000000000000002, 0x0000000000000000,
0xfffff8018d4ab3db)
*** ntoskrnl.exe - Address 0xfffff8018d465440 base at 0xfffff8018d40b000 DateStamp
0x531d349d
to your computer.
these steps:
select Safe Mode.
*** STOP: 0x0000009c (0xfffff8805453328b, 0x0000000000000008, 0xfffff8805453328b,
0x0000000000000002)
*** ntoskrnl.exe - Address 0xfffff803752c6440 base at 0xfffff8037526c000 DateStamp
0x531d349d
to your computer.
these steps:
select Safe Mode.
*** STOP: 0x0000009c (0x00000000c0000005, 0xfffff8013ae733bf, 0xfffff8800ba1adf0,
0x0000000000000000)
*** ntoskrnl.exe - Address 0xfffff8013ac5c440 base at 0xfffff8013ac02000 DateStamp
0x531d349d
to your computer.
these steps:
select Safe Mode.
*** STOP: 0x0000009c (0xffffffffc0000005, 0xfffff80398488fff, 0xfffff880009a7548,
0xfffff880009a6d80)
*** intelppm.sys - Address 0xfffff80398488fff base at 0xfffff80398009000 DateStamp
0x536464f4
to your computer.
these steps:
select Safe Mode.
*** STOP: 0x0000009c (0x0000000077982ad2, 0x0000000000000000, 0x000000000000ffff,
0xfffff8800dfdacc0)
*** win32k.sys - Address 0xfffff9600015d08a base at 0xfffff9600012e000 DateStamp
0x527ace4b
to your computer.
these steps:
select Safe Mode.
*** STOP: 0x0000009c (0xffffffffc0000005, 0xfffff8800473c67f, 0x0000000000000000,
0xffffffffffffffff)
*** intelppm.sys - Address 0xfffff8800473c67f base at 0xfffff8800473a000 DateStamp
0x50988a16
to your computer.
these steps:
select Safe Mode.
*** STOP: 0x0000009c (0x000000fffffa8053, 0x0000000000000002, 0x0000000000000001,
0xfffff88001f7dd44)
*** fvevol.sys - Address 0xfffff88001f7dd44 base at 0xfffff88001f6e000 DateStamp
0x52142f0b
to your computer.
these steps:
select Safe Mode.
*** STOP: 0x0000009c (0x0000000000000000, 0xfffffa8008d43028, 0x00000000ba000000,
0x0000000000400405)
*** intelide.sys - Address 0xfffff80088a38965 base at 0xfffff80088a0b000 DateStamp
0x50875a79
0x9c
to your computer.
these steps:
select Safe Mode.
0x0000000000000000)
0x50875a79
to your computer.
these steps:
select Safe Mode.
0xffffffffffffffff)
0x52561fc3
to your computer.
these steps:
select Safe Mode.
0xfffff8018d4ab3db)
0x531d349d
to your computer.
these steps:
select Safe Mode.
0x0000000000000002)
0x531d349d
to your computer.
these steps:
select Safe Mode.
0x0000000000000000)
0x531d349d
to your computer.
these steps:
select Safe Mode.
0xfffff880009a6d80)
0x536464f4
to your computer.
these steps:
select Safe Mode.
0xfffff8800dfdacc0)
0x527ace4b
to your computer.
these steps:
select Safe Mode.
0xffffffffffffffff)
0x50988a16
to your computer.
these steps:
select Safe Mode.
0xfffff88001f7dd44)
0x52142f0b
to your computer.
these steps:
select Safe Mode.
0x0000000000400405)
0x50875a79
