echo *****************************************************************************************
echo AIDefault.ai ****************************************************************************
aiSettings.setNSides 2
aiSettings.setAutoSpawnBots 1
REM Original AIX bot settings in case you need to copy and paste below
REM aiSettings.overrideMenuSettings 1
REM aiSettings.setMaxNBots 31
REM aiSettings.maxBotsIncludeHumans 0
REM aiSettings.setBotSkill 0.70
REM
REM *** keep the above lines intact in case you need to copy/paste them below ***
REM *** make changes here ***
REM *** max possible bots in assigned squads is 107, any more than 107 bots will not receive orders from commander
REM *** overrideMenuSettings 1 must be set, otherwise mod and map defaults will take precedence ***
REM *** botskill range is .10 to 1.00 ***
REM
REM ****CHANGE BOT NUMBER HERE! *****
aiSettings.setMaxNBots 107
aiSettings.setBotSkill 20.00
REM
run BotNames.ai
aiSettings.setInformationGridDimension 48
run AIPathFinding.ai
rem EOF
