Sammelthread UV Showcase, Show Your Results!
Sammelthread
cubi2k82
NV-UV
UV Showcase - Show Your Results!
Share your undervolting results, compare notes, and discuss what works best for your card.
Whether you're running Eco for silence or pushing Max for every last MHz, we want to see what your GPU can do.
This thread defaults to English so everyone can join in,
but feel free to post in German too, no one's getting kicked out for speaking their mother tongue. :D
Feel free to post results, ask questions about other people's settings, or share tips you've discovered along the way.
When sharing results, it helps to include:
- GPU model (e.g. RTX 5070 Ti, 5080, 5090)
- Frequency @ Voltage (e.g. 2962 MHz @ 925 mV)
- Mode used (V-Lock, Direct, Smart Curve, OCS Import)
- Power savings vs. stock (if known)
- Stable in which games/benchmarks
- Screenshot (NV-UV main window or Mini View)
Here's a template if you want to keep it structured:
GPU: RTX 5080
Setting: 3000 MHz @ 950 mV (V-Lock)
Power: ~220W vs ~300W stock (-27%)
Stable in: Cyberpunk 2077, CS2, 3DMark Steel Nomad
Notes: Ran the scanner first, then fine-tuned manually.
[screenshot]
But don't feel limited by the template, discussions, comparisons, and tips are all welcome here.
For bug reports, crashes, or setup problems please use the [Support] FAQ + Bugs thread, this one is for showing off your results. ;)
Let's see what Blackwell can do on a diet!
Weil NV UV auch in englischen Bubbles aufgefallen ist. Wie cubi selbst schreibt: Damit jeder mitmachen kann.
