20:57:23:WU01:FS00:Cleaning up
20:58:23:WU02:FS00:Connecting to 65.254.110.245:8080
20:58:23:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:58:23:WU02:FS00:Connecting to 18.218.241.186:80
20:58:23:WU02:FS00:Assigned to work server 168.245.198.125
20:58:24:WU02:FS00:Requesting new work unit for slot 00: READY cpu:28 from 168.245.198.125
20:58:24:WU02:FS00:Connecting to 168.245.198.125:8080
20:58:24:WU02:FS00
ownloading 1.23MiB
20:58:25:WU02:FS00
ownload complete
20:58:25:WU02:FS00:Received Unit: id:02 state
OWNLOAD error:NO_ERROR project:16406 run:1518 clone:4 gen:37 core:0xa7 unit:0x00000026a8f5c67d5e801e6b8d802591
20:58:25:WU02:FS00:Starting
20:58:25:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ursm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 6020 -checkpoint 15 -np 28
20:58:25:WU02:FS00:Started FahCore on PID 180204
20:58:25:WU02:FS00:Core PID:180172
20:58:25:WU02:FS00:FahCore 0xa7 started
20:58:26:WU02:FS00:0xa7:*********************** Log Started 2020-04-05T20:58:25Z ***********************
20:58:26:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:58:26:WU02:FS00:0xa7: Type: 0xa7
20:58:26:WU02:FS00:0xa7: Core: Gromacs
20:58:26:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 180204 -checkpoint 15 -np
20:58:26:WU02:FS00:0xa7: 28
20:58:26:WU02:FS00:0xa7:************************************ CBang *************************************
20:58:26:WU02:FS00:0xa7: Date: Oct 26 2019
20:58:26:WU02:FS00:0xa7: Time: 01:38:25
20:58:26:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:58:26:WU02:FS00:0xa7: Branch: master
20:58:26:WU02:FS00:0xa7: Compiler: Visual C++ 2008
20:58:26:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:58:26:WU02:FS00:0xa7: Platform: win32 10
20:58:26:WU02:FS00:0xa7: Bits: 64
20:58:26:WU02:FS00:0xa7: Mode: Release
20:58:26:WU02:FS00:0xa7:************************************ System ************************************
20:58:26:WU02:FS00:0xa7: CPU: AMD Ryzen 9 3950X 16-Core Processor
20:58:26:WU02:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
20:58:26:WU02:FS00:0xa7: CPUs: 32
20:58:26:WU02:FS00:0xa7: Memory: 63.93GiB
20:58:26:WU02:FS00:0xa7:Free Memory: 55.54GiB
20:58:26:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
20:58:26:WU02:FS00:0xa7: OS Version: 6.2
20:58:26:WU02:FS00:0xa7:Has Battery: false
20:58:26:WU02:FS00:0xa7: On Battery: false
20:58:26:WU02:FS00:0xa7: UTC Offset: 2
20:58:26:WU02:FS00:0xa7: PID: 180172
20:58:26:WU02:FS00:0xa7: CWD: C:\Users\ursm\AppData\Roaming\FAHClient\work
20:58:26:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
20:58:26:WU02:FS00:0xa7: Version: 0.0.18
20:58:26:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:58:26:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
20:58:26:WU02:FS00:0xa7: Homepage:
Folding@home – Fighting disease with a world wide distributed super computer.
20:58:26:WU02:FS00:0xa7: Time: 01:52:30
20:58:26:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:58:26:WU02:FS00:0xa7:************************************ Build *************************************
20:58:26:WU02:FS00:0xa7: SIMD: avx_256
20:58:26:WU02:FS00:0xa7:********************************************************************************
roject: 16406 (Run 1518, Clone 4, Gen 37)
20:58:26:WU02:FS00:0xa7:Unit: 0x00000026a8f5c67d5e801e6b8d802591
20:58:26:WU02:FS00:0xa7:Reading tar file core.xml
20:58:26:WU02:FS00:0xa7:Reading tar file frame37.tpr
igital signatures verified
20:58:26:WU02:FS00:0xa7:Calling: mdrun -s frame37.tpr -o frame37.trr -x frame37.xtc -cpt 15 -nt 28
20:58:26:WU02:FS00:0xa7:Steps: first=18500000 total=500000
20:58:26:WU02:FS00:0xa7:ERROR:
20:58:26:WU02:FS00:0xa7:ERROR:-------------------------------------------------------
rogram GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
20:58:26:WU02:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec.c, line: 6902
20:58:26:WU02:FS00:0xa7:ERROR:Fatal error:
20:58:26:WU02:FS00:0xa7:ERROR:There is no domain decomposition for 20 ranks that is compatible with the given box and a minimum cell size of 1.37225 nm
20:58:26:WU02:FS00:0xa7:ERROR:Change the number of ranks or mdrun option -rcon or -dds or your LINCS settings
20:58:26:WU02:FS00:0xa7:ERROR:Look in the log file for details on the domain decomposition
20:58:26:WU02:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
20:58:26:WU02:FS00:0xa7:ERROR:website at
Errors - Gromacs
20:58:31:WU02:FS00:0xa7:WARNING:Unexpected exit() call
20:58:31:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
20:58:31:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
20:58:31:WU02:FS00:0xa7:Saving result file md.log
20:58:31:WU02:FS00:0xa7:Saving result file science.log
20:58:31:WU02:FS00:0xa7:WARNING:While cleaning up: boost::filesystem::remove: The process cannot access the file because it is being used by another process: "01/md.log"
20:58:31:WU02:FS00:0xa7:Folding@home Core Shutdown: BAD_WORK_UNIT
20:58:31:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:58:31:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:16406 run:1518 clone:4 gen:37 core:0xa7 unit:0x00000026a8f5c67d5e801e6b8d802591
20:58:31:WU02:FS00:Uploading 20.00KiB to 168.245.198.125
20:58:31:WU02:FS00:Connecting to 168.245.198.125:8080
20:58:31:WU01:FS00:Connecting to 65.254.110.245:8080
20:58:32:WU02:FS00:Upload complete
20:58:32:WU02:FS00:Server responded WORK_ACK (400)
20:58:32:WU02:FS00:Cleaning up
20:58:32:WU01:FS00:Assigned to work server 13.82.98.119
20:58:32:WU01:FS00:Requesting new work unit for slot 00: READY cpu:28 from 13.82.98.119
20:58:32:WU01:FS00:Connecting to 13.82.98.119:8080
20:58:32:WU01:FS00
ownloading 6.74MiB
20:58:35:WU01:FS00
ownload complete
20:58:35:WU01:FS00:Received Unit: id:01 state
OWNLOAD error:NO_ERROR project:14412 run:298 clone:1 gen:9 core:0xa7 unit:0x0000000d0d5262775e7af199bbb7f5c7
20:58:35:WU01:FS00:Starting
20:58:35:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ursm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 6020 -checkpoint 15 -np 28
20:58:35:WU01:FS00:Started FahCore on PID 121244
20:58:36:WU01:FS00:Core PID:125000
20:58:36:WU01:FS00:FahCore 0xa7 started
20:58:36:WU01:FS00:0xa7:*********************** Log Started 2020-04-05T20:58:36Z ***********************
20:58:36:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:58:36:WU01:FS00:0xa7: Type: 0xa7
20:58:36:WU01:FS00:0xa7: Core: Gromacs
20:58:36:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 121244 -checkpoint 15 -np
20:58:36:WU01:FS00:0xa7: 28
20:58:36:WU01:FS00:0xa7:************************************ CBang *************************************
20:58:36:WU01:FS00:0xa7: Date: Oct 26 2019
20:58:36:WU01:FS00:0xa7: Time: 01:38:25
20:58:36:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:58:36:WU01:FS00:0xa7: Branch: master
20:58:36:WU01:FS00:0xa7: Compiler: Visual C++ 2008
20:58:36:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:58:36:WU01:FS00:0xa7: Platform: win32 10
20:58:36:WU01:FS00:0xa7: Bits: 64
20:58:36:WU01:FS00:0xa7: Mode: Release
20:58:36:WU01:FS00:0xa7:************************************ System ************************************
20:58:36:WU01:FS00:0xa7: CPU: AMD Ryzen 9 3950X 16-Core Processor
20:58:36:WU01:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
20:58:36:WU01:FS00:0xa7: CPUs: 32
20:58:36:WU01:FS00:0xa7: Memory: 63.93GiB
20:58:36:WU01:FS00:0xa7:Free Memory: 55.54GiB
20:58:36:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
20:58:36:WU01:FS00:0xa7: OS Version: 6.2
20:58:36:WU01:FS00:0xa7:Has Battery: false
20:58:36:WU01:FS00:0xa7: On Battery: false
20:58:36:WU01:FS00:0xa7: UTC Offset: 2
20:58:36:WU01:FS00:0xa7: PID: 125000
20:58:36:WU01:FS00:0xa7: CWD: C:\Users\ursm\AppData\Roaming\FAHClient\work
20:58:36:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
20:58:36:WU01:FS00:0xa7: Version: 0.0.18
20:58:36:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:58:36:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
20:58:36:WU01:FS00:0xa7: Homepage:
20:58:36:WU01:FS00:0xa7: Time: 01:52:30
20:58:36:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:58:36:WU01:FS00:0xa7:************************************ Build *************************************
20:58:36:WU01:FS00:0xa7: SIMD: avx_256
20:58:36:WU01:FS00:0xa7:********************************************************************************
roject: 14412 (Run 298, Clone 1, Gen 9)
20:58:36:WU01:FS00:0xa7:Unit: 0x0000000d0d5262775e7af199bbb7f5c7
20:58:36:WU01:FS00:0xa7:Reading tar file core.xml
20:58:36:WU01:FS00:0xa7:Reading tar file frame9.tpr
20:58:36:WU01:FS00:0xa7:Calling: mdrun -s frame9.tpr -o frame9.trr -x frame9.xtc -cpt 15 -nt 28
20:58:36:WU01:FS00:0xa7:Steps: first=2250000 total=250000
20:58:38:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
