15:08:08:Trying to access database...
15:08:08:Successfully acquired database lock
15:08:08:Enabled folding slot 01: PAUSED gpu:0:GM204 [GeForce GTX 970] (by user)
15:08:08:Enabled folding slot 00: PAUSED gpu:1:GM204 [GeForce GTX 970] (by user)
15:08:11:WARNING
enied 1:127.0.0.1 access to URI: /ping?_=1418828891467&callback=jQuery190009795077819822584_1418828891466
15:09:20:FS01:Unpaused
15:09:20:FS00:Unpaused
15:09:22:WU00:FS01:Connecting to 171.67.108.200:80
15:09:22:WU01:FS00:Connecting to 171.67.108.200:80
15:09:44:WARNING:WU01:FS00:Failed to get ID from '171.67.108.200:80': Failed to connect to 171.67.108.200:80: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
15:09:44:WARNING:WU00:FS01:Failed to get ID from '171.67.108.200:80': Failed to connect to 171.67.108.200:80: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
15:09:44:WU01:FS00:Connecting to 171.67.108.204:80
15:09:44:WU00:FS01:Connecting to 171.67.108.204:80
15:10:05:WARNING:WU01:FS00:Failed to get ID from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
15:10:05:ERROR:WU01:FS00:Exception: Could not get an assignment ID
15:10:05:WARNING:WU00:FS01:Failed to get ID from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
15:10:05:ERROR:WU00:FS01:Exception: Could not get an assignment ID
15:10:05:WU01:FS00:Connecting to 171.67.108.200:80
15:10:05:WU00:FS01:Connecting to 171.67.108.200:80
15:10:26:WARNING:WU00:FS01:Failed to get ID from '171.67.108.200:80': Failed to connect to 171.67.108.200:80: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
15:10:26:WARNING:WU01:FS00:Failed to get ID from '171.67.108.200:80': Failed to connect to 171.67.108.200:80: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
