PASST DAS NUN SO
CPU-Eigenschaften:
CPU Typ QuadCore Intel Core 2 Quad Q9300
CPU Bezeichnung Yorkfield-3M
CPU stepping C1/M1
Engineering Sample Nein
CPUID CPU Name Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz
CPUID Revision 00010677h
CPU VID 1.2250 V
CPU Geschwindigkeit:
CPU Takt 2999.9 MHz (Original: 2500 MHz, overclock: 20%)
CPU Multiplikator 7.5x
CPU FSB 400.0 MHz (Original: 333 MHz, overclock: 20%)
Speicherbus 533.3 MHz
DRAM:FSB Verhältnis 16:12
CPU Cache:
L1 Code Cache 32 KB per core
L1 Datencache 32 KB per core
L2 Cache 2x 3 MB (On-Die, ECC, ASC, Full-Speed)
Motherboard Eigenschaften:
Motherboard ID 65-1406-000001-00101111-100208-Eaglelake$A0999001_BIOS DATE: 10/02/08 14:56:00 VER: 08.00.14
Motherboard Name Asus P5Q Deluxe (2 PCI, 2 PCI-E x1, 3 PCI-E x16, 4 DDR2 DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
Chipsatz Eigenschaften:
Motherboard Chipsatz Intel Eaglelake P45
Speicher Timings 5-5-5-18 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
DIMM1: OCZ Reaper HPC OCZ2RPR10662G 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-5-5-13 @ 333 MHz) (3-4-4-10 @ 266 MHz)
DIMM3: OCZ Reaper HPC OCZ2RPR10662G 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-5-5-13 @ 333 MHz) (3-4-4-10 @ 266 MHz)
BIOS Eigenschaften:
Datum System BIOS 10/02/08
Datum Video BIOS 06/02/08
DMI BIOS Version 1406
Grafikprozessor Eigenschaften:
Grafikkarte ATI Radeon HD 4850 512MB GDDR3
GPU Codename RV770 (PCI Express 2.0 x16 1002 / 9442, Rev 00)
GPU Takt 500 MHz (Original: 625 MHz)
Speichertakt 750 MHz (Original: 993 MHz)
