AW: Lohnt sich bereits ein Aufrüsten?
Kollege 1:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\082111-11356-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\symbols*
http://msdl.microsoft.com/download/symbols
Executable search path is: C:\Windows\System32
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`03407000 PsLoadedModuleList = 0xfffff800`0364c670
Debug session time: Sun Aug 21 18:31:55.222 2011 (UTC + 2:00)
System Uptime: 0 days 0:42:47.862
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 50, {fffffa802b39b5f0, 1, fffff8000348da4c, 2}
Could not read faulting driver name
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+447c6 )
Followup: MachineOwner
3: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffffa802b39b5f0, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff8000348da4c, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800036b6100
fffffa802b39b5f0
FAULTING_IP:
nt!ObfDereferenceObject+2c
fffff800`0348da4c f0480fc11f lock xadd qword ptr [rdi],rbx
MM_INTERNAL_CODE: 2
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: BFBC2Game.exe
CURRENT_IRQL: 0
TRAP_FRAME: fffff8800e6526a0 -- (.trap 0xfffff8800e6526a0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=fffffa802b39b620
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8000348da4c rsp=fffff8800e652830 rbp=0000000000000001
r8=fffff8800e6528b0 r9=0000000000000001 r10=0000000000000b88
r11=fffffa800afb5e70 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
nt!ObfDereferenceObject+0x2c:
fffff800`0348da4c f0480fc11f lock xadd qword ptr [rdi],rbx ds:5180:00000000`00000000=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff8000342e3f0 to fffff80003483c40
STACK_TEXT:
fffff880`0e652538 fffff800`0342e3f0 : 00000000`00000050 fffffa80`2b39b5f0 00000000`00000001 fffff880`0e6526a0 : nt!KeBugCheckEx
fffff880`0e652540 fffff800`03481d6e : 00000000`00000001 fffffa80`2b39b5f0 fffffa80`06e99b00 ffffffff`ffffffff : nt! ?? ::FNODOBFM::`string'+0x447c6
fffff880`0e6526a0 fffff800`0348da4c : fffffa80`09f7fd00 fffffa80`0b39b620 00000000`00000000 fffff800`0345312c : nt!KiPageFault+0x16e
fffff880`0e652830 fffff800`03453097 : 00000000`00000001 fffffa80`09f7fdb0 fffffa80`0b0d78d0 00000000`00000000 : nt!ObfDereferenceObject+0x2c
fffff880`0e652890 fffff800`0348daf4 : fffffa80`0b0d78d0 00000000`00000000 fffff8a0`0970c760 fffffa80`0aebd4d0 : nt!ExpDeleteWorkerFactory+0x9f
fffff880`0e6528f0 fffff800`0377af44 : fffff8a0`0970c760 00000000`00000000 fffffa80`0a3ba800 00000000`00000000 : nt!ObfDereferenceObject+0xd4
fffff880`0e652950 fffff800`0373b344 : 00000000`00000b88 fffff8a0`0970c760 fffff8a0`09c75e20 00000000`00000b88 : nt!ObpCloseHandleTableEntry+0xc4
fffff880`0e6529e0 fffff800`0373b244 : 00000000`00000804 00000000`00000000 fffffa80`0b39b620 fffff800`03728471 : nt!ObpCloseHandleProcedure+0x30
fffff880`0e652a20 fffff800`0373b8c2 : fffff8a0`09798001 00000000`00000001 fffffa80`0b39b620 00000000`00000001 : nt!ExSweepHandleTable+0x74
fffff880`0e652a60 fffff800`03759ad2 : fffff8a0`09798060 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ObKillProcess+0x62
fffff880`0e652aa0 fffff800`0373b48c : 00000000`00000000 00000000`00000001 00000000`fffdb000 00000000`00000000 : nt!PspExitThread+0x522
fffff880`0e652ba0 fffff800`03482ed3 : fffffa80`0b39b620 fffff880`00000000 fffffa80`0a3ba800 00000000`fffdb000 : nt!NtTerminateProcess+0x138
fffff880`0e652c20 00000000`77b015da : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0008e318 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77b015da
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff800`0342e3f0 cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+447c6
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4e02aaa3
FAILURE_BUCKET_ID: X64_0x50_nt!_??_::FNODOBFM::_string_+447c6
