smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.10.21-Unraid] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke,
www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Crucial/Micron RealSSD m4/C400/P400
Device Model: M4-CT256M4SSD2
Serial Number: 000000001202032D22D5
LU WWN Device Id: 5 00a075 1032d22d5
Firmware Version: 070H
User Capacity: 256,060,514,304 bytes [256 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Apr 10 03:44:23 2021 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (10235) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 19) minutes.
Conveyance self-test routine
recommended polling time: ( 3) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 100 100 050 - 0
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
9 Power_On_Hours -O--CK 100 100 001 - 61267
12 Power_Cycle_Count -O--CK 100 100 001 - 2433
170 Grown_Failing_Block_Ct PO--CK 100 100 010 - 0
171 Program_Fail_Count -O--CK 100 100 001 - 0
172 Erase_Fail_Count -O--CK 100 100 001 - 0
173 Wear_Leveling_Count PO--CK 081 081 010 - 591
174 Unexpect_Power_Loss_Ct -O--CK 100 100 001 - 163
181 Non4k_Aligned_Access -O---K 100 100 001 - 2445 1495 950
183 SATA_Iface_Downshift -O--CK 100 100 001 - 0
184 End-to-End_Error PO--CK 100 100 050 - 0
187 Reported_Uncorrect -O--CK 100 100 001 - 0
188 Command_Timeout -O--CK 100 100 001 - 0
189 Factory_Bad_Block_Ct -OSR-- 100 100 001 - 84
194 Temperature_Celsius -O---K 100 100 000 - 0
195 Hardware_ECC_Recovered -O-RCK 100 100 001 - 1403
196 Reallocated_Event_Count -O--CK 100 100 001 - 0
197 Current_Pending_Sector -O--CK 100 100 001 - 0
198 Offline_Uncorrectable ----CK 100 100 001 - 0
199 UDMA_CRC_Error_Count -O--CK 100 100 001 - 0
202 Perc_Rated_Life_Used ---RC- 081 081 001 - 19
206 Write_Error_Rate -OSR-- 100 100 001 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 51 Comprehensive SMART error log
0x03 GPL R/O 16383 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 255 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 3449 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0 GPL VS 2000 Device vendor specific log
0xa0 SL VS 208 Device vendor specific log
0xa1-0xbf GPL,SL VS 1 Device vendor specific log
0xc0 GPL VS 80 Device vendor specific log
0xc1-0xdf GPL,SL VS 1 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (16383 sectors)
No Errors Logged
SMART Extended Self-test Log size 3449 not supported
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Vendor (0xff) Completed without error 00% 61266 -
# 2 Vendor (0xff) Completed without error 00% 61254 -
# 3 Vendor (0xff) Completed without error 00% 61241 -
# 4 Vendor (0xff) Completed without error 00% 61228 -
# 5 Vendor (0xff) Completed without error 00% 61215 -
# 6 Vendor (0xff) Completed without error 00% 61203 -
# 7 Vendor (0xff) Completed without error 00% 61190 -
# 8 Vendor (0xff) Completed without error 00% 61177 -
# 9 Vendor (0xff) Completed without error 00% 61165 -
#10 Vendor (0xff) Completed without error 00% 61152 -
#11 Vendor (0xff) Completed without error 00% 61139 -
#12 Vendor (0xff) Completed without error 00% 61127 -
#13 Vendor (0xff) Completed without error 00% 61114 -
#14 Vendor (0xff) Completed without error 00% 61101 -
#15 Vendor (0xff) Completed without error 00% 61089 -
#16 Vendor (0xff) Completed without error 00% 61076 -
#17 Vendor (0xff) Completed without error 00% 61064 -
#18 Vendor (0xff) Completed without error 00% 61051 -
#19 Vendor (0xff) Completed without error 00% 61038 -
#20 Vendor (0xff) Completed without error 00% 61026 -
#21 Vendor (0xff) Completed without error 00% 61013 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version: 3
SCT Version (vendor specific): 1 (0x0001)
Device State: SMART Off-line Data Collection executing in background (4)
Current Temperature: 0 Celsius
Power Cycle Min/Max Temperature: --/ 0 Celsius
Lifetime Min/Max Temperature: --/ 0 Celsius
SCT Temperature History Version: 2
Temperature Sampling Period: 10 minutes
Temperature Logging Interval: 10 minutes
Min/Max recommended Temperature: 0/70 Celsius
Min/Max Temperature Limit: -5/75 Celsius
Temperature History Size (Index): 478 (320)
Index Estimated Time Temperature Celsius
321 2021-04-06 20:10 0 -
... ..(476 skipped). .. -
320 2021-04-10 03:40 0 -
SCT Error Recovery Control:
Read: 40 (4.0 seconds)
Write: 40 (4.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 2) ==
0x01 0x008 4 2433 --- Lifetime Power-On Resets
0x01 0x010 4 61267 --- Power-on Hours
0x01 0x018 6 235224154942 --- Logical Sectors Written
0x01 0x020 6 1059450555 --- Number of Write Commands
0x01 0x028 6 327151281258 --- Logical Sectors Read
0x01 0x030 6 1431185526 --- Number of Read Commands
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 0 --- Current Temperature
0x05 0x010 1 0 --- Average Short Term Temperature
0x05 0x018 1 0 --- Average Long Term Temperature
0x05 0x020 1 0 --- Highest Temperature
0x05 0x028 1 0 --- Lowest Temperature
0x05 0x030 1 0 --- Highest Average Short Term Temperature
0x05 0x038 1 0 --- Lowest Average Short Term Temperature
0x05 0x040 1 0 --- Highest Average Long Term Temperature
0x05 0x048 1 0 --- Lowest Average Long Term Temperature
0x05 0x050 4 - --- Time in Over-Temperature
0x05 0x058 1 70 --- Specified Maximum Operating Temperature
0x05 0x060 4 - --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 0 --- Number of Hardware Resets
0x06 0x010 4 0 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
0x07 ===== = = === == Solid State Device Statistics (rev 1) ==
0x07 0x008 1 3 N-- Percentage Used Endurance Indicator
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 4 0 Command failed due to ICRC error
0x000a 4 6 Device-to-host register FISes sent due to a COMRESET
