GPU Clients laufen nicht mehr :(
30sectomars
PCGH-Community-Veteran(in)
Moin Leute. Seid Gestern abend laufen meine beiden Clients nicht mehr richtig auf meiner Graka. Sie laufen beide zusammen immer nur ganz kurz, dann wird sich eine neue WU geholt usw. Alleine schaffe ich auch mal ein par % aber dann bricht immer der Client ab. Hier mal ein Ausschnitt aus der LogFile...
Code:
# Windows GPU Console Edition #################################################
                       Folding@Home Client Version 6.23
                          http://folding.stanford.edu
Launch directory: C:\Users\Jens\AppData\Roaming\Folding@home-gpu_02
Arguments: -local -verbosity 9
[17:23:14] - Ask before connecting: No
[17:23:14] - User name: 30sectomars (Team 70335)
[17:23:14] - User ID: 6ADE172F78319A1D
[17:23:14] - Machine ID: 3
[17:23:14]
[17:23:14] Work directory not found. Creating...
[17:23:14] Could not open work queue, generating new queue...
[17:23:15] Initialization complete
[17:23:15] - Preparing to get new work unit...
[17:23:15] - Autosending finished units... [17:23:15]
[17:23:15] Trying to send all finished work units
[17:23:15] + Attempting to get work packet
[17:23:15] + No unsent completed units remaining.
[17:23:15] - Autosend completed
[17:23:15] - Will indicate memory of 3062 MB
[17:23:15] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 4
[17:23:15] - Connecting to assignment server
[17:23:15] Connecting to http://assign-GPU.stanford.edu:8080/
[17:23:16] Posted data.
[17:23:16] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[17:23:16] + News From Folding@Home: Welcome to Folding@Home
[17:23:16] Loaded queue successfully.
[17:23:16] Connecting to http://171.64.65.106:8080/
[17:23:17] Posted data.
[17:23:17] Initial: 0000; - Receiving payload (expected size: 66796)
[17:23:19] - Downloaded at ~32 kB/s
[17:23:19] - Averaged speed for that direction ~32 kB/s
[17:23:19] + Received work.
[17:23:19] + Closed connections
[17:23:19]
[17:23:19] + Processing work unit
[17:23:19] Core required: FahCore_11.exe
[17:23:19] Core not found.
[17:23:19] - Core is not present or corrupted.
[17:23:19] - Attempting to download new core...
[17:23:19] + Downloading new core: FahCore_11.exe
[17:23:19] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[17:23:20] Initial: AFDE; + 10240 bytes downloaded
[17:23:20] Initial: 8CE4; + 20480 bytes downloaded
[17:23:21] Initial: D8CE; + 30720 bytes downloaded
[17:23:21] Initial: 268C; + 40960 bytes downloaded
[17:23:21] Initial: F040; + 51200 bytes downloaded
[17:23:21] Initial: 8F3D; + 61440 bytes downloaded
[17:23:21] Initial: E22C; + 71680 bytes downloaded
[17:23:21] Initial: 232D; + 81920 bytes downloaded
[17:23:22] Initial: 7B96; + 92160 bytes downloaded
[17:23:23] Initial: 35ED; + 102400 bytes downloaded
[17:23:23] Initial: 12C7; + 112640 bytes downloaded
[17:23:24] Initial: CE46; + 122880 bytes downloaded
[17:23:24] Initial: 4CD5; + 133120 bytes downloaded
[17:23:25] Initial: 0CD7; + 143360 bytes downloaded
[17:23:25] Initial: 0D37; + 153600 bytes downloaded
[17:23:25] Initial: 2D4A; + 163840 bytes downloaded
[17:23:26] Initial: 602C; + 174080 bytes downloaded
[17:23:26] Initial: 4001; + 184320 bytes downloaded
[17:23:27] Initial: D84F; + 194560 bytes downloaded
[17:23:27] Initial: 2151; + 204800 bytes downloaded
[17:23:27] Initial: 2ABF; + 215040 bytes downloaded
[17:23:28] Initial: 5CA8; + 225280 bytes downloaded
[17:23:28] Initial: 40D4; + 235520 bytes downloaded
[17:23:29] Initial: 1804; + 245760 bytes downloaded
[17:23:30] Initial: 1478; + 256000 bytes downloaded
[17:23:30] Initial: D0B4; + 266240 bytes downloaded
[17:23:31] Initial: B858; + 276480 bytes downloaded
[17:23:31] Initial: 1830; + 286720 bytes downloaded
[17:23:32] Initial: BA4E; + 296960 bytes downloaded
[17:23:32] Initial: 3985; + 307200 bytes downloaded
[17:23:33] Initial: 232C; + 317440 bytes downloaded
[17:23:33] Initial: 63DF; + 327680 bytes downloaded
[17:23:34] Initial: 0AAF; + 337920 bytes downloaded
[17:23:34] Initial: 7F28; + 348160 bytes downloaded
[17:23:34] Initial: 9005; + 358400 bytes downloaded
[17:23:35] Initial: 8084; + 368640 bytes downloaded
[17:23:35] Initial: FBCE; + 378880 bytes downloaded
[17:23:35] Initial: F76F; + 389120 bytes downloaded
[17:23:36] Initial: C594; + 399360 bytes downloaded
[17:23:36] Initial: B0BC; + 409600 bytes downloaded
[17:23:37] Initial: DD0D; + 419840 bytes downloaded
[17:23:37] Initial: DCF5; + 430080 bytes downloaded
[17:23:39] Initial: 6D67; + 440320 bytes downloaded
[17:23:39] Initial: A987; + 450560 bytes downloaded
[17:23:42] Initial: E0CA; + 460800 bytes downloaded
[17:23:43] Initial: 6090; + 471040 bytes downloaded
[17:23:44] Initial: 83FD; + 481280 bytes downloaded
[17:23:45] Initial: D0F9; + 491520 bytes downloaded
[17:23:46] Initial: A4B9; + 501760 bytes downloaded
[17:23:48] Initial: 7046; + 512000 bytes downloaded
[17:23:48] Initial: 3F00; + 522240 bytes downloaded
[17:23:49] Initial: 07F1; + 532480 bytes downloaded
[17:23:50] Initial: 6E7D; + 542720 bytes downloaded
[17:23:51] Initial: 4416; + 552960 bytes downloaded
[17:23:51] Initial: 353A; + 563200 bytes downloaded
[17:23:52] Initial: 6C4D; + 573440 bytes downloaded
[17:23:52] Initial: 305A; + 583680 bytes downloaded
[17:23:53] Initial: 3D23; + 593920 bytes downloaded
[17:23:53] Initial: A242; + 604160 bytes downloaded
[17:23:53] Initial: 1E02; + 614400 bytes downloaded
[17:23:54] Initial: 75E0; + 624640 bytes downloaded
[17:23:54] Initial: 8F3A; + 634880 bytes downloaded
[17:23:55] Initial: 1E1B; + 642475 bytes downloaded
[17:23:56] Verifying core Core_11.fah...
[17:23:56] Signature is VALID
[17:23:56]
[17:23:56] Trying to unzip core FahCore_11.exe
[17:23:57] Decompressed FahCore_11.exe (1843200 bytes) successfully
[17:24:02] + Core successfully engaged
[17:24:07]
[17:24:07] + Processing work unit
[17:24:07] Core required: FahCore_11.exe
[17:24:07] Core found.
[17:24:07] Working on queue slot 01 [May 18 17:24:07 UTC]
[17:24:07] + Working ...
[17:24:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -noassembly -checkpoint 3 -verbose -lifeline 1140 -version 623'
[17:24:07]
[17:24:07] *------------------------------*
[17:24:07] Folding@Home GPU Core - Beta
[17:24:07] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[17:24:07]
[17:24:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:24:07] Build host: amoeba
[17:24:07] Board Type: Nvidia
[17:24:07] Core      :
[17:24:07] Preparing to commence simulation
[17:24:07] - User disabled assembly optimizations.
[17:24:07] - Created dyn
[17:24:07] - Files status OK
[17:24:07] - Expanded 66284 -> 348500 (decompressed 525.7 percent)
[17:24:07] Called DecompressByteArray: compressed_data_size=66284 data_size=348500, decompressed_data_size=348500 diff=0
[17:24:07] - Digital signature verified
[17:24:07]
[17:24:07] Project: 5777 (Run 1, Clone 792, Gen 8)
[17:24:07]
[17:24:07] Entering M.D.
[17:24:13] Working on Protein
[17:24:15] Client config found, loading data.
[17:24:15] Starting GUI Server
[17:25:40] Completed 1%
[17:25:40] mdrun_gpu returned
[17:25:40] NANs detected on GPU
[17:25:40]
[17:25:40] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:25:43] CoreStatus = 7A (122)
[17:25:43] Sending work to server
[17:25:43] Project: 5777 (Run 1, Clone 792, Gen 8)
[17:25:43] - Error: Could not get length of results file work/wuresults_01.dat
[17:25:43] - Error: Could not read unit 01 file. Removing from queue.
[17:25:43] Trying to send all finished work units
[17:25:43] + No unsent completed units remaining.
[17:25:43] - Preparing to get new work unit...
[17:25:43] + Attempting to get work packet
[17:25:43] - Will indicate memory of 3062 MB
[17:25:43] - Connecting to assignment server
[17:25:43] Connecting to http://assign-GPU.stanford.edu:8080/
[17:25:44] Posted data.
[17:25:44] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[17:25:44] + News From Folding@Home: Welcome to Folding@Home
[17:25:44] Loaded queue successfully.
[17:25:44] Connecting to http://171.64.65.106:8080/
[17:25:45] Posted data.
[17:25:45] Initial: 0000; - Receiving payload (expected size: 66796)
[17:25:47] - Downloaded at ~32 kB/s
[17:25:47] - Averaged speed for that direction ~32 kB/s
[17:25:47] + Received work.
[17:25:47] Trying to send all finished work units
[17:25:47] + No unsent completed units remaining.
[17:25:47] + Closed connections
[17:25:52]
[17:25:52] + Processing work unit
[17:25:52] Core required: FahCore_11.exe
[17:25:52] Core found.
[17:25:52] Working on queue slot 02 [May 18 17:25:52 UTC]
[17:25:52] + Working ...
[17:25:52] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -noassembly -checkpoint 3 -verbose -lifeline 1140 -version 623'
[17:25:52]
[17:25:52] *------------------------------*
[17:25:52] Folding@Home GPU Core - Beta
[17:25:52] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[17:25:52]
[17:25:52] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:25:52] Build host: amoeba
[17:25:52] Board Type: Nvidia
[17:25:52] Core      :
[17:25:52] Preparing to commence simulation
[17:25:52] - User disabled assembly optimizations.
[17:25:52] - Created dyn
[17:25:52] - Files status OK
[17:25:52] - Expanded 66284 -> 348500 (decompressed 525.7 percent)
[17:25:52] Called DecompressByteArray: compressed_data_size=66284 data_size=348500, decompressed_data_size=348500 diff=0
[17:25:52] - Digital signature verified
[17:25:52]
[17:25:52] Project: 5777 (Run 1, Clone 792, Gen 8)
[17:25:52]
[17:25:52] Entering M.D.
[17:25:59] Working on Protein
[17:26:00] Client config found, loading data.
[17:26:00] Starting GUI Server
Dazu gibts schon hunderte Threads und/oder Antworten in der Ruka. Hier dürfen Klutten und Co. mal wieder arbeiten :D.
Ungefähr seit gestern läuft auch meiner nicht mehr irgendwie bekommt er keine verbindung zum server...
Log file sieht ähnlich aus
so mal ganz einfach(es wurde schon ca. 1000x diskutiert)
manchmal sind die server von stanford einfach down und dann spucken sie keine wu´s aus
Also das mit den servern wusst ich ja nicht weil ich ein neuling bin aber jetzt laufen sie wieder...
Gott sei dank jetzt wird gefoldet^^
