Explosiv
Catalyst 9.10 Final ist da !
Der lang ersehnte Catalyst 9.10 ist da ! Dieses mal wurden zahlreiche Änderungen vorgenommen. Mit dabei ist endlich die volle Unterstützung der neuen Evergreengrafikkarten von AMD. Für die neuen HD5XXX ist nun auch der neue SGSSAA-Modus (Antialaising) dazu gekommen.
Operating Systems Supported:
GPU acceleration for the Windows 7 Drag and Drop video
converting application:
Resolved Issues for All Windows Operating Systems:
Quellen:
Release Notes
ATi-Forum
- Windows 7 32-bit version
- Windows 7 64-bit version
- Windows Vista 32-bit version
- Windows Vista 64-bit version
- Windows XP Professional
- Windows XP Home Edition
- Windows XP Media Center Edition
- Windows XP Professional x64 Edition
- This release of ATI Catalyst™ provides GPU support for the Windows 7 Drag and Drop video converter application found in the Windows 7 Operating System. This feature is supported on the ATI Radeon™ HD 5800, ATI Radeon™ HD 5700 and ATI Radeon™ HD 4000 Series of products.
- This release of ATI Catalyst™ provides support for a new Anti-Aliasing method on the ATI Radeon™ HD 5800 Series. Users can now experience the high level of anti-aliasing image quality using Super Sampling anti-aliasing while maintaining good performance
levels.
- The video preview in Avivo™ Video - Basic Quality page in Catalyst Control Center no longer flickers while playing SD/HD Blu-ray titles
- Underscan/Overscan settings for TV can now be applied from the Catalyst Control Center - TV Properties Adjustments page
- The display mode page will now refresh properly when selecting another display from drop down menu in Catalyst Control Center with two displays connected in extended mode
- "Component Video Properties" is no longer incorrectly listed under the "Quick Settings" tab under Catalyst Control Center - Basic view in extended mode
- Changes to the Avivo™ Video Presets page in Catalyst Control Center can now be applied and will not revert back to the default settings
- The "Use Application Settings" checkbox in Avivo™ Video Presets page can now be
unchecked in Catalyst Control Center - Changes to the “All Settings” and “Basic Quality” pages in Catalyst Control Center -Avivo™ Video will now be retained after reboot
- Switching profile settings in Avivo™ Video - Basic Quality page now functions properly in Catalyst Control Center
- EA Sports startup logo screen for "Tiger Woods PGA Tour 08" will no longer disappear or turn black
- Ghostbusters video game no longer flickers between desktop and game play when anti-aliasing is set to 8X and game resolution set to 2560x1600
- Enabling Screen Space Ambient Occlusion option in "Riddick 2 Dark Athena" no longer causes the game to fail under Multi-GPU configurations
- Severe flickering no longer observed while running 3D games/samples on specific HDMI displays with Tripod and Quad CrossFire enabled configurations
- Desktop flashing no longer observed after driver installation and reboot with systems configured with Radeon ASIC in the primary PCIe slot and Firestream ASIC in the secondary PCIe slot
- "Combat Mission Shock Force" no longer fails after a duration of game play
- Intermittent flashing no longer visible in Windows with ViewSonic VE150m displays
- Catalyst Control Center: The DTV (HDMI) Pixel Format settings will now be restored when a HDMI display is hotplugged back after a DVI display is hotplugged and unplugged during the interval to the same port
- System no longer reboots or displays a black screen while executing ATI Stream applications with a particular combination of ASICs set as primary and secondary
- "Force maximum performance clocks" option is now available for the second ASIC in the Catalyst Control Center system tray when two R700 ASICs are connected
- Corruption no longer observed during Blu-ray DVD H.264/VC-1 content playback
- Different Presets/Basic Color options can now be selected under Avivo™ Video in Catalyst Control Center Advanced View
Quellen:
Release Notes
ATi-Forum
