CORSAIR_Marcus
Hallo zusammen!
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen, inkl. einem Link zum download.
Zudem füge ich euch unseren neusten CORSAIR Explorer Artikel zum Thema iCUE 5.14+ hinzu:
Software Enhancements
- Resolved an issue that prevented firmware updates from starting during the prompt for a USB cable to be connected
- Resolved an issue that prevents the border around the Macro Recording area from blinking during a macro recording session
- Voicemod SDK is updated to the latest version – however, “Instant Censor Beep” and “Mute for Me On/Off” are temporarily disabled until they are re-implemented in the SDK
- iCUE will no longer fully quit while there is an active window prompt
- Improved the design for progress bars and their associated buttons
- Modules can no longer be deleted for devices that are still connected to the system
- Resolved an issue that caused temperature units to be displayed in Fahrenheit instead of Celsius by default
- iCUE will no longer crash while switching profiles during a pointer hover on an icon in Key Assignments
- Profile names will no longer be allowed to exceed 255 characters
- Info panels in Device Memory Mode will no longer have a text cut-off
- Resolved some user interface issues that caused improper scaling in some of the device panels
- Resolved an issue that causes iCUE to hang during the saving process of a hardware profile
- The following devices have been added for Govee Support:
- H610A Light Strips
- H61E1 Light Strips
- H61D3 Light Strips
- H6065 Y Light Bars
- H6047 Light Bars
HID Product Enhancements
- Additional notifications were added when saving multiple hardware profiles to a device
- A notification has been added for devices that are out of space while saving a hardware profile
- Added some improvements to Device Memory Mode to help with discarding changes
- Improved the notification(s) shown in iCUE macOS for a headset’s first detection in iCUE
- Pointer Speed and Enhance Pointer Precision have been removed for mice – users should enable/disable these features now through Windows Control Panel for pointer devices
- Resolved a rare issue that caused Lighting Layers and/or Key Assignments to disappear after changing DPI settings and saving the hardware profile
DIY Product Enhancements
- Various issues were resolved with Device Memory Mode while saving images to LCD-supported devices
- Switching profiles will no longer cause a lighting effect to be stuck for iCUE LINK ecosystem devices
- Updated the HX1200i image to properly reflect the actual device
- https://www.corsair.com/ww/en/explorer/gamer/mice/corsair-icue-everything-you-need-to-know/
- https://www.corsair.com/ww/en/explorer/gamer/mice/whats-new-in-icue-v-514/
- https://www.corsair.com/ww/en/explo...o-easily-customize-your-rgb-lighting-in-icue/
- https://www.corsair.com/ww/en/explo...-monitor-cpu-and-system-temperatures-in-icue/
- https://www.corsair.com/ww/en/explo...o-control-fans-and-create-fan-curves-in-icue/
- https://www.corsair.com/ww/en/explo...lighting-and-key-assignments-icue-v514-newer/
- https://www.corsair.com/ww/en/explorer/gamer/mice/how-to-set-up-device-memory-mode-dmm-in-icue/
- https://www.corsair.com/ww/en/explo...ng/how-to-set-up-a-govee-light-strip-in-icue/
