Bluescreen
Hmm stimmt habe ich nicht bemerkt.. Komischerweise lassen sich meine Dump-Dateien nichtmehr wie beim letzten Mal kopieren und auf den Desktop einfügen :o
Woran kann das auf einmal liegen?
Edit: Hab nun selbst auch mal versucht einen Dump mit dem Debugger auszuwerten. Vllt kannst du damit was anfangen :)
Dump vom 14.06.
Microsoft (R) Windows Debugger Version 6.3.9600.17298 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\061415-4781-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Symbol Path validation summary **************
Response Time (ms) Location
Deferred SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17736.amd64fre.winblue_r9.150322-1500
Machine Name:
Kernel base = 0xfffff800`d3a19000 PsLoadedModuleList = 0xfffff800`d3cf2850
Debug session time: Sun Jun 14 17:35:29.644 2015 (UTC + 2:00)
System Uptime: 2 days 1:32:56.000
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffff800d3e54920, ffffd00022ec5e30, 0}
Probably caused by : ntkrnlmp.exe ( nt!HvpGetCellPaged+50 )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff800d3e54920, Address of the instruction which caused the bugcheck
Arg3: ffffd00022ec5e30, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
FAULTING_IP:
fffff800`d3e54920 488b04c8 mov rax,qword ptr [rax+rcx*8]
CONTEXT: ffffd00022ec5e30 -- (.cxr 0xffffd00022ec5e30;r)
rax=0000000000000000 rbx=ffffc00069c21000 rcx=0000000000000132
rdx=0000000000000000 rsi=0000000000000000 rdi=ffffc0006cae4380
rip=fffff800d3e54920 rsp=ffffd00022ec6868 rbp=ffffd00022ec68d0
r8=ffffc0006a2f9000 r9=000000000000019b r10=0000000000000235
r11=ffffd00022ec6840 r12=0000000033666231 r13=0000000000000000
r14=0000000000000000 r15=ffffc00070996994
iopl=0 nv up ei pl nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010206
nt!HvpGetCellPaged+0x50:
fffff800`d3e54920 488b04c8 mov rax,qword ptr [rax+rcx*8] ds:002b:00000000`00000990=????????????????
Last set context:
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: TiWorker.exe
CURRENT_IRQL: 0
ANALYSIS_VERSION: 6.3.9600.17336 (debuggers(dbg).150226-1500) x86fre
LAST_CONTROL_TRANSFER: from fffff800d3e595dc to fffff800d3e54920
STACK_TEXT:
ffffd000`22ec6868 fffff800`d3e595dc : ffffc000`69c21000 00000000`00000000 ffffc000`6cae4380 00000000`00000000 : nt!HvpGetCellPaged+0x50
ffffd000`22ec6870 fffff800`d3e592a1 : 00000000`33666231 00000000`00000000 00000088`50e5c1b4 fffff800`00000000 : nt!CmEnumerateKey+0x17c
ffffd000`22ec6910 fffff800`d3b754b3 : ffffe001`6a8c3080 00000088`50e5c008 ffffd000`22ec6aa8 00000000`00000000 : nt!NtEnumerateKey+0x2b1
ffffd000`22ec6a90 00007fff`550e14ea : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000088`50e5c088 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007fff`550e14ea
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt!HvpGetCellPaged+50
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 550f41a6
IMAGE_VERSION: 6.3.9600.17736
STACK_COMMAND: .cxr 0xffffd00022ec5e30 ; kb
BUCKET_ID_FUNC_OFFSET: 50
FAILURE_BUCKET_ID: 0x3B_nt!HvpGetCellPaged
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x3b_nt!hvpgetcellpaged
FAILURE_ID_HASH: {3f4270b8-7b0a-894a-9742-49f2b066180b}
Dump vom 15.06.
Loading Dump File [C:\Windows\Minidump\061515-3281-01.dmp]
Machine Name:
Kernel base = 0xfffff801`1a686000 PsLoadedModuleList = 0xfffff801`1a95f850
Debug session time: Mon Jun 15 12:16:08.457 2015 (UTC + 2:00)
System Uptime: 0 days 18:40:20.116
BugCheck EF, {ffffe0011ea6e080, 0, 0, 0}
----- ETW minidump data unavailable-----
Probably caused by : csrss.exe
2: kd> !analyze -v
CRITICAL_PROCESS_DIED (ef)
A critical system process died
Arguments:
Arg1: ffffe0011ea6e080, Process object or thread object
Arg2: 0000000000000000, If this is 0, a process died. If this is 1, a thread died.
Arg3: 0000000000000000
Debugging Details:
PROCESS_OBJECT: ffffe0011ea6e080
IMAGE_NAME: csrss.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: csrss
FAULTING_MODULE: 0000000000000000
PROCESS_NAME: csrss.exe
EXCEPTION_CODE: (NTSTATUS) 0x1cf71880 - <Unable to get error code text>
BUGCHECK_STR: 0xEF_1cf71880
CURRENT_IRQL: 0
STACK_TEXT:
ffffd000`239789a8 fffff801`1ac9c918 : 00000000`000000ef ffffe001`1ea6e080 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
ffffd000`239789b0 fffff801`1abd3cea : ffffe001`1ea6e080 ffffe001`1cf71c60 00000000`00000000 00000000`c0000005 : nt!PspCatchCriticalBreak+0xa4
ffffd000`239789f0 fffff801`1aa71775 : ffffe001`1ea6e080 ffffe001`1cf71c60 ffffe001`1ea6e080 ffffe001`1ea6e080 : nt! ?? ::NNGAKEGL::`string'+0x22e3a
ffffd000`23978a50 fffff801`1aa71502 : ffffffff`ffffffff ffffe001`1ea6e080 ffffe001`1ea6e080 ffffe001`1cf71880 : nt!PspTerminateProcess+0xe5
ffffd000`23978a90 fffff801`1a7e24b3 : ffffe001`1ea6e080 ffffe001`1cf71880 ffffd000`23978b80 00000000`00000000 : nt!NtTerminateProcess+0x9e
ffffd000`23978b00 00007ffe`f110148a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
0000001f`8dcccda8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`f110148a
STACK_COMMAND: kb
IMAGE_VERSION:
FAILURE_BUCKET_ID: 0xEF_1cf71880_IMAGE_csrss.exe
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0xef_1cf71880_image_csrss.exe
FAILURE_ID_HASH: {320d8078-1448-dea5-3057-86202193e2d3}
Außer dass ein Problem mit dem Speichermanagement vorliegt, kann man hier nicht mehr herauslesen. Zumindest scheint hier keine Drittsoftware, -Treiber ursächlich zu sein.
Poste bitte noch einen Screenshot von CrystalDiskInfo, um die SMART Werte der Systemplatte lesen zu können.
Im Anhang sind die Screenshots.
Der Spoiler beinhaltet das ganze als Textform rauskopiert.
CrystalDiskInfo 6.5.2 (C) 2008-2015 hiyohiyo
Crystal Dew World : Crystal Dew World
OS : Windows 8.1 Pro [6.3 Build 9600] (x64)
Date : 2015/06/15 23:03:39
-- Controller Map ----------------------------------------------------------
+ Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller [ATA]
- TSSTcorp CDDVDW SH-224DB
- Crucial_CT256MX100SSD1
- CT250BX100SSD1
- Microsoft-Controller für Speicherplätze [SCSI]
- ASRock RAM Disk [SCSI]
-- Disk List ---------------------------------------------------------------
(1) Crucial_CT256MX100SSD1 : 256,0 GB [0/1/0, pd1] - mi
(2) CT250BX100SSD1 : 250,0 GB [1/1/0, pd1]
Model : Crucial_CT256MX100SSD1
Firmware : MU01
Serial Number : 14520E324471
Disk Size : 256,0 GB (8,4/137,4/256,0/256,0)
Buffer Size : Unbekannt
Queue Depth : 32
# of Sectors : 500118192
Rotation Rate : ---- (SSD)
Interface : Serial ATA
Major Version : ACS-2
Minor Version : ATA8-ACS version 6
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 376 Std.
Power On Count : 147 mal
Host Writes : 2921 GB
Wear Level Count : 15
Temperature : 23 C (73 F)
Health Status : Gut (100 %)
Features : S.M.A.R.T., APM, 48bit LBA, NCQ, TRIM, DevSleep
APM Level : 00FEh [ON]
AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 __0 000000000000 Lesefehlerrate (roh)
05 100 100 __0 000000000000 Wiederzugewiesene Sektoren
09 100 100 __0 000000000178 Betriebsstunden
0C 100 100 __0 000000000093 Geräte-Einschaltvorgänge
AB 100 100 __0 000000000000 Programmfehler
AC 100 100 __0 000000000000 Löschfehler
AD 100 100 __0 00000000000F Mittlere Blocklöschungen
AE 100 100 __0 000000000009 Unerwartete Spannungsabfälle
B4 __0 __0 __0 00000000086F Unbenutzte NAND-Reserveblöcke
B7 100 100 __0 000000000000 Verlangsamung der SATA-Schnittstelle
B8 100 100 __0 000000000000 Fehlerkorrekturanzahl
BB 100 100 __0 000000000000 Gemeldete nicht korrigierbare Fehler
C2 _77 _59 __0 002900110017 Gehäusetemperatur
C4 100 100 __0 000000000000 Wiederzuweisungsereignisse
C5 100 100 __0 000000000000 Aktuell ausstehende Sektoren
C6 100 100 __0 000000000000 Nicht korrigierbare Fehler nach Smart Offline Scan
C7 100 100 __0 000000000005 UltraDMA-CRC-Fehler
CA 100 100 __0 000000000000 Prozent der verbrauchten Lebensdauer
CE 100 100 __0 000000000000 Schreibfehlerrate
D2 100 100 __0 000000000000 Erfolgreiche RAIN-Wiederherstellung
F6 100 100 __0 00016D3F98B6 Gelesene Host-Sektoren (gesamt)
F7 100 100 __0 00000B72697A Host-Programmseiten
F8 100 100 __0 0000045324CA Hintergrund-Programmseiten
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 0440 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 2020 3134 3532 3045 3332 3434 3731
020: 0000 0000 0000 4D55 3031 2020 2020 4372 7563 6961
030: 6C5F 4354 3235 364D 5831 3030 5353 4431 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4001 2F00
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB B110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 40B0
070: 0000 0000 0000 0000 0000 001F 950E 00C6 016C 004C
080: 03F8 0028 7469 7D09 6163 7469 BC09 6163 207F 0000
090: 0000 00FE 0000 0000 0000 0000 0000 0000 0000 0000
100: 32B0 1DCF 0000 0000 0000 0008 6003 0000 500A 0751
110: 0E32 4471 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0000 4D55
130: 3031 2E30 342E 5330 0000 0000 0000 3236 3231 2020
140: 2020 3130 524E 3234 3431 2020 2020 4D54 4644 4441
150: 4B32 3536 4D42 4720 0000 0000 0000 0000 0001 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0001
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 0035 0000 0000 4000
210: 0000 0000 0000 0001 0000 0000 0000 0001 0000 0000
220: 0000 0000 107F 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 00FF 0000 0000 0000 0000
240: 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 4AA5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 2F 00 64 64 00 00 00 00 00 00 00 05 33
010: 00 64 64 00 00 00 00 00 00 00 09 32 00 64 64 78
020: 01 00 00 00 00 00 0C 32 00 64 64 93 00 00 00 00
030: 00 00 AB 32 00 64 64 00 00 00 00 00 00 00 AC 32
040: 00 64 64 00 00 00 00 00 00 00 AD 32 00 64 64 0F
050: 00 00 00 00 00 00 AE 32 00 64 64 09 00 00 00 00
060: 00 00 B4 33 00 00 00 6F 08 00 00 00 00 65 B7 32
070: 00 64 64 00 00 00 00 00 00 00 B8 32 00 64 64 00
080: 00 00 00 00 00 00 BB 32 00 64 64 00 00 00 00 00
090: 00 00 C2 22 00 4D 3B 17 00 11 00 29 00 00 C4 32
0A0: 00 64 64 00 00 00 00 00 00 00 C5 32 00 64 64 00
0B0: 00 00 00 00 00 00 C6 30 00 64 64 00 00 00 00 00
0C0: 00 00 C7 32 00 64 64 05 00 00 00 00 00 00 CA 31
0D0: 00 64 64 00 00 00 00 00 00 00 CE 0E 00 64 64 00
0E0: 00 00 00 00 00 00 D2 32 00 64 64 00 00 00 00 00
0F0: 00 2D F6 32 00 64 64 B6 98 3F 6D 01 00 00 F7 32
100: 00 64 64 7A 69 72 0B 00 00 00 F8 32 00 64 64 CA
110: 24 53 04 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 80 00 A6 04 00 7B
170: 03 00 01 00 02 03 03 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 00 00 00 00 00 00 00 00 00 00 00 05 00
010: 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00
020: 00 00 00 00 00 00 0C 00 00 00 00 00 00 00 00 00
030: 00 00 AB 00 00 00 00 00 00 00 00 00 00 00 AC 00
040: 00 00 00 00 00 00 00 00 00 00 AD 00 00 00 00 00
050: 00 00 00 00 00 00 AE 00 00 00 00 00 00 00 00 00
060: 00 00 B4 00 00 00 00 00 00 00 00 00 00 00 B7 00
070: 00 00 00 00 00 00 00 00 00 00 B8 00 00 00 00 00
080: 00 00 00 00 00 00 BB 00 00 00 00 00 00 00 00 00
090: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C4 00
0A0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00
0B0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00
0C0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 CA 00
0D0: 00 00 00 00 00 00 00 00 00 00 CE 00 00 00 00 00
0E0: 00 00 00 00 00 00 D2 00 00 00 00 00 00 00 00 00
0F0: 00 00 F6 00 00 00 00 00 00 00 00 00 00 00 F7 00
100: 00 00 00 00 00 00 00 00 00 00 F8 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E
(2) CT250BX100SSD1
Model : CT250BX100SSD1
Firmware : MU01
Serial Number : 1504F002219F
Disk Size : 250,0 GB (8,4/137,4/250,0/250,0)
Queue Depth : 32
# of Sectors : 488397168
Minor Version : ----
Power On Hours : 49 Std.
Power On Count : 120 mal
Health Status : Gut
Features : S.M.A.R.T., 48bit LBA, NCQ, TRIM, DevSleep
APM Level : ----
AAM Level : ----
09 100 100 __0 000000000031 Betriebsstunden
0C 100 100 __0 000000000078 Geräte-Einschaltvorgänge
A0 100 100 __0 000000000000 Herstellerspezifisch
A1 100 100 __0 000000000042 Herstellerspezifisch
A3 100 100 __0 000000000019 Herstellerspezifisch
A4 100 100 __0 000000001121 Herstellerspezifisch
A5 100 100 __0 00000000000D Herstellerspezifisch
A6 100 100 __0 000000000000 Herstellerspezifisch
A7 100 100 __0 000000000002 Herstellerspezifisch
A8 100 100 __0 0000000007D0 Herstellerspezifisch
A9 100 100 __0 000000000064 Herstellerspezifisch
AF 100 100 __0 000000000000 Herstellerspezifisch
B0 100 100 __0 000000000000 Herstellerspezifisch
B1 100 100 _50 000000000000 Herstellerspezifisch
B2 100 100 __0 000000000000 Herstellerspezifisch
B5 100 100 __0 000000000000 Herstellerspezifisch
B6 100 100 __0 000000000000 Herstellerspezifisch
C0 100 100 __0 000000000004 Unsachgemäße Ausschaltung
C2 100 100 __0 000000000017 Temperatur
C3 100 100 __0 0000000002F4 Herstellerspezifisch
C4 100 100 _16 000000000000 Wiederzuweisungsereignisse
C6 100 100 __0 000000000000 Nicht korrigierbare Sektoren
C7 100 100 _50 000000000000 Herstellerspezifisch
E8 100 100 __0 000000000064 Herstellerspezifisch
F1 100 100 __0 0000000060E7 Host-Schreibvorgänge (gesamt)
F2 100 100 __0 00000000A908 Host-Lesevorgänge (gesamt)
F5 100 100 __0 000000008908 Herstellerspezifisch
0 1 2 3 4 5 6 7 8 9
000: 0040 3FFF C837 0010 0000 0000 003F FFFF FF0F 0000
010: 3135 3034 4630 3032 3231 3946 2020 2020 2020 2020
020: 0000 0000 0000 4D55 3031 2020 2020 4354 3235 3042
030: 5831 3030 5353 4431 2020 2020 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8002 4000 2F00
050: 4000 0000 0000 0007 3FFF 0010 003F FC10 00FB 9102
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 4D20
070: 0000 0000 0000 0000 0000 001F 870E 0086 054C 004C
080: 03F0 0000 746B 7D01 4163 7469 BC01 4163 207F 0002
090: 0002 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 5970 1D1C 0000 0000 0000 0008 4000 0000 500A 0751
110: F002 219F 0000 0000 0000 0000 0000 0100 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0001
200: 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000
230: 0000 0000 0000 0000 0001 0200 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 BCA5
000: 01 00 01 00 00 64 64 00 00 00 00 00 00 00 05 00
010: 00 64 64 00 00 00 00 00 00 00 09 00 00 64 64 31
020: 00 00 00 00 00 00 0C 00 00 64 64 78 00 00 00 00
030: 00 00 A0 00 00 64 64 00 00 00 00 00 00 00 A1 00
040: 00 64 64 42 00 00 00 00 00 00 A3 00 00 64 64 19
050: 00 00 00 00 00 00 A4 00 00 64 64 21 11 00 00 00
060: 00 00 A5 00 00 64 64 0D 00 00 00 00 00 00 A6 00
070: 00 64 64 00 00 00 00 00 00 00 A7 00 00 64 64 02
080: 00 00 00 00 00 00 A8 00 00 64 64 D0 07 00 00 00
090: 00 00 A9 00 00 64 64 64 00 00 00 00 00 00 AF 00
0A0: 00 64 64 00 00 00 00 00 00 00 B0 00 00 64 64 00
0B0: 00 00 00 00 00 00 B1 00 00 64 64 00 00 00 00 00
0C0: 00 00 B2 00 00 64 64 00 00 00 00 00 00 00 B5 00
0D0: 00 64 64 00 00 00 00 00 00 00 B6 00 00 64 64 00
0E0: 00 00 00 00 00 00 C0 00 00 64 64 04 00 00 00 00
0F0: 00 00 C2 00 00 64 64 17 00 00 00 00 00 00 C3 00
100: 00 64 64 F4 02 00 00 00 00 00 C4 00 00 64 64 00
110: 00 00 00 00 00 00 C5 00 00 64 64 00 00 00 00 00
120: 00 00 C6 00 00 64 64 00 00 00 00 00 00 00 C7 00
130: 00 64 64 00 00 00 00 00 00 00 E8 00 00 64 64 64
140: 00 00 00 00 00 00 F1 00 00 64 64 E7 60 00 00 00
150: 00 00 F2 00 00 64 64 08 A9 00 00 00 00 00 F5 00
160: 00 64 64 08 89 00 00 00 00 00 00 00 00 00 00 71
170: 02 00 01 00 02 0A 02 00 00 00 00 00 00 00 00 00
180: 00 00 4D 55 30 31 20 20 20 20 00 00 00 00 00 00
190: 53 4D 32 32 34 36 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70
000: 01 00 01 00 00 00 00 00 00 00 00 00 00 00 05 00
030: 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 A1 00
040: 00 00 00 00 00 00 00 00 00 00 A3 00 00 00 00 00
050: 00 00 00 00 00 00 A4 00 00 00 00 00 00 00 00 00
060: 00 00 A5 00 00 00 00 00 00 00 00 00 00 00 A6 00
070: 00 00 00 00 00 00 00 00 00 00 A7 00 00 00 00 00
080: 00 00 00 00 00 00 A8 00 00 00 00 00 00 00 00 00
090: 00 00 A9 00 00 00 00 00 00 00 00 00 00 00 AF 00
0A0: 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00
0B0: 00 00 00 00 00 00 B1 32 00 00 00 00 00 00 00 00
0C0: 00 00 B2 00 00 00 00 00 00 00 00 00 00 00 B5 00
0D0: 00 00 00 00 00 00 00 00 00 00 B6 00 00 00 00 00
0E0: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00
0F0: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C3 00
100: 00 00 00 00 00 00 00 00 00 00 C4 10 00 00 00 00
110: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00
120: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 32
130: 00 00 00 00 00 00 00 00 00 00 E8 00 00 00 00 00
140: 00 00 00 00 00 00 F1 00 00 00 00 00 00 00 00 00
150: 00 00 F2 00 00 00 00 00 00 00 00 00 00 00 F5 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5D
Auf der System SSD sind 5 UDMA CRC Fehler protokolliert (C7 100 100 __0 000000000005 UltraDMA-CRC-Fehler).
Dies wäre durchaus eine mögliche Fehlerquelle.
Die UDMA CRC Fehler treten regelmäßig durch lockere/defekte Datenkabel auf.
Ich würde daher vorschlagen, das Datenkabel (SATA) der System-SSD (Laufwerk C) auszutauschen. Kontrolliere anschließend den Wert, insbes. nach einem weiteren Absturz.
Der Wert 00005 darf nach dem Kabeltausch nicht weiter ansteigen.
Des weiteren gibt es für beide SSDs eine aktuellere Firmware (MU02). Sollten die Probleme nach dem Kabeltausch bleiben, wäre ein Firmware Update anzuraten.
Version MU02 includes the following changes:
  • Improved stability, Efficiency, and Performance during power state transitions
  • Improved handling of environments with unstable power supplies
  • Improved handling of environments with SATA interface signal integrity issues
  • Improved response time for SMART read commands
  • Corrected error handling NCQ Trim Commands
  • Corrected reporting of SMART Attribute 5
Okey werde ich mal austauschen. Danke für deine Hilfe.
Edit: Der letzte Bluescreen vor dem Kabeltausch von heute morgen:
Loading Dump File [C:\Windows\Minidump\061615-4281-01.dmp]
Machine Name:
Kernel base = 0xfffff802`9cc0a000 PsLoadedModuleList = 0xfffff802`9cee3850
Debug session time: Tue Jun 16 12:31:45.497 2015 (UTC + 2:00)
System Uptime: 0 days 13:33:59.156
BugCheck 1000007E, {ffffffffc0000005, fffff8029cd3118a, ffffd000ec4a95c8, ffffd000ec4a8dd0}
Probably caused by : memory_corruption ( nt!MiDemoteCombinedPte+42 )
0: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8029cd3118a, The address that the exception occurred at
Arg3: ffffd000ec4a95c8, Exception Record Address
Arg4: ffffd000ec4a8dd0, Context Record Address
Debugging Details:
FAULTING_IP:
fffff802`9cd3118a 49394520 cmp qword ptr [r13+20h],rax
EXCEPTION_RECORD: ffffd000ec4a95c8 -- (.exr 0xffffd000ec4a95c8)
ExceptionAddress: fffff8029cd3118a (nt!MiDemoteCombinedPte+0x0000000000000042)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT: ffffd000ec4a8dd0 -- (.cxr 0xffffd000ec4a8dd0;r)
rax=0000000000000001 rbx=0000000000000000 rcx=fffff6bffcf2bc30
rdx=8000000000000000 rsi=fffff6bffcf2bc30 rdi=fffff58010806120
rip=fffff8029cd3118a rsp=ffffd000ec4a9800 rbp=ffffe00187cdcd98
r8=8000000000000000 r9=0000000000000013 r10=0000000000000014
r11=0000000000000013 r12=fffff6bffcf2bc30 r13=7fffffffffffffd0
r14=ffffd000ec4a9930 r15=fffff58010804000
iopl=0 nv up ei ng nz na pe nc
cs=0010 ss=0000 ds=002b es=002b fs=0053 gs=002b efl=00010282
nt!MiDemoteCombinedPte+0x42:
fffff802`9cd3118a 49394520 cmp qword ptr [r13+20h],rax ds:002b:7fffffff`fffffff0=????????????????
Last set context:
PROCESS_NAME: lsass.exe
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8029cf6d138
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
ffffffffffffffff
FOLLOWUP_IP:
BUGCHECK_STR: AV
LAST_CONTROL_TRANSFER: from fffff8029cdbe893 to fffff8029cd3118a
STACK_TEXT:
ffffd000`ec4a9800 fffff802`9cdbe893 : 00000000`00000001 ffffe001`87cdcd98 00000000`00000000 fffff580`108060d8 : nt!MiDemoteCombinedPte+0x42
ffffd000`ec4a98f0 fffff802`9cc72528 : ffffe001`87cdcd98 ffffe001`87cdcd98 00000000`00000000 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0x536d3
ffffd000`ec4a9a30 fffff802`9cc72020 : 00000000`00000000 ffffd000`ec4a9af9 ffffe001`87cdcd98 00000000`00000000 : nt!MiTrimOrAgeWorkingSet+0x200
ffffd000`ec4a9a70 fffff802`9cc351aa : 00000000`00000000 ffffe001`83ac0040 00000000`00000001 ffffe001`83ac0040 : nt!MiProcessWorkingSets+0x1c8
ffffd000`ec4a9b60 fffff802`9cd414bf : 00000000`00000008 ffffd000`ec4a9bd0 00000000`00000008 00000000`00000000 : nt!MmWorkingSetManager+0x4a
ffffd000`ec4a9b90 fffff802`9cd0a36c : ffffe001`83ac0040 8948e145`894877fa 00000000`00000080 00149238`058b48f3 : nt!KeBalanceSetManager+0x1b3
ffffd000`ec4a9c00 fffff802`9cd612c6 : ffffd000`f0bc6180 ffffe001`83ac0040 ffffd000`f0bd22c0 d68b483a`4f8d48c6 : nt!PspSystemThreadStartup+0x58
ffffd000`ec4a9c60 00000000`00000000 : ffffd000`ec4aa000 ffffd000`ec4a4000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
SYMBOL_NAME: nt!MiDemoteCombinedPte+42
MODULE_NAME: nt
STACK_COMMAND: .cxr 0xffffd000ec4a8dd0 ; kb
IMAGE_NAME: memory_corruption
BUCKET_ID_FUNC_OFFSET: 42
FAILURE_BUCKET_ID: AV_nt!MiDemoteCombinedPte
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:av_nt!midemotecombinedpte
FAILURE_ID_HASH: {c577c73b-79a7-0c44-6c62-58e1d697b6d8}
Memory Corruption durch Speicherzugriffsverletzung.
Schau bitte gleich nochmal in den SMART Werten nach, ob sich der UDMA CRC Fehlerwert erhöht hat.
Ist auf 5 geblieben, keine Änderung.
Date : 2015/06/16 14:23:11
- CT250BX100SSD1
Firmware : MU01
Queue Depth : 32
Power On Hours : 377 Std.
Power On Count : 151 mal
Host Writes : 2927 GB
Temperature : 35 C (95 F)
AAM Level : ----
09 100 100 __0 000000000179 Betriebsstunden
0C 100 100 __0 000000000097 Geräte-Einschaltvorgänge
AE 100 100 __0 00000000000A Unerwartete Spannungsabfälle
C2 _65 _59 __0 002900110023 Gehäusetemperatur
F6 100 100 __0 00016DFBD97F Gelesene Host-Sektoren (gesamt)
F7 100 100 __0 00000B7852A0 Host-Programmseiten
F8 100 100 __0 000004578E5D Hintergrund-Programmseiten
0 1 2 3 4 5 6 7 8 9
010: 00 64 64 00 00 00 00 00 00 00 09 32 00 64 64 79
020: 01 00 00 00 00 00 0C 32 00 64 64 97 00 00 00 00
050: 00 00 00 00 00 00 AE 32 00 64 64 0A 00 00 00 00
090: 00 00 C2 22 00 41 3B 23 00 11 00 29 00 00 C4 32
0F0: 00 2D F6 32 00 64 64 7F D9 FB 6D 01 00 00 F7 32
100: 00 64 64 A0 52 78 0B 00 00 00 F8 32 00 64 64 5D
110: 8E 57 04 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 32
(2) CT250BX100SSD1
Firmware : MU01
Queue Depth : 32
Power On Hours : 50 Std.
Power On Count : 124 mal
Temperature : 28 C (82 F)
Health Status : Gut
APM Level : ----
AAM Level : ----
09 100 100 __0 000000000032 Betriebsstunden
0C 100 100 __0 00000000007C Geräte-Einschaltvorgänge
C2 100 100 __0 00000000001C Temperatur
F1 100 100 __0 0000000060E8 Host-Schreibvorgänge (gesamt)
F2 100 100 __0 00000000A9AC Host-Lesevorgänge (gesamt)
0 1 2 3 4 5 6 7 8 9
010: 00 64 64 00 00 00 00 00 00 00 09 00 00 64 64 32
020: 00 00 00 00 00 00 0C 00 00 64 64 7C 00 00 00 00
0F0: 00 00 C2 00 00 64 64 1C 00 00 00 00 00 00 C3 00
140: 00 00 00 00 00 00 F1 00 00 64 64 E8 60 00 00 00
150: 00 00 F2 00 00 64 64 AC A9 00 00 00 00 00 F5 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C1
Mal wieder ein neuer Bluescreen.
Loading Dump File [C:\Windows\Minidump\061715-3718-01.dmp]
Machine Name:
Kernel base = 0xfffff801`8be0e000 PsLoadedModuleList = 0xfffff801`8c0e7850
Debug session time: Wed Jun 17 15:21:22.104 2015 (UTC + 2:00)
System Uptime: 1 days 2:19:32.763
BugCheck 3B, {c0000005, fffff960000d6c61, ffffd000270b4040, 0}
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : win32k.sys ( win32k+6dc61 )
1: kd> !analyze -v
Arguments:
Arg2: fffff960000d6c61, Address of the instruction which caused the bugcheck
Arg3: ffffd000270b4040, Address of the context record for the exception that caused the bugcheck
Debugging Details:
FAULTING_IP:
win32k+6dc61
fffff960`000d6c61 48a3ec40498bf04c8bfa mov qword ptr [FA8B4CF08B4940ECh],rax
CONTEXT: ffffd000270b4040 -- (.cxr 0xffffd000270b4040;r)
rax=00007fffffff0000 rbx=000000665d18e080 rcx=00007ffae0894350
rdx=00007ffae0600000 rsi=00007ffae0600000 rdi=000000665d18e0a8
rip=fffff960000d6c61 rsp=ffffd000270b4a70 rbp=ffffd000270b4b80
r8=ffffd000270b4ad8 r9=0000000000000000 r10=fffff960000d6de0
r11=ffffd000270b4a30 r12=000000000000099c r13=0000000000000000
r14=00007ffae0600000 r15=00007ffae0601100
win32k+0x6dc61:
fffff960`000d6c61 48a3ec40498bf04c8bfa mov qword ptr [FA8B4CF08B4940ECh],rax ds:002b:fa8b4cf0`8b4940ec=????????????????
Last set context:
win32k+0x6dc61:
BUGCHECK_STR: 0x3B
PROCESS_NAME: svchost.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 00007ffae0601100 to fffff960000d6c61
STACK_TEXT:
ffffd000`270b4a70 00007ffa`e0601100 : 00007ffa`e0600000 00000066`5d18e0a8 00007ffa`e0600000 00000066`5d18e080 : win32k+0x6dc61
ffffd000`270b4a78 00007ffa`e0600000 : 00000066`5d18e0a8 00007ffa`e0600000 00000066`5d18e080 fffff960`000d6e83 : 0x00007ffa`e0601100
ffffd000`270b4a80 00000066`5d18e0a8 : 00007ffa`e0600000 00000066`5d18e080 fffff960`000d6e83 ffffe001`bceb2080 : 0x00007ffa`e0600000
ffffd000`270b4a88 00007ffa`e0600000 : 00000066`5d18e080 fffff960`000d6e83 ffffe001`bceb2080 00007ffa`e0600000 : 0x00000066`5d18e0a8
ffffd000`270b4a90 00000066`5d18e080 : fffff960`000d6e83 ffffe001`bceb2080 00007ffa`e0600000 ffffd000`270b4ad8 : 0x00007ffa`e0600000
ffffd000`270b4a98 fffff960`000d6e83 : ffffe001`bceb2080 00007ffa`e0600000 ffffd000`270b4ad8 00000000`00000000 : 0x00000066`5d18e080
ffffd000`270b4aa0 ffffe001`bceb2080 : 00007ffa`e0600000 ffffd000`270b4ad8 00000000`00000000 00000000`00000020 : win32k+0x6de83
ffffd000`270b4aa8 00007ffa`e0600000 : ffffd000`270b4ad8 00000000`00000000 00000000`00000020 fffff801`00220020 : 0xffffe001`bceb2080
ffffd000`270b4ab0 ffffd000`270b4ad8 : 00000000`00000000 00000000`00000020 fffff801`00220020 00007ffa`e0894350 : 0x00007ffa`e0600000
ffffd000`270b4ab8 00000000`00000000 : 00000000`00000020 fffff801`00220020 00007ffa`e0894350 00000000`00000000 : 0xffffd000`270b4ad8
FOLLOWUP_IP:
win32k+6dc61
SYMBOL_NAME: win32k+6dc61
MODULE_NAME: win32k
IMAGE_NAME: win32k.sys
STACK_COMMAND: .cxr 0xffffd000270b4040 ; kb
FAILURE_BUCKET_ID: 0x3B_win32k+6dc61
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x3b_win32k+6dc61
FAILURE_ID_HASH: {ad701ee0-d495-cee0-9a8a-0e61042331d8}
Werde dann heute mal versuchen das Firmeware Update zu bekommen.
Sofern auch das Firmware Update keine Besserung bringt...hättest du die Möglichkeit einen anderen RAM Riegel zu testen (z.B. von einem Bekannten), um Kompatibilitätsprobleme (Mobo - RAM) ausschließen zu können?
Muss ich mal schauen. Nen Kumpel sollte den gleichen haben wie ich müsste mal Fragen ob er mit den gibt..
Bluescreens kommen trotz Updates beim Starten.
Hab jetzt von nem Kumpel welche eingebaut und bisher keine Bluescreens bekommen.
Aber war auch schon ab und zu so dass ich mal einen Tag lang keine hatte. Werde es mal weiter beobachten!
Danke dir für deine ausfühliche Hilfe!
Alles funktioniert.. Scheint echt am RAM zu liegen.
Soll ich dann einfach die gleichen nehmen wie mein Kumpel hat oder hast andere zu empfehlen?
Wenn der vom Kumpel einwandfrei läuft, wäre das ja schonmal ein RAM, der in die engere Wahl kommt.
Ansonsten muss ich dir ehrlich sagen, dass ich selbst immer den günstigsten RAM kaufe und primär nicht auf irgendwelche Kompatibilitätslisten schaue. Gibt es Probleme habe ich auch immer Reserve RAM zum gegentesten zur Hand. Die Kompatibilitätslisten des Motherboardherstellers werden i.d.R. auch nicht aktualiesiert, so dass hier nur älterer RAM gelistet ist, den es ggf. im Handel schon nicht mehr gibt.
Zurück zum RAM vom Kumpel. Ist bei CPU-Z (Reiter SPD), das Herstellungsdatum zu sehen? Wenn ja, sind die RAM noch (relativ) neu?
Wenn die schon ein paar Jahre auf dem Buckel haben ist nämlich nicht sichergestellt, dass genau diese RAM immer noch mit den gleichen Speicherchips verbaut werden. Soll heißen, auch wenn du die gleichen RAM kaufst, können theoretisch Probleme auftreten.
Ich würde mir daher die günstigsten RAM kaufen (1600mhz oder 1866mhz RAM) und testen, ob die fehlerfrei laufen. Wenn nicht zurück schicken und anderen RAM testen.
z.B.
Crucial Ballistix Sport DIMM Kit 8GB, DDR3-1600, CL9-9-9-24 (BLS2CP4G3D1609DS1S00) Preisvergleich | Geizhals Deutschland oder
Kingston HyperX FURY schwarz DIMM Kit 8GB, DDR3-1866, CL10 (HX318C10FBK2/8) Preisvergleich | Geizhals Deutschland
