Bluescreen, ntkrnlmp.exe
  • Ersteller Ersteller jo-ker
  • Erstellt am Erstellt am
J
jo-ker
Guest
seit gestern hab ich ziemlich häufig einen Bluescreen. Vorher noch nie.
Manchmal kommt der Bluescreen aller 5 Minuten und manchmal erst nach 2 Stunden. Hab dann mal den Log debugged. Dabei ist das zu sehen:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*C:\Symbols*Symbol information
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 6002.18209.amd64fre.vistasp2_gdr.100218-0019
Machine Name:
Kernel base = 0xfffff800`0285c000 PsLoadedModuleList = 0xfffff800`02a20dd0
Debug session time: Sat May 1 13:02:25.887 2010 (GMT+2)
System Uptime: 0 days 0:05:14.635
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000007ff`fffd4018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {fffff4e0084d6f74, 2, 0, fffff800028ade10}
Page 8c20c not present in the dump file. Type ".hh dbgerr004" for details
Probably caused by : ntkrnlmp.exe ( nt!KiPageFault+20b )
Followup: MachineOwner
3: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffff4e0084d6f74, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff800028ade10, address which referenced memory
Debugging Details:
READ_ADDRESS: fffff4e0084d6f74
CURRENT_IRQL: 2
FAULTING_IP:
nt!memcpy+b0
fffff800`028ade10 488b040a mov rax,qword ptr [rdx+rcx]
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: svchost.exe
TRAP_FRAME: fffffa60065e8620 -- (.trap 0xfffffa60065e8620)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=000000004f5e8ccb rbx=0000000000000000 rcx=fffffa60065e8804
rdx=fffffa8001eee770 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800028ade10 rsp=fffffa60065e87b8 rbp=0000000000000000
r8=0000000000000030 r9=0000000000000001 r10=0000058000000000
r11=fffffa60065e8830 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe cy
nt!memcpy+0xb0:
fffff800`028ade10 488b040a mov rax,qword ptr [rdx+rcx] ds:6650:6f74=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff800028b626e to fffff800028b64d0
STACK_TEXT:
fffffa60`065e84d8 fffff800`028b626e : 00000000`0000000a fffff4e0`084d6f74 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffffa60`065e84e0 fffff800`028b514b : 00000000`00000000 fffffa60`065e86a0 fffff880`00956000 fffffa80`0863fb02 : nt!KiBugCheckDispatch+0x6e
fffffa60`065e8620 fffff800`028ade10 : fffff800`0293d903 fffffa80`05414000 00000000`000018c0 00000000`00000000 : nt!KiPageFault+0x20b
fffffa60`065e87b8 fffff800`0293d903 : fffffa80`05414000 00000000`000018c0 00000000`00000000 fffff800`029ee160 : nt!memcpy+0xb0
fffffa60`065e87c0 fffff800`0295866c : 00000000`000a4f7c fffffa80`05414340 fffffa80`0863fbb0 00000000`00000000 : nt!MiIdentifyPfn+0x43
fffffa60`065e8860 fffff800`02c49a05 : fffffa80`05414000 fffffa60`065e8ca0 fffffa60`065e8928 00000000`00000000 : nt!MmQueryPfnList+0x13c
fffffa60`065e88a0 fffff800`02b8eb3c : 00000000`00000000 00000000`00000000 fffffa80`05414000 00000000`0487ff01 : nt!PfpPfnPrioRequest+0x115
fffffa60`065e88f0 fffff800`02b2697b : 00000000`00000000 00000000`0487fff0 00000000`038de710 fffffa60`065e8901 : nt! ?? ::NNGAKEGL::`string'+0x4a26a
fffffa60`065e8960 fffff800`028b5f73 : fffffa80`0863fbb0 00000000`0487fff0 00000000`00000000 00000000`00000000 : nt!NtQuerySystemInformation+0xe4b
fffffa60`065e8c20 00000000`77a6707a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`038de668 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77a6707a
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!KiPageFault+20b
fffff800`028b514b 488b0506e31c00 mov rax,qword ptr [nt!KiInterlockedPopEntrySListResumeEntryPoint (fffff800`02a83458)]
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: nt!KiPageFault+20b
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4b7d238f
FAILURE_BUCKET_ID: X64_0xA_nt!KiPageFault+20b
3: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 2
FAULTING_IP:
nt!memcpy+b0
BUGCHECK_STR: 0xA
nt!memcpy+0xb0:
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!KiPageFault+20b
MODULE_NAME: nt
3: kd> lmp
start end module name
fffff800`02816000 fffff800`0285c000 hal <none>
fffff800`0285c000 fffff800`02d73000 nt <none>
fffff960`00090000 fffff960`00344000 win32k <none>
fffff960`004c0000 fffff960`004ca000 TSDDD <none>
fffff960`006b0000 fffff960`006c1000 cdd <none>
fffff960`00850000 fffff960`008b1000 ATMFD <none>
fffffa60`00603000 fffffa60`0060d000 kdcom <none>
fffffa60`0060d000 fffffa60`00648000 mcupdate_GenuineIntel <none>
fffffa60`00648000 fffffa60`0065c000 PSHED <none>
fffffa60`0065c000 fffffa60`006b9000 CLFS <none>
fffffa60`006b9000 fffffa60`0076b000 CI <none>
fffffa60`0076b000 fffffa60`007af000 mv61xx <none>
fffffa60`007af000 fffffa60`007f6000 fltmgr <none>
fffffa60`00808000 fffffa60`008e2000 Wdf01000 <none>
fffffa60`008e2000 fffffa60`008f0000 WDFLDR <none>
fffffa60`008f0000 fffffa60`00905000 partmgr <none>
fffffa60`00905000 fffffa60`00919000 volmgr <none>
fffffa60`00919000 fffffa60`0097f000 volmgrx <none>
fffffa60`0097f000 fffffa60`00986000 pciide <none>
fffffa60`00986000 fffffa60`00996000 PCIIDEX <none>
fffffa60`00996000 fffffa60`009a9000 mountmgr <none>
fffffa60`009a9000 fffffa60`009b1000 atapi <none>
fffffa60`009b1000 fffffa60`009d5000 ataport <none>
fffffa60`009d5000 fffffa60`009e9000 fileinfo <none>
fffffa60`009e9000 fffffa60`009fc000 monitor <none>
fffffa60`00a01000 fffffa60`00b35000 sptd <none>
fffffa60`00b35000 fffffa60`00b3e000 WMILIB <none>
fffffa60`00b3e000 fffffa60`00b6c000 SCSIPORT <none>
fffffa60`00b6c000 fffffa60`00bc2000 acpi <none>
fffffa60`00bc2000 fffffa60`00bcc000 msisadrv <none>
fffffa60`00bcc000 fffffa60`00bfc000 pci <none>
fffffa60`00c02000 fffffa60`00c89000 ksecdd <none>
fffffa60`00c89000 fffffa60`00cd9000 msrpc <none>
fffffa60`00cd9000 fffffa60`00d32000 NETIO <none>
fffffa60`00d3a000 fffffa60`00d48000 ATITool64 <none>
fffffa60`00d48000 fffffa60`00d55000 tunnel <none>
fffffa60`00d55000 fffffa60`00d5e000 tunmp <none>
fffffa60`00d5e000 fffffa60`00d71000 intelppm <none>
fffffa60`00d71000 fffffa60`00dd6000 yk60x64 <none>
fffffa60`00dd6000 fffffa60`00df2000 cdrom <none>
fffffa60`00e03000 fffffa60`00fc6000 ndis <none>
fffffa60`00fc6000 fffffa60`00ff2000 CLASSPNP <none>
fffffa60`00ff2000 fffffa60`00ffe000 Dxapi <none>
fffffa60`01000000 fffffa60`0100c000 dump_dumpata <none>
fffffa60`0100c000 fffffa60`01182000 tcpip <none>
fffffa60`01182000 fffffa60`011ae000 fwpkclnt <none>
fffffa60`011ae000 fffffa60`011c0000 mup <none>
fffffa60`011c0000 fffffa60`011ec000 ecache <none>
fffffa60`011ec000 fffffa60`01200000 disk <none>
fffffa60`01203000 fffffa60`01383000 Ntfs <none>
fffffa60`01383000 fffffa60`013c7000 volsnap <none>
fffffa60`013c7000 fffffa60`013cf000 spldr <none>
fffffa60`013cf000 fffffa60`013d6000 speedfan <none>
fffffa60`013d6000 fffffa60`013f1000 sbp2port <none>
fffffa60`013f1000 fffffa60`013fb000 crcdisk <none>
fffffa60`0220b000 fffffa60`022ee000 dxgkrnl <none>
fffffa60`022ee000 fffffa60`022fe000 watchdog <none>
fffffa60`022fe000 fffffa60`023eb000 HDAudBus <none>
fffffa60`023eb000 fffffa60`023f7000 usbuhci <none>
fffffa60`023f7000 fffffa60`023ff000 ASACPI <none>
fffffa60`03402000 fffffa60`03946000 atikmdag <none>
fffffa60`03946000 fffffa60`0398c000 USBPORT <none>
fffffa60`0398c000 fffffa60`0399d000 usbehci <none>
fffffa60`0399d000 fffffa60`039aeb00 ohci1394 <none>
fffffa60`039af000 fffffa60`039bef00 1394BUS <none>
fffffa60`039bf000 fffffa60`039cc000 fdc <none>
fffffa60`039cc000 fffffa60`039e9000 serial <none>
fffffa60`039e9000 fffffa60`039f5000 serenum <none>
fffffa60`03a05000 fffffa60`03a5a000 awk6jhaz <none>
fffffa60`03a5a000 fffffa60`03a93000 msiscsi <none>
fffffa60`03a93000 fffffa60`03af0000 storport <none>
fffffa60`03af0000 fffffa60`03afd000 TDI <none>
fffffa60`03afd000 fffffa60`03b20000 rasl2tp <none>
fffffa60`03b20000 fffffa60`03b2c000 ndistapi <none>
fffffa60`03b2c000 fffffa60`03b5d000 ndiswan <none>
fffffa60`03b5d000 fffffa60`03b6d000 raspppoe <none>
fffffa60`03b6d000 fffffa60`03b8b000 raspptp <none>
fffffa60`03b8b000 fffffa60`03ba3000 rassstp <none>
fffffa60`03ba3000 fffffa60`03bab000 PdiPorts <none>
fffffa60`03bab000 fffffa60`03bbe000 termdd <none>
fffffa60`03bbe000 fffffa60`03bcc000 kbdclass <none>
fffffa60`03bcc000 fffffa60`03bd8000 mouclass <none>
fffffa60`03bd8000 fffffa60`03bd9480 swenum <none>
fffffa60`03bda000 fffffa60`03bf6000 cdfs <none>
fffffa60`03c07000 fffffa60`03c3b000 ks <none>
fffffa60`03c3b000 fffffa60`03c3fc80 WmBEnum <none>
fffffa60`03c40000 fffffa60`03c51100 WmXlCore <none>
fffffa60`03c52000 fffffa60`03c5d000 mssmbios <none>
fffffa60`03c5d000 fffffa60`03c6d000 umbus <none>
fffffa60`03c6d000 fffffa60`03cb5000 usbhub <none>
fffffa60`03cb5000 fffffa60`03cc0000 flpydisk <none>
fffffa60`03cc0000 fffffa60`03cd4000 NDProxy <none>
fffffa60`03cd4000 fffffa60`03d1d000 HdAudio <none>
fffffa60`03d1d000 fffffa60`03d58000 portcls <none>
fffffa60`03d58000 fffffa60`03d7b000 drmk <none>
fffffa60`03d7b000 fffffa60`03d80180 ksthunk <none>
fffffa60`03d81000 fffffa60`03df8000 ADIHdAud <none>
fffffa60`04800000 fffffa60`04808000 dump_atapi <none>
fffffa60`0480a000 fffffa60`04837000 MpFilter <none>
fffffa60`04837000 fffffa60`04841000 Fs_Rec <none>
fffffa60`04841000 fffffa60`0484a000 Null <none>
fffffa60`04855000 fffffa60`0485cb80 HIDPARSE <none>
fffffa60`0485d000 fffffa60`0486b000 vga <none>
fffffa60`0486b000 fffffa60`04890000 VIDEOPRT <none>
fffffa60`04890000 fffffa60`04899000 RDPCDD <none>
fffffa60`04899000 fffffa60`048a2000 rdpencdd <none>
fffffa60`048a2000 fffffa60`048ad000 Msfs <none>
fffffa60`048ad000 fffffa60`048be000 Npfs <none>
fffffa60`048be000 fffffa60`048c7000 rasacd <none>
fffffa60`048c7000 fffffa60`048e4000 tdx <none>
fffffa60`048e4000 fffffa60`048ff000 smb <none>
fffffa60`048ff000 fffffa60`0496a000 afd <none>
fffffa60`0496a000 fffffa60`049ae000 netbt <none>
fffffa60`049ae000 fffffa60`049cc000 pacer <none>
fffffa60`049cc000 fffffa60`049db000 netbios <none>
fffffa60`049db000 fffffa60`049e2000 TVicPort64 <none>
fffffa60`049e2000 fffffa60`049fd000 wanarp <none>
fffffa60`04a07000 fffffa60`04a54000 rdbss <none>
fffffa60`04a54000 fffffa60`04a60000 nsiproxy <none>
fffffa60`04a60000 fffffa60`04a7d000 dfsc <none>
fffffa60`04a7d000 fffffa60`04a84000 AsIO <none>
fffffa60`04a84000 fffffa60`04a8d000 hidusb <none>
fffffa60`04a8d000 fffffa60`04a9f000 HIDCLASS <none>
fffffa60`04a9f000 fffffa60`04aa0e00 USBD <none>
fffffa60`04aa1000 fffffa60`04aa9680 WmFilter <none>
fffffa60`04aaa000 fffffa60`04ac6000 usbccgp <none>
fffffa60`04ac6000 fffffa60`04ad6000 usbscan <none>
fffffa60`04ad6000 fffffa60`04ae1000 usbprint <none>
fffffa60`04ae1000 fffffa60`04af1000 dot4usb <none>
fffffa60`04af1000 fffffa60`04b19000 Dot4 <none>
fffffa60`04b19000 fffffa60`04b31000 USBSTOR <none>
fffffa60`04b31000 fffffa60`04b3b000 Dot4Prt <none>
fffffa60`04b3b000 fffffa60`04bb0000 fwlanusb <none>
fffffa60`04bb0000 fffffa60`04bc3000 LHidFilt <none>
fffffa60`04bc3000 fffffa60`04bce000 kbdhid <none>
fffffa60`04bce000 fffffa60`04bd9000 mouhid <none>
fffffa60`04bd9000 fffffa60`04bed000 LMouFilt <none>
fffffa60`04bed000 fffffa60`04bfb000 crashdmp <none>
fffffa60`05e0b000 fffffa60`05e2d000 luafv <none>
fffffa60`05e2d000 fffffa60`05ec7000 spsys <none>
fffffa60`05ec7000 fffffa60`05edb000 lltdio <none>
fffffa60`05edb000 fffffa60`05f0f000 nwifi <none>
fffffa60`05f0f000 fffffa60`05f1a000 ndisuio <none>
fffffa60`05f1a000 fffffa60`05f32000 rspndr <none>
fffffa60`05f32000 fffffa60`05fd5000 HTTP <none>
fffffa60`05fd5000 fffffa60`05ffe000 srvnet <none>
fffffa60`0680d000 fffffa60`0682b000 bowser <none>
fffffa60`0682b000 fffffa60`06845000 mpsdrv <none>
fffffa60`06845000 fffffa60`0686c000 mrxdav <none>
fffffa60`0686c000 fffffa60`06895000 mrxsmb <none>
fffffa60`06895000 fffffa60`068de000 mrxsmb10 <none>
fffffa60`068de000 fffffa60`068fd000 mrxsmb20 <none>
fffffa60`068fd000 fffffa60`0692f000 srv2 <none>
fffffa60`0692f000 fffffa60`069c4000 srv <none>
fffffa60`06c04000 fffffa60`06c5a000 acedrv11 <none>
fffffa60`06c5a000 fffffa60`06c72000 adfs <none>
fffffa60`06c72000 fffffa60`06c7d000 asyncmac <none>
fffffa60`06c7d000 fffffa60`06d33000 peauth <none>
fffffa60`06d33000 fffffa60`06d3e000 secdrv <none>
fffffa60`06d3e000 fffffa60`06d4e000 tcpipreg <none>
fffffa60`06d4e000 fffffa60`06d5e000 MpNWMon <none>
fffffa60`06d5e000 fffffa60`06d7e000 WUDFRd <none>
fffffa60`06d7e000 fffffa60`06d94000 WUDFPf <none>
fffffa60`06d94000 fffffa60`06d96400 WmVirHid <none>
fffffa60`06d97000 fffffa60`06dcc000 fastfat <none>
Unloaded modules:
fffffa60`00ff2000 fffffa60`01000000 crashdmp.sys
fffffa60`01000000 fffffa60`0100c000 dump_ataport.sys
fffffa60`00d32000 fffffa60`00d3a000 dump_atapi.sys
fffffa60`0484a000 fffffa60`04855000 kbdhid.sys
3: kd> lmp
Unloaded modules:
Also ich kann nur daraus sehen das es irgendtwas mit ntkrnlmp.exe und svchost.exe zu tun haben muss. Also irgendein Vista Treiber. Was sollte ich denn jetzt am besten mach. Oder liegt es an irgendt etwas anderem?
Vielen Dank
jo-ker
Teste zunächst jeden RAM Riegel einzeln mit memtest86+ nach Fehlern.
Kannst du dich daran erinnern, ob du irgendwelche Änderungen am System vorgenommen hast (Hardware, Treiber, Programme)?
Hi,
also ich hab mal 3 Stunden Memtest laufen lassen, hoffe das reicht. Also Fehler hat er keine gefunden. Das letzte was ich Installiert hatte, war Gametap. Scheint also daran zu liegen. Das hab ich dann aber sofort wieder deinstalliert.
Gerade eben ist mein Rechner nochmal abgestürzt. Da hatte sich irgendtwie alles aufgehangen:
Machine Name:
Kernel base = 0xfffff800`0280a000 PsLoadedModuleList = 0xfffff800`029cedd0
Debug session time: Mon May 3 19:17:18.515 2010 (GMT+2)
System Uptime: 0 days 0:02:17.609
PEB is paged out (Peb.Ldr = 000007ff`fffdf018). Type ".hh dbgerr001" for details
BugCheck 101, {31, 0, fffffa6001963180, 2}
*** ERROR: Module load completed but symbols could not be loaded for sptd.sys
*** ERROR: Symbol file could not be found. Defaulted to export symbols for CLASSPNP.SYS -
Page a44d6 not present in the dump file. Type ".hh dbgerr004" for details
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
0: kd> !analyze -v
CLOCK_WATCHDOG_TIMEOUT (101)
An expected clock interrupt was not received on a secondary processor in an
MP system within the allocated interval. This indicates that the specified
processor is hung and not processing interrupts.
Arguments:
Arg1: 0000000000000031, Clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0.
Arg3: fffffa6001963180, The PRCB address of the hung processor.
Arg4: 0000000000000002, 0.
Debugging Details:
BUGCHECK_STR: CLOCK_WATCHDOG_TIMEOUT_4_PROC
PROCESS_NAME: MsMpEng.exe
CURRENT_IRQL: d
STACK_TEXT:
fffff800`03c6a588 fffff800`02820390 : 00000000`00000101 00000000`00000031 00000000`00000000 fffffa60`01963180 : nt!KeBugCheckEx
fffff800`03c6a590 fffff800`0285ddca : fffff800`02d4e3c0 fffff800`03c6a6b0 fffffa80`07e73010 fffff800`02d4e3c0 : nt! ?? ::FNODOBFM::`string'+0x2de4
fffff800`03c6a5d0 fffff800`02d2bf04 : fffffa80`0677c3d8 00000000`0000000b fffffa80`06139000 fffffa80`06806100 : nt!KeUpdateSystemTime+0xea
fffff800`03c6a600 fffff800`0285d58d : fffffa80`00000000 00000000`00000000 fffffa80`068410c8 fffffa80`0677c3d8 : hal!HalpHpetClockInterrupt+0x8c
fffff800`03c6a630 fffff800`028e5e76 : fffff800`00000000 fffff800`03c6a7e0 00000000`00000000 00000000`00000008 : nt!KiInterruptDispatchNoLock+0x14d
fffff800`03c6a7c0 fffffa60`00a53a94 : 00000000`00000002 00000000`00000002 00000000`0000000e 00000000`00000000 : nt!KeIpiGenericCall+0xd6
fffff800`03c6a820 fffffa60`00a54391 : 00000000`00000103 fffffa80`067aa448 fffffa80`06970e50 fffffa80`068831a0 : sptd+0x44a94
fffff800`03c6a8c0 fffffa60`00a4d4cd : 00000000`00000103 fffffa80`067aa448 fffffa80`06970e50 fffffa80`06800a10 : sptd+0x45391
fffff800`03c6a920 fffffa60`00a4f432 : fffffa80`06970e50 fffffa80`06970e50 fffffa80`078f0000 fffffa80`078f0000 : sptd+0x3e4cd
fffff800`03c6a960 fffffa60`00a522e4 : fffffa80`06883102 fffff800`03c6aa30 00000000`00000001 fffffa80`068831a0 : sptd+0x40432
fffff800`03c6a9f0 fffffa80`061392ee : fffffa80`067aa3d0 fffffa60`00fc420f fffffa80`067aa3d0 fffff800`03c6ab08 : sptd+0x432e4
fffff800`03c6aae0 fffffa80`067aa3d0 : fffffa60`00fc420f fffffa80`067aa3d0 fffff800`03c6ab08 fffffa80`06806050 : 0xfffffa80`061392ee
fffff800`03c6aae8 fffffa60`00fc420f : fffffa80`067aa3d0 fffff800`03c6ab08 fffffa80`06806050 00000000`00000000 : 0xfffffa80`067aa3d0
fffff800`03c6aaf0 fffffa60`00fc4118 : fffffa80`067aa3d0 00000000`00000000 fffffa80`06811880 fffffa60`00fdd110 : CLASSPNP+0x120f
fffff800`03c6ab30 fffffa60`00fc44ee : fffffa80`06811880 fffffa80`06811730 00000000`00000000 00000000`00000002 : CLASSPNP+0x1118
fffff800`03c6ab80 fffff800`02851b53 : 00000000`00000000 00000000`00000000 00000000`0000000c fffffa80`067c33e8 : CLASSPNP+0x14ee
fffff800`03c6abc0 fffff800`028683fd : fffff800`03c6ad08 00000000`00000003 fffffa80`03daf200 fffff800`0297d680 : nt!IopTimerDispatch+0xe2
fffff800`03c6aca0 fffff800`02867818 : fffff800`03c6af00 00000000`00000002 fffff800`03c6aef8 fffffa80`00000001 : nt!KiTimerListExpire+0x30d
fffff800`03c6aed0 fffff800`02867faf : 0000006f`45ddac65 fffffa60`05e69ca0 00000000`00000001 fffff800`02980a80 : nt!KiTimerExpiration+0x1d8
fffff800`03c6af40 fffff800`02866f35 : fffffa80`03de70a0 fffff800`0297d680 fffffa60`05e69ca0 fffff800`02d4e3c0 : nt!KiRetireDpcList+0x1df
fffff800`03c6afb0 fffff800`02866d47 : fffffa60`05e69ca0 fffff800`02d2bf04 00000000`00000301 00000000`03f503bb : nt!KyRetireDpcList+0x5
fffffa60`05e69be0 fffff800`028add83 : 00000000`04ae0230 fffff800`0285d617 fffffa80`07a0dbb0 fffffa60`00000000 : nt!KiDispatchInterruptContinue
fffffa60`05e69c10 fffff800`0285d617 : fffffa80`07a0dbb0 fffffa60`00000000 00000000`00000000 fffffa80`060db230 : nt!KiDpcInterruptBypass+0x13
fffffa60`05e69c20 00000000`75231647 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchNoLock+0x1d7
00000000`033ae830 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x75231647
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_CLOCK_WATCHDOG_TIMEOUT_4_PROC_ANALYSIS_INCONCLUSIVE
0: kd> lmf
fffff800`0280a000 fffff800`02d21000 nt ntkrnlmp.exe
fffff800`02d21000 fffff800`02d67000 hal hal.dll
fffff960`000e0000 fffff960`00394000 win32k \SystemRoot\System32\win32k.sys
fffff960`004a0000 fffff960`004aa000 TSDDD \SystemRoot\System32\TSDDD.dll
fffff960`00670000 fffff960`00681000 cdd \SystemRoot\System32\cdd.dll
fffff960`00800000 fffff960`00861000 ATMFD \SystemRoot\System32\ATMFD.DLL
fffffa60`0060c000 fffffa60`00616000 kdcom kdcom.dll
fffffa60`00616000 fffffa60`00651000 begin_of_the_skype_highlighting**************00651000******end_of_the_skype_highlighting mcupdate_GenuineIntel \SystemRoot\system32\mcupdate_GenuineIntel.dll
fffffa60`00651000 fffffa60`00665000 PSHED \SystemRoot\system32\PSHED.dll
fffffa60`00665000 fffffa60`006c2000 CLFS \SystemRoot\system32\CLFS.SYS
fffffa60`006c2000 fffffa60`00774000 CI \SystemRoot\system32\CI.dll
fffffa60`00774000 fffffa60`007b8000 mv61xx \SystemRoot\system32\DRIVERS\mv61xx.sys
fffffa60`007b8000 fffffa60`007ff000 fltmgr \SystemRoot\system32\drivers\fltmgr.sys
fffffa60`0080e000 fffffa60`008e8000 Wdf01000 \SystemRoot\system32\drivers\Wdf01000.sys
fffffa60`008e8000 fffffa60`008f6000 WDFLDR \SystemRoot\system32\drivers\WDFLDR.SYS
fffffa60`008f6000 fffffa60`00926000 pci \SystemRoot\system32\drivers\pci.sys
fffffa60`00926000 fffffa60`0093a000 volmgr \SystemRoot\system32\drivers\volmgr.sys
fffffa60`0093a000 fffffa60`009a0000 volmgrx \SystemRoot\System32\drivers\volmgrx.sys
fffffa60`009a0000 fffffa60`009b0000 PCIIDEX \SystemRoot\system32\drivers\PCIIDEX.SYS
fffffa60`009b0000 fffffa60`009c3000 mountmgr \SystemRoot\System32\drivers\mountmgr.sys
fffffa60`009c3000 fffffa60`009e7000 ataport \SystemRoot\system32\drivers\ataport.SYS
fffffa60`009e7000 fffffa60`009fb000 fileinfo \SystemRoot\system32\drivers\fileinfo.sys
fffffa60`00a0f000 fffffa60`00b43000 sptd \SystemRoot\System32\Drivers\sptd.sys
fffffa60`00b43000 fffffa60`00b4c000 WMILIB \SystemRoot\System32\Drivers\WMILIB.SYS
fffffa60`00b4c000 fffffa60`00b7a000 SCSIPORT \SystemRoot\System32\Drivers\SCSIPORT.SYS
fffffa60`00b7a000 fffffa60`00bd0000 acpi \SystemRoot\system32\drivers\acpi.sys
fffffa60`00bd0000 fffffa60`00bda000 msisadrv \SystemRoot\system32\drivers\msisadrv.sys
fffffa60`00bda000 fffffa60`00bef000 partmgr \SystemRoot\System32\drivers\partmgr.sys
fffffa60`00bef000 fffffa60`00bf6000 pciide \SystemRoot\system32\drivers\pciide.sys
fffffa60`00bf6000 fffffa60`00bfe000 atapi \SystemRoot\system32\drivers\atapi.sys
fffffa60`00c0e000 fffffa60`00c95000 ksecdd \SystemRoot\System32\Drivers\ksecdd.sys
fffffa60`00c95000 fffffa60`00ce5000 msrpc \SystemRoot\system32\drivers\msrpc.sys
fffffa60`00ce5000 fffffa60`00d3e000 NETIO \SystemRoot\system32\drivers\NETIO.SYS
fffffa60`00d3e000 fffffa60`00d4c000 ATITool64 \SystemRoot\system32\DRIVERS\ATITool64.sys
fffffa60`00d4c000 fffffa60`00d59000 tunnel \SystemRoot\system32\DRIVERS\tunnel.sys
fffffa60`00d59000 fffffa60`00d62000 tunmp \SystemRoot\system32\DRIVERS\tunmp.sys
fffffa60`00d62000 fffffa60`00d75000 intelppm \SystemRoot\system32\DRIVERS\intelppm.sys
fffffa60`00d75000 fffffa60`00d86b00 ohci1394 \SystemRoot\system32\DRIVERS\ohci1394.sys
fffffa60`00d87000 fffffa60`00d96f00 1394BUS \SystemRoot\system32\DRIVERS\1394BUS.SYS
fffffa60`00d97000 fffffa60`00d9f000 ASACPI \SystemRoot\system32\DRIVERS\ASACPI.sys
fffffa60`00d9f000 fffffa60`00dbc000 serial \SystemRoot\system32\DRIVERS\serial.sys
fffffa60`00dbc000 fffffa60`00dc8000 serenum \SystemRoot\system32\DRIVERS\serenum.sys
fffffa60`00dc8000 fffffa60`00de4000 cdrom \SystemRoot\system32\DRIVERS\cdrom.sys
fffffa60`00de4000 fffffa60`00dfc000 adfs \SystemRoot\System32\Drivers\adfs.SYS
fffffa60`00e00000 fffffa60`00fc3000 ndis \SystemRoot\system32\drivers\ndis.sys
fffffa60`00fc3000 fffffa60`00fef000 CLASSPNP \SystemRoot\system32\drivers\CLASSPNP.SYS
fffffa60`0100c000 fffffa60`01182000 tcpip \SystemRoot\System32\drivers\tcpip.sys
fffffa60`01182000 fffffa60`011ae000 fwpkclnt \SystemRoot\System32\drivers\fwpkclnt.sys
fffffa60`011ae000 fffffa60`011da000 ecache \SystemRoot\System32\drivers\ecache.sys
fffffa60`011da000 fffffa60`011ee000 disk \SystemRoot\system32\drivers\disk.sys
fffffa60`011ee000 fffffa60`011f8000 crcdisk \SystemRoot\system32\drivers\crcdisk.sys
fffffa60`01200000 fffffa60`01380000 Ntfs \SystemRoot\System32\Drivers\Ntfs.sys
fffffa60`01380000 fffffa60`013c4000 volsnap \SystemRoot\system32\drivers\volsnap.sys
fffffa60`013c4000 fffffa60`013cc000 spldr \SystemRoot\System32\Drivers\spldr.sys
fffffa60`013cc000 fffffa60`013d3000 speedfan \SystemRoot\SysWOW64\speedfan.sys
fffffa60`013d3000 fffffa60`013ee000 sbp2port \SystemRoot\system32\DRIVERS\sbp2port.sys
fffffa60`013ee000 fffffa60`01400000 mup \SystemRoot\System32\Drivers\mup.sys
fffffa60`03400000 fffffa60`0340d000 fdc \SystemRoot\system32\DRIVERS\fdc.sys
fffffa60`0340e000 fffffa60`03952000 atikmdag \SystemRoot\system32\DRIVERS\atikmdag.sys
fffffa60`03952000 fffffa60`03998000 USBPORT \SystemRoot\system32\DRIVERS\USBPORT.SYS
fffffa60`03998000 fffffa60`039fd000 yk60x64 \SystemRoot\system32\DRIVERS\yk60x64.sys
fffffa60`03a00000 fffffa60`03ae3000 dxgkrnl \SystemRoot\System32\drivers\dxgkrnl.sys
fffffa60`03ae3000 fffffa60`03af3000 watchdog \SystemRoot\System32\drivers\watchdog.sys
fffffa60`03af3000 fffffa60`03be0000 HDAudBus \SystemRoot\system32\DRIVERS\HDAudBus.sys
fffffa60`03be0000 fffffa60`03bec000 usbuhci \SystemRoot\system32\DRIVERS\usbuhci.sys
fffffa60`03bec000 fffffa60`03bfd000 usbehci \SystemRoot\system32\DRIVERS\usbehci.sys
fffffa60`03c08000 fffffa60`03c5d000 az1eo4nn \SystemRoot\System32\Drivers\az1eo4nn.SYS
fffffa60`03c5d000 fffffa60`03c96000 msiscsi \SystemRoot\system32\DRIVERS\msiscsi.sys
fffffa60`03c96000 fffffa60`03cf3000 storport \SystemRoot\system32\DRIVERS\storport.sys
fffffa60`03cf3000 fffffa60`03d00000 TDI \SystemRoot\system32\DRIVERS\TDI.SYS
fffffa60`03d00000 fffffa60`03d23000 rasl2tp \SystemRoot\system32\DRIVERS\rasl2tp.sys
fffffa60`03d23000 fffffa60`03d2f000 ndistapi \SystemRoot\system32\DRIVERS\ndistapi.sys
fffffa60`03d2f000 fffffa60`03d60000 ndiswan \SystemRoot\system32\DRIVERS\ndiswan.sys
fffffa60`03d60000 fffffa60`03d70000 raspppoe \SystemRoot\system32\DRIVERS\raspppoe.sys
fffffa60`03d70000 fffffa60`03d8e000 raspptp \SystemRoot\system32\DRIVERS\raspptp.sys
fffffa60`03d8e000 fffffa60`03da6000 rassstp \SystemRoot\system32\DRIVERS\rassstp.sys
fffffa60`03da6000 fffffa60`03dae000 PdiPorts \SystemRoot\system32\DRIVERS\PdiPorts.sys
fffffa60`03dae000 fffffa60`03dc1000 termdd \SystemRoot\system32\DRIVERS\termdd.sys
fffffa60`03dc1000 fffffa60`03dcf000 kbdclass \SystemRoot\system32\DRIVERS\kbdclass.sys
fffffa60`03dcf000 fffffa60`03ddb000 mouclass \SystemRoot\system32\DRIVERS\mouclass.sys
fffffa60`03ddb000 fffffa60`03ddc480 swenum \SystemRoot\system32\DRIVERS\swenum.sys
fffffa60`03ddd000 fffffa60`03df7000 mpsdrv \SystemRoot\System32\drivers\mpsdrv.sys
fffffa60`03e0b000 fffffa60`03e3f000 ks \SystemRoot\system32\DRIVERS\ks.sys
fffffa60`03e3f000 fffffa60`03e43c80 WmBEnum \SystemRoot\system32\drivers\WmBEnum.sys
fffffa60`03e44000 fffffa60`03e55100 WmXlCore \SystemRoot\system32\drivers\WmXlCore.sys
fffffa60`03e56000 fffffa60`03e61000 mssmbios \SystemRoot\system32\DRIVERS\mssmbios.sys
fffffa60`03e61000 fffffa60`03e71000 umbus \SystemRoot\system32\DRIVERS\umbus.sys
fffffa60`03e71000 fffffa60`03eb9000 usbhub \SystemRoot\system32\DRIVERS\usbhub.sys
fffffa60`03eb9000 fffffa60`03ec4000 flpydisk \SystemRoot\system32\DRIVERS\flpydisk.sys
fffffa60`03ec4000 fffffa60`03ed8000 NDProxy \SystemRoot\System32\Drivers\NDProxy.SYS
fffffa60`03ed8000 fffffa60`03f21000 HdAudio \SystemRoot\system32\drivers\HdAudio.sys
fffffa60`03f21000 fffffa60`03f5c000 portcls \SystemRoot\system32\drivers\portcls.sys
fffffa60`03f5c000 fffffa60`03f7f000 drmk \SystemRoot\system32\drivers\drmk.sys
fffffa60`03f7f000 fffffa60`03f84180 ksthunk \SystemRoot\system32\drivers\ksthunk.sys
fffffa60`03f85000 fffffa60`03ffc000 ADIHdAud \SystemRoot\system32\drivers\ADIHdAud.sys
fffffa60`0480c000 fffffa60`04839000 MpFilter \SystemRoot\system32\DRIVERS\MpFilter.sys
fffffa60`04839000 fffffa60`04843000 Fs_Rec \SystemRoot\System32\Drivers\Fs_Rec.SYS
fffffa60`04843000 fffffa60`0484c000 Null \SystemRoot\System32\Drivers\Null.SYS
fffffa60`04857000 fffffa60`0485eb80 HIDPARSE \SystemRoot\system32\DRIVERS\HIDPARSE.SYS
fffffa60`0485f000 fffffa60`0486d000 vga \SystemRoot\System32\drivers\vga.sys
fffffa60`0486d000 fffffa60`04892000 VIDEOPRT \SystemRoot\System32\drivers\VIDEOPRT.SYS
fffffa60`04892000 fffffa60`0489b000 RDPCDD \SystemRoot\System32\DRIVERS\RDPCDD.sys
fffffa60`0489b000 fffffa60`048a4000 rdpencdd \SystemRoot\system32\drivers\rdpencdd.sys
fffffa60`048a4000 fffffa60`048af000 Msfs \SystemRoot\System32\Drivers\Msfs.SYS
fffffa60`048af000 fffffa60`048c0000 Npfs \SystemRoot\System32\Drivers\Npfs.SYS
fffffa60`048c0000 fffffa60`048c9000 rasacd \SystemRoot\System32\DRIVERS\rasacd.sys
fffffa60`048c9000 fffffa60`048e6000 tdx \SystemRoot\system32\DRIVERS\tdx.sys
fffffa60`048e6000 fffffa60`04901000 smb \SystemRoot\system32\DRIVERS\smb.sys
fffffa60`04901000 fffffa60`0496c000 afd \SystemRoot\system32\drivers\afd.sys
fffffa60`0496c000 fffffa60`049b0000 netbt \SystemRoot\System32\DRIVERS\netbt.sys
fffffa60`049b0000 fffffa60`049ce000 pacer \SystemRoot\system32\DRIVERS\pacer.sys
fffffa60`049ce000 fffffa60`049dd000 netbios \SystemRoot\system32\DRIVERS\netbios.sys
fffffa60`049dd000 fffffa60`049e4000 TVicPort64 \??\C:\Windows\SysWOW64\drivers\TVicPort64.sys
fffffa60`049e4000 fffffa60`049ff000 wanarp \SystemRoot\system32\DRIVERS\wanarp.sys
fffffa60`04a04000 fffffa60`04a51000 rdbss \SystemRoot\system32\DRIVERS\rdbss.sys
fffffa60`04a51000 fffffa60`04a5d000 nsiproxy \SystemRoot\system32\drivers\nsiproxy.sys
fffffa60`04a5d000 fffffa60`04a7a000 dfsc \SystemRoot\System32\Drivers\dfsc.sys
fffffa60`04a7a000 fffffa60`04a81000 AsIO \SystemRoot\SysWow64\drivers\AsIO.sys
fffffa60`04a81000 fffffa60`04a9d000 cdfs \SystemRoot\system32\DRIVERS\cdfs.sys
fffffa60`04a9d000 fffffa60`04aa6000 hidusb \SystemRoot\system32\DRIVERS\hidusb.sys
fffffa60`04aa6000 fffffa60`04ab8000 HIDCLASS \SystemRoot\system32\DRIVERS\HIDCLASS.SYS
fffffa60`04ab8000 fffffa60`04ab9e00 USBD \SystemRoot\system32\DRIVERS\USBD.SYS
fffffa60`04aba000 fffffa60`04ac2680 WmFilter \SystemRoot\system32\drivers\WmFilter.sys
fffffa60`04ac3000 fffffa60`04ad1000 crashdmp \SystemRoot\System32\Drivers\crashdmp.sys
fffffa60`04ad1000 fffffa60`04add000 dump_dumpata \SystemRoot\System32\Drivers\dump_dumpata.sys
fffffa60`04add000 fffffa60`04ae5000 dump_atapi \SystemRoot\System32\Drivers\dump_atapi.sys
fffffa60`04ae5000 fffffa60`04b01000 usbccgp \SystemRoot\system32\DRIVERS\usbccgp.sys
fffffa60`04b01000 fffffa60`04b14000 LHidFilt \SystemRoot\system32\DRIVERS\LHidFilt.Sys
fffffa60`04b14000 fffffa60`04b1f000 kbdhid \SystemRoot\system32\DRIVERS\kbdhid.sys
fffffa60`04b1f000 fffffa60`04b2a000 mouhid \SystemRoot\system32\DRIVERS\mouhid.sys
fffffa60`04b2a000 fffffa60`04b3e000 LMouFilt \SystemRoot\system32\DRIVERS\LMouFilt.Sys
fffffa60`04b3e000 fffffa60`04bb3000 fwlanusb \SystemRoot\system32\DRIVERS\fwlanusb.sys
fffffa60`04bb3000 fffffa60`04bbf000 Dxapi \SystemRoot\System32\drivers\Dxapi.sys
fffffa60`04bbf000 fffffa60`04bd2000 monitor \SystemRoot\system32\DRIVERS\monitor.sys
fffffa60`04bd2000 fffffa60`04bf4000 luafv \SystemRoot\system32\drivers\luafv.sys
fffffa60`06204000 fffffa60`0629e000 spsys \SystemRoot\system32\drivers\spsys.sys
fffffa60`0629e000 fffffa60`062b2000 lltdio \SystemRoot\system32\DRIVERS\lltdio.sys
fffffa60`062b2000 fffffa60`062e6000 nwifi \SystemRoot\system32\DRIVERS\nwifi.sys
fffffa60`062e6000 fffffa60`062f1000 ndisuio \SystemRoot\system32\DRIVERS\ndisuio.sys
fffffa60`062f1000 fffffa60`06309000 rspndr \SystemRoot\system32\DRIVERS\rspndr.sys
fffffa60`06309000 fffffa60`063ac000 HTTP \SystemRoot\system32\drivers\HTTP.sys
fffffa60`063ac000 fffffa60`063d5000 srvnet \SystemRoot\System32\DRIVERS\srvnet.sys
fffffa60`063d5000 fffffa60`063f3000 bowser \SystemRoot\system32\DRIVERS\bowser.sys
fffffa60`0660c000 fffffa60`06633000 mrxdav \SystemRoot\system32\drivers\mrxdav.sys
fffffa60`06633000 fffffa60`0665c000 mrxsmb \SystemRoot\system32\DRIVERS\mrxsmb.sys
fffffa60`0665c000 fffffa60`066a5000 mrxsmb10 \SystemRoot\system32\DRIVERS\mrxsmb10.sys
fffffa60`066a5000 fffffa60`066c4000 mrxsmb20 \SystemRoot\system32\DRIVERS\mrxsmb20.sys
fffffa60`066c4000 fffffa60`066f6000 srv2 \SystemRoot\System32\DRIVERS\srv2.sys
fffffa60`066f6000 fffffa60`0678b000 srv \SystemRoot\System32\DRIVERS\srv.sys
fffffa60`0678b000 fffffa60`06796000 asyncmac \SystemRoot\system32\DRIVERS\asyncmac.sys
fffffa60`06796000 fffffa60`067a6000 MpNWMon \SystemRoot\system32\DRIVERS\MpNWMon.sys
fffffa60`067a6000 fffffa60`067fc000 acedrv11 \??\C:\Windows\system32\drivers\acedrv11.sys
fffffa60`07005000 fffffa60`070bb000 peauth \SystemRoot\system32\drivers\peauth.sys
fffffa60`070bb000 fffffa60`070c6000 secdrv \SystemRoot\System32\Drivers\secdrv.SYS
fffffa60`070c6000 fffffa60`070d6000 tcpipreg \SystemRoot\System32\drivers\tcpipreg.sys
fffffa60`070d6000 fffffa60`0710b000 fastfat \SystemRoot\System32\Drivers\fastfat.SYS
fffffa60`0710b000 fffffa60`0710d400 WmVirHid \SystemRoot\system32\drivers\WmVirHid.sys
Unloaded modules:
fffffa60`00fef000 fffffa60`00ffd000 crashdmp.sys
fffffa60`011f8000 fffffa60`01200000 dump_atapi.sys
fffffa60`0484c000 fffffa60`04857000 kbdhid.sys
0: kd> lmf
fffffa60`00616000 fffffa60`00651000 mcupdate_GenuineIntel \SystemRoot\system32\mcupdate_GenuineIntel.dll
Unloaded modules:
0: kd> lmp
fffff800`0280a000 fffff800`02d21000 nt <none>
fffff800`02d21000 fffff800`02d67000 hal <none>
fffff960`000e0000 fffff960`00394000 win32k <none>
fffff960`004a0000 fffff960`004aa000 TSDDD <none>
fffff960`00670000 fffff960`00681000 cdd <none>
fffff960`00800000 fffff960`00861000 ATMFD <none>
fffffa60`0060c000 fffffa60`00616000 kdcom <none>
fffffa60`00616000 fffffa60`00651000 mcupdate_GenuineIntel <none>
fffffa60`00651000 fffffa60`00665000 PSHED <none>
fffffa60`00665000 fffffa60`006c2000 CLFS <none>
fffffa60`006c2000 fffffa60`00774000 CI <none>
fffffa60`00774000 fffffa60`007b8000 mv61xx <none>
fffffa60`007b8000 fffffa60`007ff000 fltmgr <none>
fffffa60`0080e000 fffffa60`008e8000 Wdf01000 <none>
fffffa60`008e8000 fffffa60`008f6000 WDFLDR <none>
fffffa60`008f6000 fffffa60`00926000 pci <none>
fffffa60`00926000 fffffa60`0093a000 volmgr <none>
fffffa60`0093a000 fffffa60`009a0000 volmgrx <none>
fffffa60`009a0000 fffffa60`009b0000 PCIIDEX <none>
fffffa60`009b0000 fffffa60`009c3000 mountmgr <none>
fffffa60`009c3000 fffffa60`009e7000 ataport <none>
fffffa60`009e7000 fffffa60`009fb000 fileinfo <none>
fffffa60`00a0f000 fffffa60`00b43000 sptd <none>
fffffa60`00b43000 fffffa60`00b4c000 WMILIB <none>
fffffa60`00b4c000 fffffa60`00b7a000 SCSIPORT <none>
fffffa60`00b7a000 fffffa60`00bd0000 acpi <none>
fffffa60`00bd0000 fffffa60`00bda000 msisadrv <none>
fffffa60`00bda000 fffffa60`00bef000 partmgr <none>
fffffa60`00bef000 fffffa60`00bf6000 pciide <none>
fffffa60`00bf6000 fffffa60`00bfe000 atapi <none>
fffffa60`00c0e000 fffffa60`00c95000 ksecdd <none>
fffffa60`00c95000 fffffa60`00ce5000 msrpc <none>
fffffa60`00ce5000 fffffa60`00d3e000 NETIO <none>
fffffa60`00d3e000 fffffa60`00d4c000 ATITool64 <none>
fffffa60`00d4c000 fffffa60`00d59000 tunnel <none>
fffffa60`00d59000 fffffa60`00d62000 tunmp <none>
fffffa60`00d62000 fffffa60`00d75000 intelppm <none>
fffffa60`00d75000 fffffa60`00d86b00 ohci1394 <none>
fffffa60`00d87000 fffffa60`00d96f00 1394BUS <none>
fffffa60`00d97000 fffffa60`00d9f000 ASACPI <none>
fffffa60`00d9f000 fffffa60`00dbc000 serial <none>
fffffa60`00dbc000 fffffa60`00dc8000 serenum <none>
fffffa60`00dc8000 fffffa60`00de4000 cdrom <none>
fffffa60`00de4000 fffffa60`00dfc000 adfs <none>
fffffa60`00e00000 fffffa60`00fc3000 ndis <none>
fffffa60`00fc3000 fffffa60`00fef000 CLASSPNP <none>
fffffa60`011ae000 fffffa60`011da000 ecache <none>
fffffa60`011da000 fffffa60`011ee000 disk <none>
fffffa60`011ee000 fffffa60`011f8000 crcdisk <none>
fffffa60`01200000 fffffa60`01380000 Ntfs <none>
fffffa60`01380000 fffffa60`013c4000 volsnap <none>
fffffa60`013c4000 fffffa60`013cc000 spldr <none>
fffffa60`013cc000 fffffa60`013d3000 speedfan <none>
fffffa60`013d3000 fffffa60`013ee000 sbp2port <none>
fffffa60`013ee000 fffffa60`01400000 mup <none>
fffffa60`03400000 fffffa60`0340d000 fdc <none>
fffffa60`0340e000 fffffa60`03952000 atikmdag <none>
fffffa60`03952000 fffffa60`03998000 USBPORT <none>
fffffa60`03998000 fffffa60`039fd000 yk60x64 <none>
fffffa60`03a00000 fffffa60`03ae3000 dxgkrnl <none>
fffffa60`03ae3000 fffffa60`03af3000 watchdog <none>
fffffa60`03af3000 fffffa60`03be0000 HDAudBus <none>
fffffa60`03be0000 fffffa60`03bec000 usbuhci <none>
fffffa60`03bec000 fffffa60`03bfd000 usbehci <none>
fffffa60`03c08000 fffffa60`03c5d000 az1eo4nn <none>
fffffa60`03c5d000 fffffa60`03c96000 msiscsi <none>
fffffa60`03c96000 fffffa60`03cf3000 storport <none>
fffffa60`03cf3000 fffffa60`03d00000 TDI <none>
fffffa60`03d00000 fffffa60`03d23000 rasl2tp <none>
fffffa60`03d23000 fffffa60`03d2f000 ndistapi <none>
fffffa60`03d2f000 fffffa60`03d60000 ndiswan <none>
fffffa60`03d60000 fffffa60`03d70000 raspppoe <none>
fffffa60`03d70000 fffffa60`03d8e000 raspptp <none>
fffffa60`03d8e000 fffffa60`03da6000 rassstp <none>
fffffa60`03da6000 fffffa60`03dae000 PdiPorts <none>
fffffa60`03dae000 fffffa60`03dc1000 termdd <none>
fffffa60`03dc1000 fffffa60`03dcf000 kbdclass <none>
fffffa60`03dcf000 fffffa60`03ddb000 mouclass <none>
fffffa60`03ddb000 fffffa60`03ddc480 swenum <none>
fffffa60`03ddd000 fffffa60`03df7000 mpsdrv <none>
fffffa60`03e0b000 fffffa60`03e3f000 ks <none>
fffffa60`03e3f000 fffffa60`03e43c80 WmBEnum <none>
fffffa60`03e44000 fffffa60`03e55100 WmXlCore <none>
fffffa60`03e56000 fffffa60`03e61000 mssmbios <none>
fffffa60`03e61000 fffffa60`03e71000 umbus <none>
fffffa60`03e71000 fffffa60`03eb9000 usbhub <none>
fffffa60`03eb9000 fffffa60`03ec4000 flpydisk <none>
fffffa60`03ec4000 fffffa60`03ed8000 NDProxy <none>
fffffa60`03ed8000 fffffa60`03f21000 HdAudio <none>
fffffa60`03f21000 fffffa60`03f5c000 portcls <none>
fffffa60`03f5c000 fffffa60`03f7f000 drmk <none>
fffffa60`03f7f000 fffffa60`03f84180 ksthunk <none>
fffffa60`03f85000 fffffa60`03ffc000 ADIHdAud <none>
fffffa60`0480c000 fffffa60`04839000 MpFilter <none>
fffffa60`04839000 fffffa60`04843000 Fs_Rec <none>
fffffa60`04843000 fffffa60`0484c000 Null <none>
fffffa60`04857000 fffffa60`0485eb80 HIDPARSE <none>
fffffa60`0485f000 fffffa60`0486d000 vga <none>
fffffa60`0486d000 fffffa60`04892000 VIDEOPRT <none>
fffffa60`04892000 fffffa60`0489b000 RDPCDD <none>
fffffa60`0489b000 fffffa60`048a4000 rdpencdd <none>
fffffa60`048a4000 fffffa60`048af000 Msfs <none>
fffffa60`048af000 fffffa60`048c0000 Npfs <none>
fffffa60`048c0000 fffffa60`048c9000 rasacd <none>
fffffa60`048c9000 fffffa60`048e6000 tdx <none>
fffffa60`048e6000 fffffa60`04901000 smb <none>
fffffa60`04901000 fffffa60`0496c000 afd <none>
fffffa60`0496c000 fffffa60`049b0000 netbt <none>
fffffa60`049b0000 fffffa60`049ce000 pacer <none>
fffffa60`049ce000 fffffa60`049dd000 netbios <none>
fffffa60`049dd000 fffffa60`049e4000 TVicPort64 <none>
fffffa60`049e4000 fffffa60`049ff000 wanarp <none>
fffffa60`04a04000 fffffa60`04a51000 rdbss <none>
fffffa60`04a51000 fffffa60`04a5d000 nsiproxy <none>
fffffa60`04a5d000 fffffa60`04a7a000 dfsc <none>
fffffa60`04a7a000 fffffa60`04a81000 AsIO <none>
fffffa60`04a81000 fffffa60`04a9d000 cdfs <none>
fffffa60`04a9d000 fffffa60`04aa6000 hidusb <none>
fffffa60`04aa6000 fffffa60`04ab8000 HIDCLASS <none>
fffffa60`04ab8000 fffffa60`04ab9e00 USBD <none>
fffffa60`04aba000 fffffa60`04ac2680 WmFilter <none>
fffffa60`04ac3000 fffffa60`04ad1000 crashdmp <none>
fffffa60`04ad1000 fffffa60`04add000 dump_dumpata <none>
fffffa60`04add000 fffffa60`04ae5000 dump_atapi <none>
fffffa60`04ae5000 fffffa60`04b01000 usbccgp <none>
fffffa60`04b01000 fffffa60`04b14000 LHidFilt <none>
fffffa60`04b14000 fffffa60`04b1f000 kbdhid <none>
fffffa60`04b1f000 fffffa60`04b2a000 mouhid <none>
fffffa60`04b2a000 fffffa60`04b3e000 LMouFilt <none>
fffffa60`04b3e000 fffffa60`04bb3000 fwlanusb <none>
fffffa60`04bb3000 fffffa60`04bbf000 Dxapi <none>
fffffa60`04bbf000 fffffa60`04bd2000 monitor <none>
fffffa60`04bd2000 fffffa60`04bf4000 luafv <none>
fffffa60`06204000 fffffa60`0629e000 spsys <none>
fffffa60`0629e000 fffffa60`062b2000 lltdio <none>
fffffa60`062b2000 fffffa60`062e6000 nwifi <none>
fffffa60`062e6000 fffffa60`062f1000 ndisuio <none>
fffffa60`062f1000 fffffa60`06309000 rspndr <none>
fffffa60`06309000 fffffa60`063ac000 HTTP <none>
fffffa60`063ac000 fffffa60`063d5000 srvnet <none>
fffffa60`063d5000 fffffa60`063f3000 bowser <none>
fffffa60`0660c000 fffffa60`06633000 mrxdav <none>
fffffa60`06633000 fffffa60`0665c000 mrxsmb <none>
fffffa60`0665c000 fffffa60`066a5000 mrxsmb10 <none>
fffffa60`066a5000 fffffa60`066c4000 mrxsmb20 <none>
fffffa60`066c4000 fffffa60`066f6000 srv2 <none>
fffffa60`066f6000 fffffa60`0678b000 srv <none>
fffffa60`0678b000 fffffa60`06796000 asyncmac <none>
fffffa60`06796000 fffffa60`067a6000 MpNWMon <none>
fffffa60`067a6000 fffffa60`067fc000 acedrv11 <none>
fffffa60`07005000 fffffa60`070bb000 peauth <none>
fffffa60`070bb000 fffffa60`070c6000 secdrv <none>
fffffa60`070c6000 fffffa60`070d6000 tcpipreg <none>
fffffa60`070d6000 fffffa60`0710b000 fastfat <none>
fffffa60`0710b000 fffffa60`0710d400 WmVirHid <none>
Unloaded modules:
0: kd> lmp
Unloaded modules:
0: kd> lmv
fffff800`0280a000 fffff800`02d21000 nt (pdb symbols) c:\symbols\ntkrnlmp.pdb\41536C33A33844E79C3A08D47B6F967F2\ntkrnlmp.pdb
Loaded symbol image file: ntkrnlmp.exe
Image path: ntkrnlmp.exe
Image name: ntkrnlmp.exe
Timestamp: Thu Feb 18 12:25:03 2010 (4B7D238F)
CheckSum: 00483E07
ImageSize: 00517000
File version: 6.0.6002.18209
Product version: 6.0.6002.18209
File flags: 0 (Mask 3F)
File OS: 40004 NT Win32
File type: 1.0 App
File date: 00000000.00000000
Translations: 0409.04b0
CompanyName: Microsoft Corporation
ProductName: Microsoft® Windows® Operating System
InternalName: ntkrnlmp.exe
OriginalFilename: ntkrnlmp.exe
ProductVersion: 6.0.6002.18209
FileVersion: 6.0.6002.18209 (vistasp2_gdr.100218-0019)
FileDescription: NT Kernel & System
LegalCopyright: © Microsoft Corporation. All rights reserved.
fffff800`02d21000 fffff800`02d67000 hal (pdb symbols) c:\symbols\hal.pdb\5E5C6555035349D9950043A182DF64702\hal.pdb
Loaded symbol image file: hal.dll
Image path: hal.dll
Image name: hal.dll
Timestamp: Sat Apr 11 09:04:56 2009 (49E04118)
CheckSum: 0003D17E
ImageSize: 00046000
File version: 6.0.6002.18005
Product version: 6.0.6002.18005
File type: 2.0 Dll
InternalName: hal.dll
OriginalFilename: hal.dll
ProductVersion: 6.0.6002.18005
FileVersion: 6.0.6002.18005 (lh_sp2rtm.090410-1830)
FileDescription: Hardware Abstraction Layer DLL
fffff960`000e0000 fffff960`00394000 win32k (deferred)
Image path: \SystemRoot\System32\win32k.sys
Image name: win32k.sys
Timestamp: Fri Aug 14 15:42:57 2009 (4A8569E1)
CheckSum: 002A4EC1
ImageSize: 002B4000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
fffff960`004a0000 fffff960`004aa000 TSDDD (deferred)
Image path: \SystemRoot\System32\TSDDD.dll
Image name: TSDDD.dll
Timestamp: Sat Jan 19 07:42:04 2008 (47919BBC)
CheckSum: 00012267
ImageSize: 0000A000
Page a2c7d not present in the dump file. Type ".hh dbgerr004" for details
fffff960`00670000 fffff960`00681000 cdd (deferred)
Image path: \SystemRoot\System32\cdd.dll
Image name: cdd.dll
Timestamp: Fri Sep 25 03:26:38 2009 (4ABC1C4E)
CheckSum: 0000E59E
ImageSize: 00011000
fffff960`00800000 fffff960`00861000 ATMFD (deferred)
Image path: \SystemRoot\System32\ATMFD.DLL
Image name: ATMFD.DLL
Timestamp: Mon Jun 15 15:05:59 2009 (4A364737)
CheckSum: 00064BB1
ImageSize: 00061000
Page 9f74f not present in the dump file. Type ".hh dbgerr004" for details
fffffa60`0060c000 fffffa60`00616000 kdcom (deferred)
Image path: kdcom.dll
Image name: kdcom.dll
Timestamp: Sat Apr 11 09:07:57 2009 (49E041CD)
CheckSum: 0000C7BC
ImageSize: 0000A000
fffffa60`00616000 fffffa60`00651000 mcupdate_GenuineIntel (deferred)
Image path: \SystemRoot\system32\mcupdate_GenuineIntel.dll
Image name: mcupdate_GenuineIntel.dll
Timestamp: Sat Apr 11 09:05:41 2009 (49E04145)
CheckSum: 0003DEC1
ImageSize: 0003B000
fffffa60`00651000 fffffa60`00665000 PSHED (deferred)
Image path: \SystemRoot\system32\PSHED.dll
Image name: PSHED.dll
Timestamp: Sat Apr 11 09:08:17 2009 (49E041E1)
CheckSum: 0001C903
ImageSize: 00014000
fffffa60`00665000 fffffa60`006c2000 CLFS (deferred)
Image path: \SystemRoot\system32\CLFS.SYS
Image name: CLFS.SYS
Timestamp: Sat Apr 11 06:54:21 2009 (49E0227D)
CheckSum: 0006013C
ImageSize: 0005D000
fffffa60`006c2000 fffffa60`00774000 CI (deferred)
Image path: \SystemRoot\system32\CI.dll
Image name: CI.dll
Timestamp: Sat Apr 11 09:08:09 2009 (49E041D9)
CheckSum: 0006295F
ImageSize: 000B2000
fffffa60`00774000 fffffa60`007b8000 mv61xx (deferred)
Image path: \SystemRoot\system32\DRIVERS\mv61xx.sys
Image name: mv61xx.sys
Timestamp: Mon May 19 08:50:08 2008 (48312320)
CheckSum: 00036100
ImageSize: 00044000
fffffa60`007b8000 fffffa60`007ff000 fltmgr (deferred)
Image path: \SystemRoot\system32\drivers\fltmgr.sys
Image name: fltmgr.sys
Timestamp: Sat Apr 11 06:54:38 2009 (49E0228E)
CheckSum: 0004C6F4
ImageSize: 00047000
fffffa60`0080e000 fffffa60`008e8000 Wdf01000 (deferred)
Image path: \SystemRoot\system32\drivers\Wdf01000.sys
Image name: Wdf01000.sys
Timestamp: Sat Jan 19 07:33:27 2008 (479199B7)
CheckSum: 000D946B
ImageSize: 000DA000
fffffa60`008e8000 fffffa60`008f6000 WDFLDR (deferred)
Image path: \SystemRoot\system32\drivers\WDFLDR.SYS
Image name: WDFLDR.SYS
Timestamp: Sat Jan 19 07:32:33 2008 (47919981)
CheckSum: 00018BBD
ImageSize: 0000E000
fffffa60`008f6000 fffffa60`00926000 pci (deferred)
Image path: \SystemRoot\system32\drivers\pci.sys
Image name: pci.sys
Timestamp: Sat Apr 11 07:03:33 2009 (49E024A5)
CheckSum: 000330BC
ImageSize: 00030000
File type: 2.0 Dll
InternalName: pci.sys
OriginalFilename: pci.sys
FileDescription: NT Plug and Play PCI Enumerator
fffffa60`00926000 fffffa60`0093a000 volmgr (deferred)
Image path: \SystemRoot\system32\drivers\volmgr.sys
Image name: volmgr.sys
Timestamp: Sat Apr 11 07:34:49 2009 (49E02BF9)
CheckSum: 000131ED
ImageSize: 00014000
fffffa60`0093a000 fffffa60`009a0000 volmgrx (deferred)
Image path: \SystemRoot\System32\drivers\volmgrx.sys
Image name: volmgrx.sys
Timestamp: Sat Apr 11 07:35:14 2009 (49E02C12)
CheckSum: 00073802
ImageSize: 00066000
fffffa60`009a0000 fffffa60`009b0000 PCIIDEX (deferred)
Image path: \SystemRoot\system32\drivers\PCIIDEX.SYS
Image name: PCIIDEX.SYS
Timestamp: Sat Apr 11 07:34:22 2009 (49E02BDE)
CheckSum: 0000FE5B
ImageSize: 00010000
fffffa60`009b0000 fffffa60`009c3000 mountmgr (deferred)
Image path: \SystemRoot\System32\drivers\mountmgr.sys
Image name: mountmgr.sys
Timestamp: Sat Jan 19 07:28:01 2008 (47919871)
CheckSum: 000157AE
ImageSize: 00013000
fffffa60`009c3000 fffffa60`009e7000 ataport (deferred)
Image path: \SystemRoot\system32\drivers\ataport.SYS
Image name: ataport.SYS
Timestamp: Sat Apr 11 07:34:25 2009 (49E02BE1)
CheckSum: 000267F3
ImageSize: 00024000
fffffa60`009e7000 fffffa60`009fb000 fileinfo (deferred)
Image path: \SystemRoot\system32\drivers\fileinfo.sys
Image name: fileinfo.sys
Timestamp: Sat Jan 19 07:05:23 2008 (47919323)
CheckSum: 0002031C
ImageSize: 00014000
fffffa60`00a0f000 fffffa60`00b43000 sptd (no symbols)
Loaded symbol image file: sptd.sys
Image path: \SystemRoot\System32\Drivers\sptd.sys
Image name: sptd.sys
Timestamp: Thu Mar 06 01:34:27 2008 (47CF3C13)
CheckSum: 000DA3DE
ImageSize: 00134000
fffffa60`00b43000 fffffa60`00b4c000 WMILIB (deferred)
Image path: \SystemRoot\System32\Drivers\WMILIB.SYS
Image name: WMILIB.SYS
Timestamp: Sat Jan 19 07:33:45 2008 (479199C9)
CheckSum: 0000994C
ImageSize: 00009000
fffffa60`00b4c000 fffffa60`00b7a000 SCSIPORT (deferred)
Image path: \SystemRoot\System32\Drivers\SCSIPORT.SYS
Image name: SCSIPORT.SYS
Timestamp: Sat Jan 19 07:28:52 2008 (479198A4)
CheckSum: 0002E61E
ImageSize: 0002E000
fffffa60`00b7a000 fffffa60`00bd0000 acpi (deferred)
Image path: \SystemRoot\system32\drivers\acpi.sys
Image name: acpi.sys
Timestamp: Sat Apr 11 07:03:26 2009 (49E0249E)
CheckSum: 00052D93
ImageSize: 00056000
fffffa60`00bd0000 fffffa60`00bda000 msisadrv (deferred)
Image path: \SystemRoot\system32\drivers\msisadrv.sys
Image name: msisadrv.sys
Timestamp: Sat Jan 19 07:02:50 2008 (4791928A)
CheckSum: 0000AD81
ImageSize: 0000A000
fffffa60`00bda000 fffffa60`00bef000 partmgr (deferred)
Image path: \SystemRoot\System32\drivers\partmgr.sys
Image name: partmgr.sys
Timestamp: Sat Apr 11 07:34:51 2009 (49E02BFB)
CheckSum: 00019CD5
ImageSize: 00015000
fffffa60`00bef000 fffffa60`00bf6000 pciide (deferred)
Image path: \SystemRoot\system32\drivers\pciide.sys
Image name: pciide.sys
Timestamp: Sat Apr 11 07:34:28 2009 (49E02BE4)
CheckSum: 0001260A
ImageSize: 00007000
File type: 3.7 Driver
InternalName: pciide.sys
OriginalFilename: pciide.sys
FileDescription: Generic PCI IDE Bus Driver
fffffa60`00bf6000 fffffa60`00bfe000 atapi (deferred)
Image path: \SystemRoot\system32\drivers\atapi.sys
Image name: atapi.sys
Timestamp: Sat Apr 11 07:34:19 2009 (49E02BDB)
CheckSum: 000112F5
ImageSize: 00008000
fffffa60`00c0e000 fffffa60`00c95000 ksecdd (deferred)
Image path: \SystemRoot\System32\Drivers\ksecdd.sys
Image name: ksecdd.sys
Timestamp: Mon Jun 15 15:15:18 2009 (4A364966)
CheckSum: 0007ED50
ImageSize: 00087000
fffffa60`00c95000 fffffa60`00ce5000 msrpc (deferred)
Image path: \SystemRoot\system32\drivers\msrpc.sys
Image name: msrpc.sys
Timestamp: Sat Apr 11 07:32:13 2009 (49E02B5D)
CheckSum: 00057CB1
ImageSize: 00050000
fffffa60`00ce5000 fffffa60`00d3e000 NETIO (deferred)
Image path: \SystemRoot\system32\drivers\NETIO.SYS
Image name: NETIO.SYS
Timestamp: Sat Apr 11 07:43:34 2009 (49E02E06)
CheckSum: 0005AECE
ImageSize: 00059000
fffffa60`00d3e000 fffffa60`00d4c000 ATITool64 (deferred)
Image path: \SystemRoot\system32\DRIVERS\ATITool64.sys
Image name: ATITool64.sys
Timestamp: Wed Aug 08 18:42:26 2007 (46B9F272)
CheckSum: 0001540C
ImageSize: 0000E000
fffffa60`00d4c000 fffffa60`00d59000 tunnel (deferred)
Image path: \SystemRoot\system32\DRIVERS\tunnel.sys
Image name: tunnel.sys
Timestamp: Thu Feb 18 12:59:46 2010 (4B7D2BB2)
CheckSum: 000153F1
ImageSize: 0000D000
fffffa60`00d59000 fffffa60`00d62000 tunmp (deferred)
Image path: \SystemRoot\system32\DRIVERS\tunmp.sys
Image name: tunmp.sys
Timestamp: Sat Jan 19 07:36:30 2008 (47919A6E)
CheckSum: 0000DBCB
ImageSize: 00009000
fffffa60`00d62000 fffffa60`00d75000 intelppm (deferred)
Image path: \SystemRoot\system32\DRIVERS\intelppm.sys
Image name: intelppm.sys
Timestamp: Sat Jan 19 06:52:45 2008 (4791902D)
CheckSum: 0000BEEB
ImageSize: 00013000
fffffa60`00d75000 fffffa60`00d86b00 ohci1394 (deferred)
Image path: \SystemRoot\system32\DRIVERS\ohci1394.sys
Image name: ohci1394.sys
Timestamp: Sat Apr 11 07:39:49 2009 (49E02D25)
CheckSum: 0001FAC5
ImageSize: 00011B00
fffffa60`00d87000 fffffa60`00d96f00 1394BUS (deferred)
Image path: \SystemRoot\system32\DRIVERS\1394BUS.SYS
Image name: 1394BUS.SYS
Timestamp: Sat Jan 19 07:34:04 2008 (479199DC)
CheckSum: 000129D0
ImageSize: 0000FF00
File version: 6.0.6001.18000
Product version: 6.0.6001.18000
InternalName: 1394bus.sys
OriginalFilename: 1394bus.sys
ProductVersion: 6.0.6001.18000
FileVersion: 6.0.6001.18000 (longhorn_rtm.080118-1840)
FileDescription: 1394 Bus Device Driver
fffffa60`00d97000 fffffa60`00d9f000 ASACPI (deferred)
Image path: \SystemRoot\system32\DRIVERS\ASACPI.sys
Image name: ASACPI.sys
Timestamp: Tue Oct 31 03:09:12 2006 (4546B048)
CheckSum: 000089FB
ImageSize: 00008000
fffffa60`00d9f000 fffffa60`00dbc000 serial (deferred)
Image path: \SystemRoot\system32\DRIVERS\serial.sys
Image name: serial.sys
Timestamp: Sat Jan 19 07:28:41 2008 (47919899)
CheckSum: 0001A92E
ImageSize: 0001D000
fffffa60`00dbc000 fffffa60`00dc8000 serenum (deferred)
Image path: \SystemRoot\system32\DRIVERS\serenum.sys
Image name: serenum.sys
Timestamp: Sat Jan 19 07:28:36 2008 (47919894)
CheckSum: 000156DF
ImageSize: 0000C000
fffffa60`00dc8000 fffffa60`00de4000 cdrom (deferred)
Image path: \SystemRoot\system32\DRIVERS\cdrom.sys
Image name: cdrom.sys
Timestamp: Sat Apr 11 07:34:39 2009 (49E02BEF)
CheckSum: 0001F76A
ImageSize: 0001C000
fffffa60`00de4000 fffffa60`00dfc000 adfs (deferred)
Image path: \SystemRoot\System32\Drivers\adfs.SYS
Image name: adfs.SYS
Timestamp: Thu Jun 26 22:52:37 2008 (48640195)
CheckSum: 00024203
ImageSize: 00018000
fffffa60`00e00000 fffffa60`00fc3000 ndis (deferred)
Image path: \SystemRoot\system32\drivers\ndis.sys
Image name: ndis.sys
Timestamp: Sat Apr 11 07:43:15 2009 (49E02DF3)
CheckSum: 000B4C34
ImageSize: 001C3000
fffffa60`00fc3000 fffffa60`00fef000 CLASSPNP (export symbols) CLASSPNP.SYS
Loaded symbol image file: CLASSPNP.SYS
Image path: \SystemRoot\system32\drivers\CLASSPNP.SYS
Image name: CLASSPNP.SYS
Timestamp: Sat Apr 11 07:34:15 2009 (49E02BD7)
CheckSum: 00033AA3
ImageSize: 0002C000
fffffa60`0100c000 fffffa60`01182000 tcpip (deferred)
Image path: \SystemRoot\System32\drivers\tcpip.sys
Image name: tcpip.sys
Timestamp: Thu Feb 18 13:01:09 2010 (4B7D2C05)
CheckSum: 0015E59F
ImageSize: 00176000
fffffa60`01182000 fffffa60`011ae000 fwpkclnt (deferred)
Image path: \SystemRoot\System32\drivers\fwpkclnt.sys
Image name: fwpkclnt.sys
Timestamp: Sat Apr 11 07:42:44 2009 (49E02DD4)
CheckSum: 0002F708
ImageSize: 0002C000
fffffa60`011ae000 fffffa60`011da000 ecache (deferred)
Image path: \SystemRoot\System32\drivers\ecache.sys
Image name: ecache.sys
Timestamp: Sat Apr 11 07:36:18 2009 (49E02C52)
CheckSum: 0002EA7C
ImageSize: 0002C000
fffffa60`011da000 fffffa60`011ee000 disk (deferred)
Image path: \SystemRoot\system32\drivers\disk.sys
Image name: disk.sys
Timestamp: Sat Apr 11 07:34:38 2009 (49E02BEE)
CheckSum: 0001C619
ImageSize: 00014000
fffffa60`011ee000 fffffa60`011f8000 crcdisk (deferred)
Image path: \SystemRoot\system32\drivers\crcdisk.sys
Image name: crcdisk.sys
Timestamp: Sat Jan 19 07:30:12 2008 (479198F4)
CheckSum: 0001435C
ImageSize: 0000A000
fffffa60`01200000 fffffa60`01380000 Ntfs (deferred)
Image path: \SystemRoot\System32\Drivers\Ntfs.sys
Image name: Ntfs.sys
Timestamp: Sat Apr 11 06:55:38 2009 (49E022CA)
CheckSum: 00179837
ImageSize: 00180000
InternalName: ntfs.sys
OriginalFilename: ntfs.sys
FileDescription: NT File System Driver
fffffa60`01380000 fffffa60`013c4000 volsnap (deferred)
Image path: \SystemRoot\system32\drivers\volsnap.sys
Image name: volsnap.sys
Timestamp: Sat Apr 11 07:35:33 2009 (49E02C25)
CheckSum: 0004B04C
ImageSize: 00044000
fffffa60`013c4000 fffffa60`013cc000 spldr (deferred)
Image path: \SystemRoot\System32\Drivers\spldr.sys
Image name: spldr.sys
Timestamp: Mon Jan 12 22:51:29 2009 (496BBB61)
CheckSum: 0000806F
ImageSize: 00008000
fffffa60`013cc000 fffffa60`013d3000 speedfan (deferred)
Image path: \SystemRoot\SysWOW64\speedfan.sys
Image name: speedfan.sys
Timestamp: Sun Sep 24 15:26:48 2006 (45168798)
CheckSum: 00005062
ImageSize: 00007000
fffffa60`013d3000 fffffa60`013ee000 sbp2port (deferred)
Image path: \SystemRoot\system32\DRIVERS\sbp2port.sys
Image name: sbp2port.sys
Timestamp: Sat Apr 11 07:34:42 2009 (49E02BF2)
CheckSum: 0001F41E
ImageSize: 0001B000
fffffa60`013ee000 fffffa60`01400000 mup (deferred)
Image path: \SystemRoot\System32\Drivers\mup.sys
Image name: mup.sys
Timestamp: Sat Apr 11 06:54:47 2009 (49E02297)
CheckSum: 00012FEF
ImageSize: 00012000
fffffa60`03400000 fffffa60`0340d000 fdc (deferred)
Image path: \SystemRoot\system32\DRIVERS\fdc.sys
Image name: fdc.sys
Timestamp: Sat Jan 19 07:28:45 2008 (4791989D)
CheckSum: 00010F0C
ImageSize: 0000D000
fffffa60`0340e000 fffffa60`03952000 atikmdag (deferred)
Image path: \SystemRoot\system32\DRIVERS\atikmdag.sys
Image name: atikmdag.sys
Timestamp: Wed Feb 04 06:19:13 2009 (49892551)
CheckSum: 004F4C10
ImageSize: 00544000
File version: 7.1.1.871
Product version: 7.1.1.871
File flags: 8 (Mask 3F) Private
File type: 3.4 Driver
CompanyName: ATI Technologies Inc.
ProductName: ATI Radeon Family
InternalName: atikmdag.sys
OriginalFilename: atikmdag.sys
ProductVersion: 7.01.01.871
FileVersion: 7.01.01.871
FileDescription: ATI Radeon Kernel Mode Driver
LegalCopyright: Copyright (C) 1998-2006 ATI Technologies Inc.
fffffa60`03952000 fffffa60`03998000 USBPORT (deferred)
Image path: \SystemRoot\system32\DRIVERS\USBPORT.SYS
Image name: USBPORT.SYS
Timestamp: Sat Apr 11 07:39:39 2009 (49E02D1B)
CheckSum: 00046070
ImageSize: 00046000
File type: 2.0 Dll
InternalName: usbport.sys
OriginalFilename: usbport.sys
FileDescription: USB 1.1 & 2.0 Port Driver
fffffa60`03998000 fffffa60`039fd000 yk60x64 (deferred)
Image path: \SystemRoot\system32\DRIVERS\yk60x64.sys
Image name: yk60x64.sys
Timestamp: Thu Dec 06 14:50:34 2007 (4757FE2A)
CheckSum: 00066200
ImageSize: 00065000
fffffa60`03a00000 fffffa60`03ae3000 dxgkrnl (deferred)
Image path: \SystemRoot\System32\drivers\dxgkrnl.sys
Image name: dxgkrnl.sys
Timestamp: Fri Sep 25 03:27:15 2009 (4ABC1C73)
CheckSum: 000E17BC
ImageSize: 000E3000
fffffa60`03ae3000 fffffa60`03af3000 watchdog (deferred)
Image path: \SystemRoot\System32\drivers\watchdog.sys
Image name: watchdog.sys
Timestamp: Sat Apr 11 07:09:16 2009 (49E025FC)
CheckSum: 00019630
ImageSize: 00010000
File type: 2.0 Dll
InternalName: watchdog.sys
OriginalFilename: watchdog.sys
FileDescription: Watchdog Driver
fffffa60`03af3000 fffffa60`03be0000 HDAudBus (deferred)
Image path: \SystemRoot\system32\DRIVERS\HDAudBus.sys
Image name: HDAudBus.sys
Timestamp: Sat Apr 11 07:39:38 2009 (49E02D1A)
CheckSum: 000F03F1
ImageSize: 000ED000
fffffa60`03be0000 fffffa60`03bec000 usbuhci (deferred)
Image path: \SystemRoot\system32\DRIVERS\usbuhci.sys
Image name: usbuhci.sys
Timestamp: Sat Jan 19 07:33:56 2008 (479199D4)
CheckSum: 00010547
ImageSize: 0000C000
fffffa60`03bec000 fffffa60`03bfd000 usbehci (deferred)
Image path: \SystemRoot\system32\DRIVERS\usbehci.sys
Image name: usbehci.sys
Timestamp: Sat Apr 11 07:39:36 2009 (49E02D18)
CheckSum: 0000DE60
ImageSize: 00011000
fffffa60`03c08000 fffffa60`03c5d000 az1eo4nn (deferred)
Image path: \SystemRoot\System32\Drivers\az1eo4nn.SYS
Image name: az1eo4nn.SYS
Timestamp: Tue Sep 26 13:09:58 2006 (45190A86)
CheckSum: 00046C0E
ImageSize: 00055000
fffffa60`03c5d000 fffffa60`03c96000 msiscsi (deferred)
Image path: \SystemRoot\system32\DRIVERS\msiscsi.sys
Image name: msiscsi.sys
Timestamp: Sat Apr 11 07:36:09 2009 (49E02C49)
CheckSum: 0003EC8E
ImageSize: 00039000
fffffa60`03c96000 fffffa60`03cf3000 storport (deferred)
Image path: \SystemRoot\system32\DRIVERS\storport.sys
Image name: storport.sys
Timestamp: Sat Apr 11 07:34:45 2009 (49E02BF5)
CheckSum: 00032227
ImageSize: 0005D000
InternalName: storport.sys
OriginalFilename: storport.sys
FileDescription: Microsoft Storage Port Driver
fffffa60`03cf3000 fffffa60`03d00000 TDI (deferred)
Image path: \SystemRoot\system32\DRIVERS\TDI.SYS
Image name: TDI.SYS
Timestamp: Sat Apr 11 07:44:14 2009 (49E02E2E)
CheckSum: 0000C014
ImageSize: 0000D000
File type: 3.6 Driver
InternalName: tdi.sys
OriginalFilename: tdi.sys
FileDescription: TDI Wrapper
fffffa60`03d00000 fffffa60`03d23000 rasl2tp (deferred)
Image path: \SystemRoot\system32\DRIVERS\rasl2tp.sys
Image name: rasl2tp.sys
Timestamp: Sat Apr 11 07:43:37 2009 (49E02E09)
CheckSum: 00028BFC
ImageSize: 00023000
fffffa60`03d23000 fffffa60`03d2f000 ndistapi (deferred)
Image path: \SystemRoot\system32\DRIVERS\ndistapi.sys
Image name: ndistapi.sys
Timestamp: Sat Jan 19 07:37:22 2008 (47919AA2)
CheckSum: 0000CA62
ImageSize: 0000C000
fffffa60`03d2f000 fffffa60`03d60000 ndiswan (deferred)
Image path: \SystemRoot\system32\DRIVERS\ndiswan.sys
Image name: ndiswan.sys
Timestamp: Sat Apr 11 07:43:39 2009 (49E02E0B)
CheckSum: 00029ED4
ImageSize: 00031000
fffffa60`03d60000 fffffa60`03d70000 raspppoe (deferred)
Image path: \SystemRoot\system32\DRIVERS\raspppoe.sys
Image name: raspppoe.sys
Timestamp: Sat Apr 11 07:43:33 2009 (49E02E05)
CheckSum: 00015E5B
ImageSize: 00010000
fffffa60`03d70000 fffffa60`03d8e000 raspptp (deferred)
Image path: \SystemRoot\system32\DRIVERS\raspptp.sys
Image name: raspptp.sys
Timestamp: Sat Apr 11 07:43:38 2009 (49E02E0A)
CheckSum: 0001FAEE
ImageSize: 0001E000
fffffa60`03d8e000 fffffa60`03da6000 rassstp (deferred)
Image path: \SystemRoot\system32\DRIVERS\rassstp.sys
Image name: rassstp.sys
Timestamp: Sat Apr 11 07:43:46 2009 (49E02E12)
CheckSum: 0001B5E9
ImageSize: 00018000
fffffa60`03da6000 fffffa60`03dae000 PdiPorts (deferred)
Image path: \SystemRoot\system32\DRIVERS\PdiPorts.sys
Image name: PdiPorts.sys
Timestamp: Fri Nov 17 01:31:16 2006 (455D02D4)
CheckSum: 0000E8C4
ImageSize: 00008000
fffffa60`03dae000 fffffa60`03dc1000 termdd (deferred)
Image path: \SystemRoot\system32\DRIVERS\termdd.sys
Image name: termdd.sys
Timestamp: Sat Apr 11 07:48:13 2009 (49E02F1D)
CheckSum: 0001B681
ImageSize: 00013000
fffffa60`03dc1000 fffffa60`03dcf000 kbdclass (deferred)
Image path: \SystemRoot\system32\DRIVERS\kbdclass.sys
Image name: kbdclass.sys
Timestamp: Sat Jan 19 07:28:05 2008 (47919875)
CheckSum: 0000AF5D
ImageSize: 0000E000
fffffa60`03dcf000 fffffa60`03ddb000 mouclass (deferred)
Image path: \SystemRoot\system32\DRIVERS\mouclass.sys
Image name: mouclass.sys
CheckSum: 00017BB4
ImageSize: 0000C000
fffffa60`03ddb000 fffffa60`03ddc480 swenum (deferred)
Image path: \SystemRoot\system32\DRIVERS\swenum.sys
Image name: swenum.sys
Timestamp: Thu Nov 02 10:37:33 2006 (4549BC5D)
CheckSum: 0000447A
ImageSize: 00001480
fffffa60`03ddd000 fffffa60`03df7000 mpsdrv (deferred)
Image path: \SystemRoot\System32\drivers\mpsdrv.sys
Image name: mpsdrv.sys
Timestamp: Sat Jan 19 07:35:28 2008 (47919A30)
CheckSum: 000167F0
ImageSize: 0001A000
fffffa60`03e0b000 fffffa60`03e3f000 ks (deferred)
Image path: \SystemRoot\system32\DRIVERS\ks.sys
Image name: ks.sys
Timestamp: Sat Apr 11 07:33:51 2009 (49E02BBF)
CheckSum: 0003990E
ImageSize: 00034000
File type: 3.0 Driver
InternalName: ks.sys
OriginalFilename: ks.sys
FileDescription: Kernel CSA Library
fffffa60`03e3f000 fffffa60`03e43c80 WmBEnum (deferred)
Image path: \SystemRoot\system32\drivers\WmBEnum.sys
Image name: WmBEnum.sys
Timestamp: Fri Sep 11 21:40:09 2009 (4AAAA799)
CheckSum: 000158A9
ImageSize: 00004C80
fffffa60`03e44000 fffffa60`03e55100 WmXlCore (deferred)
Image path: \SystemRoot\system32\drivers\WmXlCore.sys
Image name: WmXlCore.sys
Timestamp: Fri Sep 11 21:40:07 2009 (4AAAA797)
CheckSum: 0001FA2F
ImageSize: 00011100
fffffa60`03e56000 fffffa60`03e61000 mssmbios (deferred)
Image path: \SystemRoot\system32\DRIVERS\mssmbios.sys
Image name: mssmbios.sys
Timestamp: Sat Jan 19 07:02:54 2008 (4791928E)
CheckSum: 0000EECB
ImageSize: 0000B000
fffffa60`03e61000 fffffa60`03e71000 umbus (deferred)
Image path: \SystemRoot\system32\DRIVERS\umbus.sys
Image name: umbus.sys
Timestamp: Sat Jan 19 07:34:16 2008 (479199E8)
CheckSum: 0001333F
ImageSize: 00010000
fffffa60`03e71000 fffffa60`03eb9000 usbhub (deferred)
Image path: \SystemRoot\system32\DRIVERS\usbhub.sys
Image name: usbhub.sys
Timestamp: Sat Apr 11 07:39:52 2009 (49E02D28)
CheckSum: 0004C820
ImageSize: 00048000
fffffa60`03eb9000 fffffa60`03ec4000 flpydisk (deferred)
Image path: \SystemRoot\system32\DRIVERS\flpydisk.sys
Image name: flpydisk.sys
CheckSum: 0001588D
ImageSize: 0000B000
fffffa60`03ec4000 fffffa60`03ed8000 NDProxy (deferred)
Image path: \SystemRoot\System32\Drivers\NDProxy.SYS
Image name: NDProxy.SYS
Timestamp: Sat Jan 19 07:37:26 2008 (47919AA6)
CheckSum: 0001366B
ImageSize: 00014000
fffffa60`03ed8000 fffffa60`03f21000 HdAudio (deferred)
Image path: \SystemRoot\system32\drivers\HdAudio.sys
Image name: HdAudio.sys
Timestamp: Sat Apr 11 07:39:51 2009 (49E02D27)
CheckSum: 00043FB3
ImageSize: 00049000
fffffa60`03f21000 fffffa60`03f5c000 portcls (deferred)
Image path: \SystemRoot\system32\drivers\portcls.sys
Image name: portcls.sys
CheckSum: 0003AE69
ImageSize: 0003B000
File type: 3.9 Driver
InternalName: portcls.sys
OriginalFilename: portcls.sys
FileDescription: Port Class (Class Driver for Port/Miniport Devices)
fffffa60`03f5c000 fffffa60`03f7f000 drmk (deferred)
Image path: \SystemRoot\system32\drivers\drmk.sys
Image name: drmk.sys
Timestamp: Sat Jan 19 08:20:04 2008 (4791A4A4)
CheckSum: 00022D56
ImageSize: 00023000
File type: 2.0 Dll
InternalName: drmk.sys
OriginalFilename: drmk.sys
FileDescription: Microsoft Kernel DRM Descrambler Filter
fffffa60`03f7f000 fffffa60`03f84180 ksthunk (deferred)
Image path: \SystemRoot\system32\drivers\ksthunk.sys
Image name: ksthunk.sys
Timestamp: Sat Jan 19 07:28:14 2008 (4791987E)
CheckSum: 0000A913
ImageSize: 00005180
fffffa60`03f85000 fffffa60`03ffc000 ADIHdAud (deferred)
Image path: \SystemRoot\system32\drivers\ADIHdAud.sys
Image name: ADIHdAud.sys
Timestamp: Thu Mar 20 13:44:33 2008 (47E25C31)
CheckSum: 00078D83
ImageSize: 00077000
fffffa60`0480c000 fffffa60`04839000 MpFilter (deferred)
Image path: \SystemRoot\system32\DRIVERS\MpFilter.sys
Image name: MpFilter.sys
Timestamp: Sat Nov 21 03:56:47 2009 (4B0756EF)
CheckSum: 00035D94
ImageSize: 0002D000
fffffa60`04839000 fffffa60`04843000 Fs_Rec (deferred)
Image path: \SystemRoot\System32\Drivers\Fs_Rec.SYS
Image name: Fs_Rec.SYS
Timestamp: Sat Jan 19 06:53:41 2008 (47919065)
CheckSum: 0000F90C
ImageSize: 0000A000
fffffa60`04843000 fffffa60`0484c000 Null (deferred)
Image path: \SystemRoot\System32\Drivers\Null.SYS
Image name: Null.SYS
Timestamp: Thu Nov 02 10:37:15 2006 (4549BC4B)
CheckSum: 0000B49D
ImageSize: 00009000
fffffa60`04857000 fffffa60`0485eb80 HIDPARSE (deferred)
Image path: \SystemRoot\system32\DRIVERS\HIDPARSE.SYS
Image name: HIDPARSE.SYS
Timestamp: Sat Jan 19 07:33:51 2008 (479199CF)
CheckSum: 0001084B
ImageSize: 00007B80
File type: 2.0 Dll
InternalName: hidparse.sys
OriginalFilename: hidparse.sys
FileDescription: Hid Parsing Library
fffffa60`0485f000 fffffa60`0486d000 vga (deferred)
Image path: \SystemRoot\System32\drivers\vga.sys
Image name: vga.sys
Timestamp: Sat Jan 19 07:32:21 2008 (47919975)
CheckSum: 00007D47
ImageSize: 0000E000
fffffa60`0486d000 fffffa60`04892000 VIDEOPRT (deferred)
Image path: \SystemRoot\System32\drivers\VIDEOPRT.SYS
Image name: VIDEOPRT.SYS
Timestamp: Sat Jan 19 07:32:25 2008 (47919979)
CheckSum: 00027AC2
ImageSize: 00025000
InternalName: videoprt.sys
OriginalFilename: videoprt.sys
FileDescription: Video Port Driver
fffffa60`04892000 fffffa60`0489b000 RDPCDD (deferred)
Image path: \SystemRoot\System32\DRIVERS\RDPCDD.sys
Image name: RDPCDD.sys
CheckSum: 0000B335
ImageSize: 00009000
fffffa60`0489b000 fffffa60`048a4000 rdpencdd (deferred)
Image path: \SystemRoot\system32\drivers\rdpencdd.sys
Image name: rdpencdd.sys
Timestamp: Sat Jan 19 07:42:03 2008 (47919BBB)
CheckSum: 00003BDB
ImageSize: 00009000
fffffa60`048a4000 fffffa60`048af000 Msfs (deferred)
Image path: \SystemRoot\System32\Drivers\Msfs.SYS
Image name: Msfs.SYS
Timestamp: Sat Jan 19 06:53:55 2008 (47919073)
CheckSum: 00008E66
ImageSize: 0000B000
fffffa60`048af000 fffffa60`048c0000 Npfs (deferred)
Image path: \SystemRoot\System32\Drivers\Npfs.SYS
Image name: Npfs.SYS
Timestamp: Sat Apr 11 06:54:22 2009 (49E0227E)
CheckSum: 000193D4
ImageSize: 00011000
fffffa60`048c0000 fffffa60`048c9000 rasacd (deferred)
Image path: \SystemRoot\System32\DRIVERS\rasacd.sys
Image name: rasacd.sys
Timestamp: Sat Jan 19 07:37:30 2008 (47919AAA)
CheckSum: 0000DB26
ImageSize: 00009000
fffffa60`048c9000 fffffa60`048e6000 tdx (deferred)
Image path: \SystemRoot\system32\DRIVERS\tdx.sys
Image name: tdx.sys
Timestamp: Sat Apr 11 07:43:00 2009 (49E02DE4)
CheckSum: 00022F45
ImageSize: 0001D000
fffffa60`048e6000 fffffa60`04901000 smb (deferred)
Image path: \SystemRoot\system32\DRIVERS\smb.sys
Image name: smb.sys
Timestamp: Sat Apr 11 07:42:19 2009 (49E02DBB)
CheckSum: 0001FBF4
ImageSize: 0001B000
fffffa60`04901000 fffffa60`0496c000 afd (deferred)
Image path: \SystemRoot\system32\drivers\afd.sys
Image name: afd.sys
Timestamp: Sat Apr 11 07:44:21 2009 (49E02E35)
CheckSum: 0006F99A
ImageSize: 0006B000
fffffa60`0496c000 fffffa60`049b0000 netbt (deferred)
Image path: \SystemRoot\System32\DRIVERS\netbt.sys
Image name: netbt.sys
Timestamp: Sat Apr 11 07:42:31 2009 (49E02DC7)
CheckSum: 0004C008
ImageSize: 00044000
fffffa60`049b0000 fffffa60`049ce000 pacer (deferred)
Image path: \SystemRoot\system32\DRIVERS\pacer.sys
Image name: pacer.sys
Timestamp: Sat Apr 11 07:42:56 2009 (49E02DE0)
CheckSum: 0001AEBA
ImageSize: 0001E000
fffffa60`049ce000 fffffa60`049dd000 netbios (deferred)
Image path: \SystemRoot\system32\DRIVERS\netbios.sys
Image name: netbios.sys
Timestamp: Sat Jan 19 07:36:35 2008 (47919A73)
CheckSum: 00015AAA
ImageSize: 0000F000
fffffa60`049dd000 fffffa60`049e4000 TVicPort64 (deferred)
Image path: \??\C:\Windows\SysWOW64\drivers\TVicPort64.sys
Image name: TVicPort64.sys
Timestamp: Wed Mar 30 11:12:54 2005 (424A6D96)
CheckSum: 00007AD0
ImageSize: 00007000
fffffa60`049e4000 fffffa60`049ff000 wanarp (deferred)
Image path: \SystemRoot\system32\DRIVERS\wanarp.sys
Image name: wanarp.sys
CheckSum: 0001BFAA
ImageSize: 0001B000
fffffa60`04a04000 fffffa60`04a51000 rdbss (deferred)
Image path: \SystemRoot\system32\DRIVERS\rdbss.sys
Image name: rdbss.sys
Timestamp: Sat Apr 11 06:55:21 2009 (49E022B9)
CheckSum: 0004FC14
ImageSize: 0004D000
fffffa60`04a51000 fffffa60`04a5d000 nsiproxy (deferred)
Image path: \SystemRoot\system32\drivers\nsiproxy.sys
Image name: nsiproxy.sys
Timestamp: Sat Jan 19 07:36:45 2008 (47919A7D)
CheckSum: 00013617
ImageSize: 0000C000
fffffa60`04a5d000 fffffa60`04a7a000 dfsc (deferred)
Image path: \SystemRoot\System32\Drivers\dfsc.sys
Image name: dfsc.sys
Timestamp: Sat Apr 11 06:54:44 2009 (49E02294)
CheckSum: 00019214
ImageSize: 0001D000
fffffa60`04a7a000 fffffa60`04a81000 AsIO (deferred)
Image path: \SystemRoot\SysWow64\drivers\AsIO.sys
Image name: AsIO.sys
Timestamp: Mon Dec 17 10:11:49 2007 (47663D55)
CheckSum: 00008D1F
ImageSize: 00007000
fffffa60`04a81000 fffffa60`04a9d000 cdfs (deferred)
Image path: \SystemRoot\system32\DRIVERS\cdfs.sys
Image name: cdfs.sys
Timestamp: Sat Jan 19 06:53:45 2008 (47919069)
CheckSum: 0001CCC4
ImageSize: 0001C000
fffffa60`04a9d000 fffffa60`04aa6000 hidusb (deferred)
Image path: \SystemRoot\system32\DRIVERS\hidusb.sys
Image name: hidusb.sys
Timestamp: Sat Apr 11 07:39:32 2009 (49E02D14)
CheckSum: 0000A824
ImageSize: 00009000
fffffa60`04aa6000 fffffa60`04ab8000 HIDCLASS (deferred)
Image path: \SystemRoot\system32\DRIVERS\HIDCLASS.SYS
Image name: HIDCLASS.SYS
CheckSum: 0001609C
ImageSize: 00012000
File type: 2.0 Dll
InternalName: hidclass.sys
OriginalFilename: hidclass.sys
FileDescription: Hid Class Library
fffffa60`04ab8000 fffffa60`04ab9e00 USBD (deferred)
Image path: \SystemRoot\system32\DRIVERS\USBD.SYS
Image name: USBD.SYS
Timestamp: Sat Jan 19 07:33:53 2008 (479199D1)
CheckSum: 00010C2B
ImageSize: 00001E00
File type: 2.0 Dll
InternalName: usbd.sys
OriginalFilename: usbd.sys
FileDescription: Universal Serial Bus Driver
fffffa60`04aba000 fffffa60`04ac2680 WmFilter (deferred)
Image path: \SystemRoot\system32\drivers\WmFilter.sys
Image name: WmFilter.sys
CheckSum: 00012FEF
ImageSize: 00008680
fffffa60`04ac3000 fffffa60`04ad1000 crashdmp (deferred)
Image path: \SystemRoot\System32\Drivers\crashdmp.sys
Image name: crashdmp.sys
Timestamp: Sat Apr 11 07:34:31 2009 (49E02BE7)
CheckSum: 0000B10F
ImageSize: 0000E000
InternalName: crashdmp.sys
OriginalFilename: crashdmp.sys
FileDescription: Crash Dump Driver
fffffa60`04ad1000 fffffa60`04add000 dump_dumpata (deferred)
Image path: \SystemRoot\System32\Drivers\dump_dumpata.sys
Image name: dump_dumpata.sys
CheckSum: 0000E322
ImageSize: 0000C000
InternalName: dumpata.sys
OriginalFilename: dumpata.sys
FileDescription: ATAPI Dump Driver
fffffa60`04add000 fffffa60`04ae5000 dump_atapi (deferred)
Image path: \SystemRoot\System32\Drivers\dump_atapi.sys
Image name: dump_atapi.sys
CheckSum: 000112F5
ImageSize: 00008000
InternalName: atapi.sys
OriginalFilename: atapi.sys
FileDescription: ATAPI IDE Miniport Driver
fffffa60`04ae5000 fffffa60`04b01000 usbccgp (deferred)
Image path: \SystemRoot\system32\DRIVERS\usbccgp.sys
Image name: usbccgp.sys
CheckSum: 000229C9
ImageSize: 0001C000
fffffa60`04b01000 fffffa60`04b14000 LHidFilt (deferred)
Image path: \SystemRoot\system32\DRIVERS\LHidFilt.Sys
Image name: LHidFilt.Sys
Timestamp: Fri Feb 29 11:08:27 2008 (47C7D99B)
CheckSum: 0000FBB4
ImageSize: 00013000
fffffa60`04b14000 fffffa60`04b1f000 kbdhid (deferred)
Image path: \SystemRoot\system32\DRIVERS\kbdhid.sys
Image name: kbdhid.sys
Timestamp: Sat Apr 11 07:33:40 2009 (49E02BB4)
CheckSum: 0000C1A4
ImageSize: 0000B000
fffffa60`04b1f000 fffffa60`04b2a000 mouhid (deferred)
Image path: \SystemRoot\system32\DRIVERS\mouhid.sys
Image name: mouhid.sys
Timestamp: Sat Jan 19 07:28:10 2008 (4791987A)
CheckSum: 0000DA7D
ImageSize: 0000B000
fffffa60`04b2a000 fffffa60`04b3e000 LMouFilt (deferred)
Image path: \SystemRoot\system32\DRIVERS\LMouFilt.Sys
Image name: LMouFilt.Sys
Timestamp: Fri Feb 29 11:08:31 2008 (47C7D99F)
CheckSum: 000168EC
ImageSize: 00014000
fffffa60`04b3e000 fffffa60`04bb3000 fwlanusb (deferred)
Image path: \SystemRoot\system32\DRIVERS\fwlanusb.sys
Image name: fwlanusb.sys
Timestamp: Thu Dec 14 18:04:55 2006 (45818437)
CheckSum: 00070E59
ImageSize: 00075000
fffffa60`04bb3000 fffffa60`04bbf000 Dxapi (deferred)
Image path: \SystemRoot\System32\drivers\Dxapi.sys
Image name: Dxapi.sys
Timestamp: Sat Jan 19 07:08:00 2008 (479193C0)
CheckSum: 00007785
ImageSize: 0000C000
InternalName: dxapi.sys
OriginalFilename: dxapi.sys
FileDescription: DirectX API Driver
fffffa60`04bbf000 fffffa60`04bd2000 monitor (deferred)
Image path: \SystemRoot\system32\DRIVERS\monitor.sys
Image name: monitor.sys
Timestamp: Sat Jan 19 07:32:34 2008 (47919982)
CheckSum: 0001BE53
ImageSize: 00013000
fffffa60`04bd2000 fffffa60`04bf4000 luafv (deferred)
Image path: \SystemRoot\system32\drivers\luafv.sys
Image name: luafv.sys
Timestamp: Sat Jan 19 06:59:06 2008 (479191AA)
CheckSum: 0001E74E
ImageSize: 00022000
fffffa60`06204000 fffffa60`0629e000 spsys (deferred)
Image path: \SystemRoot\system32\drivers\spsys.sys
Image name: spsys.sys
Timestamp: Tue Mar 10 18:16:43 2009 (49B6A07B)
CheckSum: 0009AA05
ImageSize: 0009A000
File version: 6.0.6002.17040
Product version: 6.0.6002.17040
InternalName: spsys.sys
OriginalFilename: spsys.sys
ProductVersion: 6.0.6002.17040
FileVersion: 6.0.6002.17040 (longhorn(sepbld-s).090310-1003)
FileDescription: security processor
fffffa60`0629e000 fffffa60`062b2000 lltdio (deferred)
Image path: \SystemRoot\system32\DRIVERS\lltdio.sys
Image name: lltdio.sys
Timestamp: Sat Jan 19 07:35:48 2008 (47919A44)
CheckSum: 000186DE
ImageSize: 00014000
fffffa60`062b2000 fffffa60`062e6000 nwifi (deferred)
Image path: \SystemRoot\system32\DRIVERS\nwifi.sys
Image name: nwifi.sys
Timestamp: Sat Apr 11 07:40:19 2009 (49E02D43)
CheckSum: 0002DF25
ImageSize: 00034000
fffffa60`062e6000 fffffa60`062f1000 ndisuio (deferred)
Image path: \SystemRoot\system32\DRIVERS\ndisuio.sys
Image name: ndisuio.sys
Timestamp: Sat Jan 19 07:36:29 2008 (47919A6D)
CheckSum: 0001472B
ImageSize: 0000B000
fffffa60`062f1000 fffffa60`06309000 rspndr (deferred)
Image path: \SystemRoot\system32\DRIVERS\rspndr.sys
Image name: rspndr.sys
CheckSum: 000132AD
ImageSize: 00018000
fffffa60`06309000 fffffa60`063ac000 HTTP (deferred)
Image path: \SystemRoot\system32\drivers\HTTP.sys
Image name: HTTP.sys
Timestamp: Sat Feb 20 22:30:05 2010 (4B80545D)
CheckSum: 0009BA1A
ImageSize: 000A3000
fffffa60`063ac000 fffffa60`063d5000 srvnet (deferred)
Image path: \SystemRoot\System32\DRIVERS\srvnet.sys
Image name: srvnet.sys
Timestamp: Fri Dec 11 13:03:47 2009 (4B223523)
CheckSum: 00030E2C
ImageSize: 00029000
fffffa60`063d5000 fffffa60`063f3000 bowser (deferred)
Image path: \SystemRoot\system32\DRIVERS\bowser.sys
Image name: bowser.sys
Timestamp: Sat Jan 19 06:54:51 2008 (479190AB)
CheckSum: 00021CAB
ImageSize: 0001E000
fffffa60`0660c000 fffffa60`06633000 mrxdav (deferred)
Image path: \SystemRoot\system32\drivers\mrxdav.sys
Image name: mrxdav.sys
Timestamp: Sat Apr 11 06:55:42 2009 (49E022CE)
CheckSum: 0002F134
ImageSize: 00027000
fffffa60`06633000 fffffa60`0665c000 mrxsmb (deferred)
Image path: \SystemRoot\system32\DRIVERS\mrxsmb.sys
Image name: mrxsmb.sys
Timestamp: Tue Feb 23 12:32:22 2010 (4B83BCC6)
CheckSum: 0002FFC0
ImageSize: 00029000
fffffa60`0665c000 fffffa60`066a5000 mrxsmb10 (deferred)
Image path: \SystemRoot\system32\DRIVERS\mrxsmb10.sys
Image name: mrxsmb10.sys
Timestamp: Tue Feb 23 12:32:21 2010 (4B83BCC5)
CheckSum: 00044B25
ImageSize: 00049000
fffffa60`066a5000 fffffa60`066c4000 mrxsmb20 (deferred)
Image path: \SystemRoot\system32\DRIVERS\mrxsmb20.sys
Image name: mrxsmb20.sys
Timestamp: Tue Feb 23 12:32:20 2010 (4B83BCC4)
CheckSum: 0001F056
ImageSize: 0001F000
fffffa60`066c4000 fffffa60`066f6000 srv2 (deferred)
Image path: \SystemRoot\System32\DRIVERS\srv2.sys
Image name: srv2.sys
Timestamp: Mon Sep 14 11:45:22 2009 (4AAE10B2)
CheckSum: 0002B62B
ImageSize: 00032000
fffffa60`066f6000 fffffa60`0678b000 srv (deferred)
Image path: \SystemRoot\System32\DRIVERS\srv.sys
Image name: srv.sys
Timestamp: Fri Dec 11 13:04:08 2009 (4B223538)
CheckSum: 0007607A
ImageSize: 00095000
fffffa60`0678b000 fffffa60`06796000 asyncmac (deferred)
Image path: \SystemRoot\system32\DRIVERS\asyncmac.sys
Image name: asyncmac.sys
Timestamp: Sat Jan 19 07:37:27 2008 (47919AA7)
CheckSum: 00005CC4
ImageSize: 0000B000
fffffa60`06796000 fffffa60`067a6000 MpNWMon (deferred)
Image path: \SystemRoot\system32\DRIVERS\MpNWMon.sys
Image name: MpNWMon.sys
Timestamp: Sat Nov 21 03:56:38 2009 (4B0756E6)
CheckSum: 0000AF59
ImageSize: 00010000
fffffa60`067a6000 fffffa60`067fc000 acedrv11 (deferred)
Image path: \??\C:\Windows\system32\drivers\acedrv11.sys
Image name: acedrv11.sys
Timestamp: Mon Jan 19 19:32:09 2009 (4974C729)
CheckSum: 00056117
ImageSize: 00056000
File version: 11.0.0.12
Product version: 9.0.0.0
CompanyName: Protect Software GmbH
ProductName: ProtectDisc x64/x86 Hybrid Driver
InternalName: acedrv.sys
OriginalFilename: acedrv.sys
ProductVersion: 9.0.0.0
FileVersion: 11.0.0.12 built by: WinDDK
FileDescription: ProtectDisc x64/x86 Hybrid Driver
LegalCopyright: Copyright (C) 1995-2009 Protect Software GmbH
fffffa60`07005000 fffffa60`070bb000 peauth (deferred)
Image path: \SystemRoot\system32\drivers\peauth.sys
Image name: peauth.sys
Timestamp: Mon Oct 23 13:57:00 2006 (453CAE0C)
CheckSum: 000AE0B2
ImageSize: 000B6000
File version: 6.0.5840.16385
Product version: 6.0.5840.16385
InternalName: PEAuth.sys
OriginalFilename: PEAuth.sys
ProductVersion: 6.0.5840.16385
FileVersion: 6.0.5840.16385 (VISTA_RTM_CLIENT_akaDMD.061022-1800)
FileDescription: Protected Environment Authentication and Authorization Export Driver
fffffa60`070bb000 fffffa60`070c6000 secdrv (deferred)
Image path: \SystemRoot\System32\Drivers\secdrv.SYS
Image name: secdrv.SYS
Timestamp: Wed Sep 13 15:18:38 2006 (4508052E)
CheckSum: 00010B40
ImageSize: 0000B000
fffffa60`070c6000 fffffa60`070d6000 tcpipreg (deferred)
Image path: \SystemRoot\System32\drivers\tcpipreg.sys
Image name: tcpipreg.sys
Timestamp: Tue Dec 08 18:55:32 2009 (4B1E9314)
CheckSum: 000171C3
ImageSize: 00010000
fffffa60`070d6000 fffffa60`0710b000 fastfat (deferred)
Image path: \SystemRoot\System32\Drivers\fastfat.SYS
Image name: fastfat.SYS
Timestamp: Sat Apr 11 06:54:10 2009 (49E02272)
CheckSum: 0003DE0E
ImageSize: 00035000
fffffa60`0710b000 fffffa60`0710d400 WmVirHid (deferred)
Image path: \SystemRoot\system32\drivers\WmVirHid.sys
Image name: WmVirHid.sys
Timestamp: Fri Sep 11 21:40:05 2009 (4AAAA795)
CheckSum: 0000B268
ImageSize: 00002400
Unloaded modules:
Timestamp: unavailable (00000000)
Checksum: 00000000
fffffa60`01000000 fffffa60`0100c000 dump_ataport.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
0: kd> lmvm Unknown_Module
start end module name
Gametap wird ganz bestimmt nicht der Grund für die Bluescreens sein.
Die Problematik ist tiefergehend. Laut den Auswertungen (BugCheck 101, BugCheck A) spielen systemrelevante Prozesse / Treiber verrückt, die auf Hardwareprobleme (evtl. auch Energieprobleme) hindeuten.
Mache bitte mal ein paar Screenshots mit CPU-Z (Reiter CPU, Mainboard, SPD und Memory).
Liste bitte auch noch deine komplette Hardware auf (insbes. Netzteil).
Einen Verdacht hätte ich trotzdem. In der zweiten Auswertung fallen die sptd.sys und CLASSPNP.SYS auf. Wenn du Daemon Tools installiert hast, deinstalliere es bitte und berichte, ob die Bugcheck 101 Fehlermeldungen ausbleiben.
Bezüglich des Verdachts, lies bitte noch mal den letzten Bluescreen aus "!analyze -v" und gib danach "lmvm Unknown_Module" ein (ohne "").
Ich hoffe in den erweiterten Systemeinstellung ist die Einstellung, dass die Minidumps überschrieben werden deaktiviert, ansonsten wäre die spezielle minidump vermutlich nicht mehr vorhanden.
danke erstmal für die Antwort.
Hier erstmal die Bilder von CPU-Z:
Die Hardware:
CPU: Intel Core 2 Quad Q9550
MB: Intel Core 2 Quad Q9550
Ram: 4GB DDR2 Corsair Twin2X CL5, PC6400/800
GPU: Sapphire HD4870 512MB GDDR5
NT: Coolermaster M520 modular
HDD: WD Caviar SE16 320GB SATA II 16MB
LW: LG GH22LS30 bare schwarz SATA II Lightscribe
Daemon Tools hab ich bei mir nicht installiert.
Wegen dem dritten, naja die is nun überschrieben. Hab das jetzt aber geändert, das der nicht mehr überschreibt. Auch das Wiederherstellen glückte aufgrund der Überschreibung nicht.
Hoffe du kannst damit erstmal was anfangen.
Heute hatte ich jedenfalls wieder einen Bluescreen:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*C:\Symbols*Symbol information
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 6002.18209.amd64fre.vistasp2_gdr.100218-0019
Machine Name:
Kernel base = 0xfffff800`02856000 PsLoadedModuleList = 0xfffff800`02a1add0
Debug session time: Tue May 4 17:17:15.659 2010 (GMT+2)
System Uptime: 0 days 0:11:14.409
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000007ff`fffd5018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {fffff4e009d085d4, 2, 0, fffff800028a7e10}
Page a57ed not present in the dump file. Type ".hh dbgerr004" for details
Probably caused by : ntkrnlmp.exe ( nt!KiPageFault+20b )
Followup: MachineOwner
3: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffff4e009d085d4, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff800028a7e10, address which referenced memory
Debugging Details:
READ_ADDRESS: fffff4e009d085d4
CURRENT_IRQL: 2
FAULTING_IP:
nt!memcpy+b0
fffff800`028a7e10 488b040a mov rax,qword ptr [rdx+rcx]
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: svchost.exe
TRAP_FRAME: fffffa6006b6b620 -- (.trap 0xfffffa6006b6b620)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=000000004fbebccb rbx=0000000000000000 rcx=fffffa6006b6b804
rdx=fffffa800319cdd0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800028a7e10 rsp=fffffa6006b6b7b8 rbp=0000000000000000
r8=0000000000000030 r9=0000000000000001 r10=0000058000000000
r11=fffffa6006b6b830 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe cy
nt!memcpy+0xb0:
fffff800`028a7e10 488b040a mov rax,qword ptr [rdx+rcx] ds:6650:85d4=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff800028b026e to fffff800028b04d0
STACK_TEXT:
fffffa60`06b6b4d8 fffff800`028b026e : 00000000`0000000a fffff4e0`09d085d4 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffffa60`06b6b4e0 fffff800`028af14b : 00000000`00000000 fffff800`028a9eff fffff880`11600000 fffffa80`07c04006 : nt!KiBugCheckDispatch+0x6e
fffffa60`06b6b620 fffff800`028a7e10 : fffff800`02937903 fffffa80`059fd000 00000000`000018c0 00000000`00000000 : nt!KiPageFault+0x20b
fffffa60`06b6b7b8 fffff800`02937903 : fffffa80`059fd000 00000000`000018c0 00000000`00000000 fffff800`029e8160 : nt!memcpy+0xb0
fffffa60`06b6b7c0 fffff800`0295266c : 00000000`0010899e fffffa80`059fe0f0 fffffa80`07c04060 00000000`00000000 : nt!MiIdentifyPfn+0x43
fffffa60`06b6b860 fffff800`02c43a05 : fffffa80`059fd000 fffffa60`06b6bca0 fffffa60`06b6b928 00000000`00000000 : nt!MmQueryPfnList+0x13c
fffffa60`06b6b8a0 fffff800`02b88b3c : 00000000`00000000 00000000`00000000 fffffa80`059fd000 00000000`04c98f01 : nt!PfpPfnPrioRequest+0x115
fffffa60`06b6b8f0 fffff800`02b2097b : 00000000`00000000 00000000`04c98ff0 00000000`0374ea50 00000000`00000201 : nt! ?? ::NNGAKEGL::`string'+0x4a26a
fffffa60`06b6b960 fffff800`028aff73 : fffffa80`07c04060 00000000`04c98ff0 00000000`03e0a1e0 00000000`00000000 : nt!NtQuerySystemInformation+0xe4b
fffffa60`06b6bc20 00000000`7769707a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0374e9a8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7769707a
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!KiPageFault+20b
fffff800`028af14b 488b0506e31c00 mov rax,qword ptr [nt!KiInterlockedPopEntrySListResumeEntryPoint (fffff800`02a7d458)]
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: nt!KiPageFault+20b
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4b7d238f
FAILURE_BUCKET_ID: X64_0xA_nt!KiPageFault+20b
3: kd> lmvm Unknown_Module
3: kd> lmv
fffff800`02810000 fffff800`02856000 hal (deferred)
Image path: hal.dll
Image name: hal.dll
CheckSum: 0003D17E
ImageSize: 00046000
File type: 2.0 Dll
fffff800`02856000 fffff800`02d6d000 nt (pdb symbols) c:\symbols\ntkrnlmp.pdb\41536C33A33844E79C3A08D47B6F967F2\ntkrnlmp.pdb
CheckSum: 00483E07
ImageSize: 00517000
File type: 1.0 App
fffff960`00030000 fffff960`002e4000 win32k (deferred)
CheckSum: 002A4EC1
ImageSize: 002B4000
fffff960`00450000 fffff960`0045a000 TSDDD (deferred)
CheckSum: 00012267
ImageSize: 0000A000
Page a3e7f not present in the dump file. Type ".hh dbgerr004" for details
fffff960`006f0000 fffff960`00701000 cdd (deferred)
Image name: cdd.dll
CheckSum: 0000E59E
ImageSize: 00011000
fffff960`00880000 fffff960`008e1000 ATMFD (deferred)
CheckSum: 00064BB1
ImageSize: 00061000
Page a0bcb not present in the dump file. Type ".hh dbgerr004" for details
fffffa60`00602000 fffffa60`0060c000 kdcom (deferred)
CheckSum: 0000C7BC
ImageSize: 0000A000
fffffa60`0060c000 fffffa60`00647000 mcupdate_GenuineIntel (deferred)
CheckSum: 0003DEC1
ImageSize: 0003B000
fffffa60`00647000 fffffa60`0065b000 PSHED (deferred)
CheckSum: 0001C903
ImageSize: 00014000
fffffa60`0065b000 fffffa60`006b8000 CLFS (deferred)
CheckSum: 0006013C
ImageSize: 0005D000
fffffa60`006b8000 fffffa60`0076a000 CI (deferred)
Image name: CI.dll
CheckSum: 0006295F
ImageSize: 000B2000
fffffa60`0076a000 fffffa60`007ae000 mv61xx (deferred)
CheckSum: 00036100
ImageSize: 00044000
fffffa60`007ae000 fffffa60`007f5000 fltmgr (deferred)
CheckSum: 0004C6F4
ImageSize: 00047000
fffffa60`00805000 fffffa60`008df000 Wdf01000 (deferred)
CheckSum: 000D946B
ImageSize: 000DA000
fffffa60`008df000 fffffa60`008ed000 WDFLDR (deferred)
CheckSum: 00018BBD
ImageSize: 0000E000
fffffa60`008ed000 fffffa60`00902000 partmgr (deferred)
CheckSum: 00019CD5
ImageSize: 00015000
fffffa60`00902000 fffffa60`00916000 volmgr (deferred)
CheckSum: 000131ED
ImageSize: 00014000
fffffa60`00916000 fffffa60`0097c000 volmgrx (deferred)
CheckSum: 00073802
ImageSize: 00066000
fffffa60`0097c000 fffffa60`00983000 pciide (deferred)
CheckSum: 0001260A
ImageSize: 00007000
fffffa60`00983000 fffffa60`00993000 PCIIDEX (deferred)
CheckSum: 0000FE5B
ImageSize: 00010000
fffffa60`00993000 fffffa60`009a6000 mountmgr (deferred)
CheckSum: 000157AE
ImageSize: 00013000
fffffa60`009a6000 fffffa60`009ae000 atapi (deferred)
CheckSum: 000112F5
ImageSize: 00008000
fffffa60`009ae000 fffffa60`009d2000 ataport (deferred)
CheckSum: 000267F3
ImageSize: 00024000
fffffa60`009d2000 fffffa60`009e6000 fileinfo (deferred)
CheckSum: 0002031C
ImageSize: 00014000
fffffa60`009e6000 fffffa60`009f8000 HIDCLASS (deferred)
CheckSum: 0001609C
ImageSize: 00012000
File type: 2.0 Dll
fffffa60`00a05000 fffffa60`00b39000 sptd (deferred)
CheckSum: 000DA3DE
ImageSize: 00134000
fffffa60`00b39000 fffffa60`00b42000 WMILIB (deferred)
CheckSum: 0000994C
ImageSize: 00009000
fffffa60`00b42000 fffffa60`00b70000 SCSIPORT (deferred)
CheckSum: 0002E61E
ImageSize: 0002E000
fffffa60`00b70000 fffffa60`00bc6000 acpi (deferred)
CheckSum: 00052D93
ImageSize: 00056000
fffffa60`00bc6000 fffffa60`00bd0000 msisadrv (deferred)
CheckSum: 0000AD81
ImageSize: 0000A000
fffffa60`00bd0000 fffffa60`00c00000 pci (deferred)
Image name: pci.sys
CheckSum: 000330BC
ImageSize: 00030000
File type: 2.0 Dll
fffffa60`00c03000 fffffa60`00c8a000 ksecdd (deferred)
CheckSum: 0007ED50
ImageSize: 00087000
fffffa60`00c8a000 fffffa60`00cda000 msrpc (deferred)
CheckSum: 00057CB1
ImageSize: 00050000
fffffa60`00cda000 fffffa60`00d33000 NETIO (deferred)
CheckSum: 0005AECE
ImageSize: 00059000
fffffa60`00d49000 fffffa60`00d57000 ATITool64 (deferred)
CheckSum: 0001540C
ImageSize: 0000E000
fffffa60`00d57000 fffffa60`00d64000 tunnel (deferred)
CheckSum: 000153F1
ImageSize: 0000D000
fffffa60`00d64000 fffffa60`00d6d000 tunmp (deferred)
CheckSum: 0000DBCB
ImageSize: 00009000
fffffa60`00d6d000 fffffa60`00d80000 intelppm (deferred)
CheckSum: 0000BEEB
ImageSize: 00013000
fffffa60`00d80000 fffffa60`00de5000 yk60x64 (deferred)
CheckSum: 00066200
ImageSize: 00065000
fffffa60`00e0d000 fffffa60`00fd0000 ndis (deferred)
CheckSum: 000B4C34
ImageSize: 001C3000
fffffa60`00fd0000 fffffa60`00ffc000 CLASSPNP (deferred)
CheckSum: 00033AA3
ImageSize: 0002C000
fffffa60`01007000 fffffa60`0117d000 tcpip (deferred)
CheckSum: 0015E59F
ImageSize: 00176000
fffffa60`0117d000 fffffa60`011a9000 fwpkclnt (deferred)
CheckSum: 0002F708
ImageSize: 0002C000
fffffa60`011a9000 fffffa60`011bb000 mup (deferred)
Image name: mup.sys
CheckSum: 00012FEF
ImageSize: 00012000
fffffa60`011bb000 fffffa60`011e7000 ecache (deferred)
CheckSum: 0002EA7C
ImageSize: 0002C000
fffffa60`011e7000 fffffa60`011fb000 disk (deferred)
CheckSum: 0001C619
ImageSize: 00014000
fffffa60`01200000 fffffa60`0120a000 crcdisk (deferred)
CheckSum: 0001435C
ImageSize: 0000A000
fffffa60`0120c000 fffffa60`0138c000 Ntfs (deferred)
CheckSum: 00179837
ImageSize: 00180000
fffffa60`0138c000 fffffa60`013d0000 volsnap (deferred)
CheckSum: 0004B04C
ImageSize: 00044000
fffffa60`013d0000 fffffa60`013d8000 spldr (deferred)
CheckSum: 0000806F
ImageSize: 00008000
fffffa60`013d8000 fffffa60`013df000 speedfan (deferred)
CheckSum: 00005062
ImageSize: 00007000
fffffa60`013df000 fffffa60`013fa000 sbp2port (deferred)
CheckSum: 0001F41E
ImageSize: 0001B000
fffffa60`03209000 fffffa60`0374d000 atikmdag (deferred)
CheckSum: 004F4C10
ImageSize: 00544000
fffffa60`0374d000 fffffa60`03793000 USBPORT (deferred)
CheckSum: 00046070
ImageSize: 00046000
File type: 2.0 Dll
fffffa60`03793000 fffffa60`037a4000 usbehci (deferred)
CheckSum: 0000DE60
ImageSize: 00011000
fffffa60`037a4000 fffffa60`037b5b00 ohci1394 (deferred)
CheckSum: 0001FAC5
ImageSize: 00011B00
fffffa60`037b6000 fffffa60`037c5f00 1394BUS (deferred)
CheckSum: 000129D0
ImageSize: 0000FF00
fffffa60`037c6000 fffffa60`037d3000 fdc (deferred)
Image name: fdc.sys
CheckSum: 00010F0C
ImageSize: 0000D000
fffffa60`037d3000 fffffa60`037f0000 serial (deferred)
CheckSum: 0001A92E
ImageSize: 0001D000
fffffa60`037f0000 fffffa60`037fc000 serenum (deferred)
CheckSum: 000156DF
ImageSize: 0000C000
fffffa60`03800000 fffffa60`03808680 WmFilter (deferred)
CheckSum: 00012FEF
ImageSize: 00008680
fffffa60`03809000 fffffa60`038ec000 dxgkrnl (deferred)
CheckSum: 000E17BC
ImageSize: 000E3000
fffffa60`038ec000 fffffa60`038fc000 watchdog (deferred)
CheckSum: 00019630
ImageSize: 00010000
File type: 2.0 Dll
fffffa60`038fc000 fffffa60`039e9000 HDAudBus (deferred)
CheckSum: 000F03F1
ImageSize: 000ED000
fffffa60`039e9000 fffffa60`039f5000 usbuhci (deferred)
CheckSum: 00010547
ImageSize: 0000C000
fffffa60`039f5000 fffffa60`039fd000 ASACPI (deferred)
CheckSum: 000089FB
ImageSize: 00008000
fffffa60`03a00000 fffffa60`03a07b80 HIDPARSE (deferred)
CheckSum: 0001084B
ImageSize: 00007B80
File type: 2.0 Dll
fffffa60`03a09000 fffffa60`03a25000 cdrom (deferred)
CheckSum: 0001F76A
ImageSize: 0001C000
fffffa60`03a25000 fffffa60`03a7a000 aegn3f3v (deferred)
Image path: \SystemRoot\System32\Drivers\aegn3f3v.SYS
Image name: aegn3f3v.SYS
CheckSum: 00046C0E
ImageSize: 00055000
fffffa60`03a7a000 fffffa60`03ab3000 msiscsi (deferred)
CheckSum: 0003EC8E
ImageSize: 00039000
fffffa60`03ab3000 fffffa60`03b10000 storport (deferred)
CheckSum: 00032227
ImageSize: 0005D000
fffffa60`03b10000 fffffa60`03b1d000 TDI (deferred)
Image name: TDI.SYS
CheckSum: 0000C014
ImageSize: 0000D000
fffffa60`03b1d000 fffffa60`03b40000 rasl2tp (deferred)
CheckSum: 00028BFC
ImageSize: 00023000
fffffa60`03b40000 fffffa60`03b4c000 ndistapi (deferred)
CheckSum: 0000CA62
ImageSize: 0000C000
fffffa60`03b4c000 fffffa60`03b7d000 ndiswan (deferred)
CheckSum: 00029ED4
ImageSize: 00031000
fffffa60`03b7d000 fffffa60`03b8d000 raspppoe (deferred)
CheckSum: 00015E5B
ImageSize: 00010000
fffffa60`03b8d000 fffffa60`03bab000 raspptp (deferred)
CheckSum: 0001FAEE
ImageSize: 0001E000
fffffa60`03bab000 fffffa60`03bc3000 rassstp (deferred)
CheckSum: 0001B5E9
ImageSize: 00018000
fffffa60`03bc3000 fffffa60`03bcb000 PdiPorts (deferred)
CheckSum: 0000E8C4
ImageSize: 00008000
fffffa60`03bcb000 fffffa60`03bde000 termdd (deferred)
CheckSum: 0001B681
ImageSize: 00013000
fffffa60`03bde000 fffffa60`03bec000 kbdclass (deferred)
CheckSum: 0000AF5D
ImageSize: 0000E000
fffffa60`03bec000 fffffa60`03bf8000 mouclass (deferred)
CheckSum: 00017BB4
ImageSize: 0000C000
fffffa60`03bf8000 fffffa60`03bf9480 swenum (deferred)
CheckSum: 0000447A
ImageSize: 00001480
fffffa60`03c01000 fffffa60`03c35000 ks (deferred)
Image name: ks.sys
CheckSum: 0003990E
ImageSize: 00034000
fffffa60`03c35000 fffffa60`03c39c80 WmBEnum (deferred)
CheckSum: 000158A9
ImageSize: 00004C80
fffffa60`03c3a000 fffffa60`03c4b100 WmXlCore (deferred)
CheckSum: 0001FA2F
ImageSize: 00011100
fffffa60`03c4c000 fffffa60`03c57000 mssmbios (deferred)
CheckSum: 0000EECB
ImageSize: 0000B000
fffffa60`03c57000 fffffa60`03c67000 umbus (deferred)
CheckSum: 0001333F
ImageSize: 00010000
fffffa60`03c67000 fffffa60`03caf000 usbhub (deferred)
CheckSum: 0004C820
ImageSize: 00048000
fffffa60`03caf000 fffffa60`03cba000 flpydisk (deferred)
CheckSum: 0001588D
ImageSize: 0000B000
fffffa60`03cba000 fffffa60`03cce000 NDProxy (deferred)
CheckSum: 0001366B
ImageSize: 00014000
fffffa60`03cce000 fffffa60`03d17000 HdAudio (deferred)
CheckSum: 00043FB3
ImageSize: 00049000
fffffa60`03d17000 fffffa60`03d52000 portcls (deferred)
CheckSum: 0003AE69
ImageSize: 0003B000
fffffa60`03d52000 fffffa60`03d75000 drmk (deferred)
CheckSum: 00022D56
ImageSize: 00023000
File type: 2.0 Dll
fffffa60`03d75000 fffffa60`03d7a180 ksthunk (deferred)
CheckSum: 0000A913
ImageSize: 00005180
fffffa60`03d7b000 fffffa60`03df2000 ADIHdAud (deferred)
CheckSum: 00078D83
ImageSize: 00077000
fffffa60`03df2000 fffffa60`03df3e00 USBD (deferred)
CheckSum: 00010C2B
ImageSize: 00001E00
File type: 2.0 Dll
fffffa60`03df4000 fffffa60`03dfd000 hidusb (deferred)
CheckSum: 0000A824
ImageSize: 00009000
fffffa60`04808000 fffffa60`04835000 MpFilter (deferred)
CheckSum: 00035D94
ImageSize: 0002D000
fffffa60`04835000 fffffa60`0483f000 Fs_Rec (deferred)
CheckSum: 0000F90C
ImageSize: 0000A000
fffffa60`0483f000 fffffa60`04848000 Null (deferred)
CheckSum: 0000B49D
ImageSize: 00009000
fffffa60`04853000 fffffa60`04861000 vga (deferred)
Image name: vga.sys
CheckSum: 00007D47
ImageSize: 0000E000
fffffa60`04861000 fffffa60`04886000 VIDEOPRT (deferred)
CheckSum: 00027AC2
ImageSize: 00025000
fffffa60`04886000 fffffa60`0488f000 RDPCDD (deferred)
CheckSum: 0000B335
ImageSize: 00009000
fffffa60`0488f000 fffffa60`04898000 rdpencdd (deferred)
CheckSum: 00003BDB
ImageSize: 00009000
fffffa60`04898000 fffffa60`048a3000 Msfs (deferred)
CheckSum: 00008E66
ImageSize: 0000B000
fffffa60`048a3000 fffffa60`048b4000 Npfs (deferred)
CheckSum: 000193D4
ImageSize: 00011000
fffffa60`048b4000 fffffa60`048bd000 rasacd (deferred)
CheckSum: 0000DB26
ImageSize: 00009000
fffffa60`048bd000 fffffa60`048da000 tdx (deferred)
Image name: tdx.sys
CheckSum: 00022F45
ImageSize: 0001D000
fffffa60`048da000 fffffa60`048f5000 smb (deferred)
Image name: smb.sys
CheckSum: 0001FBF4
ImageSize: 0001B000
fffffa60`048f5000 fffffa60`04960000 afd (deferred)
Image name: afd.sys
CheckSum: 0006F99A
ImageSize: 0006B000
fffffa60`04960000 fffffa60`049a4000 netbt (deferred)
CheckSum: 0004C008
ImageSize: 00044000
fffffa60`049a4000 fffffa60`049c2000 pacer (deferred)
CheckSum: 0001AEBA
ImageSize: 0001E000
fffffa60`049c2000 fffffa60`049d1000 netbios (deferred)
CheckSum: 00015AAA
ImageSize: 0000F000
fffffa60`049d1000 fffffa60`049d8000 TVicPort64 (deferred)
CheckSum: 00007AD0
ImageSize: 00007000
fffffa60`049d8000 fffffa60`049f3000 wanarp (deferred)
CheckSum: 0001BFAA
ImageSize: 0001B000
CheckSum: 0004FC14
ImageSize: 0004D000
CheckSum: 00013617
ImageSize: 0000C000
CheckSum: 00019214
ImageSize: 0001D000
CheckSum: 00008D1F
ImageSize: 00007000
CheckSum: 0001CCC4
ImageSize: 0001C000
fffffa60`04a9d000 fffffa60`04aab000 crashdmp (deferred)
CheckSum: 0000B10F
ImageSize: 0000E000
fffffa60`04aab000 fffffa60`04ab7000 dump_dumpata (deferred)
CheckSum: 0000E322
ImageSize: 0000C000
fffffa60`04ab7000 fffffa60`04abf000 dump_atapi (deferred)
CheckSum: 000112F5
ImageSize: 00008000
fffffa60`04abf000 fffffa60`04adb000 usbccgp (deferred)
CheckSum: 000229C9
ImageSize: 0001C000
fffffa60`04adb000 fffffa60`04aee000 LHidFilt (deferred)
CheckSum: 0000FBB4
ImageSize: 00013000
fffffa60`04aee000 fffffa60`04af9000 kbdhid (deferred)
CheckSum: 0000C1A4
ImageSize: 0000B000
fffffa60`04af9000 fffffa60`04b04000 mouhid (deferred)
CheckSum: 0000DA7D
ImageSize: 0000B000
fffffa60`04b04000 fffffa60`04b18000 LMouFilt (deferred)
CheckSum: 000168EC
ImageSize: 00014000
fffffa60`04b18000 fffffa60`04b24000 Dxapi (deferred)
CheckSum: 00007785
ImageSize: 0000C000
fffffa60`04b24000 fffffa60`04b37000 monitor (deferred)
CheckSum: 0001BE53
ImageSize: 00013000
fffffa60`04b37000 fffffa60`04bac000 fwlanusb (deferred)
CheckSum: 00070E59
ImageSize: 00075000
fffffa60`04bac000 fffffa60`04bce000 luafv (deferred)
CheckSum: 0001E74E
ImageSize: 00022000
fffffa60`04bce000 fffffa60`04be8000 mpsdrv (deferred)
CheckSum: 000167F0
ImageSize: 0001A000
fffffa60`04be8000 fffffa60`04c00000 adfs (deferred)
CheckSum: 00024203
ImageSize: 00018000
fffffa60`0620f000 fffffa60`062a9000 spsys (deferred)
CheckSum: 0009AA05
ImageSize: 0009A000
fffffa60`062a9000 fffffa60`062bd000 lltdio (deferred)
CheckSum: 000186DE
ImageSize: 00014000
fffffa60`062bd000 fffffa60`062f1000 nwifi (deferred)
CheckSum: 0002DF25
ImageSize: 00034000
fffffa60`062f1000 fffffa60`062fc000 ndisuio (deferred)
CheckSum: 0001472B
ImageSize: 0000B000
fffffa60`062fc000 fffffa60`06314000 rspndr (deferred)
CheckSum: 000132AD
ImageSize: 00018000
fffffa60`06314000 fffffa60`063b7000 HTTP (deferred)
CheckSum: 0009BA1A
ImageSize: 000A3000
fffffa60`063b7000 fffffa60`063e0000 srvnet (deferred)
CheckSum: 00030E2C
ImageSize: 00029000
fffffa60`063e0000 fffffa60`063fe000 bowser (deferred)
CheckSum: 00021CAB
ImageSize: 0001E000
fffffa60`0660d000 fffffa60`06634000 mrxdav (deferred)
CheckSum: 0002F134
ImageSize: 00027000
fffffa60`06634000 fffffa60`0665d000 mrxsmb (deferred)
CheckSum: 0002FFC0
ImageSize: 00029000
fffffa60`0665d000 fffffa60`066a6000 mrxsmb10 (deferred)
CheckSum: 00044B25
ImageSize: 00049000
fffffa60`066a6000 fffffa60`066c5000 mrxsmb20 (deferred)
CheckSum: 0001F056
ImageSize: 0001F000
fffffa60`066c5000 fffffa60`066f7000 srv2 (deferred)
CheckSum: 0002B62B
ImageSize: 00032000
fffffa60`066f7000 fffffa60`0678c000 srv (deferred)
Image name: srv.sys
CheckSum: 0007607A
ImageSize: 00095000
fffffa60`0678c000 fffffa60`06797000 asyncmac (deferred)
CheckSum: 00005CC4
ImageSize: 0000B000
fffffa60`06797000 fffffa60`067a7000 MpNWMon (deferred)
CheckSum: 0000AF59
ImageSize: 00010000
fffffa60`067a7000 fffffa60`067fd000 acedrv11 (deferred)
CheckSum: 00056117
ImageSize: 00056000
fffffa60`07205000 fffffa60`072bb000 peauth (deferred)
CheckSum: 000AE0B2
ImageSize: 000B6000
fffffa60`072bb000 fffffa60`072c6000 secdrv (deferred)
CheckSum: 00010B40
ImageSize: 0000B000
fffffa60`072c6000 fffffa60`072d6000 tcpipreg (deferred)
CheckSum: 000171C3
ImageSize: 00010000
fffffa60`072d6000 fffffa60`0730b000 fastfat (deferred)
CheckSum: 0003DE0E
ImageSize: 00035000
fffffa60`0730b000 fffffa60`0730d400 WmVirHid (deferred)
CheckSum: 0000B268
ImageSize: 00002400
Unloaded modules:
fffffa60`00de5000 fffffa60`00dfd000 USBSTOR.SYS
Checksum: 00000000
fffffa60`00d33000 fffffa60`00d41000 crashdmp.sys
Checksum: 00000000
fffffa60`00e00000 fffffa60`00e0c000 dump_ataport.sys
Checksum: 00000000
fffffa60`00d41000 fffffa60`00d49000 dump_atapi.sys
Checksum: 00000000
fffffa60`04848000 fffffa60`04853000 kbdhid.sys
Checksum: 00000000
3: kd> lmp
fffff800`02810000 fffff800`02856000 hal <none>
fffff800`02856000 fffff800`02d6d000 nt <none>
fffff960`00030000 fffff960`002e4000 win32k <none>
fffff960`00450000 fffff960`0045a000 TSDDD <none>
fffff960`006f0000 fffff960`00701000 cdd <none>
fffff960`00880000 fffff960`008e1000 ATMFD <none>
fffffa60`00602000 fffffa60`0060c000 kdcom <none>
fffffa60`0060c000 fffffa60`00647000 mcupdate_GenuineIntel <none>
fffffa60`00647000 fffffa60`0065b000 PSHED <none>
fffffa60`0065b000 fffffa60`006b8000 CLFS <none>
fffffa60`006b8000 fffffa60`0076a000 CI <none>
fffffa60`0076a000 fffffa60`007ae000 mv61xx <none>
fffffa60`007ae000 fffffa60`007f5000 fltmgr <none>
fffffa60`00805000 fffffa60`008df000 Wdf01000 <none>
fffffa60`008df000 fffffa60`008ed000 WDFLDR <none>
fffffa60`008ed000 fffffa60`00902000 partmgr <none>
fffffa60`00902000 fffffa60`00916000 volmgr <none>
fffffa60`00916000 fffffa60`0097c000 volmgrx <none>
fffffa60`0097c000 fffffa60`00983000 pciide <none>
fffffa60`00983000 fffffa60`00993000 PCIIDEX <none>
fffffa60`00993000 fffffa60`009a6000 mountmgr <none>
fffffa60`009a6000 fffffa60`009ae000 atapi <none>
fffffa60`009ae000 fffffa60`009d2000 ataport <none>
fffffa60`009d2000 fffffa60`009e6000 fileinfo <none>
fffffa60`009e6000 fffffa60`009f8000 HIDCLASS <none>
fffffa60`00a05000 fffffa60`00b39000 sptd <none>
fffffa60`00b39000 fffffa60`00b42000 WMILIB <none>
fffffa60`00b42000 fffffa60`00b70000 SCSIPORT <none>
fffffa60`00b70000 fffffa60`00bc6000 acpi <none>
fffffa60`00bc6000 fffffa60`00bd0000 msisadrv <none>
fffffa60`00bd0000 fffffa60`00c00000 pci <none>
fffffa60`00c03000 fffffa60`00c8a000 ksecdd <none>
fffffa60`00c8a000 fffffa60`00cda000 msrpc <none>
fffffa60`00cda000 fffffa60`00d33000 NETIO <none>
fffffa60`00d49000 fffffa60`00d57000 ATITool64 <none>
fffffa60`00d57000 fffffa60`00d64000 tunnel <none>
fffffa60`00d64000 fffffa60`00d6d000 tunmp <none>
fffffa60`00d6d000 fffffa60`00d80000 intelppm <none>
fffffa60`00d80000 fffffa60`00de5000 yk60x64 <none>
fffffa60`00e0d000 fffffa60`00fd0000 ndis <none>
fffffa60`00fd0000 fffffa60`00ffc000 CLASSPNP <none>
fffffa60`01007000 fffffa60`0117d000 tcpip <none>
fffffa60`0117d000 fffffa60`011a9000 fwpkclnt <none>
fffffa60`011a9000 fffffa60`011bb000 mup <none>
fffffa60`011bb000 fffffa60`011e7000 ecache <none>
fffffa60`011e7000 fffffa60`011fb000 disk <none>
fffffa60`01200000 fffffa60`0120a000 crcdisk <none>
fffffa60`0120c000 fffffa60`0138c000 Ntfs <none>
fffffa60`0138c000 fffffa60`013d0000 volsnap <none>
fffffa60`013d0000 fffffa60`013d8000 spldr <none>
fffffa60`013d8000 fffffa60`013df000 speedfan <none>
fffffa60`013df000 fffffa60`013fa000 sbp2port <none>
fffffa60`03209000 fffffa60`0374d000 atikmdag <none>
fffffa60`0374d000 fffffa60`03793000 USBPORT <none>
fffffa60`03793000 fffffa60`037a4000 usbehci <none>
fffffa60`037a4000 fffffa60`037b5b00 ohci1394 <none>
fffffa60`037b6000 fffffa60`037c5f00 1394BUS <none>
fffffa60`037c6000 fffffa60`037d3000 fdc <none>
fffffa60`037d3000 fffffa60`037f0000 serial <none>
fffffa60`037f0000 fffffa60`037fc000 serenum <none>
fffffa60`03800000 fffffa60`03808680 WmFilter <none>
fffffa60`03809000 fffffa60`038ec000 dxgkrnl <none>
fffffa60`038ec000 fffffa60`038fc000 watchdog <none>
fffffa60`038fc000 fffffa60`039e9000 HDAudBus <none>
fffffa60`039e9000 fffffa60`039f5000 usbuhci <none>
fffffa60`039f5000 fffffa60`039fd000 ASACPI <none>
fffffa60`03a00000 fffffa60`03a07b80 HIDPARSE <none>
fffffa60`03a09000 fffffa60`03a25000 cdrom <none>
fffffa60`03a25000 fffffa60`03a7a000 aegn3f3v <none>
fffffa60`03a7a000 fffffa60`03ab3000 msiscsi <none>
fffffa60`03ab3000 fffffa60`03b10000 storport <none>
fffffa60`03b10000 fffffa60`03b1d000 TDI <none>
fffffa60`03b1d000 fffffa60`03b40000 rasl2tp <none>
fffffa60`03b40000 fffffa60`03b4c000 ndistapi <none>
fffffa60`03b4c000 fffffa60`03b7d000 ndiswan <none>
fffffa60`03b7d000 fffffa60`03b8d000 raspppoe <none>
fffffa60`03b8d000 fffffa60`03bab000 raspptp <none>
fffffa60`03bab000 fffffa60`03bc3000 rassstp <none>
fffffa60`03bc3000 fffffa60`03bcb000 PdiPorts <none>
fffffa60`03bcb000 fffffa60`03bde000 termdd <none>
fffffa60`03bde000 fffffa60`03bec000 kbdclass <none>
fffffa60`03bec000 fffffa60`03bf8000 mouclass <none>
fffffa60`03bf8000 fffffa60`03bf9480 swenum <none>
fffffa60`03c01000 fffffa60`03c35000 ks <none>
fffffa60`03c35000 fffffa60`03c39c80 WmBEnum <none>
fffffa60`03c3a000 fffffa60`03c4b100 WmXlCore <none>
fffffa60`03c4c000 fffffa60`03c57000 mssmbios <none>
fffffa60`03c57000 fffffa60`03c67000 umbus <none>
fffffa60`03c67000 fffffa60`03caf000 usbhub <none>
fffffa60`03caf000 fffffa60`03cba000 flpydisk <none>
fffffa60`03cba000 fffffa60`03cce000 NDProxy <none>
fffffa60`03cce000 fffffa60`03d17000 HdAudio <none>
fffffa60`03d17000 fffffa60`03d52000 portcls <none>
fffffa60`03d52000 fffffa60`03d75000 drmk <none>
fffffa60`03d75000 fffffa60`03d7a180 ksthunk <none>
fffffa60`03d7b000 fffffa60`03df2000 ADIHdAud <none>
fffffa60`03df2000 fffffa60`03df3e00 USBD <none>
fffffa60`03df4000 fffffa60`03dfd000 hidusb <none>
fffffa60`04808000 fffffa60`04835000 MpFilter <none>
fffffa60`04835000 fffffa60`0483f000 Fs_Rec <none>
fffffa60`0483f000 fffffa60`04848000 Null <none>
fffffa60`04853000 fffffa60`04861000 vga <none>
fffffa60`04861000 fffffa60`04886000 VIDEOPRT <none>
fffffa60`04886000 fffffa60`0488f000 RDPCDD <none>
fffffa60`0488f000 fffffa60`04898000 rdpencdd <none>
fffffa60`04898000 fffffa60`048a3000 Msfs <none>
fffffa60`048a3000 fffffa60`048b4000 Npfs <none>
fffffa60`048b4000 fffffa60`048bd000 rasacd <none>
fffffa60`048bd000 fffffa60`048da000 tdx <none>
fffffa60`048da000 fffffa60`048f5000 smb <none>
fffffa60`048f5000 fffffa60`04960000 afd <none>
fffffa60`04960000 fffffa60`049a4000 netbt <none>
fffffa60`049a4000 fffffa60`049c2000 pacer <none>
fffffa60`049c2000 fffffa60`049d1000 netbios <none>
fffffa60`049d1000 fffffa60`049d8000 TVicPort64 <none>
fffffa60`049d8000 fffffa60`049f3000 wanarp <none>
fffffa60`04a04000 fffffa60`04a51000 rdbss <none>
fffffa60`04a51000 fffffa60`04a5d000 nsiproxy <none>
fffffa60`04a5d000 fffffa60`04a7a000 dfsc <none>
fffffa60`04a7a000 fffffa60`04a81000 AsIO <none>
fffffa60`04a81000 fffffa60`04a9d000 cdfs <none>
fffffa60`04a9d000 fffffa60`04aab000 crashdmp <none>
fffffa60`04aab000 fffffa60`04ab7000 dump_dumpata <none>
fffffa60`04ab7000 fffffa60`04abf000 dump_atapi <none>
fffffa60`04abf000 fffffa60`04adb000 usbccgp <none>
fffffa60`04adb000 fffffa60`04aee000 LHidFilt <none>
fffffa60`04aee000 fffffa60`04af9000 kbdhid <none>
fffffa60`04af9000 fffffa60`04b04000 mouhid <none>
fffffa60`04b04000 fffffa60`04b18000 LMouFilt <none>
fffffa60`04b18000 fffffa60`04b24000 Dxapi <none>
fffffa60`04b24000 fffffa60`04b37000 monitor <none>
fffffa60`04b37000 fffffa60`04bac000 fwlanusb <none>
fffffa60`04bac000 fffffa60`04bce000 luafv <none>
fffffa60`04bce000 fffffa60`04be8000 mpsdrv <none>
fffffa60`04be8000 fffffa60`04c00000 adfs <none>
fffffa60`0620f000 fffffa60`062a9000 spsys <none>
fffffa60`062a9000 fffffa60`062bd000 lltdio <none>
fffffa60`062bd000 fffffa60`062f1000 nwifi <none>
fffffa60`062f1000 fffffa60`062fc000 ndisuio <none>
fffffa60`062fc000 fffffa60`06314000 rspndr <none>
fffffa60`06314000 fffffa60`063b7000 HTTP <none>
fffffa60`063b7000 fffffa60`063e0000 srvnet <none>
fffffa60`063e0000 fffffa60`063fe000 bowser <none>
fffffa60`0660d000 fffffa60`06634000 mrxdav <none>
fffffa60`06634000 fffffa60`0665d000 mrxsmb <none>
fffffa60`0665d000 fffffa60`066a6000 mrxsmb10 <none>
fffffa60`066a6000 fffffa60`066c5000 mrxsmb20 <none>
fffffa60`066c5000 fffffa60`066f7000 srv2 <none>
fffffa60`066f7000 fffffa60`0678c000 srv <none>
fffffa60`0678c000 fffffa60`06797000 asyncmac <none>
fffffa60`06797000 fffffa60`067a7000 MpNWMon <none>
fffffa60`067a7000 fffffa60`067fd000 acedrv11 <none>
fffffa60`07205000 fffffa60`072bb000 peauth <none>
fffffa60`072bb000 fffffa60`072c6000 secdrv <none>
fffffa60`072c6000 fffffa60`072d6000 tcpipreg <none>
fffffa60`072d6000 fffffa60`0730b000 fastfat <none>
fffffa60`0730b000 fffffa60`0730d400 WmVirHid <none>
Unloaded modules:
3: kd> lmf
fffff800`02810000 fffff800`02856000 hal hal.dll
fffff800`02856000 fffff800`02d6d000 nt ntkrnlmp.exe
fffff960`00030000 fffff960`002e4000 win32k \SystemRoot\System32\win32k.sys
fffff960`00450000 fffff960`0045a000 TSDDD \SystemRoot\System32\TSDDD.dll
fffff960`006f0000 fffff960`00701000 cdd \SystemRoot\System32\cdd.dll
fffff960`00880000 fffff960`008e1000 ATMFD \SystemRoot\System32\ATMFD.DLL
fffffa60`00602000 fffffa60`0060c000 kdcom kdcom.dll
fffffa60`0060c000 fffffa60`00647000 mcupdate_GenuineIntel \SystemRoot\system32\mcupdate_GenuineIntel.dll
fffffa60`00647000 fffffa60`0065b000 PSHED \SystemRoot\system32\PSHED.dll
fffffa60`0065b000 fffffa60`006b8000 CLFS \SystemRoot\system32\CLFS.SYS
fffffa60`006b8000 fffffa60`0076a000 CI \SystemRoot\system32\CI.dll
fffffa60`0076a000 fffffa60`007ae000 mv61xx \SystemRoot\system32\DRIVERS\mv61xx.sys
fffffa60`007ae000 fffffa60`007f5000 fltmgr \SystemRoot\system32\drivers\fltmgr.sys
fffffa60`00805000 fffffa60`008df000 Wdf01000 \SystemRoot\system32\drivers\Wdf01000.sys
fffffa60`008df000 fffffa60`008ed000 WDFLDR \SystemRoot\system32\drivers\WDFLDR.SYS
fffffa60`008ed000 fffffa60`00902000 partmgr \SystemRoot\System32\drivers\partmgr.sys
fffffa60`00902000 fffffa60`00916000 volmgr \SystemRoot\system32\drivers\volmgr.sys
fffffa60`00916000 fffffa60`0097c000 volmgrx \SystemRoot\System32\drivers\volmgrx.sys
fffffa60`0097c000 fffffa60`00983000 pciide \SystemRoot\system32\drivers\pciide.sys
fffffa60`00983000 fffffa60`00993000 PCIIDEX \SystemRoot\system32\drivers\PCIIDEX.SYS
fffffa60`00993000 fffffa60`009a6000 mountmgr \SystemRoot\System32\drivers\mountmgr.sys
fffffa60`009a6000 fffffa60`009ae000 atapi \SystemRoot\system32\drivers\atapi.sys
fffffa60`009ae000 fffffa60`009d2000 ataport \SystemRoot\system32\drivers\ataport.SYS
fffffa60`009d2000 fffffa60`009e6000 fileinfo \SystemRoot\system32\drivers\fileinfo.sys
fffffa60`009e6000 fffffa60`009f8000 HIDCLASS \SystemRoot\system32\DRIVERS\HIDCLASS.SYS
fffffa60`00a05000 fffffa60`00b39000 sptd \SystemRoot\System32\Drivers\sptd.sys
fffffa60`00b39000 fffffa60`00b42000 WMILIB \SystemRoot\System32\Drivers\WMILIB.SYS
fffffa60`00b42000 fffffa60`00b70000 SCSIPORT \SystemRoot\System32\Drivers\SCSIPORT.SYS
fffffa60`00b70000 fffffa60`00bc6000 acpi \SystemRoot\system32\drivers\acpi.sys
fffffa60`00bc6000 fffffa60`00bd0000 msisadrv \SystemRoot\system32\drivers\msisadrv.sys
fffffa60`00bd0000 fffffa60`00c00000 pci \SystemRoot\system32\drivers\pci.sys
fffffa60`00c03000 fffffa60`00c8a000 ksecdd \SystemRoot\System32\Drivers\ksecdd.sys
fffffa60`00c8a000 fffffa60`00cda000 msrpc \SystemRoot\system32\drivers\msrpc.sys
fffffa60`00cda000 fffffa60`00d33000 NETIO \SystemRoot\system32\drivers\NETIO.SYS
fffffa60`00d49000 fffffa60`00d57000 ATITool64 \SystemRoot\system32\DRIVERS\ATITool64.sys
fffffa60`00d57000 fffffa60`00d64000 tunnel \SystemRoot\system32\DRIVERS\tunnel.sys
fffffa60`00d64000 fffffa60`00d6d000 tunmp \SystemRoot\system32\DRIVERS\tunmp.sys
fffffa60`00d6d000 fffffa60`00d80000 intelppm \SystemRoot\system32\DRIVERS\intelppm.sys
fffffa60`00d80000 fffffa60`00de5000 yk60x64 \SystemRoot\system32\DRIVERS\yk60x64.sys
fffffa60`00e0d000 fffffa60`00fd0000 ndis \SystemRoot\system32\drivers\ndis.sys
fffffa60`00fd0000 fffffa60`00ffc000 CLASSPNP \SystemRoot\system32\drivers\CLASSPNP.SYS
fffffa60`01007000 fffffa60`0117d000 tcpip \SystemRoot\System32\drivers\tcpip.sys
fffffa60`0117d000 fffffa60`011a9000 fwpkclnt \SystemRoot\System32\drivers\fwpkclnt.sys
fffffa60`011a9000 fffffa60`011bb000 mup \SystemRoot\System32\Drivers\mup.sys
fffffa60`011bb000 fffffa60`011e7000 ecache \SystemRoot\System32\drivers\ecache.sys
fffffa60`011e7000 fffffa60`011fb000 disk \SystemRoot\system32\drivers\disk.sys
fffffa60`01200000 fffffa60`0120a000 crcdisk \SystemRoot\system32\drivers\crcdisk.sys
fffffa60`0120c000 fffffa60`0138c000 Ntfs \SystemRoot\System32\Drivers\Ntfs.sys
fffffa60`0138c000 fffffa60`013d0000 volsnap \SystemRoot\system32\drivers\volsnap.sys
fffffa60`013d0000 fffffa60`013d8000 spldr \SystemRoot\System32\Drivers\spldr.sys
fffffa60`013d8000 fffffa60`013df000 speedfan \SystemRoot\SysWOW64\speedfan.sys
fffffa60`013df000 fffffa60`013fa000 sbp2port \SystemRoot\system32\DRIVERS\sbp2port.sys
fffffa60`03209000 fffffa60`0374d000 atikmdag \SystemRoot\system32\DRIVERS\atikmdag.sys
fffffa60`0374d000 fffffa60`03793000 USBPORT \SystemRoot\system32\DRIVERS\USBPORT.SYS
fffffa60`03793000 fffffa60`037a4000 usbehci \SystemRoot\system32\DRIVERS\usbehci.sys
fffffa60`037a4000 fffffa60`037b5b00 ohci1394 \SystemRoot\system32\DRIVERS\ohci1394.sys
fffffa60`037b6000 fffffa60`037c5f00 1394BUS \SystemRoot\system32\DRIVERS\1394BUS.SYS
fffffa60`037c6000 fffffa60`037d3000 fdc \SystemRoot\system32\DRIVERS\fdc.sys
fffffa60`037d3000 fffffa60`037f0000 serial \SystemRoot\system32\DRIVERS\serial.sys
fffffa60`037f0000 fffffa60`037fc000 serenum \SystemRoot\system32\DRIVERS\serenum.sys
fffffa60`03800000 fffffa60`03808680 WmFilter \SystemRoot\system32\drivers\WmFilter.sys
fffffa60`03809000 fffffa60`038ec000 dxgkrnl \SystemRoot\System32\drivers\dxgkrnl.sys
fffffa60`038ec000 fffffa60`038fc000 watchdog \SystemRoot\System32\drivers\watchdog.sys
fffffa60`038fc000 fffffa60`039e9000 HDAudBus \SystemRoot\system32\DRIVERS\HDAudBus.sys
fffffa60`039e9000 fffffa60`039f5000 usbuhci \SystemRoot\system32\DRIVERS\usbuhci.sys
fffffa60`039f5000 fffffa60`039fd000 ASACPI \SystemRoot\system32\DRIVERS\ASACPI.sys
fffffa60`03a00000 fffffa60`03a07b80 HIDPARSE \SystemRoot\system32\DRIVERS\HIDPARSE.SYS
fffffa60`03a09000 fffffa60`03a25000 cdrom \SystemRoot\system32\DRIVERS\cdrom.sys
fffffa60`03a25000 fffffa60`03a7a000 aegn3f3v \SystemRoot\System32\Drivers\aegn3f3v.SYS
fffffa60`03a7a000 fffffa60`03ab3000 msiscsi \SystemRoot\system32\DRIVERS\msiscsi.sys
fffffa60`03ab3000 fffffa60`03b10000 storport \SystemRoot\system32\DRIVERS\storport.sys
fffffa60`03b10000 fffffa60`03b1d000 TDI \SystemRoot\system32\DRIVERS\TDI.SYS
fffffa60`03b1d000 fffffa60`03b40000 rasl2tp \SystemRoot\system32\DRIVERS\rasl2tp.sys
fffffa60`03b40000 fffffa60`03b4c000 ndistapi \SystemRoot\system32\DRIVERS\ndistapi.sys
fffffa60`03b4c000 fffffa60`03b7d000 ndiswan \SystemRoot\system32\DRIVERS\ndiswan.sys
fffffa60`03b7d000 fffffa60`03b8d000 raspppoe \SystemRoot\system32\DRIVERS\raspppoe.sys
fffffa60`03b8d000 fffffa60`03bab000 raspptp \SystemRoot\system32\DRIVERS\raspptp.sys
fffffa60`03bab000 fffffa60`03bc3000 rassstp \SystemRoot\system32\DRIVERS\rassstp.sys
fffffa60`03bc3000 fffffa60`03bcb000 PdiPorts \SystemRoot\system32\DRIVERS\PdiPorts.sys
fffffa60`03bcb000 fffffa60`03bde000 termdd \SystemRoot\system32\DRIVERS\termdd.sys
fffffa60`03bde000 fffffa60`03bec000 kbdclass \SystemRoot\system32\DRIVERS\kbdclass.sys
fffffa60`03bec000 fffffa60`03bf8000 mouclass \SystemRoot\system32\DRIVERS\mouclass.sys
fffffa60`03bf8000 fffffa60`03bf9480 swenum \SystemRoot\system32\DRIVERS\swenum.sys
fffffa60`03c01000 fffffa60`03c35000 ks \SystemRoot\system32\DRIVERS\ks.sys
fffffa60`03c35000 fffffa60`03c39c80 WmBEnum \SystemRoot\system32\drivers\WmBEnum.sys
fffffa60`03c3a000 fffffa60`03c4b100 WmXlCore \SystemRoot\system32\drivers\WmXlCore.sys
fffffa60`03c4c000 fffffa60`03c57000 mssmbios \SystemRoot\system32\DRIVERS\mssmbios.sys
fffffa60`03c57000 fffffa60`03c67000 umbus \SystemRoot\system32\DRIVERS\umbus.sys
fffffa60`03c67000 fffffa60`03caf000 usbhub \SystemRoot\system32\DRIVERS\usbhub.sys
fffffa60`03caf000 fffffa60`03cba000 flpydisk \SystemRoot\system32\DRIVERS\flpydisk.sys
fffffa60`03cba000 fffffa60`03cce000 NDProxy \SystemRoot\System32\Drivers\NDProxy.SYS
fffffa60`03cce000 fffffa60`03d17000 HdAudio \SystemRoot\system32\drivers\HdAudio.sys
fffffa60`03d17000 fffffa60`03d52000 portcls \SystemRoot\system32\drivers\portcls.sys
fffffa60`03d52000 fffffa60`03d75000 drmk \SystemRoot\system32\drivers\drmk.sys
fffffa60`03d75000 fffffa60`03d7a180 ksthunk \SystemRoot\system32\drivers\ksthunk.sys
fffffa60`03d7b000 fffffa60`03df2000 ADIHdAud \SystemRoot\system32\drivers\ADIHdAud.sys
fffffa60`03df2000 fffffa60`03df3e00 USBD \SystemRoot\system32\DRIVERS\USBD.SYS
fffffa60`03df4000 fffffa60`03dfd000 hidusb \SystemRoot\system32\DRIVERS\hidusb.sys
fffffa60`04808000 fffffa60`04835000 MpFilter \SystemRoot\system32\DRIVERS\MpFilter.sys
fffffa60`04835000 fffffa60`0483f000 Fs_Rec \SystemRoot\System32\Drivers\Fs_Rec.SYS
fffffa60`0483f000 fffffa60`04848000 Null \SystemRoot\System32\Drivers\Null.SYS
fffffa60`04853000 fffffa60`04861000 vga \SystemRoot\System32\drivers\vga.sys
fffffa60`04861000 fffffa60`04886000 VIDEOPRT \SystemRoot\System32\drivers\VIDEOPRT.SYS
fffffa60`04886000 fffffa60`0488f000 RDPCDD \SystemRoot\System32\DRIVERS\RDPCDD.sys
fffffa60`0488f000 fffffa60`04898000 rdpencdd \SystemRoot\system32\drivers\rdpencdd.sys
fffffa60`04898000 fffffa60`048a3000 Msfs \SystemRoot\System32\Drivers\Msfs.SYS
fffffa60`048a3000 fffffa60`048b4000 Npfs \SystemRoot\System32\Drivers\Npfs.SYS
fffffa60`048b4000 fffffa60`048bd000 rasacd \SystemRoot\System32\DRIVERS\rasacd.sys
fffffa60`048bd000 fffffa60`048da000 tdx \SystemRoot\system32\DRIVERS\tdx.sys
fffffa60`048da000 fffffa60`048f5000 smb \SystemRoot\system32\DRIVERS\smb.sys
fffffa60`048f5000 fffffa60`04960000 afd \SystemRoot\system32\drivers\afd.sys
fffffa60`04960000 fffffa60`049a4000 netbt \SystemRoot\System32\DRIVERS\netbt.sys
fffffa60`049a4000 fffffa60`049c2000 pacer \SystemRoot\system32\DRIVERS\pacer.sys
fffffa60`049c2000 fffffa60`049d1000 netbios \SystemRoot\system32\DRIVERS\netbios.sys
fffffa60`049d1000 fffffa60`049d8000 TVicPort64 \??\C:\Windows\SysWOW64\drivers\TVicPort64.sys
fffffa60`049d8000 fffffa60`049f3000 wanarp \SystemRoot\system32\DRIVERS\wanarp.sys
fffffa60`04a04000 fffffa60`04a51000 rdbss \SystemRoot\system32\DRIVERS\rdbss.sys
fffffa60`04a51000 fffffa60`04a5d000 nsiproxy \SystemRoot\system32\drivers\nsiproxy.sys
fffffa60`04a5d000 fffffa60`04a7a000 dfsc \SystemRoot\System32\Drivers\dfsc.sys
fffffa60`04a7a000 fffffa60`04a81000 AsIO \SystemRoot\SysWow64\drivers\AsIO.sys
fffffa60`04a81000 fffffa60`04a9d000 cdfs \SystemRoot\system32\DRIVERS\cdfs.sys
fffffa60`04a9d000 fffffa60`04aab000 crashdmp \SystemRoot\System32\Drivers\crashdmp.sys
fffffa60`04aab000 fffffa60`04ab7000 dump_dumpata \SystemRoot\System32\Drivers\dump_dumpata.sys
fffffa60`04ab7000 fffffa60`04abf000 dump_atapi \SystemRoot\System32\Drivers\dump_atapi.sys
fffffa60`04abf000 fffffa60`04adb000 usbccgp \SystemRoot\system32\DRIVERS\usbccgp.sys
fffffa60`04adb000 fffffa60`04aee000 LHidFilt \SystemRoot\system32\DRIVERS\LHidFilt.Sys
fffffa60`04aee000 fffffa60`04af9000 kbdhid \SystemRoot\system32\DRIVERS\kbdhid.sys
fffffa60`04af9000 fffffa60`04b04000 mouhid \SystemRoot\system32\DRIVERS\mouhid.sys
fffffa60`04b04000 fffffa60`04b18000 LMouFilt \SystemRoot\system32\DRIVERS\LMouFilt.Sys
fffffa60`04b18000 fffffa60`04b24000 Dxapi \SystemRoot\System32\drivers\Dxapi.sys
fffffa60`04b24000 fffffa60`04b37000 monitor \SystemRoot\system32\DRIVERS\monitor.sys
fffffa60`04b37000 fffffa60`04bac000 fwlanusb \SystemRoot\system32\DRIVERS\fwlanusb.sys
fffffa60`04bac000 fffffa60`04bce000 luafv \SystemRoot\system32\drivers\luafv.sys
fffffa60`04bce000 fffffa60`04be8000 mpsdrv \SystemRoot\System32\drivers\mpsdrv.sys
fffffa60`04be8000 fffffa60`04c00000 adfs \SystemRoot\System32\Drivers\adfs.SYS
fffffa60`0620f000 fffffa60`062a9000 spsys \SystemRoot\system32\drivers\spsys.sys
fffffa60`062a9000 fffffa60`062bd000 lltdio \SystemRoot\system32\DRIVERS\lltdio.sys
fffffa60`062bd000 fffffa60`062f1000 nwifi \SystemRoot\system32\DRIVERS\nwifi.sys
fffffa60`062f1000 fffffa60`062fc000 ndisuio \SystemRoot\system32\DRIVERS\ndisuio.sys
fffffa60`062fc000 fffffa60`06314000 rspndr \SystemRoot\system32\DRIVERS\rspndr.sys
fffffa60`06314000 fffffa60`063b7000 HTTP \SystemRoot\system32\drivers\HTTP.sys
fffffa60`063b7000 fffffa60`063e0000 srvnet \SystemRoot\System32\DRIVERS\srvnet.sys
fffffa60`063e0000 fffffa60`063fe000 bowser \SystemRoot\system32\DRIVERS\bowser.sys
fffffa60`0660d000 fffffa60`06634000 mrxdav \SystemRoot\system32\drivers\mrxdav.sys
fffffa60`06634000 fffffa60`0665d000 mrxsmb \SystemRoot\system32\DRIVERS\mrxsmb.sys
fffffa60`0665d000 fffffa60`066a6000 mrxsmb10 \SystemRoot\system32\DRIVERS\mrxsmb10.sys
fffffa60`066a6000 fffffa60`066c5000 mrxsmb20 \SystemRoot\system32\DRIVERS\mrxsmb20.sys
fffffa60`066c5000 fffffa60`066f7000 srv2 \SystemRoot\System32\DRIVERS\srv2.sys
fffffa60`066f7000 fffffa60`0678c000 srv \SystemRoot\System32\DRIVERS\srv.sys
fffffa60`0678c000 fffffa60`06797000 asyncmac \SystemRoot\system32\DRIVERS\asyncmac.sys
fffffa60`06797000 fffffa60`067a7000 MpNWMon \SystemRoot\system32\DRIVERS\MpNWMon.sys
fffffa60`067a7000 fffffa60`067fd000 acedrv11 \??\C:\Windows\system32\drivers\acedrv11.sys
fffffa60`07205000 fffffa60`072bb000 peauth \SystemRoot\system32\drivers\peauth.sys
fffffa60`072bb000 fffffa60`072c6000 secdrv \SystemRoot\System32\Drivers\secdrv.SYS
fffffa60`072c6000 fffffa60`072d6000 tcpipreg \SystemRoot\System32\drivers\tcpipreg.sys
fffffa60`072d6000 fffffa60`0730b000 fastfat \SystemRoot\System32\Drivers\fastfat.SYS
fffffa60`0730b000 fffffa60`0730d400 WmVirHid \SystemRoot\system32\drivers\WmVirHid.sys
Unloaded modules:
Edit: So, gerade hatte ich noch einen. Den Log wollte ich ja jetzt auch debuggen. Aber es gibt keinen, von dem gerade eben. Hatte ja das Häkchen bei "Vorhandene Dateien überschreiben" rausgemacht. Vllt. hat er deswegen kein neues gemacht. Soll ich das Häkchen wieder rein machen oder immer den Namen ändern oder so. Weil sonst hab ich ja keinen neuen Log?
Hi,
danke für den Tipp, jetzt läuft der PC seit fünf Stunden problemlos, ohne zu murren. Doch an was lag es denn nun. Am Netzteil glaub ich mal eher nicht, oder? Sollte doch eigentlich reichen. Was ich mir vostellen könnte, ist der RAM. Weil bei einem 430er FSB hat der damals nämlich mächtig gezickt. (@1,9V). Am Rest kanns meiner Meinung nach eigentlich nich liegen. Denn für Kühlung ist ja gesorgt.
Was denkst du denn?
mfg
Am NT liegt es eher nicht.
Möglich, dass sich die RAM´s nicht übertakten lassen. Probiere doch zunächst einen 400er FSB aus, ob es damit stabil bleibt.
Wie hast du die Spannungen bei der Übertaktung eingestellt?
