jukebox fehler: IRQL... muss nacher wieda ein foto schiesen!
hab grad das neue PCGH heft vor mir, da stehen 3 seiten über bluescreens! werd das mal durcharbeiten!!!
edit:
http://msdn2.microsoft.com/en-us/library/ms793232.aspx
dies were zum bluescreen von n-tune!
edit 2: fehler bei TV schauen über digittrade usb stick: IRQL_LESS_OR_EQUAL
http://msdn2.microsoft.com/en-us/library/ms793589.aspx
das bringt mich echt nicht weiter!
das sagt das debugging tool:
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffa600923dff8, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80001a1f99e, address which referenced memory
MODULE_NAME: nt
FAULTING_MODULE: fffff80001a4e000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 479192b7
WRITE_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
fffffa600923dff8
CURRENT_IRQL: 2
FAULTING_IP:
hal!memcpy+25e
fffff800`01a1f99e 48894118 mov qword ptr [rcx+18h],rax
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WRONG_SYMBOLS
BUGCHECK_STR: 0xA
LAST_CONTROL_TRANSFER: from fffff80001aa312e to fffff80001aa3390
und bei analyse:
0: kd> lmvm nt
start end module name
fffff800`01a4e000 fffff800`01f66000 nt T (no symbols)
Loaded symbol image file: ntoskrnl.exe
Image path: \SystemRoot\system32\ntoskrnl.exe
Image name: ntoskrnl.exe
Timestamp: Sat Jan 19 07:03:35 2008 (479192B7)
CheckSum: 00485FC7
ImageSize: 00518000
Translations: 0000.04b0 0000.04e0 0409.04b0 0409.04e0
