AW: 6 Jahre Aldi sind genug!
In dem Ordner sind 2 solcher Dateien..Ergebnisse:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\032811-17238-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02c5e000 PsLoadedModuleList = 0xfffff800`02e9be50
Debug session time: Mon Mar 28 17:49:56.337 2011 (UTC + 2:00)
System Uptime: 0 days 0:02:08.290
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {22, 2, 0, fffff80002c5f36d}
Probably caused by : ntkrnlmp.exe ( nt!IoBoostThreadIoPriority+2ed )
Followup: MachineOwner
2: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000022, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80002c5f36d, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002f060e0
0000000000000022
CURRENT_IRQL: 2
FAULTING_IP:
fffff800`02c5f36d 418a442422 mov al,byte ptr [r12+22h]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: System
TRAP_FRAME: fffff88003185620 -- (.trap 0xfffff88003185620)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffff88003185830 rbx=0000000000000000 rcx=fffff88003185848
rdx=fffffa8008fa3a7e rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002c5f36d rsp=fffff880031857b0 rbp=0000000000000000
r8=0000000000000000 r9=0000000000000000 r10=0000000000000000
r11=fffff8a006c80140 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na po cy
nt!IoBoostThreadIoPriority+0x2ed:
fffff800`02c5f36d 418a442422 mov al,byte ptr [r12+22h] ds:00000000`00000022=??
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002ccf469 to fffff80002ccff00
STACK_TEXT:
fffff880`031854d8 fffff800`02ccf469 : 00000000`0000000a 00000000`00000022 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`031854e0 fffff800`02cce0e0 : fffff800`02e5c5e0 00000000`00000001 fffff880`00010000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`03185620 fffff800`02c5f36d : fffffa80`06725740 00000000`00000000 00000000`00000001 fffff800`02e735b8 : nt!KiPageFault+0x260
fffff880`031857b0 fffff800`02d18a76 : fffffa80`067f3ae8 fffff8a0`00000002 fffffa80`067f3ed0 fffff880`03185830 : nt!IoBoostThreadIoPriority+0x2ed
fffff880`03185960 fffff800`02c98afd : fffffa80`067f3ac0 00000000`00000001 00000000`00000000 fffff880`02f64180 : nt! ?? ::FNODOBFM::`string'+0x1a6c4
fffff880`031859a0 fffff800`02cd81bc : ffffffff`ffb3b4c0 fffffa80`067f3ae8 fffffa80`067f3ac0 00000000`00000000 : nt!ExpWaitForResource+0x8d
fffff880`03185a10 fffff880`0124d5d3 : 00000000`c00000d8 fffff8a0`06c80010 fffffa80`067bf7e0 fffffa80`00000001 : nt!ExAcquireResourceExclusiveLite+0x14f
fffff880`03185a80 fffff880`012e9560 : fffffa80`067bf7e0 fffff800`02e735a0 fffff8a0`06c80010 00000000`00000009 : Ntfs!NtfsAcquireExclusiveFcb+0x73
fffff880`03185ad0 fffff880`012c338f : fffffa80`067bf7e0 fffff8a0`06c80140 fffff8a0`06c80010 fffffa80`0910d180 : Ntfs!NtfsCommonClose+0xa0
fffff880`03185ba0 fffff800`02cdd161 : 00000000`00000000 fffff880`012c3200 fffff800`02ed5101 fffffa80`00000003 : Ntfs!NtfsFspClose+0x15f
fffff880`03185c70 fffff800`02f73166 : 000001a8`24948b48 fffffa80`06725680 00000000`00000080 fffffa80`06709040 : nt!ExpWorkerThread+0x111
fffff880`03185d00 fffff800`02cae486 : fffff880`02f64180 fffffa80`06725680 fffff880`02f6efc0 3344247c`89000000 : nt!PspSystemThreadStartup+0x5a
fffff880`03185d40 00000000`00000000 : fffff880`03186000 fffff880`03180000 fffff880`03185660 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!IoBoostThreadIoPriority+2ed
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc600
FAILURE_BUCKET_ID: X64_0xA_nt!IoBoostThreadIoPriority+2ed
Machine Name:
2: kd> !analyze -v
Arguments:
Debugging Details:
0000000000000022
CURRENT_IRQL: 2
FAULTING_IP:
BUGCHECK_STR: 0xA
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
Simpel1970
hier im Forum mehr. Schreib ihm am besten mal ne PN.
