Rumpelkammer: PCGH Folding@Home-Thread II
Ach Mensch das ist ärgerlich wenn Hardware sich schrottet.
Hoffentlich hat keine weitere Har[d]ware gelitten.
Muss auch mal wieder meinen Senf dazugeben. Hat schon mal einer diesen Effekt mit dem GPU2-Consolen-Client gehabt::ugly:
- Client hat Projekt zuende gerechnet, Anzeige:
Code:
[21:29:08] Completed 100%
[21:30:03] Successful run
[21:30:03] DynamicWrapper: Finished Work Unit: sleep=10000
[21:30:14] Reserved 75764 bytes for xtc file; Cosm status=0
[21:30:14] Allocated 75764 bytes for xtc file
[21:30:14] - Reading up to 75764 from "work/wudata_09.xtc": Read 75764
[21:30:14] Read 75764 bytes from xtc file; available packet space=786354700
[21:30:14] xtc file hash check passed.
[21:30:14] Reserved 15168 15168 786354700 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[21:30:14] Allocated 15168 bytes for arc file
[21:30:14] - Reading up to 15168 from "work/wudata_09.trr": Read 15168
[21:30:14] Read 15168 bytes from arc file; available packet space=786339532
[21:30:14] trr file hash check passed.
[21:30:14] Allocated 560 bytes for edr file
[21:30:14] Read bedfile
[21:30:14] edr file hash check passed.
[21:30:14] Allocated 0 bytes for logfile
[21:30:14] Could not open/read logfile=<work/wudata_09.log>; Cosm status=-1
[21:30:14] GuardedRun: success in DynamicWrapper
[21:30:15] GuardedRun: done
[21:30:15] Run: GuardedRun completed.
[21:30:32] + Opened results file
[21:30:32] - Writing 92004 bytes of core data to disk...
[21:30:33] Done: 91492 -> 90139 (compressed to 98.5 percent)
[21:30:33]   ... Done.
[21:30:36] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[21:30:37] Shutting down core
[21:30:37]
[21:30:37] Folding@home Core Shutdown: FINISHED_UNIT
- dann tut sich nichts mehr, Client scheint stehen zu bleiben
- <Strg>C eingegeben und Client beendet sich, FahCore_11.exe läuft jedoch weiter :huh:
Code:
Folding@Home Client Shutdown.
- Client mit -send all gestartet, nichts passiert:
Code:
[21:37:25] Loaded queue successfully.
[21:37:25] Attempting to return result(s) to server...
- FahCore_11.exe im Process Explorer gekillt
- Client neu gestartet und dann das:
Code:
[21:38:18] Error: Missing work file=<>
[21:38:18]
[21:38:18] Folding@home Core Shutdown: MISSING_WORK_FILES
[21:38:22] CoreStatus = 74 (116)
[21:38:22] The core could not find the work files specified. Removing from queue
[21:38:22] Deleting current work unit & continuing...
Jetzt faltet er dasselbe Projekt noch mal, eine Stunde Folding futsch.:what: Waren zwar nur 353 Punkte, aber trotzdem blöd.
Solangsam finde ich das nicht mehr lustig. mein i7 920 ist jetzt mit 1,3125v lt Bios und 1,296 v lt. CPUz faltstabil...wo kann man da sparen? hat jemand paar Bioskniffe?
achso mich interessieren da ehr Einstellungen zur stabilisierung das Vcore um diesen ggf. zu senken..
Ist es normal, dass n I5-2430M ca 20mins für 1% braucht, und dass er seit ca 1h mittlerweile steht?
Ist es normal, dass be GT555M ca 1h für 1% braucht und seit ca 1,5h steht?
Das stehen nach 1/1,5h ist NICHT normal... Alles andere: Kein plan, habe andere Hardware am Start ;)
Zur lösung des "stehens": Welche Temps hast du auf der GPU/CPU? Welche Taktraten liegen beim "stehen" an?
Grad hat er gesagt, dass ein schwerwiegendes Problem aufgetreten ist und er deshalb abbrechen muss...
--> Temps und Takte kann ich dir grad schlecht sagen...
Deine Entscheidung ;) aber auch so @ Stock sollte der was bringen... Probiers einfach mal aus... Wenn dein Bruder (was ich ausm anderen Thread entnehme) sehr viel an dem Computer ist, kann ich die Empfehlung unterschreiben die dir in dem Thread gemacht wurde: Einfach nen Singlecore Client nebenher laufen lassen... Vielleicht kannst ja iwann auch SMP falten...
Wie wärs mit dem System aus meiner Sig?
Würde das mehr bringen?
Also mit dem 7er Client dürfte dein Sys ~15k PPD schaffen. (~9k PPD für die CPU und ~6k PPD für die GPU) Du kannst ja mal hier schauen. Mit der Liste kannst du in etwa abschätzen, was deine CPU bringt.
Wenn es ums Stromsparen geht, könntest du auch nur die GPU arbeiten lassen. Laut Messung von PCGH verbraucht die HD5770 beim Falten nur ~60W (leider wird dabei vernachlässigt, dass die CPU auch belastet wird). Im Leerlauf soll sie laut Liste bei Wiki ~20 W verbrauchen. Wären also ~40W Mehrverbrauch für 6k PPD.
nen Single-Core kann ich schon laufen lassen, nur muss der halt am systemstart immer angeschalten werden...
(dafür is mein Bro zu faul...)
Wenn ich mit der GraKa falte, kann ich dann nebenbei noch spielen (MW2/BFBC2/BF3/MW3)??
Das is nämlich seine Haupt-Beschäftigung...
Kann ich den Großen hauptsächlich falten lassen und den Lappi nur manchmal/nebenher?
Zum ersten: Sowohl der 6er als auch der 7er Client können automatisch mit Win gestartet werden. Beim 6er Client musst du das ganze als Service lösen. (Gibts hier sicher eine Anleitung dazu, wenn nicht einfach danach fragen) Der 7er Client, den du sowieso wegen der GPU bräuchtest, startet alles normalerweise sowie mit Win, dass kann man aber auch umstellen.
Zum Spielen nebenbei: Grundsätzlich kann man den Client beim Spielen weiter laufen lassen, weil er nur mit einer niedrigen Priorität läuft. Müsstest du aber mal ausprobieren, ob und wie gut das funktioniert.
Ja klar du kannst beide Rechner falten lassen. Wichtig dabei ist nur, dass du die WUs mit Bonus (SMP und einige Singelcore-WUs) am Stück laufen lässt, weil sonst die Bonuspunkte durch die Pause verringert werden.
Hallo:
Ich hab ein vergleichbares system
1055t + 6950 ..
Bei mir Läuft der V7 Client als SMP (CPU) und manchesmal auch der GPU Client..
Ich schalte eigentlich den Client auch beim Spielen nicht aus, und hätte noch keine Probleme bemerkt (Witcher 2,..)
mach bei 3,5ghz ca 12k punkte..
die AMD Grafikkarte falten zu lassen bringt zwar mehr punkte, allerdings sackt dafür der SMP client ein, so dass der effektive Mehrgewinn meiner Meinung nach zu gering ist (derzeit)
neue AMD Projekte ändern das stetig in eine "gute" Richtung
Ich hoffe, dass ich dir helfen konnte
mfg
ps: also den 6Kerner samt SMP anschmeißen ;)
pps: mit dem System schaffst du es je nach Faltzeit richtung TOP 100/200 !!! (in unserem Team..)
@klefreak: Hast du mal gemessen, wie sich das PPD/W-Verhältnis beim CPU-only und beim CPU- und GPU-Falten verändert?
Die AMD-Karten verbrauchen ja nicht so sehr viel Strom. In einer älteren PCGH war da ein Test drin. Ich hab nur noch den Wert für meine HD5770 im Kopf da waren es 60W beim Falten und es sollten so 20W in idle sein. Bei den größeren Karten waren es aber auch nicht mehr als 100W. Den Mehrverbrauch bei der CPU kann man ja vernachlässigen, weil die CPU ja sowieso unter Volllast läuft.
