11:54:07:WU01:FS01
ownloading 7.85MiB11:54:13:WU01:FS01
ownload 99.49%
11:54:13:WU01:FS01
ownload complete
11:54:13:WU01:FS01:Received Unit: id:01 state
OWNLOAD error:NO_ERROR project:11750 run:0 clone:4770 gen:14 core:0x22 unit:0x0000001e8ca304e75e6a80354fd9b673
11:54:13:WU01:FS01:Starting
11:54:13:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
11:55:13:WU01:FS01:Starting
11:55:13:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
11:56:50:WU01:FS01:Starting
11:56:50:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
11:58:22:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
11:58:22:ERROR:durch den Hostcomputer abgebrochen.
11:59:27:WU01:FS01:Starting
11:59:27:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
12:03:42:WU01:FS01:Starting
12:03:42:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
12:03:42:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:11750 run:0 clone:4770 gen:14 core:0x22 unit:0x0000001e8ca304e75e6a80354fd9b673
12:03:42:WU01:FS01:Connecting to 140.163.4.231:8080
12:03:42:WU02:FS01:Connecting to 65.254.110.245:8080
12:03:43:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:03:43:WU02:FS01:Connecting to 18.218.241.186:80
12:03:43:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:03:43:ERROR:WU02:FS01:Exception: Could not get an assignment
12:03:43:WU02:FS01:Connecting to 65.254.110.245:8080
12:03:44:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:03:44:WU02:FS01:Connecting to 18.218.241.186:80
12:03:44:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:03:44:ERROR:WU02:FS01:Exception: Could not get an assignment
