*********************** Log Started 2020-02-15T16:32:48Z ***********************
16:32:48:************************* Folding@home Client *************************
16:32:48: Website:
Folding@home – Fighting disease with a world wide distributed super computer.
16:32:48: Copyright: (c) 2009-2018 foldingathome.org
16:32:48: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:32:48: Args:
16:32:48: Config: C:\Users\gsfor\AppData\Roaming\FAHClient\config.xml
16:32:48:******************************** Build ********************************
16:32:48: Version: 7.5.1
16:32:48: Date: May 11 2018
16:32:48: Time: 13:06:32
16:32:48: Repository: Git
16:32:48: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
16:32:48: Branch: master
16:32:48: Compiler: Visual C++ 2008
16:32:48: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:32:48: Platform: win32 10
16:32:48: Bits: 32
16:32:48: Mode: Release
16:32:48:******************************* System ********************************
16:32:48: CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
16:32:48: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
16:32:48: CPUs: 4
16:32:48: Memory: 15.93GiB
16:32:48: Free Memory: 13.12GiB
16:32:48: Threads: WINDOWS_THREADS
16:32:48: OS Version: 6.2
16:32:48: Has Battery: false
16:32:48: On Battery: false
16:32:48: UTC Offset: 1
16:32:48: PID: 11780
16:32:48: CWD: C:\Users\gsfor\AppData\Roaming\FAHClient
16:32:48: OS: Windows 10 Home
16:32:48: OS Arch: AMD64
16:32:48: GPUs: 1
16:32:48: GPU 0: Bus:3 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64]
16:32:48: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
16:32:48: angegebene Modul wurde nicht gefunden.
16:32:48:
16:32:48:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3004.8
16:32:48: Win32 Service: false
16:32:48:***********************************************************************
16:32:49:<config>
16:32:49: <!-- Folding Slot Configuration -->
16:32:49: <cause v='CANCER'/>
16:32:49:
16:32:49: <!-- Network -->
16:32:49: <proxy v=':8080'/>
16:32:49:
16:32:49: <!-- Slot Control -->
16:32:49: <power v='full'/>
16:32:49:
16:32:49: <!-- User Information -->
16:32:49: <passkey v='********************************'/>
16:32:49: <team v='70335'/>
16:32:49: <user v='Raeuber'/>
16:32:49:
16:32:49: <!-- Folding Slots -->
16:32:49: <slot id='0' type='CPU'>
16:32:49: <pause-on-start v='true'/>
16:32:49: </slot>
16:32:49: <slot id='1' type='GPU'>
16:32:49: </slot>
16:32:49:</config>
16:32:49:Trying to access database...
16:32:49:Successfully acquired database lock
16:32:49:Enabled folding slot 00: PAUSED cpu:3 (by user)
16:32:49:Enabled folding slot 01: PAUSED gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] (by user)
16:34:21:FS01:Unpaused
16:34:21:WU00:FS01:Connecting to 65.254.110.245:8080
16:34:22:WU00:FS01:Assigned to work server 140.163.4.241
16:34:22:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 140.163.4.241
16:34:22:WU00:FS01:Connecting to 140.163.4.241:8080
16:34:24:WU00:FS01
ownloading 11.66MiB
16:34:30:WU00:FS01
ownload 47.70%
16:34:34:WU00:FS01
ownload complete
16:34:34:WU00:FS01:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:11737 run:0 clone:691 gen:235 core:0x22 unit:0x000001148ca304f15df3d377d5af5d06
16:34:34:WU00:FS01:Starting
16:34:34:WU00:FS01:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\gsfor\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 11780 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:34:34:WU00:FS01:Started FahCore on PID 9244
16:34:34:WU00:FS01:Core PID:1940
16:34:34:WU00:FS01:FahCore 0x22 started
16:34:35:WU00:FS01:0x22:*********************** Log Started 2020-02-15T16:34:35Z ***********************
16:34:35:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:34:35:WU00:FS01:0x22: Type: 0x22
16:34:35:WU00:FS01:0x22: Core: Core22
16:34:35:WU00:FS01:0x22: Website:
16:34:35:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
16:34:35:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:34:35:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
16:34:35:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 9244 -checkpoint 15
16:34:35:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:34:35:WU00:FS01:0x22: Config: <none>
16:34:35:WU00:FS01:0x22:************************************ Build *************************************
16:34:35:WU00:FS01:0x22: Version: 0.0.2
16:34:35:WU00:FS01:0x22: Date: Dec 6 2019
16:34:35:WU00:FS01:0x22: Time: 21:30:31
16:34:35:WU00:FS01:0x22: Repository: Git
16:34:35:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
16:34:35:WU00:FS01:0x22: Branch: HEAD
16:34:35:WU00:FS01:0x22: Compiler: Visual C++ 2008
16:34:35:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:34:35:WU00:FS01:0x22: Platform: win32 10
16:34:35:WU00:FS01:0x22: Bits: 64
16:34:35:WU00:FS01:0x22: Mode: Release
16:34:35:WU00:FS01:0x22:************************************ System ************************************
16:34:35:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
16:34:35:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
16:34:35:WU00:FS01:0x22: CPUs: 4
16:34:35:WU00:FS01:0x22: Memory: 15.93GiB
16:34:35:WU00:FS01:0x22:Free Memory: 12.70GiB
16:34:35:WU00:FS01:0x22: Threads: WINDOWS_THREADS
16:34:35:WU00:FS01:0x22: OS Version: 6.2
16:34:35:WU00:FS01:0x22:Has Battery: false
16:34:35:WU00:FS01:0x22: On Battery: false
16:34:35:WU00:FS01:0x22: UTC Offset: 1
16:34:35:WU00:FS01:0x22: PID: 1940
16:34:35:WU00:FS01:0x22: CWD: C:\Users\gsfor\AppData\Roaming\FAHClient\work
16:34:35:WU00:FS01:0x22: OS: Windows 10 Home
16:34:35:WU00:FS01:0x22: OS Arch: AMD64
16:34:35:WU00:FS01:0x22:********************************************************************************
roject: 11737 (Run 0, Clone 691, Gen 235)
16:34:35:WU00:FS01:0x22:Unit: 0x000001148ca304f15df3d377d5af5d06
16:34:35:WU00:FS01:0x22:Reading tar file core.xml
16:34:35:WU00:FS01:0x22:Reading tar file integrator.xml
16:34:35:WU00:FS01:0x22:Reading tar file state.xml
16:34:35:WU00:FS01:0x22:Reading tar file system.xml
igital signatures verified
16:34:35:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:34:35:WU00:FS01:0x22:Version 0.0.2
16:34:41:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
16:34:41:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:35:56:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
16:37:11:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
16:38:26:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
16:39:41:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
16:40:55:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
16:42:10:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
16:43:26:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
16:44:41:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
16:45:56:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
16:47:11:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
16:48:27:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
16:49:42:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
16:50:57:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
16:52:13:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
16:53:28:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
16:54:43:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
16:55:58:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
16:57:12:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
16:58:27:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
16:59:42:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
17:00:57:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
17:02:12:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
17:03:28:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
17:04:47:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
17:06:07:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
17:07:23:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
17:08:44:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
17:10:03:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
17:11:20:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
17:12:36:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
17:13:53:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
17:15:09:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
17:16:25:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
17:17:43:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
17:19:01:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
17:20:22:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
17:21:43:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
17:23:02:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
17:24:27:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
17:25:53:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
17:27:26:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
17:28:54:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
17:30:26:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
17:31:46:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
17:33:08:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
17:34:25:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
17:35:42:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
17:36:57:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
17:38:12:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
17:39:26:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
17:40:42:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
17:41:57:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
17:43:11:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
17:44:26:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
17:45:41:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
17:46:55:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
17:48:10:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
17:49:25:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
17:50:40:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
17:51:54:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
17:53:10:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
17:54:25:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
17:55:39:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
17:56:54:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
17:58:09:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
17:59:23:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
18:00:38:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
18:01:53:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
18:03:08:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
18:04:22:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
18:05:38:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
18:06:53:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
18:08:08:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
18:09:22:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
18:10:37:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
18:11:51:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
18:13:06:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
18:14:21:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
18:15:35:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
18:16:52:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
18:17:22:FS01:Finishing
18:18:07:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
18:19:22:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
18:20:36:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
18:21:51:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
18:23:05:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
18:24:20:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
18:25:35:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
18:26:49:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
18:28:04:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
18:29:19:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
18:30:34:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
18:31:49:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
18:33:14:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
18:34:29:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
18:35:44:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
18:36:58:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
18:38:13:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
18:39:28:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
18:40:43:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
18:41:57:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
18:41:58:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
18:41:58:WU00:FS01:0x22:Saving result file checkpointState.xml
18:41:58:WU00:FS01:0x22:Saving result file checkpt.crc
18:41:58:WU00:FS01:0x22:Saving result file positions.xtc
18:41:58:WU00:FS01:0x22:Saving result file science.log
18:41:58:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:41:59:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:41:59:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11737 run:0 clone:691 gen:235 core:0x22 unit:0x000001148ca304f15df3d377d5af5d06
18:41:59:WU00:FS01:Uploading 6.51MiB to 140.163.4.241
18:41:59:WU00:FS01:Connecting to 140.163.4.241:8080
18:42:05:WU00:FS01:Upload 15.37%
18:42:11:WU00:FS01:Upload 35.53%
18:42:17:WU00:FS01:Upload 56.66%
18:42:23:WU00:FS01:Upload 77.79%
18:42:29:WU00:FS01:Upload 99.88%
18:42:29:WU00:FS01:Upload complete
18:42:30:WU00:FS01:Server responded WORK_ACK (400)
18:42:30:WU00:FS01:Final credit estimate, 62335.00 points
18:42:30:WU00:FS01:Cleaning up
