Rumpelkammer: PCGH Folding@Home-Thread II
Code:
02:32:45:WU01:FS00:0x21:Completed 2225000 out of 2500000 steps (89%)
02:34:40:WU02:FS01:0x21:Completed 175000 out of 2500000 steps (7%)
02:35:45:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9209 run:2 clone:10 gen:33 core:0x21 unit:0x0000009a664f2dd055edf02e98ca1048
02:35:45:WU00:FS01:Uploading 17.50MiB to 171.64.65.104
02:35:45:WU00:FS01:Connecting to 171.64.65.104:8080
02:35:47:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
02:35:47:WU00:FS01:Connecting to 171.64.65.104:80
02:35:48:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
02:35:48:WU00:FS01:Trying to send results to collection server
02:35:48:WU00:FS01:Uploading 17.50MiB to 171.65.103.160
02:35:48:WU00:FS01:Connecting to 171.65.103.160:8080
02:35:54:WU00:FS01:Upload 1.79%
02:36:00:WU00:FS01:Upload 3.93%
02:36:06:WU00:FS01:Upload 5.71%
02:36:12:WU00:FS01:Upload 7.86%
02:36:18:WU00:FS01:Upload 10.00%
02:36:24:WU00:FS01:Upload 12.14%
02:36:30:WU00:FS01:Upload 14.29%
02:36:36:WU00:FS01:Upload 16.07%
02:36:42:WU00:FS01:Upload 18.21%
02:36:48:WU00:FS01:Upload 20.36%
02:36:54:WU00:FS01:Upload 22.50%
02:37:00:WU00:FS01:Upload 24.29%
02:37:06:WU00:FS01:Upload 26.43%
02:37:12:WU00:FS01:Upload 28.57%
02:37:18:WU00:FS01:Upload 30.36%
02:37:24:WU00:FS01:Upload 32.50%
02:37:29:WU01:FS00:0x21:Completed 2250000 out of 2500000 steps (90%)
02:37:30:WU00:FS01:Upload 34.64%
02:37:36:WU00:FS01:Upload 36.43%
02:37:42:WU00:FS01:Upload 38.57%
02:37:48:WU00:FS01:Upload 40.72%
02:37:54:WU00:FS01:Upload 42.86%
02:38:00:WU00:FS01:Upload 45.00%
02:38:06:WU00:FS01:Upload 46.79%
02:38:12:WU00:FS01:Upload 48.93%
02:38:18:WU00:FS01:Upload 51.07%
02:38:24:WU00:FS01:Upload 53.22%
02:38:30:WU00:FS01:Upload 55.00%
02:38:36:WU00:FS01:Upload 57.14%
02:38:42:WU00:FS01:Upload 59.29%
02:38:48:WU00:FS01:Upload 61.43%
02:38:54:WU00:FS01:Upload 63.57%
02:39:00:WU00:FS01:Upload 65.36%
02:39:06:WU00:FS01:Upload 67.50%
02:39:12:WU00:FS01:Upload 69.64%
02:39:18:WU00:FS01:Upload 71.79%
02:39:24:WU00:FS01:Upload 73.57%
02:39:30:WU00:FS01:Upload 75.72%
02:39:36:WU00:FS01:Upload 77.86%
02:39:42:WU00:FS01:Upload 80.00%
02:39:48:WU00:FS01:Upload 81.79%
02:39:54:WU00:FS01:Upload 83.93%
02:40:00:WU00:FS01:Upload 86.07%
02:40:06:WU00:FS01:Upload 88.22%
02:40:12:WU00:FS01:Upload 90.00%
02:40:18:WU00:FS01:Upload 92.15%
02:40:24:WU00:FS01:Upload 94.29%
02:40:30:WU00:FS01:Upload 96.43%
02:40:36:WU00:FS01:Upload 98.57%
02:40:41:WU00:FS01:Upload complete
02:40:41:WU00:FS01:Server responded PLEASE_WAIT (464)
02:40:41:WARNING:WU00:FS01:Failed to send results, will try again later
02:42:14:WU01:FS00:0x21:Completed 2275000 out of 2500000 steps (91%)
Was ist das? Please Wait?
6 Tage später hat's heute morgen um 2 endlich geklappt - die WU hatte unterdessen aber schon einen Großteil ihrer Punkte verloren..
jap die gibt es, habe ich aber auch vorher irgendwo im Thread mal erwähnt glaube ich..
ist aber auch noch viel optimierungsbedarf vorhanden :(
Auf dem iPad kann man sich glaube ich auch den Viewer anzeigen lassen,
aber immerhin hat man schon ein getrennte auflistung der PPD ;)
Auf meinem IPhone 5s mit Ios 9 kann ich keine Angaben machen. Er bleibt immer im Reiter Work-Unit stehen. Hat wer eine Idee? Später werde ich auch noch einmal neu installieren.
Für Einsteiger ist die Debian Edition nicht empfohlen.
"LMDE is less mainstream than Linux Mint, it has a much smaller user base, it is not compatible with PPAs, and it lacks a few features. That makes it a bit harder to use and harder to find help for, so it is not recommended for novice users."
Auf meinem alten Laptop habe ich auch Mint (Cinnamon), aber diese Diskussion macht mich etwas nachdenklich:
Linux Mint downloads (briefly) compromised [LWN.net]
Kurze Frage: ich versuche ja immer noch von Windoof wegzukommen - daher:
Linux Mint Ubuntu
oder
Linux Mint Debian ?
Das ist ein Versuch, der sich sicher lohnt. Ich finde das gut.
Es kommt aber auf Dauer darauf an, wie bequem man es haben will.
Ich meine, wenn neue Harware angeschafft wird, dann muß die Erwartungshaltung des leichten Einbaus / Übernahme ins System funktionieren.
Ich betreibe meinen Drucker beispielsweise im LAN. Das war beim letzten Versuch vor einiger Zeit noch eine Herausforderung, weil Einträge per Hand in bestimmten Dateien nötig wurden. Ich habe das ohne fremde Hilfe hinbekommen, aber die Zeit für solche Aktionen will ich mir nicht jedes Mal genehmigen. ...
Ich muß nun aber noch dazusagen, daß ich mich ganz leidlich unter SUN SOLARIS bewegen und scripten kann und daß ich den vi liebe, denn den findet man immer und überall und hat damit dann auch immer seine gewohnte Umgebung. Aber eines ist sicher: Ich werde mir in bälde nochmals eine Linuxversion anschauen, dabei sind mir Posts wie die vom Prof oben wichtig. Denn wenn erstmal "Verzweiflung" Einzug hält, dann geht man unweigerlich den Möglichkeiten, die Linux bietet verloren.
Ich wünsche Dir eine glückliche Hand bei der Wahl.
Falls es Dir bei Mint vor allem um die Desktopumgebung geht und Du Bedenken hast:
Cinnamon gibt es auch für Ubuntu. Die Installation ist nicht schwieriger als Folding@home einzurichten, behaupte ich mal.
Egal, welche Distribution Du Dir aussuchst, das Ubuntuusers-Wiki kann ich nur empfehlen. Ich habe bisher keine Seite gefunden, auf der es für so viele Dinge konkrete, zugängliche Anleitungen/Lösungen gibt.
Danke für Eure Meinungen. Bei der Versionswahl achte ich auf LTS, da scheidet Ubuntu Mate derzeit aus. ;)
Was die USB-Hardware betrifft, da habe ich "gemogelt". Jeder kennt das, daß Scanner, Drucker & TV-Stick unter Linux nicht den vollen Funktionsumfang bieten, wie unter Windows. Also habe ich den VMware-Player unter LinuxMint 17.3 mit einer Windows XP Prof Version eingerichtet & diese sogar freigeschaltet. Da eine VMware vor allem USB-Hardware an den Gast weiterleitet, konnte ich unter XP dann die Windows-Treiber installieren und die Geräte wie gewohnt im vollen Umfang nutzen. Voraussetzung hierbei ist aber, daß Ubuntu die Hardware mit Standard-Treibern erkennt und einrichtet. Von der XP-Image habe ich natürlich ein Backup angelegt, was sauber bleibt und zudem ewig freigeschaltet ist. ;)
Der Vorteil an Mint Debian ist das Rolling Release. Hab's derzeit in ner VMware laufen, wirkt ebenfalls recht benutzerfreundlich.
So, dann teste ich mal weiter & FaH läuft bei beiden Systemen ohne Probleme, also Mint Ubuntu & Mint Debian. :)
Edit: mit "Get Linux" habe ich mir in den letzten Wochen weit über 100 Linux-Distribution reingezogen. Ich muß sagen, daß hier optisch und auch funktional recht ansprechende Versionen bei sind - die Qual der Wahl ... ;)
Warum sind AMD Karten soviel schlechter beim Falten?
R9 Fury X @ 1050 MHz = 360.000 PPD
GTX TITAN X = 1478 MHz = 1.005.025 PPD
Die Theoretische Rechnenleistung von der Fury X ist doch um einiges höher
Hallo Tobi, es liegt leider an den ROPs, die bei AMD leider nicht so zahlreich vorhanden sind. Die AMD Top-Modelle habe "nur" soviele wie bspw. eine GTX 970.
Moin zusammen,
dadurch das Ich seit neusten Probleme mit meinem Netzteil habe, muss ich das Falten vorerst auf Eis legen :(
Ich weis nicht was mein Netzteil hat und vor allem welche Schutzschaltung hier greift.
Um einem Hardware defekt vorzubeugen, bin ich gezwungen das Falten Ruhen zu lassen. Das ist mir nicht geheuer ...
Ich hoffe ja das es "nur" die OTP ist die greift ... Sollte die UVP/OVP oder gar die OCP greifen, liegt ein anderer Defekt vor ... Das wird nun im laufe der nächsten Zeit von SuperFlower geprüft werden ...
Wenn das neue Netzteil da ist, wird selbstverständlich weiter gefaltet :daumen:
Hi,
ich werde über Ostern mit den falten pausieren. Die Tage werde ich mein altes Laptop wieder auspacken und erstmal entmüllen. Ich hoffe die Punkteausbeute ist mit einen i3-2310M und einer GT 555M mit DDR3 vertretbar, weil ich dann ab Mai 13 Wochen zuhause bin und nicht auf die Leistung meines PC's zurückgreifen kann.
ich wünsche allen frohe Ostern.
Alex
PS: ca. 150-160 Dauerfalter von 5183 Mann ist ein bisschen wenig, oder?
