kaisims
Hey Leute,
seit der Windows 7 Installation auf einer SSD (siehe Signatur) kann ich z.B. kein Minecraft und kein Adobe After Effects öffnen.
-Neuester stabiler Grafikkartentreiber
-Windows7 64-Bit
-vor der installation gings
-After Effects Fehler 0 § 42
Vielleicht könnte sich das jemand mal anschauen...
Vielen Dank,
kaisims
-Windows7 64-Bit
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_INT_DIVIDE_BY_ZERO (0xc0000094) at pc=0x00000000633fa67f, pid=1348, tid=4872
# JRE version: 7.0_17-b02
# Java VM: Java HotSpot(TM) 64-Bit Server VM (23.7-b01 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [atio6axx.dll+0x118a67f] DrvPresentBuffers+0x114793f
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# HotSpot Virtual Machine Error Reporting Page
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x000000001bd19800): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=4872, stack(0x0000000014c80000,0x0000000014d80000)]
siginfo: ExceptionCode=0xc0000094
Registers:
RAX=0x0000000000070000, RBX=0x0000000017034210, RCX=0x0000000000000000, RDX=0x0000000000000000
RSP=0x0000000014d7e1f0, RBP=0x0000000014d7e2f0, RSI=0x0000000000000380, RDI=0x0000000000000200
R8 =0x0000000000000001, R9 =0x0000000002040101, R10=0x0000000000000000, R11=0x0000000000000007
R12=0x0000000000000000, R13=0x000000001e5aaac0, R14=0x0000000000000000, R15=0x000000001df009a0
RIP=0x00000000633fa67f, EFLAGS=0x0000000000010246
Top of Stack: (sp=0x0000000014d7e1f0)
0x0000000014d7e1f0: 0000000100001000 0000000000001000
0x0000000014d7e200: 0000000000001000 00000000634769cb
0x0000000014d7e210: 0000000000000002 0000000000000004
0x0000000014d7e220: 0000000000000001 0000000000000000
0x0000000014d7e230: 0000000000000001 0000000063477547
0x0000000014d7e240: 0000000000000004 0000000000000000
0x0000000014d7e250: 0000000000000000 0000000062dd169f
0x0000000014d7e260: 000000001e051bb8 0000000000000001
0x0000000014d7e270: 0000000077015410 0000000014d7e528
0x0000000014d7e280: 000000001e050d98 0000000062dccb07
0x0000000014d7e290: 0000000000000000 0000000014d7e528
0x0000000014d7e2a0: 0000000000000000 00000000170b44b0
0x0000000014d7e2b0: 000000001e70e0f0 0000000062d9e776
0x0000000014d7e2c0: 0000000000000000 0000000000000022
0x0000000014d7e2d0: 00000000170b44b0 00000000170ab250
0x0000000014d7e2e0: 000000001e5aac60 000000001e70e0f0
Instructions: (pc=0x00000000633fa67f)
0x00000000633fa65f: 45 85 c0 0f 84 81 04 00 00 ff c9 74 0c ff c9 74
0x00000000633fa66f: 2e ff c9 0f 85 7b 05 00 00 33 d2 8b c7 0f af c6
0x00000000633fa67f: 41 f7 b7 20 05 00 00 44 8b e0 3d 00 00 08 00 0f
0x00000000633fa68f: 87 86 02 00 00 bb 08 00 00 00 e9 9e 02 00 00 41
Register to memory mapping:
RAX=0x0000000000070000 is an unknown value
RBX=0x0000000017034210 is an unknown value
RCX=0x0000000000000000 is an unknown value
RDX=0x0000000000000000 is an unknown value
RSP=0x0000000014d7e1f0 is pointing into the stack for thread: 0x000000001bd19800
RBP=0x0000000014d7e2f0 is pointing into the stack for thread: 0x000000001bd19800
RSI=0x0000000000000380 is an unknown value
RDI=0x0000000000000200 is an unknown value
R8 =0x0000000000000001 is an unknown value
R9 =0x0000000002040101 is an unknown value
R10=0x0000000000000000 is an unknown value
R11=0x0000000000000007 is an unknown value
R12=0x0000000000000000 is an unknown value
R13=0x000000001e5aaac0 is an unknown value
R14=0x0000000000000000 is an unknown value
R15=0x000000001df009a0 is an unknown value
Stack: [0x0000000014c80000,0x0000000014d80000], sp=0x0000000014d7e1f0, free space=1016k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x0000000000000000
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.GL11.nglClear(IJ)V+0
j org.lwjgl.opengl.GL11.glClear(I)V+15
j org.lwjgl.opengl.Display.initContext()V+16
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribs
V+97
V+9
j net.minecraft.client.Minecraft.a()V+174
j asq.a()V+94
j net.minecraft.client.Minecraft.run()V+6
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x000000001bd19800 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=4872, stack(0x0000000014c80000,0x0000000014d80000)]
0x000000001bd17800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=2364, stack(0x0000000014b80000,0x0000000014c80000)]
0x000000001bd19000 JavaThread "Snooper Timer" daemon [_thread_blocked, id=4960, stack(0x00000000149d0000,0x0000000014ad0000)]
0x0000000013292800 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=1344, stack(0x000000001a200000,0x000000001a300000)]
0x00000000021dc800 JavaThread "DestroyJavaVM" [_thread_blocked, id=2372, stack(0x0000000002440000,0x0000000002540000)]
0x00000000131f3000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=1352, stack(0x0000000018eb0000,0x0000000018fb0000)]
0x00000000131d6000 JavaThread "TimerQueue" daemon [_thread_blocked, id=5524, stack(0x00000000189a0000,0x0000000018aa0000)]
0x0000000012f8c800 JavaThread "SwingWorker-pool-1-thread-1" daemon [_thread_blocked, id=4736, stack(0x00000000187e0000,0x00000000188e0000)]
0x0000000012fd4000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=5188, stack(0x0000000013900000,0x0000000013a00000)]
0x0000000012fd3800 JavaThread "AWT-Shutdown" [_thread_blocked, id=5360, stack(0x0000000013b20000,0x0000000013c20000)]
0x0000000013000000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=648, stack(0x0000000013a00000,0x0000000013b00000)]
0x000000001110f800 JavaThread "Service Thread" daemon [_thread_blocked, id=3848, stack(0x0000000012a50000,0x0000000012b50000)]
0x000000001110e800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=4708, stack(0x0000000012930000,0x0000000012a30000)]
0x0000000011109000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=4368, stack(0x0000000012760000,0x0000000012860000)]
0x0000000011108000 JavaThread "Attach Listener" daemon [_thread_blocked, id=3404, stack(0x0000000012600000,0x0000000012700000)]
0x0000000011101000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4588, stack(0x0000000012370000,0x0000000012470000)]
0x00000000022d8000 JavaThread "Finalizer" daemon [_thread_blocked, id=4684, stack(0x0000000012070000,0x0000000012170000)]
0x00000000022d1800 JavaThread "Reference Handler" daemon [_thread_blocked, id=5676, stack(0x00000000121b0000,0x00000000122b0000)]
Other Threads:
0x0000000011083000 VMThread [stack: 0x0000000011f40000,0x0000000012040000] [id=2432]
0x0000000011122000 WatcherThread [stack: 0x0000000012be0000,0x0000000012ce0000] [id=1660]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 1223360K, used 398485K [0x00000007aaab0000, 0x0000000800000000, 0x0000000800000000)
eden space 1048640K, 38% used [0x00000007aaab0000,0x00000007c2fd54c0,0x00000007eaac0000)
from space 174720K, 0% used [0x00000007f5560000,0x00000007f5560000,0x0000000800000000)
to space 174720K, 0% used [0x00000007eaac0000,0x00000007eaac0000,0x00000007f5560000)
ParOldGen total 2796224K, used 0K [0x0000000700000000, 0x00000007aaab0000, 0x00000007aaab0000)
object space 2796224K, 0% used [0x0000000700000000,0x0000000700000000,0x00000007aaab0000)
PSPermGen total 21248K, used 21098K [0x00000006fae00000, 0x00000006fc2c0000, 0x0000000700000000)
object space 21248K, 99% used [0x00000006fae00000,0x00000006fc29a898,0x00000006fc2c0000)
Card table byte_map: [0x0000000005600000,0x0000000005e30000] byte_map_base: 0x0000000001e29000
Polling page: 0x0000000000240000
Code Cache [0x0000000002540000, 0x00000000027b0000, 0x0000000005540000)
total_blobs=1121 nmethods=460 adapters=612 free_code_cache=47463Kb largest_free_block=48585088
Compilation events (10 events):
Event: 17.466 Thread 0x000000001110e800 nmethod 457 0x00000000026cbed0 code [0x00000000026cc000, 0x00000000026cc058]
Event: 17.466 Thread 0x0000000011109000 nmethod 456 0x00000000026d7a90 code [0x00000000026d7be0, 0x00000000026d7eb8]
Event: 17.467 Thread 0x000000001110e800 458 java.util.regex.Pattern$BmpCharProperty::match (50 bytes)
Event: 17.468 Thread 0x000000001110e800 nmethod 458 0x00000000026dbb90 code [0x00000000026dbce0, 0x00000000026dbe98]
Event: 17.500 Thread 0x0000000011109000 459 ! java.io.BufferedReader::readLine (304 bytes)
Event: 17.500 Thread 0x000000001110e800 460 java.lang.AbstractStringBuilder::<init> (12 bytes)
Event: 17.501 Thread 0x000000001110e800 nmethod 460 0x00000000026db890 code [0x00000000026db9e0, 0x00000000026dbaf8]
Event: 17.518 Thread 0x0000000011109000 nmethod 459 0x00000000026e1950 code [0x00000000026e1b20, 0x00000000026e31b0]
Event: 17.528 Thread 0x000000001110e800 461 sun.net.www.ParseUtil::encodePath (336 bytes)
Event: 17.547 Thread 0x000000001110e800 nmethod 461 0x00000000026de690 code [0x00000000026de8c0, 0x00000000026df988]
GC Heap History (0 events):
No events
Deoptimization events (10 events):
Event: 17.410 Thread 0x000000001bd18000 Uncommon trap -75 fr.pc 0x00000000026da39c
Event: 17.412 Thread 0x000000001bd18000 Uncommon trap -75 fr.pc 0x00000000026da01c
Event: 17.428 Thread 0x000000001bd18000 Uncommon trap -75 fr.pc 0x00000000026d991c
Event: 17.431 Thread 0x000000001bd18000 Uncommon trap -75 fr.pc 0x00000000026d959c
Event: 17.433 Thread 0x000000001bd18000 Uncommon trap -75 fr.pc 0x00000000026d921c
Event: 17.435 Thread 0x000000001bd18000 Uncommon trap -75 fr.pc 0x00000000026d8e9c
Event: 17.438 Thread 0x000000001bd18000 Uncommon trap -75 fr.pc 0x00000000026d8b1c
Event: 17.451 Thread 0x000000001bd18000 Uncommon trap -75 fr.pc 0x00000000026d9c9c
Event: 17.451 Thread 0x000000001bd18000 Uncommon trap -75 fr.pc 0x00000000026d879c
Event: 17.492 Thread 0x00000000131f3000 Uncommon trap -34 fr.pc 0x000000000267a8ec
Internal exceptions (10 events):
Event: 17.721 Thread 0x000000001bd19800 Threw 0x00000007c1d91030 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.721 Thread 0x000000001bd19800 Threw 0x00000007c1d91430 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.726 Thread 0x000000001bd19800 Threw 0x00000007c1dbe800 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.726 Thread 0x000000001bd19800 Threw 0x00000007c1dbec00 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.757 Thread 0x000000001bd19800 Threw 0x00000007c1deae30 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.757 Thread 0x000000001bd19800 Threw 0x00000007c1deb298 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.758 Thread 0x000000001bd19800 Threw 0x00000007c1dee3b8 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.758 Thread 0x000000001bd19800 Threw 0x00000007c1dee7f8 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.758 Thread 0x000000001bd19800 Threw 0x00000007c1df1ae0 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.758 Thread 0x000000001bd19800 Threw 0x00000007c1df1f40 at C:\jdk7u2_64p\jdk7u17\hotspot\src\share\vm\prims\jvm.cpp:1166
Events (10 events):
Event: 17.721 loading class 0x0000000013536ed0
Event: 17.721 loading class 0x0000000013536ed0 done
Event: 17.726 loading class 0x00000000134957d0
Event: 17.726 loading class 0x00000000134957d0 done
Event: 17.757 loading class 0x000000001b977f70
Event: 17.757 loading class 0x000000001b977f70 done
Event: 17.758 loading class 0x000000001b9d6ce0
Event: 17.758 loading class 0x000000001b9d6ce0 done
Event: 17.758 loading class 0x000000001b9797b0
Event: 17.758 loading class 0x000000001b9797b0 done
Dynamic libraries:
0x000000013f3d0000 - 0x000000013f403000 C:\Windows\system32\java.exe
0x0000000076f00000 - 0x00000000770a9000 C:\Windows\SYSTEM32\ntdll.dll
0x0000000076ce0000 - 0x0000000076dff000 C:\Windows\system32\kernel32.dll
0x000007fefc310000 - 0x000007fefc37b000 C:\Windows\system32\KERNELBASE.dll
0x000007fefe260000 - 0x000007fefe33b000 C:\Windows\system32\ADVAPI32.dll
0x000007fefdc80000 - 0x000007fefdd1f000 C:\Windows\system32\msvcrt.dll
0x000007fefc690000 - 0x000007fefc6af000 C:\Windows\SYSTEM32\sechost.dll
0x000007fefc980000 - 0x000007fefcaad000 C:\Windows\system32\RPCRT4.dll
0x0000000076e00000 - 0x0000000076efa000 C:\Windows\system32\USER32.dll
0x000007fefcab0000 - 0x000007fefcb17000 C:\Windows\system32\GDI32.dll
0x000007fefc960000 - 0x000007fefc96e000 C:\Windows\system32\LPK.dll
0x000007fefe450000 - 0x000007fefe519000 C:\Windows\system32\USP10.dll
0x000007fefa870000 - 0x000007fefaa64000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\COMCTL32.dll
0x000007fefe520000 - 0x000007fefe591000 C:\Windows\system32\SHLWAPI.dll
0x000007fefdfd0000 - 0x000007fefdffe000 C:\Windows\system32\IMM32.DLL
0x000007fefe340000 - 0x000007fefe449000 C:\Windows\system32\MSCTF.dll
0x0000000064ee0000 - 0x0000000064fb1000 C:\Program Files\Java\jre7\bin\msvcr100.dll
0x00000000639f0000 - 0x000000006410f000 C:\Program Files\Java\jre7\bin\server\jvm.dll
0x000007feeb900000 - 0x000007feeb909000 C:\Windows\system32\WSOCK32.dll
0x000007fefc910000 - 0x000007fefc95d000 C:\Windows\system32\WS2_32.dll
0x000007fefc970000 - 0x000007fefc978000 C:\Windows\system32\NSI.dll
0x000007fef6120000 - 0x000007fef615b000 C:\Windows\system32\WINMM.dll
0x00000000770c0000 - 0x00000000770c7000 C:\Windows\system32\PSAPI.DLL
0x0000000065090000 - 0x000000006509f000 C:\Program Files\Java\jre7\bin\verify.dll
0x0000000065060000 - 0x0000000065088000 C:\Program Files\Java\jre7\bin\java.dll
0x0000000065040000 - 0x0000000065055000 C:\Program Files\Java\jre7\bin\zip.dll
0x0000000064d40000 - 0x0000000064ed3000 C:\Program Files\Java\jre7\bin\awt.dll
0x000007fefc830000 - 0x000007fefc907000 C:\Windows\system32\OLEAUT32.dll
0x000007fefddc0000 - 0x000007fefdfc3000 C:\Windows\system32\ole32.dll
0x000007fefa7f0000 - 0x000007fefa846000 C:\Windows\system32\uxtheme.dll
0x000007fefa220000 - 0x000007fefa238000 C:\Windows\system32\dwmapi.dll
0x000007fefc110000 - 0x000007fefc11f000 C:\Windows\system32\CRYPTBASE.dll
0x000007fefcda0000 - 0x000007fefdb28000 C:\Windows\system32\SHELL32.dll
0x000007fee7180000 - 0x000007fee737f000 C:\Windows\system32\d3d9.dll
0x000007fefb2f0000 - 0x000007fefb2fc000 C:\Windows\system32\VERSION.dll
0x000007feea850000 - 0x000007feea857000 C:\Windows\system32\d3d8thk.dll
0x000007fef7fe0000 - 0x000007fef80fb000 C:\Windows\system32\aticfx64.dll
0x000007feea830000 - 0x000007feea850000 C:\Windows\system32\atiu9p64.dll
0x000007fee6ac0000 - 0x000007fee7177000 C:\Windows\system32\atiumd64.dll
0x0000000067490000 - 0x0000000067965000 C:\Windows\system32\atiumd6a.dll
0x0000000065000000 - 0x0000000065034000 C:\Program Files\Java\jre7\bin\fontmanager.dll
0x0000000064fe0000 - 0x0000000064ff9000 C:\Program Files\Java\jre7\bin\net.dll
0x000007fefba50000 - 0x000007fefbaa5000 C:\Windows\system32\mswsock.dll
0x000007fefba40000 - 0x000007fefba47000 C:\Windows\System32\wship6.dll
0x0000000064fc0000 - 0x0000000064fd1000 C:\Program Files\Java\jre7\bin\nio.dll
0x000007fefa4e0000 - 0x000007fefa4f5000 C:\Windows\system32\NLAapi.dll
0x000007fef9950000 - 0x000007fef9965000 C:\Windows\system32\napinsp.dll
0x000007fef9900000 - 0x000007fef9919000 C:\Windows\system32\pnrpnsp.dll
0x000007fefb8d0000 - 0x000007fefb92b000 C:\Windows\system32\DNSAPI.dll
0x000007fef98f0000 - 0x000007fef98fb000 C:\Windows\System32\winrnr.dll
0x0000000072300000 - 0x0000000072326000 C:\Program Files\Bonjour\mdnsNSP.dll
0x000007fefa160000 - 0x000007fefa187000 C:\Windows\system32\Iphlpapi.DLL
0x000007fefa150000 - 0x000007fefa15b000 C:\Windows\system32\WINNSI.DLL
0x00000000722a0000 - 0x00000000722ce000 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
0x000007fef97a0000 - 0x000007fef97b0000 C:\Windows\system32\wshbth.dll
0x000007fefa010000 - 0x000007fefa063000 C:\Windows\System32\fwpuclnt.dll
0x000007fef9140000 - 0x000007fef9148000 C:\Windows\system32\rasadhlp.dll
0x000007fefb410000 - 0x000007fefb417000 C:\Windows\System32\wshtcpip.dll
0x000007fefbab0000 - 0x000007fefbac7000 C:\Windows\system32\CRYPTSP.dll
0x000007fefb7b0000 - 0x000007fefb7f7000 C:\Windows\system32\rsaenh.dll
0x000007fefb520000 - 0x000007fefb53e000 C:\Windows\system32\USERENV.dll
0x000007fefc1e0000 - 0x000007fefc1ef000 C:\Windows\system32\profapi.dll
0x0000000064ce0000 - 0x0000000064d04000 C:\Program Files\Java\jre7\bin\sunec.dll
0x0000000064c90000 - 0x0000000064cd1000 C:\Program Files\Java\jre7\bin\t2k.dll
0x000007fefcb20000 - 0x000007fefcbb9000 C:\Windows\system32\CLBCatQ.DLL
0x000007fef9e50000 - 0x000007fef9fb1000 C:\Windows\system32\WindowsCodecs.dll
0x000007fefc0b0000 - 0x000007fefc107000 C:\Windows\system32\apphelp.dll
0x000007fef8350000 - 0x000007fef837a000 C:\Users\Kai\AppData\Roaming\Dropbox\bin\DropboxExt64.17.dll
0x000007fef7e40000 - 0x000007fef7f65000 C:\Windows\system32\dbghelp.dll
0x00000000718a0000 - 0x0000000071973000 C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\MSVCP90.dll
0x00000000717d0000 - 0x0000000071873000 C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\MSVCR90.dll
0x000007fef70b0000 - 0x000007fef70e5000 C:\Windows\system32\EhStorShell.dll
0x000007fefcbc0000 - 0x000007fefcd97000 C:\Windows\system32\SETUPAPI.dll
0x000007fefc2d0000 - 0x000007fefc306000 C:\Windows\system32\CFGMGR32.dll
0x000007fefc380000 - 0x000007fefc39a000 C:\Windows\system32\DEVOBJ.dll
0x000007fefaf20000 - 0x000007fefb04c000 C:\Windows\system32\PROPSYS.dll
0x000007fef7030000 - 0x000007fef70b0000 C:\Windows\system32\ntshrui.dll
0x000007fefbd50000 - 0x000007fefbd73000 C:\Windows\system32\srvcli.dll
0x000007fef7cf0000 - 0x000007fef7cff000 C:\Windows\system32\cscapi.dll
0x000007fefa2e0000 - 0x000007fefa2eb000 C:\Windows\system32\slc.dll
0x0000000064d30000 - 0x0000000064d3b000 C:\Program Files\Java\jre7\bin\sunmscapi.dll
0x000007fefc3a0000 - 0x000007fefc50a000 C:\Windows\system32\CRYPT32.dll
0x000007fefc280000 - 0x000007fefc28f000 C:\Windows\system32\MSASN1.dll
0x0000000180000000 - 0x0000000180048000 E:\Spiele\Minecraft\Minecraft\.minecraft\bin\natives\lwjgl64.dll
0x000007fee4fe0000 - 0x000007fee50fd000 C:\Windows\system32\OPENGL32.dll
0x000007fee6190000 - 0x000007fee61bd000 C:\Windows\system32\GLU32.dll
0x000007fee5300000 - 0x000007fee53f1000 C:\Windows\system32\DDRAW.dll
0x000007fef6e60000 - 0x000007fef6e68000 C:\Windows\system32\DCIMAN32.dll
0x0000000064d20000 - 0x0000000064d27000 C:\Program Files\Java\jre7\bin\jawt.dll
0x000007fef9940000 - 0x000007fef9949000 C:\Windows\system32\atig6pxx.dll
0x0000000062270000 - 0x00000000639e7000 C:\Windows\system32\atio6axx.dll
0x000007fef97d0000 - 0x000007fef9879000 C:\Windows\system32\atiadlxx.dll
0x000007fefb3f0000 - 0x000007fefb401000 C:\Windows\system32\WTSAPI32.dll
0x000007fefc290000 - 0x000007fefc2c9000 C:\Windows\system32\WINTRUST.dll
0x000007feed610000 - 0x000007feed61f000 C:\Windows\system32\atig6txx.dll
VM Arguments:
jvm_args: -Xmx4096M -Xms4096M
java_command: minecraft.jar kaisims
Launcher Type: SUN_STANDARD
Environment Variables:
CLASSPATH=.;C:\Program Files (x86)\Java\jre7\lib\ext\QTJava.zip
PATH=C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files\Common Files\Microsoft Shared\Windows Live
USERNAME=Kai
OS=Windows_NT
PROCESSOR_IDENTIFIER=AMD64 Family 16 Model 10 Stepping 0, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 Service Pack 1
CPU:total 4 (4 cores per cpu, 1 threads per core) family 16 model 10 stepping 0, cmov, cx8, fxsr, mmx, sse, sse2, sse3, popcnt, mmxext, 3dnowpref, lzcnt, sse4a, tsc, tscinvbit, tscinv
Memory: 4k page, physical 16771952k(14058492k free), swap 33542048k(25318124k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (23.7-b01) for windows-amd64 JRE (1.7.0_17-b02), built on Mar 1 2013 03:38:30 by "java_re" with unknown MS VC++:1600
time: Tue Mar 26 21:45:38 2013
elapsed time: 17 seconds
Registers:
j asq.a()V+94
Other Threads:
Heap
No events
Events (10 events):
Dynamic libraries:
VM Arguments:
USERNAME=Kai
OS=Windows_NT
Vielen Dank,
kaisims
