Neuer Gaming-PC fuer Shooter-Games (BRINK atm)
... ok, hier mal ein Versuch ein kleineres, aber nach wie vor gutes Netzteil (Cable-Management waere nett | muss einiges aushalten, da wir hier sehr viele Strom-Blackouts haben) zu finden: ...
... habe hier noch ein etwas betagtes Hiper Type-R 580W: ...
EXTREME Overclocking - Hiper Type-R 580W Modular Power Supply Review - Page: 1 - Tweaking PC Hardware To The Max
HIPER - PRODUCTS - HIPERPOWER - Type R - HPU-4B580
CORSAIR HX650W Modular Power Supply 650Watt
Item Code psCOhx_650
Corsair HX650W Features:
* Guaranteed to sustain its full rated wattage at an ambient temperature of 50°C
* Up to 85% energy-efficiency under real-world load conditions*
* Single +12V rail design providing up to 52A
* Multi-GPU ready
* Active Power Factor Correction (PFC) with PF value of 0.99
* Supports ATX12V 2.2 and EPS12V 2.91 standards. Backwards compatible with ATX12V 2.01
* Auto switching circuitry for universal AC input from 90-264V
* Over Current/Voltage/Power Protection, Under Voltage Protection and Short Circuit Protection provide complete component safety
* Dimensions: 150mm(W) x 86mm(H) x 150mm(L)
* MTBF: 100,000 hours
* Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
Price $ 139
ANTEC 550watt NEO PSU MODEL : NEOPOWER 550
Item Code psANneo_550
Cool, efficient, and quiet
The Neo HE line combines the most desired features in PC power supplies with remarkable efficiency in design. These new power supplies' energy-efficient operation reduces power consumption by up to 20% compared with traditional power supplies, saving users money. NeoHE also generate less heat, and enable cooling with a smaller, slower, quieter fan. Active PFC circuitry further reduces their impact on the power infrastructure. The result is cooler, quieter, and more environmentally friendly power.
Features:
* Nvidia SLI certified
* Highly efficient (up to 85%), one super-silent 80mm fan keeps Neo HE cool; less than 18dBA noise level
* . Advanced Cable Management System improves internal airflow and reduces system clutter by allowing you to use only the cables you need.
* Universal Input with Active PFC: Use anywhere in the world without worrying about input voltages; Active PFC improves voltage stability and delivers environmentally-friendlier power.
* Dedicated Power Circuitry: Delivers safer, more reliable output to your system’s delicate components. Includes dedicated voltage outputs, triple +12V output circuits, voltage feedback circuitry, and tighter ±3% regulation for improved system stability.
* ATX12V v2.2 compliant; backward compatible with all ATX12V v2.01 systems.
* Three +12V output circuits provide maximum stable power for the CPU independently of the other peripherals.
* Accurate power rating allows Neo HE to deliver its full rated power, 24 hours a day rated at 50ºC.
* PCI Express graphics card power connector.
* Low-speed 80mm fan delivers whisper-quiet cooling and ensures quiet operation by varying fan speed in response to load and conditions.
* SATA connectors for your Serial ATA drives.
* Industrial grade protection circuitry prevents damage resulting from short circuits (SCP), under voltage protection (UVP), power overloads (OPP), excessive current (OCP) and excessive voltages (OVP).
Price $ 149
THERMALTAKE 675W Toughpower XT High Quality Japanese Capacitors Model: TPX-675M
Item Code psTH675w_tp_xt
Specifications
P/N TPX-675M
Model TP-675AH3CC
Type Intel ATX 12V 2.3 & EPS 12V 2.91
Max. Output Capacity 675W
Peak Output Capacity 775W
Color Black
Dimension ( W / H / D ) 150mm(W) x 86mm(H) x 160mm(L)
PFC (Power Factor Correction) Active PFC
Power Good Signal 100-500 msec
Hold Up Time 15msec (minimum) at 80% of full load at 230Vac input.
Input Current 115Vac / 12A max. 230Vac / 6A max.
Input Frequency Range 47 Hz ~ 63 Hz
Input Voltage 100 VAC- 240 VAC
Operation Temperature 0℃ to +50℃
Operating Humidity 20% to 90%,non-condensing
Storage Temperature -20 ℃ to +70 ℃
Storage Humidity 5% to 95%, non-condensing
Cooling System 140mm dual ball bearing Fan:1900 RPM � 10%
Efficiency 82% ~85% at full load (typical) and 115Vac input. Up to 89% at 230V Input.
MTBF 120,000 hrs minimum
Safety Approval UL/CUL, FCC, TUV, CE, BSMI, GOST
Price $ 165
CORSAIR HX750W Modular Power Supply 750Watt
Item Code psCOhx_750
Corsair Professional Series power supply units have been designed by Corsair and engineered to the highest quality standards to meet the demands of enthusiasts that expect the very best. The Corsair Professional Series HX750W PSU utilizes advanced DC-to-DC circuitry and meets 80 PLUS SILVER certification standards for up to 90% energy-efficiency*, reducing wasted energy and lowering the amount of excess heat generated. Corsair Professional Series power supplies are built using industrial grade electrical components, ensuring the stable, clean and reliable voltages that are essential for high-end gaming PCs and workstations.
Corsair Professional Series power supplies boast an innovative cabling configuration that uses low-profile, flat modular cables that reduce air friction to help maximize airflow through the computer chassis. The modular design also simplifies installation as it allows unprecedented flexibility in using only those cables which are needed.
* Tested at room temperature, using a 50% load and 230V AC input.
Corsair HX750W Features:
* Up to 90% energy-efficiency under real-world load conditions*
* Single +12V rail design providing up to 62A
* Multi-GPU ready
* 105°C solid state capacitors
* Supports ATX12V 2.3 and EPS12V 2.91 standards. Backwards compatible with ATX12V 2.01
* Dimensions: 150mm(W) x 86mm(H) x 180mm(L)
Price $ 195
... wegen dem RAM: ...
CORSAIR QUAD XMS3 2gig x 4 (8 Gig) DDR3 XMS3-1333C9 1333mhz Model: CMX8GX3M4A1333C9
Item Code memCOqu_d3_8gig1333c9
Corsair CMX8GX3M4A1333C9 8GB (4x XMS3 2GB) PC-10600 (1333MHz) XMS KIT, DDR3 For MB i7/ i5 Core dual channel DDR3 processors, 2x240-pin DIMMs, DUAL CHANNEL, Non ECC Unbuffered, 9-9-9-24, XMS Heat Spreader, 1.5V
Price $ 99
CORSAIR QUAD XMS3 2gig x 4 (8 Gig) DDR3 XMS3-1600C9 1600mhz Model: CMX8GX3M4A1600C9
Item Code memCOqu_d3_8gig1600c9
Corsair CMX8GX3M4A1600C9 8GB (4x XMS3 2GB) PC-12800 (1600MHz) XMS KIT, DDR3 For MB i7/ i5 Core dual channel DDR3 processors, 2x240-pin DIMMs, DUAL CHANNEL, Non ECC Unbuffered, 9-9-9-24, XMS Heat Spreader, 1.65V
Price $ 109
... GraKa habe ich kleiner gefunden: ...
GIGABYTE GTX560Ti OVERCLOCK 1024MB GDDR5 Dual DVI HDMI Clock:900MHz Model:GV-N560OC-1GI
Item Code viGIgtx_560_oc_1024
Series GeForce 500 Series
Chipset GeForce GTX 560 Ti
Key Features UDV
Core Clock 900 MHz
Shader Clock 1800 MHz
Memory Clock 4000 MHz
Memory Type GDDR5
DirectX 11
D-sub Yes (By Adapter)
DVI Yes
HDMI Yes
Memory Size 1 GB
Price $ 239
Boah ey, was ist das denn für ein Schuppen. :D
... ich nenne das "Paradise" ... :D
Wenn die Lautstärke keine Rolle spielt, kannst Du einen der bereits genannten Kühler schon nehmen. Zur Not kannst Du ja nen leiseren Lüfter montieren.
... den 11X Extreme hatte ich schonmal in meiner Auswahl, somit wechsle ich da mal wieder zurueck ... :)
Gruss
TONSCHUH :daumen:
Netzteil würde ich das Antec True Power New 550 nehmen, das habe ich vorher in dem ersten Shop gefunden.
Beim RAM den mit 1333MHz Frequenz. Aber besser wären 2x4GB statt 4x2GB
Graka: :daumen:
Graka: :daumen:
... sollte dann wohl dieses NT sein: ...
ANTEC (USA) 550watt TRUE POWER NEW 120mm Fan Model: TP-550
Item Code psANtrue_550_new
New features. Same true power. The TruePower New series by Antec offers users an advanced power supply solution, striking the perfect balance of reliability, efficiency and quality. With DC to DC voltage regulator modules, a 120mm PWM fan, and 80 PLUS� Bronze certification, the TP-550, TP-650, TP-750 and TP-750 Blue are the ideal solution for elite system builders and quality-minded enthusiasts alike.
Features:
* NVIDIA� SLI� - ready certified
* 80PLUS� Bronze Certified saves energy and lowers your electric bill
* DC to DC voltage regulator modules for greater system stability
* 120mm PWM fan runs up to 50% quieter than standard fans
* Advanced Hybrid Cable Management improves airflow and reduces clutter
* Double layer PCB optimizes cooling efficiency and allows for heavy duty components
* Universal Input and Active Power Factor Correction
* Supports dual GPUs and dual/quad core CPUs
* 4 +12V output circuits provide stable power
* ATX12V v2.3 and EPS12V v2.91
* 1 x 6 pin and 1 x 8 (6+2) pin PCI-E graphics card connectors for TP-550
* Safety approval: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick, BSMI
* Weight: 2.3 kg; 5 lbs
* Dimensions:
- 3.4" (H) x 5.9" (W) x 5.9" (D)
- 86mm (H) x 150mm (W) x 150mm (D)
Price $ 108
... werde dann mal meine Liste auf den aktuellen Stand bringen, damit ich sehe, wo ich stehe ... :)
Gruss
TONSCHUH :daumen:
Hallo, die GIGABYTE GTX560Ti OVERCLOCK 1024MB aus Post #21 kann man auch verschärft im Auge behalten. 239 AUD macht nach Tageskurs ca. 176€ - kann man das so ansetzen,
also ein bischen kaufkraftbereinigt etc, oder ist das unrealistisch? 176€ für die Karte ist hier echt günstig. - Greetz -
... ok, diesmal ohne Bilder: ...
Case (habe ich schonmal als Basis fuer einen Kunden-Office-PC benutzt und war mit dem Aufbau sehr zufrieden):
AEROCOOL STRIKE-X Black/Red High Performance Gaming Case Japanese Steel 2x12cm / 1x 14cm Fan => $ 129
zusaetzliche Gehaeuse-Luefter (macht dann insgesamt 6 Luefter | PC laeuft 24/7, deshalb keine "billigen"):
AEROCOOL SHARK 120mm Red Fluid Bearing 14 Blades => 3 x $ 25 = $ 75
Netzteil:
ANTEC (USA) 550watt TRUE POWER NEW 120mm Fan Model: TP-550 => $ 108
Motherboard:
ASUS P8P67 REV3.0 Intel P67 Chipset DDR3 2200Mhz (OC 32GB MAX) ATX 8Channel HDAudio SATA3 USB 3.0 => $ 183
CPU (sollte ich die 2500K bekommen, ersetze ich die 2600K):
INTEL CORE i7 2600K 3.40Ghz 8MB CACHE 95W LGA1155 => $325
CPU-Cooler:
ZALMAN CNPS11X EXTREME ULTRA Performance Cooler AMD AM2+/AM2/AM3/754/939/940 Intel LGA775/1155/1366 => $ 99
RAM:
CORSAIR QUAD XMS3 2gig x 4 (8 Gig) DDR3 XMS3-1333C9 1333mhz Model: CMX8GX3M4A1333C9 => $ 99
Grafikkarte:
GIGABYTE GTX560Ti OVERCLOCK 1024MB GDDR5 Dual DVI HDMI Clock:900MHz Model:GV-N560OC-1GI => $ 239
Festplatten:
SeaGate 1TB 7200rpm SATA-3 32meg Cache Barracuda 7200.12 Model: ST31000524AS => 2 x $ 59 = $ 118
DVD-Brenner:
LG 22x DVD+/-R Burner SATA Model: GH22NS70 DUAL LAYER BLACK => $ 27
SATA-Kabel:
SATA 60cm LENGTH Data Cable connect SATA Device to motherboard => 3 x $ 5 = $ 15
Summe: $ 1417
... der Preis ging dann doch ein ganzes Stueck runter mit Eurer Hilfe, Danke ! ... :)
... bleibt die Frage, SSD ja / nein ? ...
... wenn ueberhaupt, wuerde ich nur diese hier kaufen, weil ich kein kleines Vermoegen fuer eine SSD ausgeben moechte: ...
OCZ Vertex2 120GB SSD Read / Write 285/275MB/S SandForce Controller 3.5inch SATA OCZSSD3-2VTX120G
Item Code ssdOC35vertex2_120
* Max Read: up to 285MB/s
* Max Write: up to 275MB/s
* Sustained Write: up to 250MB/s
* Random Write 4KB (Aligned): 50,000 IOPS
# Native TRIM support
# Max IOPS Firmware
# Seek Time: .1ms
# 3.5" Anodized Casing
# 146 (L) x 101.6 (W) x 11mm (H)
# Operating Temp: 0�C ~ 70�C
# Storage Temp: -45�C ~ +85�C
# Low Power Consumption: 2W in operation, .5W in standby
# Shock Resistant up to 1500G
# RAID Support
# Compatible with Windows XP, Vista, 7, Mac OS X and Linux
# MTBF: 2 million hours
Price $ 209
... auf die SSD wuerden nur Win-7-Ulti-x64 + Office 2010 + kleinere Tools + Webseiten-Appz kommen ... die Games liegen auf einer der obigen Seagates ... solltet ihr eine SSD empfehlen, kaufe ich nur 1 Seagate-Platte ... fuer Backup's + groessere Datenmengen benutze ich nur externe USB-Platten (im Moment 1 TB - Seagate + 2 TB - Seagate) ... :)
... sollte in etwa hinkommen: ...
http://au.finance.yahoo.com/q?s=AUDEUR=X
... laesst sich aber schwer vergleichen, da unser System komplett anders ist ... ich konvertiere gefuehlte 1:1 ... als ich Ende 2008 hier angekommen bin, waren viele Sachen etwa um die haelfte billiger (AUD lag bei etwa 0.62 EUR) ... da bei uns aber viele Preise / Kosten nach oben schiessen, kann man das nur noch schwer vergleichen ... Paradise war gestern ...
Gruss
TONSCHUH :daumen:
vor allem würde ich aber keine sechs Gehäuselüfter einbauen, selbst mit OC reicht in der Regel ein Front-, Heck- und Deckellüfter aus!
Zur SSD, sie beschleunigt hauptsächlich das Betriebssystem und Programme, bei Spielen reduziert sie die Lade- und evtl. vorhandene Nachladezeit, das Spiel selbst läuft aber nicht schneller/flüssiger. Wenn du das Geld investieren möchtest das ist das schon eine feine Sache weil sich der PC insgesamt schneller "anfühlt", zwingend notwendig ist sie aber nicht.
Lordac
... habe hier zwar eine Platte mit der Modell-Bezeichnung, allerdings nix mit SpinPoint (?): ...
SAMSUNG 1TB SATA-2 32meg Cache 7200rpm Model: HD103SJ
Item Code hddSA1tb_sata2
Price $ 58
... bei Umart waere sie eine Spinpoint (Model #: HD103SJ/SI) ... wuerde auch dort zwischen $ 58 - $ 68 kosten ...
... Enermax bekomme ich bei uns nicht ... den Scythe mit 800rpm muesste ich bei Umart bestellen ($ 14,50 - 24,50), genauso wie den mit 1200rpm ... haetten nur den 1900er auf Lager, allerdings weniger als 5 Stueck, was bei denen dann eher bedeutet 1 St. ...
Lordac
... werde mir das mal nochmal durch den Kopf gehen lassen, wegen der SSD ... haette hier noch eine nur minimal teure: ...
CORSAIR FORCE 3 120GB SSD SATA3 6Gb/s Read/Write 550/510MB/S 2.5inch CSSD-F120GB3-BK
Item Code ssdCOforce3_120
Corsair Force Series 3 120GB SSD. Step up to SATA 6Gb/s performance with a Corsair Force Series 3 SSD. Your system responds better, boots quicker, and loads applications faster. Ideal for notebooks, Corsair SSDs run cooler and quieter than traditional hard drives, using less power.
Product Features:
* Sequential read speeds of up to 550 MB/s;
* Sequential write speeds of up to 510 MB/s;
* SATA 6Gb/s (SATA 3) connectivity;
* High performance SandForce SF-2200 SSD controller
* Native TRIM support (O/S support required);
* RAID Support;
*BGC (Background Garbage Collection).
Price $ 259
... wegen den Lueftern: ...
... ok, auch wenn man das nicht direkt vergleichen kann, als ich hier angekommen bin, brachte ich mein A7N8X-Deluxe | 3200+ - Sys und habe sogar ein besseres Gehaeuse gekauft: ...
Thermaltakeusa » Chassis » Xaser VI Series » Xaser VI » Xaser VI : Xaser VI VG4000SWA
... Sys lief in Deutschland im Hochsommer ohne jegliche Probs in einem Standart-Tower-Gehaeuse ... hier hat sich das komplette Sys bei 31 Grad Zimmer-Temp. abgeschaltet ... habe dann nochmal, wenn auch komplett ueberteuert, die komplette Kuehlung aufs Maximum hochgefahren (keine Wakue) und die Kiste laeuft nach wie vor ... einzig meine ehemalige X1950-Pro hat den Geist aufgegeben und wurde mit einer HD4670 ersetzt ...
... das war aber im Haus der Schwiegereltern ... nun wohnen wir in einem kleinen Haeuschen mit Metalldach und komplett keiner Isolierung in den Holz/Regips-Aussenwaenden und haben die selben Temps drinnen wie draussen, sprich wenn's draussen 35 Grad hat, haben wir mindestens 35 Grad drinnen ... Klimaanlage ist leider ein Witz ... wenn Du aber trotzdem denkst, dass es mit den 3 vorhandenen Lueftern laufen sollte, spare ich mir natuerlich die $ 75 ... ;)
Gruss
TONSCHUH :daumen:
Die Vertex 2 ist schon etwas älter, die Vertex 3 ist moderner, die Crucial m4 auch. Ich würden, wenn SSD, von diesen beiden eine nehmen.
3 Lüfter reichen in der Regel, Vorne einer, Hinten einer und im Deckel einer. Mehr Lüfter bringen die kein Grad weniger im Case.
SSD ist im Moment die Crucial m4 die erste Wahl für ein Gamingsystem.
Festplatte solltest Du die flottere HD103SJ nehmen, nicht die -SI.
... ok, dann werde ich diese hier nehmen: ...
OCZ Vertex3 120GB SSD Read / Write 550/500MB/S SandForce Controller 2.5inch SATA VTX3-25SAT3-120G
Item Code ssdOC25vertex3_120
* Max Read: up to 550MB/s
* Max Write: up to 500MB/s
* Random Write 4KB (Aligned): 60,000 IOPS
# MLC NAND Flash
# Interface: SATA 6Gbps / Backwards Compatible 3Gbps
# Seek Time: .1ms
# Slim 2.5" Design
# 99.8 x 69.63 x 9.3mm
# Lightweight: 77g
# Operating Temp: 0�C ~ 55�C
# Storage Temp: -45�C ~ 85�C
# Low Power Consumption: 2W in operation,.5W in standby
# RAID Support
# Included 3.5" Desktop adapter bracket
# Compatible with Windows 7, Vista, XP 32-bit/64-bit, Mac OSX
Price $ 289
... da muss ich dann mal schauen, was sich da so machen laesst ...
... gebe hier auf jeden Fall eine Rueckmeldung, was ich an Teilen bekommen / verbaut habe und wie das Sys so laeuft, wenn es soweit ist ... kann je nachdem 2-4 Wochen dauern ...
... Vielen Dank nochmal Euch Allen fuer die zahlreichen Tip's und Hinweise ! ... :hail:
Gruss
TONSCHUH :daumen:
... als Maximum-System habe ich mich nun fuer das hier entschieden: ...
Case:
zusaetzliche Gehaeuse-Luefter:
Netzteil:
ANTEC TruePower QUATTRO 1000watt PSU EPS SLI-Ready Model: TPQ-1000 => $ 229
Motherboard:
CPU:
CPU-Cooler:
THERMALTAKE FRIO OCK CPU Cooler CPU Support Intel LGA1366/1155/775 AMD AM3/AM2+/AM2 CLP0575 => $ 89
RAM:
CORSAIR QUAD XMS3 2gig x 4 (8 Gig) DDR3 XMS3-1600C9 1600mhz Model: CMX8GX3M4A1600C9 => $ 109
Grafikkarte:
GIGABYTE GTX580 SUPER OVERCLOCK 1536MB GDDR5 Dual DVI Mini HDMI Clock:855MHz GV-N580SO-15I => $ 585
Festplatte:
SeaGate 1TB 7200rpm SATA-3 32meg Cache Barracuda 7200.12 Model: ST31000524AS => $ 59
SSD:
OCZ Vertex3 120GB SSD Read / Write 550/500MB/S SandForce Controller 2.5inch SATA VTX3-25SAT3-120G => $ 289
DVD-Brenner:
SATA-Kabel:
Summe: $ 2114
PS: ... denke mal, dass das Sys mit etwas OC (auf ~4.0GHz) fuer die naechsten 2-3 Jahre ausreichend sein sollte ... anschliessend hoffe ich nur RAM + GraKa + CPU upgraden zu muessen ... ok, evtl. auch die PSU ...
PPS: ... laeuft alles glatt, gebe ich in etwa 2 Wochen eine Bestandsaufnahme ...
PPPS: ... XBox-Kauf habe ich verschoben ... :)
Gruss
TONSCHUH :daumen:
Ein 1000W Netzteil brauchst Du nie im Leben. Selbst für 2x GTX580 reicht ein ~750-850 Watt Netzteil aus. Für eine GTX 580 ein Netzteil ab 500W.
Item Code viGIgtx_580_so_1024
Chipset GeForce GTX 580
Core Clock 855 MHz
Shader Clock 1710 MHz
Memory Clock 4100 MHz
Process Technology 40 nm
Memory Size 1536 MB
Memory Bus 384 bit
Card Bus PCI-E 2.0
Memory Type GDDR5
DirectX 11
OpenGL 4.1
Digital max resolution 2560 x 1600
Analog max resolution 2048 x 1536
Multi-view 2
# Powered by NVIDIA GeForce GTX 580 GPU
# Integrated with industry's best 1536 MB GDDR5 memory and 384-bit memory interface
# Features Dual link DVI-I*2 / mini HDMI with HDCP protection
# GIGABYTE GTX 580 SuperOverclock edition
# GIGABYTE WindForceâ„¢ 3X cooling design
# Support NVIDIA 3D Visionâ„¢ and SLI technologies
# Minimum 750W or greater system power supply with one 8-pin and 6-pin external power connectors
Price $ 585
... von daher sollte ich auf der sicheren Seite sein, sollte ich spaeter eine GTX590 oder was auch immer reinsetzen ... :)
Gruss
TONSCHUH :daumen:
Also von Brinker zu Brinker, ich hab 120-180 frames auf 1920x1200 mit meiner EVGA 560Ti FPB(also die schlechteste, fast ohne OC). Ok das is mit comp config.
Als ich noch mit vsync auf full details gespielt hab, hatte ich auch immer konstante 60fps.
Jedenfalls is die Karte mehr als ausreichend für die nächste Zukunft. Dabei kostet sie nichtmal die Hälfte, frisst extrem viel weniger Strom/braucht Leistung, ist extrem leise und weils bei dir ja ein großes Thema ist: Sie ist kühl im ganzen System.
Auch beim RAM würd ich das hier oder sogar den ganzen Artikel lesen:
Test: Welcher Speicher für
SATA Kabel sollten beim Mainboard dabei sein.
Die 480W meines Netzteils reichen ja wie gesagt... Danke hier nochmals an Softy für die Zusammenstellung:D
Du kannst dir auch für die allerschärfste Zukunftskiste ganz viel Geld sparen. Du wirst in den nächsten 2-3Jahren wohl nur die Graka wechseln müssen. CPU vielleicht irgendwann, aber sogar der billigste RAM is prima :)
Und weil ich den Thread ja schon aus dem SD forum kenn... Für Brink reicht ne kleine 560 graka echt dick!!
... ok, habe heute versucht die Teile zu bekommen und musste leider ein wenig vom Minimal-Sys abweichen, da wie hier leider ueblich nicht alles zu bekommen war ...
... Aenderungen: ...
- 2600K (2500K nicht erhaeltlich)
- 750W PSU (war das kleinste brauchbare Antec Netzteil, was zu bekommen war)
- keine SSD (da ich mich fuer das kleinere System entschieden hatte, hatte ich meiner Frau $ 500 fuer den Hochzeitstag versprochen und war dann leider etwas limitiert)
- 2x 1gb SATA-3 Seagate (siehe SSD)
- GTX-570-OC (keine 560er-Ti in absehbarer Zeit zu bekommen)
- 2x 4gb DDR3 - 1600 - CL8 - Corsair (weder billige 1333er noch billige 1600er zu bekommen)
- Luefter in orange (nur orange oder blau erhaeltlich)
... habe das Sys schon zusammengebaut und hatte ein paar Platz-Probs und musste den Seitenluefter entfernen ... dann mal schauen, ob alles laeuft ...
... Erfahrungsbericht gibt es die Tage ... :)
Gruss
TONSCHUH :daumen:
Klingt doch nicht schlecht. Das Netzteil reicht auch für optionales SLI aus. Beim RAM würde ich darauf achten, dass die Spannung nicht höher als 1,55V eingestellt ist. Falls der mit 1,65V spezifiziert ist, kannst Du ihn i.d.R. auf 1333Mhz runtertakten und mit 1,5V laufen lassen.
Grüße
