- Vehicles in your garage can no longer be accidentally replaced with vehicles from the street. For details, see this page.
- Improved stability and fixed several crashes and hangs while transitioning between Jobs in GTA Online.
- Fixed an issue where certain players were unable to exit their garages while inside of a personal vehicle.
- Fixed an issue where the game could freeze if you were robbing a store while someone else was attempting to buy snacks there.
- A rare issue has been fixed where some players received a “Purchase Failed” error when attempting to buy apartments.
- Fixed an issue where players would be asked to quit the game while using text chat in Golf and pressing the “E” key.
- GTA Online characters can now be added to your shortlist in the Rockstar Editor.
- Fixed several clipping issues that occurred when taking Snapmatic selfies.
- One-on-One Vehicle Deathmatches in Free Roam will now properly spawn all participants in vehicles.
- Fixed a Steam-only issue where you could not alt-tab back into GTAV if you alt-tabbed out while the Steam overlay was active.
- Various fixes to bring improved patch download speeds.
- Improvements to matchmaking so players that have good connections to each other are matched together more frequently.
- Fixed a Steam-only issue where players could not use Mexican Spanish as a subtitle language.
- General stability fixes for director mode and video editor.
- Various crash fixes.
- Fixes for issues caused by launching the game in offline mode.
Ja hat er. Die Performance im CPU Limit ist definitiv etwas besser. Stellen an denen ich bisher reproduzierbar auf unter ~55 FPS gekommen bin laufen nun mit 58-60 FPS. Allgemein sehe ich auch viel seltener die FPS unterhalb von 60 (Vsync).
Einstellungen: Graß auf "Hoch", der Rest auf "Sehr hoch", Erweiterte Grafikeinstellungen alle deaktiviert.
Jetzt noch ein neuer nVidia Treiber, der noch bisschen was am DX11 Overhead optimiert und die 60 FPS stehen auf der ganzen Map konstant.
Mal sehen, was GPU Seitig noch geht. Hab zwar fast immer nur ne GPU Last von 70-80% trotz aktivem DSR @ 3135x1323, aber jede Der Ultra Einstellungen sorgte bisher dafür, dass ich teilweise ins GPU limit kam und damit stellenweise unter 60 FPS. Mal sehen, ob auch da noch was optimiert wurde...
Ich verstehe das nicht so ganz wie manche Konstant auf 60fps zocken können.
Ich hab alles auf Max gedreht mit 2 x MSAA und lediglich Full HD habe aber gerade einmal zwischen 30 und 70fps jenachdem wo ich grad auf der map bin, jedoch nie konstant.
Meiner Meinung nach läuft es seit dem Patch nochmal schlechter als vorher immer wieder Nachruckler und etc.
An der 970 wirds nicht liegen, der Vram hängt bei 3.1GB rum.
Hat nochwer solche Probleme?
Was mir allerdings sehr negativ auffällt, ist dieses Geruckel schon im Hauptmenü ist genau wie bei Assassins Creed Unity, die Maus zieht total nach.
Meine CPU Auslastung hängt während des Spielstarts auch sogut wie durchgehend auf 100%.
Ingame ist die Auslastung dann zwischen 80 und 95%
frag mich echt wie manche leute da nen performance boost bekommen haben wenn da garkeine performance verbesserung drin war![]()
Die tragen längst nicht alles ein, z.B werde mit jedem PATCH sehr oft Glitches gepatcht die aber nicht dabei sind. Und ein Freund berichtet auch das diese unnötigen Drops Geschichte endlich sind.
.Vertraue nie auf die Patchnotes von Rockstar.Die tragen längst nicht alles ein, z.B werde mit jedem PATCH sehr oft Glitches gepatcht die aber nicht dabei sind. Und ein Freund berichtet auch das diese unnötigen Drops Geschichte endlich sind.
Überlebensmission beim Güterbahnhof oder wie die Map heißt. Da gibt es so nen Lagerhaus wo man sich gut drin verschanzen kann. 10 Wellen bringen 30k$
Dankee!Hab das selbe glaube ich. Im ganzen Haus ist das Internet nicht mehr benutzbar, nichtmal WhatsApp Nachrichten werden versendet.
Deine CPU limitiert in GTA V ziemlich.
