-B Query/set Advanced Power Management feature, if the drive supports it. A low value means aggressive power management and a high value means better performance. Possible settings range from values 1 through 127 (which permit spin-down), and values 128 through 254 (which do not permit spin-down). The highest degree of power management is attained with a setting of 1, and the highest I/O performance with a setting of 254. A value of 255 tells hdparm to disable Advanced Power Management altogether on the drive (not all drives support disabling it, but most do).
-y Force an IDE drive to immediately enter the low power consumption standby mode, usually causing it to spin down. The current power mode status can be checked using the -C flag.
-Y Force an IDE drive to immediately enter the lowest power consumption sleep mode, causing it to shut down completely. A hard or soft reset is required before the drive can be accessed again (the Linux IDE driver will automatically handle issuing a reset if/when needed). The current power mode status can be checked using the -C flag.
