AW: Brauche eure Hilfe--Bluescreen bei Hdmianschluß an 5870
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\032310-18985-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*
Symbol information
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`0304c000 PsLoadedModuleList = 0xfffff800`03289e50
Debug session time: Tue Mar 23 08:35:16.078 2010 (GMT+1)
System Uptime: 0 days 0:04:48.763
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {fffff8800130d0fc, 2, 8, fffff8800130d0fc}
Probably caused by : Ntfs.sys ( Ntfs! ?? ::NNGAKEGL::`string'+6d19 )
Followup: MachineOwner
2: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: fffff8800130d0fc, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: fffff8800130d0fc, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800032f40e0
fffff8800130d0fc
CURRENT_IRQL: 2
FAULTING_IP:
fffff880`0130d0fc 55 push rbp
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: VSSVC.exe
TRAP_FRAME: fffff8800a8514a0 -- (.trap 0xfffff8800a8514a0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=f7fffa8008ee6628 rbx=0000000000000000 rcx=fffff88002f64840
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800030a95b3 rsp=fffff8800a851630 rbp=fffff8800a851768
r8=0000000000000000 r9=0000000000000000 r10=0000000000000000
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
nt!CcFlushCache+0x103:
fffff800`030a95b3 488b7808 mov rdi,qword ptr [rax+8] ds:e018:f7fffa80`08ee6630=????????????????
Resetting default scope
EXCEPTION_RECORD: fffff8800a8513f8 -- (.exr 0xfffff8800a8513f8)
ExceptionAddress: fffff800030a95b3 (nt!CcFlushCache+0x0000000000000103)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
LAST_CONTROL_TRANSFER: from fffff800030bd469 to fffff800030bdf00
FAILED_INSTRUCTION_ADDRESS:
STACK_TEXT:
fffff880`0a8501b8 fffff800`030bd469 : 00000000`0000000a fffff880`0130d0fc 00000000`00000002 00000000`00000008 : nt!KeBugCheckEx
fffff880`0a8501c0 fffff800`030bc0e0 : fffff8a0`0325be50 fffff880`0126a4f4 fffff880`0a850480 fffff8a0`02ef0488 : nt!KiBugCheckDispatch+0x69
fffff880`0a850300 fffff880`0130d0fc : fffff800`030ec4dc fffff8a0`02ef047c fffff8a0`02ef0460 fffff8a0`02ef0498 : nt!KiPageFault+0x260
fffff880`0a850498 fffff800`030ec4dc : fffff8a0`02ef047c fffff8a0`02ef0460 fffff8a0`02ef0498 fffff8a0`02ef0488 : Ntfs! ?? ::NNGAKEGL::`string'+0x6d19
fffff880`0a8504a0 fffff800`030e3bed : fffff880`0126a4e8 fffff880`0a8517b0 00000000`00000000 fffff880`01218000 : nt!_C_specific_handler+0x8c
fffff880`0a850510 fffff800`030eb250 : fffff880`0126a4e8 fffff880`0a850588 fffff880`0a8513f8 fffff880`01218000 : nt!RtlpExecuteHandlerForException+0xd
fffff880`0a850540 fffff800`030f81b5 : fffff880`0a8513f8 fffff880`0a850c50 fffff880`00000000 fffff800`032f6800 : nt!RtlDispatchException+0x410
fffff880`0a850c20 fffff800`030bd542 : fffff880`0a8513f8 fffff880`02f64180 fffff880`0a8514a0 00000000`00000000 : nt!KiDispatchException+0x135
fffff880`0a8512c0 fffff800`030bbe4a : 00000000`00000000 fffff980`0c62f000 fffffa80`06a0f1b0 fffffa80`07303060 : nt!KiExceptionDispatch+0xc2
fffff880`0a8514a0 fffff800`030a95b3 : fffff8a0`02b4e100 fffff980`0c62e178 fffff8a0`02b4e140 fffff880`012cc961 : nt!KiGeneralProtectionFault+0x10a
fffff880`0a851630 fffff880`012e3642 : f7fffa80`08ee6628 00000000`00000000 fffff8a0`00000000 00000000`00000001 : nt!CcFlushCache+0x103
fffff880`0a851730 fffff880`012929e7 : 00000000`00000000 fffff8a0`03fd1140 00000000`00000000 00000000`00000001 : Ntfs!NtfsFlushUserStream+0x92
fffff880`0a8517b0 fffff880`012e3bbd : fffffa80`06c99770 fffffa80`07bad180 00000000`00000001 0000000f`ffffff00 : Ntfs!NtfsFlushVolume+0x2c7
fffff880`0a8518e0 fffff880`012e45f0 : fffffa80`06c99770 fffffa80`074aa710 fffffa80`07253a20 00000000`00000000 : Ntfs!NtfsCommonFlushBuffers+0x459
fffff880`0a8519c0 fffff880`00d8923f : fffffa80`074aaab0 fffffa80`074aa710 fffffa80`06c99770 fffff880`0a8519e8 : Ntfs!NtfsFsdFlushBuffers+0x104
fffff880`0a851a30 fffff880`00d876df : fffffa80`079fbde0 00000000`00000000 fffffa80`079fbd00 fffffa80`074aa710 : fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x24f
fffff880`0a851ac0 fffff800`033d1929 : 00000000`00000002 fffffa80`07253a20 00000000`00000000 fffffa80`074aa710 : fltmgr!FltpDispatch+0xcf
fffff880`0a851b20 fffff800`0335f8ad : fffffa80`074aa710 fffffa80`07303060 fffffa80`07253a20 00000000`000007ff : nt!IopSynchronousServiceTail+0xf9
fffff880`0a851b90 fffff800`030bd153 : fffffa80`07303060 00000000`ffe92270 fffffa80`079fbde0 fffffa80`07253a20 : nt!NtFlushBuffersFile+0x171
fffff880`0a851c20 00000000`7793036a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`035ff678 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7793036a
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: Ntfs! ?? ::NNGAKEGL::`string'+6d19
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Ntfs
IMAGE_NAME: Ntfs.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc14f
FAILURE_BUCKET_ID: X64_0xD1_CODE_AV_BAD_IP_Ntfs!_??_::NNGAKEGL::_string_+6d19
So das ist der letzte Crash hab da mehrere Dateien
Hoffe das bringt etwas!!
LG
