habe folgendes problem: nach der installation von AC:B erscheint eine fehlermeldung...das der "launcher" von AC:B nicht mehr funktioniert!!! wenn ich versuche das spiel zu beenden, erscheint ein bluescreen und der rechner startet neu...
hier die minidump auswertung:
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 50, {fffff80012ae51af, 8, fffff80012ae51af, 2}
Could not read faulting driver name
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+448c6 )
Followup: MachineOwner
0: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff80012ae51af, memory referenced.
Arg2: 0000000000000008, value 0 = read operation, 1 = write operation.
Arg3: fffff80012ae51af, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002d0e0e8
fffff80012ae51af
FAULTING_IP:
+3730643962633236
fffff800`12ae51af ?? ???
MM_INTERNAL_CODE: 2
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: iPodService.ex
CURRENT_IRQL: 0
TRAP_FRAME: fffff88009120980 -- (.trap 0xfffff88009120980)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000102 rbx=0000000000000000 rcx=0000000000000000
rdx=00000000000007ff rsi=0000000000000000 rdi=0000000000000000
rip=fffff80012ae51af rsp=fffff88009120b10 rbp=0000000000000000
r8=fffffa800829abb8 r9=0000000000000000 r10=fffffffffffffffe
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002a87ca0 to fffff80002add640
STACK_TEXT:
fffff880`09120818 fffff800`02a87ca0 : 00000000`00000050 fffff800`12ae51af 00000000`00000008 fffff880`09120980 : nt!KeBugCheckEx
fffff880`09120820 fffff800`02adb76e : 00000000`00000008 fffff800`12ae51af 00000000`00000000 00000001`39fc41c6 : nt! ?? ::FNODOBFM::`string'+0x448c6
fffff880`09120980 fffff800`12ae51af : 00000000`000001b4 00000000`00000000 00000000`000000e7 00000000`00000000 : nt!KiPageFault+0x16e
fffff880`09120b10 00000000`000001b4 : 00000000`00000000 00000000`000000e7 00000000`00000000 00000000`000000e7 : 0xfffff800`12ae51af
fffff880`09120b18 00000000`00000000 : 00000000`000000e7 00000000`00000000 00000000`000000e7 00000000`00000000 : 0x1b4
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff800`02a87ca0 cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+448c6
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4ce7951a
FAILURE_BUCKET_ID: X64_0x50_nt!_??_::FNODOBFM::_string_+448c6
0: kd> !analyze –v
0: kd> !analyze -v
Arguments:
address.
Debugging Details:
WRITE_ADDRESS: fffff80012ae51af
FAULTING_IP:
+3730643962633236
MM_INTERNAL_CODE: 2
BUGCHECK_STR: 0x50
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
